Results 1 to 5 of 5
Thread: A6 C6 central locking fault
    May 2020
    Scotland
    one the key is pressed to lock the car it locks ok it will unlock with the key ok but if you leave it 30 the key wont work have to put the key in the door lock then the same key works then dose not the alarm light dose not work this car was ok up till a week ago. need adv also on the battery system and the engine fault.
    Tuesday,02,June,2020,15:35:58:62413
    VCDS Version: 20.4.0.1  HEX-V2 CB: 0.4508.4
    Dealer/Shop Name: CC Cars & Light Commercials
    VIN: WAUZZZ4FX8N169597   License Plate: D20CC
    Mileage: 190880km-118607mi   Repair Order: D20CC1
    Chassis Type: 4F (4L0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
              62 72 76
    VIN: WAUZZZ4FX8N169597   Mileage: 190880km-118607miles
    Address 01: Engine        Labels: 059-907-401-BPP.clb
       Part No SW: 4F5 910 401 Q    HW: 4F0 907 401 C
       Component: 2.7L V6TDI  G000CG  0020
       Revision: --H05---    Serial number:
       Coding: 0011382
       Shop #: WSC 00001 551 00000
       VCID: 2F3B15C59B1270A3FA8-807A
    004120 - Intake Manifold Runner (Bank 2)
                   P1018 - 001 - Lower limit not reached
                        Fault Status: 01100001
                        Mileage: 190873 km
                        Date: 2020.06.01
                        Time: 09:33:24
                        RPM: 903 /min
                        Torque: 78.0 Nm
                        Voltage: 13.83 V
                        Duty Cycle: 80.9 %
                        Duty Cycle: 89.2 %
                        Duty Cycle: 80.9 %
    Readiness: 1 1 0 0 0
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F5 910 155 R    HW: 01J 927 156 JG
       Component: V30 0AN 2.7lTDI RdW 0020
       Revision: --H05---    Serial number: 00000000000140
       Shop #: WSC 02325 785 00200
       VCID: 363520A16448416BB9E-8062
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AC    HW: 4F0 614 517 T
       Component: ESP8 front      H01 0070
       Coding: 0020876
       VCID: 6597B7ED896EFAF3C04-8030
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
       Component: FBSAUDIC6 ELV   H05 0090
       Revision: 00H05000    Serial number: 10602401131805
       Coding: 0000019
       Shop #: WSC 02323 785 00200
       VCID: 2517F7EDC9EE3AF3004-8070
       Subsystem 1 - Part No: 4F0 910 132 E
       Component: FBSAUDIC6 IDG   H01 0040
    Address 07: Control Head        Labels: Redir Fail!
       Part No SW: 4F0 910 769 G    HW: 4F0 035 769 A
       Component: MMI Cockpit     H35 0410
       Revision: C61060DE    Serial number: AUZ6Z3H6TD37R3
       Coding: 0540122
       VCID: 313F13BD8D266653ECC-8064
       Component: Bedienteil MMIC6H02 0060
       Subsystem 2 - Serial number: 00000000456590
       Subsystem 3 - Serial number: 0128.06.060000000100010826˙
       Subsystem 4 - Serial number: 010826˙
       Part No SW: 4F0 910 043 A    HW: 4F2 820 043 Q
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000053    Serial number: 00000030367996
       Coding: 0001046
       Shop #: WSC 02325 551 00000
       VCID: 1C61D209FAA4FB3BAFA-8048
       Part No SW: 4F0 910 279 N    HW: 4F0 907 279
       Component: ILM Fahrer      H21 0310
       Coding: 0011121
       Shop #: WSC 02335 551 00000
       VCID: 34311AA97234537B87A-8060
       Subsystem 1 - Part No: 4F2 910 113 B  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H06 0190
       Coding: 00064784
       Shop #: WSC 02335
       Coding: 00146221
       Shop #: WSC 02335
    Address 0E: Media Player 1        Labels: Redir Fail!
       Coding: 0540122
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0Z0BJN
       Coding: 0013381
       VCID: 290FFBDDA5F61E9324C-807C
       Subsystem 1 - Serial number: 6332CSME3D734250+
       Subsystem 2 - Serial number: 6342CSME3D7353455
       Subsystem 3 - Serial number: 6352QSME786C383D.
       Subsystem 4 - Serial number: 6362QSME786C3D27-
       Subsystem 5 - Serial number: 63734SME772C2D214
       Subsystem 6 - Serial number: 63834SME77181605.
       Revision: 00H03000    Serial number: 90025081690384
       Coding: 0102141
       VCID: 270BFDE5B3E228E3328-8072
       Part No SW: 4F0 910 900 C    HW: 4F0 920 951
       Component: KOMBIINSTR. M73 H16 0240
       Revision: 00300000    Serial number: 647119U68
       Coding: 2304458
       Shop #: WSC 12345 067 57207
       VCID: 2019E6F9D6CCDFDB732-8074
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B087038061
       Coding: F5519E5730020600
       Shop #: WSC 02335 785 00200
       VCID: 2D070FCD911E02B3C84-8078
       Component: TSG FA          H12 0210
       Revision: 00-00000
       Coding: 0002682
       Shop #: WSC 02327 785 00200
       VCID: 2C0102C9AA040BBBDFA-8078
                        Reset counter: 131
                        Mileage: 190873 km
                        Date: 2020.05.29
                        Time: 15:34:57
       Part No SW: 4F0 910 289 J    HW: 4F0 907 289 J
       Component: Komfortgeraet   H27 0220
       Revision: 02200027    Serial number: 01128871180000
       Coding: 0008443
       Shop #: WSC 02335 067 57207
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 K    HW: 4F0 035 223 L
       Component: Amp.-ASK-RD   H07 0250
       Revision: S7000000
       Coding: 030000
       Shop #: WSC 02399 823 56573
       VCID: 2615F0E1B8E831EB09E-8072
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000568545
       Coding: 0001103
       Shop #: WSC 02145 785 00200
       VCID: 5EE59801AC38A92B01E-800A
       Component: TSG BF          H12 0210
       Revision: 00-00000
       Coding: 0002682
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000531
    Address 56: Radio        Labels: Redir Fail!
       Coding: 0540122
       Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
       Component: J0644 BEM       H12 0760
       Revision: 00000000    Serial number: 00000000122055
       Shop #: WSC 00000 384 00290
       VCID: 2411EAE9C2D4C3FB17A-8070
       Subsystem 1 - Part No: EB1 100 850 AE
       Component: von TU3  3661024036
       Coding: 454231313030383530414554553333363631303234303336
    02275 - Quiescent Current Stage 4
                        Fault Frequency: 15
                        Mileage: 190873 km
                        Date: 2020.05.29
                        Time: 15:15:16
    02256 - Quiescent Current
                        Fault Status: 00110001
                        Reset counter: 133
                        Mileage: 190873 km
                        Date: 2020.05.31
                        Time: 14:14:28
       Component: TSG HL          H21 0210
       Coding: 0002090
       VCID: 2E0508C19C1879ABF1E-807A
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0210
       Coding: 0002090
       Part No SW: 4F0 910 283 F    HW: 4F0 919 283 F
       Revision: 00H09000    Serial number: 06230818709061
       Coding: 0001106
    End----------(Elapsed Time: 01:52, VBatt start/end: 12.6V/12.5V)-----------
    Address 01: DTCs cleared
    I would guess you either have issues with the Driver's door module, or the car's battery is weak enough that the CCM is shutting down the radio receiver to shed load.
  3. Likes PetrolDave liked this post
    May 2020
    Scotland
    Thanks for quick response is this the correct number for a replacement door module 4L0-910-468.
    Quote Originally Posted by Colliboy View Post
    Your current door module is: 4F0-910-793-E.
    4L0-910-468-A looks to be your CAN Gateway.
    May 2020
    Scotland
    update took adv and replaced the battery all problems have now fixed thanks
  7. Likes Uwe liked this post
