Got here 05, 7LA Touareg, Im normally ok with the air suspension on the VAG range but this one is kicking my butt, the arse end was in the air and it was bouncing along, it would not lower, I put 2 new genuine residual pressure valves on the rear airsprings, manually removed the pressure from the system to level the vehicle, In basic settings I can fill, bleed, empty, lower raise the vehicle no problems but when I get to last stage of calibration in adaption, Channel 05 (confirmation) I always get error when Im clicking from 4 up to 5, any clues why
Tuesday,02,June,2020,19:22:56:39628
VCDS Version: 20.4.1.0 HEX-NET CB: 0.4508.4
Dealer/Shop Name: Tech
Workshop Code: 912 91234 091235
VIN: WVGZZZ7LZ6D016072 License Plate: 8001DVH
Mileage: 272800km-169510mi Repair Order: 2-6-20
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ6D016072 Mileage: 272800km-169510miles
Part No SW: 070 906 016 AA HW: 028 101 148 1
Component: V10 5,0L EDCG000AGMª6189
Coding: 0010575
Shop #: WSC 31414 000 00000
VCID: 4FEE872BDF47E0FEC2-5160
Readiness: 0 0 X X X
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No: 09D 927 750 BM
Component: AL 750 6A 0592
Coding: 0012328
VCID: 7AB806FF3445955645-5160
Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl
Part No: 7L0 907 379 G
Component: ESP ALLRAD MK25 0203
Coding: 0022786
VCID: 3D32CDE365EB626E20-5160
Address 05: Acc/Start Auth. Labels: 3D0-909-13x-05.lbl
Part No SW: 3D0 909 137 HW: 5WK 470 22
Component: 08 Kessy 6700
Revision: 67005514 Serial number: VWZ3Z0E3371531
Coding: 0147688
VCID: 64845887A6C173A68F-5160
Component: ELV XXXX
Address 08: Auto HVAC Labels: 7L6-907-040.clb
Part No: 7L6 907 040 L
Component: CLIMAtronic R/L 4017
Coding: 0000030
VCID: 393AD9F371C35E4E0C-5160
00710 - Defroster Flap Positioning Motor (V107)
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3001
Coding: 0111868
VCID: 47DEAF0B373738BE8A-5160
00070 - Starting Battery Voltage
Address 11: Engine II Labels: Redir Fail!
Component: V10 5,0L EDCG000AGSª6189
Coding: 0010575
Address 15: Airbags Labels: 3D0-909-601.lbl
Part No: 3D0 909 601 F
Component: 0B Airbag 8.4E+ H11 1151
Coding: 0012354
VCID: 2600028F907DC1B651-5160
Address 16: Steering wheel Labels: 7L6-953-549.lbl
Part No: 7L6 953 549 D
Component: Lenksäulenmodul 3301
Coding: 0000032
VCID: 40CCB41712190F864B-5160
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl
Part No: 7L6 920 881 B
Component: KOMBIINSTRUMENT RB8 3135
Coding: 0007111
Shop #: WSC 22140 282 70448
VCID: 373EDFCB47D7483EFA-5160
01304 - Radio
Address 18: Aux. Heat Labels: 7L6-819-008.clb
Part No: 7L6 815 071 C
Component: Standheizung E1MAC
Coding: 0000000
VCID: 3228EEDFACB5AD16CD-5160
02251 - Heater Unit Locked
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<>CAN 0101
Coding: 0000006
VCID: 70AC24D76239DF06FB-5160
01304 - Radio
Address 22: AWD Labels: None
Part No: 0AD 927 755 BE
Component: TRANSFERCASE 0122
VCID: 7F4EF7EB2F67B07E72-5160
Address 34: Level Control Labels: 7Lx-907-553-34.clb
Part No: 7L0 907 553 F
Component: LUFTFDR.-CDC- 3C3P1 3081
Coding: 0015521
Shop #: WSC 00999 444 64523
VCID: 3620D2CF40DDB136E1-5160
01437 - Control Position not Learned
01400 - Suspension Level Control
Part No: 7L6 959 257
Component: Steuergerät 0701
VCID: 7EB00AEF286DB97679-5160
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 K
Component: 34 HSG 4105
Coding: 0000081
VCID: 44C4B807060113A66F-4B1E
Subsystem 1 - Part No: 7L0 959 701 H
Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 H
Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 D
Subsystem 4 - Part No: 7L0 959 704 D
Subsystem 5 - Part No: 7L0 907 719
Component: Neigungssensor 0020
Subsystem 6 - Part No: 7L6 951 171
Component: B Innenraumsensor 0020
Address 55: Headlight Range Labels: 7L6-907-357.lbl
Part No SW: 7L6 907 357 HW: 7L6 907 357
Component: AFS-Steuergeraet X016
Revision: H09 Serial number:
Coding: 0000003
Shop #: WSC 21000 282 67271
VCID: 78BC1CF70A49874633-5160
Subsystem 1 - Part No: 7L6 941 329 Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l X017
Coding: 00000034
Subsystem 2 - Part No: 7L6 941 330
Component: AFS-Lst.-Modul r X017
Coding: 00000034
01310 - Level Control System Control Module (J197)
Fault Status: 11101101
Reset counter: 169
Address 68: Wiper Electr. Labels: None
Part No: 7L0 955 119 M
Component: Front Wiper 4028
Coding: 0000768
VCID: 3E30CAEF68ED797639-5160
Subsystem 2 - Part No: 1K0 955 559 R Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 010 1010
Coding: 00208933
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0D Einparkhilfe 1107
Address 77: Telephone Labels: Redir Fail!
Part No SW: 7L6 035 729 F HW: 7L6 035 729 F
Component: FSE_275x H18 0020
Revision: 00000001 Serial number: 00000000265093
Coding: 0000211
02503 - Output Wire to Radio
Reset counter: 208
Time Indication: 15
01304 - Radio
Reset counter: 208
Time Indication: 15
End----------(Elapsed Time: 08:11, VBatt start/end: 12.6V/12.2V)-----------
