Results 1 to 6 of 6
Thread: Missing ROD file
    Jan 2020
    Missing ROD file
    Hi all
    I've recently fitted a PDC module from a different VAG vehicle to my Transporter T6. The module gives me PDC auto activation when pulling forwards to an obstacle. Its fitted and working. I'm able to code it but it has an error saying no ROD file is available and I can not see any adaptations. Is there a work around for this, can I get an updated ROD file anywhere.
    Thanks for any help.
    Tuesday,02,June,2020,09:29:26:32461
    VCDS Version: 20.4.1.0 (x64)
    VIN: WV1ZZZ7HZJH051877   License Plate:
    Chassis Type: 7H-VN75 (7E0)
    Scan: 01 02 03 04 08 09 0D 10 13 15 17 19 20 25 3C 55 5F 61 65 69
              6D 6E 78 0B
    VIN: WV1ZZZ7HZJH051877   Mileage: 50070km-31112miles
    0D-Slide Door, Left -- Status: OK 0000
    6E-Ctrl Head Roof -- Status: OK 0000
    78-Slide Door, Right -- Status: OK 0000
    Address 01: Engine (2D2D2-CXEB)       Labels:. 04L-907-309-V2.clb
       Part No SW: 04L 906 056 KQ    HW: 04L 907 445 A
       Component: R4 2.0l BTD   H03 3775
       Revision: 23101001
       Coding: 00254014436401080000
       Shop #: WSC 02739 790 50316
       ASAM Dataset: EV_ECM20BTD03004L906056KQ 004004
       ROD: EV_ECM20BTD03004L906056KN_004.rod
       VCID: 06037A8EB959E0B631-8052
    Readiness: N/A
       Part No SW: 0BT 300 046 J    HW: 0BH 927 711 G
       Component: DSG DQ500-7F  H11 5302
       Revision: 00H11V01
       VCID: 3D71D562AC0F636E20-8068
    Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
       Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
       Component: ESC           H06 0133
       Revision: 00000000    Serial number: 62367000000025
       Coding: 347E40986567847F2C7D027DA689218379F700
       ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
       VCID: 408FAC96DBFD0E864B-8014
       Component: LENKW.SENSOR  H07 0070
       Serial number: 25081713471616
       Coding: 01
       ROD: EV_LWSKLOVW25X.rod
       VCID: 7EF3126EE189B87679-802A
    Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
       Part No SW: 7E0 907 047 AC    HW: 7E0 907 047 AC
       Component: Climatic-T5   H22 0708
       Revision: 00001002
       Coding: 0000000003
       ROD: EV_ClimaT5Basis.rod
       VCID: 6BD52B3A82FB3DDECE-803E
    Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
       Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
       Component: BCM PQ25 Max4 H82 0752
       Revision: B9082001    Serial number: 4000 236171756
       Coding: B8DEF9B80A63340381288F607FEB9FF4C094731960CD79E03304033F0860
       Shop #: WSC 02739 022 243150
       VCID: 2B55EB3A4A7BFDDE8E-807E
       Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
       Component: RLS 250817 04  42  0106
       Coding: 0228EE
       Subsystem 2 - Part No SW: 7E0 959 801 R    HW: 7E0 959 801 R  Labels: 7E0-959-80X-V2.CLB
       Component: J386__TSG_FT  004 0653
       Serial number: KU0KU022081772343178
       Coding: 1400B1
       Subsystem 3 - Part No SW: 7E0 959 802 Q    HW: 7E0 959 802 Q  Labels: 7E0-959-80X-V2.CLB
       Component: J387__TSG_BT  003 0653
       Serial number: KU0KU021081772334945
       Coding: 0400A1
       Subsystem 4 - Part No: 1K0 951 605 F
       Component: LIN BACKUP HO  H01 0008
       Subsystem 5 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A
       Component: E221__MFL-DC1  H02 0103
       Serial number: 39170002193340067333
       Coding: B4FFFF
    Address 0D: Slide Door, Left        Labels: Redir Fail!
       Part No: 7E0 959 243 D
       Component: Schiebetuer-SG  407 0328
       Shop #: WSC 02739 790 00000
       VCID: 306FFC56A35D9E06BB-8064
    Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
       Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0480
       Revision: --------    Serial number: 39331613113703
       Coding: 0021191111
       Shop #: WSC 99999 123 12345
       ASAM Dataset: EV_EPHVA18VW364GP00 001007
       ROD: N/A
       VCID: 377DC74A8E33493EFA-8062
    No ASAM data for: "EV_EPHVA18VW364GP00" (VN75)
    12718592 - ROD - Unknown Error Code
              - 00 [009]
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:38
    Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
       Part No SW: 7N0 907 572 C    HW: 7E0 907 572
       Component: ACC Bosch PQx H03 0211
       Serial number: 2308170452A8C0
       Coding: 00005000FE0779
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_ACCBEGVW361 001006
       ROD: EV_ACCBEGVW361.rod
       VCID: 3663CA4E8939B036E1-8062
       Part No SW: 7E0 959 655 G    HW: 7E0 959 655 G
       Component: VW10Airbag021 H08 0018
       Revision: --------    Serial number: 003V30061NAY
       Coding: 000000000000000000000000000000003231
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
       ROD: EV_AirbaVW10BPAVN750.rod
       VCID: 3A7BDE7EBD21545605-806E
       Part No SW: 7E0 920 970 S    HW: 7E0 920 970 S
       Component: KOMBI         H03 1107
       Coding: 440F020300
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
       ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
    Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
       Part No SW: 7E0 909 901     HW: 7E0 937 090 C
       Component: GW-K-CAN TP20 H82 0752
       Revision: B9082001
       Coding: 042307
       VCID: 68DF54369B0D16C6A3-803C
    Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
       Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
       Component: FLA           H10 0003
       Revision: AA001001
       Coding: 040401E200000100000000
       ASAM Dataset: EV_HighBeamAssisAU316 001004
       ROD: EV_HighBeamAssisAU316.rod
       VCID: 2D51E5227C6FF3EE90-8078
       Component: IMMO          H03 1107
       VCID: 6ADB2E3E8D0124D6B5-803E
       Part No SW: 7E0 907 566 C    HW: 4H0 907 566 F
       Component: SWA Master    H07 0030
       Serial number: 0383721903
       Coding: 030321
       ROD: EV_LaneChangAssis_VN75.rod
       VCID: 306FFC566B5D9E06BB-8064
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 7E0 907 568 C    HW: 4H0 907 568 F
       Component: SWA Slave  H07 0030
       Serial number: 0383713030
       Coding: 030321
    Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
       Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
       Component: AFS-ECU       005 0050
       Coding: 0FCE020001000000
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
       ROD: EV_HeadlRegulVWLWRCC.rod
       Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
       Component: MU-S-ND-ER    H41 0449
       Serial number: VWZAZ2T5357545
       Coding: 06570001BE00000011111101008808001F0100D6002001004F
       ROD: EV_MUStd4CTSAT_VW32.rod
       VCID: 25411D02249FCBAE58-8070
       Subsystem 1 - Part No SW: 5NA 919 866     HW: -----------
       Component: ECE1 2018/19  --- 1030
    6 Faults Found:
    0512 - Rear Right Bass Speaker
              B1067 13 [009] - Open Circuit
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:40
                        Voltage terminal 30: 12.1 V
    0517 - Front Right Bass Speaker
              B1062 13 [009] - Open Circuit
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:40
              B1064 13 [009] - Open Circuit
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:40
    0522 - Front Left Bass Speaker
              B105F 13 [009] - Open Circuit
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:40
              B1061 13 [009] - Open Circuit
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:40
    0527 - Rear Left Bass Speaker
              B1065 13 [009] - Open Circuit
                        Reset counter: 43
                        Mileage: 50078 km
                        Date: 2020.06.02
                        Time: 09:23:40
       Part No SW: 7E0 907 534     HW: 7E0 937 090 C
       Component: Batt.regelung H82 0752
       Coding: 330B1A73
       Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
       Serial number: 75885700001708240010
       Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0011
       Serial number: 30000000010228
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
       Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0130
       Revision: 3B001001    Serial number: 00000452146382
       Coding: 410D000103000000
       VCID: 326BF65E6D51AC16CD-8066
    Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
       Part No SW: 7E0 959 107 A    HW: 7E0 959 107
       Component: HDSG-Modul    H02 0653
       Revision: 31002002    Serial number: 114900016
       Coding: 1963094003
       ASAM Dataset: EV_HDSGVN46T 203001
       ROD: EV_HDSGVN46T.rod
       VCID: 2C57E8264775FAE687-8078
    Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-L2.clb
       Part No SW: 7E5 919 037 H    HW: 7E5 919 037 H
       Component: Dachdisplay   H18 0200
       Revision: 11100013    Serial number: 504385
       Coding: 000106
       Shop #: WSC 02759 790 00000
       VCID: 3663CA4E8139B036E1-8062
    Address 78: Slide Door, Right        Labels: Redir Fail!
    Address 0B: Sec. Air Heating        Labels: None
       Part No: 7E0 819 006 M
       Component: J604  Standheizung  0401
       Revision: L100400A    Serial number: 00000000000000
       VCID: 3169F952AB57970EB4-5122
    End-------------------------(Elapsed Time: 04:28)--------------------------
    VCDS Distributor AINils's Avatar
    Apr 2020
    Germany (AIB)
    Check if EV_EPHVA18VW364GP00_VW32.rod is in your VCDS Folder. It´s th right ROD File for this ECU. But maybe Assignment for commercial vehicles is different.
  3. Likes Deaky liked this post
    Jan 2020
    Hi @AINils Thanks for your reply. Yes, EV_EPHVA18VW364GP00_VW32.rod is in the VCDS UDS_EV folder.
    This can happen when one retrofits "incorrect" parts. We have a means to implement a work-around, but this is not instant.
    FWIW, the fault code is:
    Databus: Missing Message
    Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation
  6. Likes Deaky liked this post
    Jan 2020
    Thanks Uwe. The fault code makes sense because the PDC module will expect to see an electric steering rack, which I don’t have. What do I have to do to start the workaround procedure? There is no rush as the module is working correctly for me.
    Apr 2020
    Germany (AIB)
    @Uwe your're right didn't see this ECU in commercial vehicles till now, only PQ 36 Facelift (golf, Jetta, scirocco and also PQ4x based Passat CC) use this module, but never seen in PQ26 (commercial vehicles).
    As Iam right mZAS = Zündanlasschalter means Kessy Engine Start knob or different ignition key system.
  9. Likes Uwe liked this post
