Results 1 to 10 of 17
Thread: Touareg 7L air suspension problems
    Feb 2015
    Spain
    Got here 05, 7LA Touareg, Im normally ok with the air suspension on the VAG range but this one is kicking my butt, the arse end was in the air and it was bouncing along, it would not lower, I put 2 new genuine residual pressure valves on the rear airsprings, manually removed the pressure from the system to level the vehicle, In basic settings I can fill, bleed, empty, lower raise the vehicle no problems but when I get to last stage of calibration in adaption, Channel 05 (confirmation) I always get error when Im clicking from 4 up to 5, any clues why
    Thanks
    Tuesday,02,June,2020,19:22:56:39628
    VCDS Version: 20.4.1.0  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: Tech
    Workshop Code: 912 91234 091235
    VIN: WVGZZZ7LZ6D016072   License Plate: 8001DVH
    Mileage: 272800km-169510mi   Repair Order: 2-6-20
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ6D016072   Mileage: 272800km-169510miles
       Part No SW: 070 906 016 AA    HW: 028 101 148 1
       Component: V10 5,0L EDCG000AGMª6189
       Coding: 0010575
       Shop #: WSC 31414 000 00000
       VCID: 4FEE872BDF47E0FEC2-5160
    Readiness: 0 0 X X X
    Address 02: Auto Trans        Labels: 09D-927-750.clb
       Part No: 09D 927 750 BM
       Component: AL 750 6A           0592
       Coding: 0012328
       VCID: 7AB806FF3445955645-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 G
       Component: ESP ALLRAD MK25     0203
       Coding: 0022786
       VCID: 3D32CDE365EB626E20-5160
       Part No SW: 3D0 909 137     HW: 5WK 470 22
       Component: 08 Kessy            6700
       Revision: 67005514    Serial number: VWZ3Z0E3371531
       Coding: 0147688
       VCID: 64845887A6C173A68F-5160
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 L
       Component: CLIMAtronic R/L     4017
       Coding: 0000030
       VCID: 393AD9F371C35E4E0C-5160
    00710 - Defroster Flap Positioning Motor (V107)
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 N
       Component:                     3001
       Coding: 0111868
       VCID: 47DEAF0B373738BE8A-5160
    00070 - Starting Battery Voltage
       Component: V10 5,0L EDCG000AGSª6189
       Coding: 0010575
    Address 15: Airbags        Labels: 3D0-909-601.lbl
       Part No: 3D0 909 601 F
       Component: 0B Airbag 8.4E+ H11 1151
       Coding: 0012354
       VCID: 2600028F907DC1B651-5160
    Address 16: Steering wheel        Labels: 7L6-953-549.lbl
       Part No: 7L6 953 549 D
       Component: Lenksäulenmodul     3301
       Coding: 0000032
       VCID: 40CCB41712190F864B-5160
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 881 B
       Component: KOMBIINSTRUMENT RB8 3135
       Coding: 0007111
       Shop #: WSC 22140 282 70448
       VCID: 373EDFCB47D7483EFA-5160
    01304 - Radio
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 815 071 C
       Component: Standheizung E1MAC
       Coding: 0000000
       VCID: 3228EEDFACB5AD16CD-5160
    02251 - Heater Unit Locked
       Part No: 6N0 909 901
       Component: Gateway K<>CAN      0101
       Coding: 0000006
       VCID: 70AC24D76239DF06FB-5160
    00463 - Control Module for Digital Sound Package (J525)
    01304 - Radio
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F4EF7EB2F67B07E72-5160
    Address 34: Level Control        Labels: 7Lx-907-553-34.clb
       Part No: 7L0 907 553 F
       Component: LUFTFDR.-CDC- 3C3P1 3081
       Coding: 0015521
       Shop #: WSC 00999 444 64523
       VCID: 3620D2CF40DDB136E1-5160
    01437 - Control Position not Learned
    01400 - Suspension Level Control
       Part No: 7L6 959 257
       Component: Steuergerät         0701
       VCID: 7EB00AEF286DB97679-5160
    Address 46: Central Conv.        Labels: 7L0-959-933.lbl
       Part No: 7L0 959 933 K
       Component: 34 HSG              4105
       Coding: 0000081
       VCID: 44C4B807060113A66F-4B1E
       Subsystem 1 - Part No: 7L0 959 701 H
       Subsystem 2 - Part No: 7L0 959 702 H
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0020
       Subsystem 6 - Part No: 7L6 951 171
       Component: B  Innenraumsensor  0020
    Address 55: Headlight Range        Labels: 7L6-907-357.lbl
       Part No SW: 7L6 907 357     HW: 7L6 907 357
       Component: AFS-Steuergeraet    X016
       Revision:   H09       Serial number:
       Coding: 0000003
       Shop #: WSC 21000 282 67271
       VCID: 78BC1CF70A49874633-5160
       Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    X017
       Coding: 00000034
       Subsystem 2 - Part No: 7L6 941 330
       Component: AFS-Lst.-Modul r    X017
       Coding: 00000034
    01310 - Level Control System Control Module (J197)
                        Fault Status: 11101101
                        Reset counter: 169
    Address 68: Wiper Electr.        Labels: None
       Part No: 7L0 955 119 M
       Component: Front Wiper         4028
       Coding: 0000768
       VCID: 3E30CAEF68ED797639-5160
       Subsystem 2 - Part No: 1K0 955 559 R  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 010  1010
       Coding: 00208933
    Address 76: Park Assist        Labels: Redir Fail!
       Part No: 7L0 919 283 F
       Component: 0D Einparkhilfe     1107
    Address 77: Telephone        Labels: Redir Fail!
       Part No SW: 7L6 035 729 F    HW: 7L6 035 729 F
       Component: FSE_275x        H18 0020
       Revision: 00000001    Serial number: 00000000265093
       Coding: 0000211
    02503 - Output Wire to Radio
                        Fault Status: 01101011
                        Reset counter: 208
                        Time Indication: 15
    01304 - Radio
                        Reset counter: 208
                        Time Indication: 15
    End----------(Elapsed Time: 08:11, VBatt start/end: 12.6V/12.2V)-----------
    Do whatever is necessary to get the vehicle reasonably level and at something resembling normal height and then look through the Measuring Blocks in the 34 - Level Control module to see if one of the height readings is substantially different than the other three.
    Sensor mechanical basic setting invalid?
    Did you consider must be set manually to achieve range desired of target in controller for adaptation or value input is implausible target?
    Battery charger!
    Feb 2015
    Spain
    All sensors have been checked, I depressurized the system, checked low reading of sensors then slowly jacked each corner also with scope pinned to module to make sure there was no dropouts, when the "wait" command it displayed it does sort itself out to normal level.
    I did set it manually by measuring each corner, there's only about 10mm difference, battery charger?, I dont think its needed as this has to be done with the engine running
    Any other clues
    Thanks
    Any other clues
    Thanks
    Okay dismiss me, however, you do realize I'm not speaking of measuring sweep with meter/scope or speaking of electrical faults, I am speaking of range of mechanical basic setting of physical sensor placement or rod to sensor?
    Clue......
    Did you even read the DTC reported?
    If you change position slightly can you vacate DTC and complete the adaptation?
  6. #6
    Feb 2015
    Spain
    Clue......
    Ive read this:
    Possible Causes
    Leakage
    Excess Temperature Shut Off
    Possible Solutions
    Check System for Leaks
    See Factory Repair Manual for Details
    Let the System cool down before any further Attempts
    Ive no idea what the operating temperature is on these compressors, Ive had the compressor lying on the cold stone floor waiting for it do something, it would be nice if it did cut off due to overheating at least then I know its tried
    Im 110% sure its got no leaks, thats been checked and checked again
    Ive got in MB's 005
    LF(G78).............RF(G289).............LR(G76).. ...........RR(G77)
    ...90.0...................112.0.................11 2.0.................114.0
    Im thinking maybe left front as its 12/4 mm lower maybe causing the problem but I also though thats why the system needed calibrating to even them all out
    any more clues
    Thanks
  7. #7
    Did you know electronic calibration can only be done if mechanical components measured basic settings are in criteria range to permit it to achieve an adaption point to point & too establish the full RANGE?
  8. #8
    Feb 2015
    Spain
    So whats next step with this one ?
  9. #9
    Sep 2016
    Riga, Latvia
    If we count one (what Jack wrote) plus one (Your measurements), what should we get? Maybe five?
  10. Likes Jack@European_Parts liked this post
  11. #10
    Sep 2016
    Riga, Latvia
    But ok, if You said, LF is really physically lower, then do couple other tests (on level surface, of course) - lower vehicle as low as it is possible, check all level measurements, and lift it as high as possible and check measurements again.
    In some position one or more measurements may go outside of acceptable range, so it may cause the DTC 01400 - Suspension Level Control
  12. Likes Jack@European_Parts, Uwe liked this post
