Results 1 to 10 of 11
Thread: 2008 Touareg goes not out of parking
    Belize
    i have a 2008 Touareg V6 follow problem shows up now. the car was driving shifting perfectly. i parked it over night outside and it was heavly raining now. on the next morning i want to drive to work but the shift stick doesn't go out of the parking position. all warning light are now on traction control,ABS,the red brake light,engine light. the dash show brake fault. i hooked up VCDS and that is the Auto Scan
    Monday,01,June,2020,17:42:02:32045
    VCDS Version: 20.4.1.0 (x64)
    VIN: WVGBE77L88D003070   License Plate:
    Chassis Type: 7L (6N0)
    Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 28 46 47 55 56 65 68
              6D 6E 76
    VIN: WVGBE77L88D003070   Mileage: 159270km-98965miles
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    22-AWD -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    68-Wiper Electr. -- Status: Malfunction 0010
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine (BHK)       Labels: 03H-906-032-BLV.clb
       Part No SW: 03H 906 032 S    HW: 03H 906 032 S
       Component: T-GP LEV2       G   1489
       Revision: 5FH04---    Serial number: VWX3Z0G6593462
       Coding: 0001175
       Shop #: WSC 31414 790 00001
       VCID: 326BA792AE524C16CD-5122
    9 Faults Found:
    053269 - Control Module for ABS Brakes
                   U1015 - 008 - No Communications
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.224 V
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
    049409 - No Communication with Transmission Control Module
                   U0101 - 008 -  - MIL ON
                        Fault Status: 11101000
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
    049446 - No Communications with Steering Angle Sender (G85)
                   U0126 - 008 -
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
    049428 - Control Module for All Wheel Drive Clutch
                   U0114 - 008 - No Communication
                        Mileage: 159278 km
                        RPM: 978 /min
                        Load: 36.8 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.224 V
    000406 - Engine Oil Temp. Sensor (G8)
                   P0196 - 004 - Implausible Signal
                        Mileage: 159278 km
                        RPM: 1002 /min
                        Load: 29.0 %
                        Temperature: 76.0C
                        Temperature: 34.0C
                        Voltage: 14.097 V
    Readiness: 0110 0101
    Address 02: Auto Trans
    Address 03: ABS Brakes
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 137 B    HW: 5WK 485 17
       Component: 11 Kessy            6840
       Revision: 68406418    Serial number: VWX3Z0G6593462
       Coding: 0147688
       VCID: 326BA792A9524C16CD-8066
    9 Faults Found:
    00955 - Key 1
                002 - Lower Limit Exceeded
    00956 - Key 2
    00184 - Control Circuit for Engine Start/Stop Switch
    00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                009 - Open or Short to Ground
    00576 - Terminal 15
                013 - Check DTC Memory
    00183 - Interior Access/Start Authorization Antenna 1 (R138)
       Part No: 7L6 907 044 AD
       Component: CLIMAtronic 2+2     4326
       Coding: 0020030
       VCID: 76E35B8205BA103621-8022
       Subsystem 1 - Part No: 7L6 907 049 E
       Component: CLIMAtronic FOND    0400
    8 Faults Found:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
                010 - Open or Short to Plus
    02599 - Rear Left Temperature Flap Motor (V313)
    02597 - Rear Left Upper Body Vent Motor (V315)
    00064 - Left B-pillar/Footwell Shut-Off Flap Motor (V212)
    00362 - Rear Left Air Flap Motor (V239)
    02600 - Rear Right Temperature Flap Motor (V314)
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
       Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
       Component: J519                2000
       Revision: -0004---    Serial number: --------------
       Coding: 230008002F043C000000000000000000
       VCID: 000F3D5A577E2E860B-8054
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0076493
       VCID: 2E53B3E2B96A68F6A9-807A
                        Reset counter: 184
                        Mileage: 156389 km
                        Date: 2018.05.22
                        Time: 10:02:54
    01304 - Radio
                        Reset counter: 200
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 17:28:03
    Address 15: Airbags        Labels: 7L0-959-655.lbl
       Part No SW: 7L0 959 655     HW: 7L0 959 655
       Component: J234  3A VW8T       0250
       Revision: 92011025    Serial number: 0039P00196HR
       Coding: 0013121
       VCID: 7AFB4FB231A2745645-802E
       Subsystem 1 - Part No: 7L0 959 339 F
       Component: BF-Gewichtsens. 007 0010
       Subsystem 2 - Serial number: 3KF5X
                        Fault Frequency: 12
                        Reset counter: 200
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
       Part No: 7L6 953 549 F
       Component: Lenksaeulenmodul    3501
       Coding: 0010011
       VCID: 428BF75219F2FC965D-8016
    Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
       Part No SW: 7L6 920 975 G    HW: 7L6 920 975 G
       Component: J0285 KOMBI-INST.   6418
       Revision: KHH05X52
       Coding: 0007201
       Shop #: WSC 05087 444 82774
       VCID: 408FFD5A13FEEE864B-8014
    8 Faults Found:
    01304 - Radio
                        Mileage: 159178 km
                        Date: 2019.06.10
                        Time: 22:25:19
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
    01771 - Control Module for Headlight Range (J431)
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Fault Status: 01101010
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:45:45
                        Fault Status: 01101101
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 17:37:27
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 7L6 920 975 G
       Component: J533  GW-K-CAN TP20 6418
       Coding: 77E2F7B963066002
       VCID: 70EF6D9A63DE3E06FB-8024
    6 Faults Found:
    01304 - Radio
                        Mileage: 159178 km
                        Date: 2019.06.10
                        Time: 22:25:19
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:50
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1439802T0A9A02
       VCID: 4683EB4231DAC0B671-8012
                        Fault Frequency: 9
                        Reset counter: 200
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 07:42:48
    Address 22: AWD
    Address 28: HVAC, Rear
       Part No: 7L6 959 933
       Component: 10 HSG              7124
       Coding: 0000085
       Shop #: WSC 05079 444 84550
       VCID: 7F0DBEA62D80517E72-4B1A
       Subsystem 1 - Part No: 7L0 959 701 P
       Component: Tuersteuergeraet FS 6302
       Subsystem 2 - Part No: 7L0 959 702 P
       Component: Tuersteuergeraet BF 6302
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
    00576 - Terminal 15
    01312 - Powertrain Data Bus
    00120 - Outside Warning Light/Door exit Light Driver Side
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No SW: 7L6 035 466 A    HW: 7L6 035 466 A
       Component: DSP 10 Kanal        0003
       Revision: 00001000    Serial number: 00000000002370
       VCID: 326BA792AD524C16CD-8066
    00419 - Left Front DSP Midrange Speaker (R103)
                        Fault Status: 00101011
                        Reset counter: 240
                        Mileage: 158145 km
                        Date: 2018.12.05
                        Time: 10:02:56
                        Reset counter: 240
                        Mileage: 159271 km
                        Date: 2019.07.02
                        Time: 16:39:44
    Address 55: Headlight Range
    Address 56: Radio
    Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
       Part No SW: 7L6 907 273 E    HW: 7L6 907 273 E
       Component: J0502 RDK           0006
       Revision: 00004006    Serial number: 00000600005538
       Coding: 0040006B6B0000000000000000
       VCID: 3A7B8FB27122B45605-806E
                        Reset counter: 200
                        Mileage: 159278 km
                        Date: 2019.07.05
                        Time: 17:37:31
                        (no units): 27.0
    02214 - Tire Pressure Warning
                        Reset counter: 190
                        Mileage: 159252 km
                        Date: 2019.06.29
                        Time: 04:22:31
                        (no units): 77.0
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L6 955 119
       Component: J400__ Front Wiper  5101
       Coding: 0000341
       VCID: 77FD568606B0693E3A-8022
       Subsystem 2 - Part No: 1K0 955 559 AB  Labels: 1K0-955-559-AF.CLB
       Component: RLS     120407 020  0105
       Coding: 00208933
       Shop #: WSC 31414
    Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
       Part No SW: 7L6 959 107 A    HW: 7L6 959 107 A
       Component: J605  HECKKLAPPE    1210
       Revision: --H05---    Serial number: --------012798
       Coding: 0122110
       VCID: 397990BE7424BF4E0C-806C
    Address 6E: Ctrl Head Roof        Labels: None
       Part No SW: 7L6 919 044 Q    HW: 7L6 919 044 Q
       Component: J702  Dachdisplay   0400
       Revision: --30004S    Serial number: 00000000016799
       VCID: 4581EC4E0CDCCBAE78-8010
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
    00436 - Rear Left Inner Parking Aid Sensor (G334)
    01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
                006 - Short to Plus
    End-------------------------(Elapsed Time: 04:29)--------------------------
    Do anyone know how to get the Transmission manually in N to tow it or do i have to lose the Bolts by the Hardy disc that the Wheels coming free? Please need here urgent help.
    HQ
    Thank you for posting a full Auto-Scan!
    For any given control module to communicate, one must have:
    Quote Originally Posted by thor1974 View Post
    Coding: 0147688
    Component: ELV XXXX
    9 Faults Found:
    00955 - Key 1
    00956 - Key 2
    00576 - Terminal 15
    So with the relay that controls Terminal 15 power being wonky for some reason, that is where I'd start. This is the J329 relay in the wiring diagram. Without that J329 relay working, you will not have the required "Power" that is needed for control modules to be able to communicate.
    The low side circuit of the J329 gets power from fuse SB39 and is grounded by the Access/Start (Kessy) module.... to which it says "Open or Short to Ground". So is that fuse popped? Relay bad? Wiring issue?
    Jef
  3. Likes PetrolDave, Uwe, Jack@European_Parts liked this post
    Belize
    Thanks for the quick reply
    all fuses are ok. i will check now under the driver seat the J329 Relay. i keep you posted.
    Belize
    i check now the relay and that part make the problems. if i knock it i get the transmission in D R N etc but if i stop the Engine the shifter stock i will order now the new relay and see if that solve all my problems
    Belize
    i got today finally the relay i put it in but still the same problems. here the new autoscan
    Wednesday,08,July,2020,13:23:35:32045
              6D 6E 76
       Coding: 0001175
    10 Faults Found:
                        Fault Frequency: 10
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.970 V
                        Fault Frequency: 10
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                        Fault Frequency: 10
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                        Fault Frequency: 10
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                   U0121 - 008 -
                        Fault Frequency: 40
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                   U0126 - 008 -
                        Fault Frequency: 10
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                        Fault Frequency: 11
                        Mileage: 159278 km
                        RPM: 1021 /min
                        Load: 33.3 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 13.970 V
                        Mileage: 159278 km
                        RPM: 704 /min
                        Load: 36.1 %
                        Temperature: 75.0C
                        Temperature: 36.0C
                        Voltage: 14.351 V
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 008 -
                        Mileage: 159278 km
                        RPM: 684 /min
                        Load: 39.6 %
                        Temperature: 82.0C
                        Temperature: 56.0C
                        Voltage: 13.208 V
       Coding: 0147688
    7 Faults Found:
    00576 - Terminal 15
    00955 - Key 1
       Coding: 0020030
    7 Faults Found:
                        Reset counter: 200
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:46:57
    01304 - Radio
                        Fault Frequency: 110
                        Reset counter: 205
                        Mileage: 159278 km
                        Date: 2019.08.11
                        Time: 06:46:53
       Coding: 0013121
                        Fault Frequency: 45
                        Reset counter: 205
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:46:57
       Coding: 0010011
       Revision: KHH05X52
       Coding: 0007201
    9 Faults Found:
                        Mileage: 159278 km
                        Date: 2019.08.11
                        Time: 06:46:59
                        Reset counter: 245
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 10
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 10
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 13
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 13
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:10
    01304 - Radio
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:14
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:52:09
    6 Faults Found:
                        Fault Frequency: 10
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 10
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 13
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:09
                        Fault Frequency: 13
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:10
    01304 - Radio
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:51:14
                        Fault Frequency: 40
                        Reset counter: 205
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:47:22
    Address 22: AWD
       Coding: 0000085
       VCID: 7F0DBEA62D80517E72-4B02
    00576 - Terminal 15
    01134 - Alarm Horn (H12)
                        Reset counter: 205
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:55:07
    Address 56: Radio
                        Reset counter: 205
                        Mileage: 159278 km
                        Date: 2019.08.11
                        Time: 06:47:03
                        (no units): 27.0
                        Reset counter: 200
                        Mileage: 159278 km
                        Date: 2019.07.06
                        Time: 00:49:07
                        (no units): 77.0
       Coding: 0000341
       Coding: 00208933
       Shop #: WSC 31414
       Coding: 0122110
    End-------------------------(Elapsed Time: 04:34)--------------------------
    i still have the terminal 15 problem so i will check the red/white wire which goes from the relay to the kessy
    Aug 2014
    Maryland, USA
    Hi Thor,
    If you say that " if i knock it i get the transmission in D R N etc" that means probably it is a connection problem; take out the female socket to the relay and inspect the slots, I suspect they are over-widened and creating poor connection to the relay. If possible, take out the relay socket out of the holder and connect the relay, make sure all pins are tight to the male pins, clear the fault memory and recheck the system.
  8. Likes Uwe, Jack@European_Parts liked this post
    Belize
    ok thank i will try that and keep you updated
  10. #8
    HQ
    Jef
  12. #9
    Belize
    exaclly the same wire got rotten in my touareg. i will wire it new and keep your posted
  13. Likes Uwe, Jef, Jack@European_Parts liked this post
  14. #10
    HQ
    If possible, post a photo. Water I take it? If so, where is the water coming in from?
    Jef
  15. Likes Uwe, Jack@European_Parts liked this post
