Results 1 to 4 of 4
Thread: Door projectors/lock when leaving
    Jul 2017
    Hello. I have a 2018 SEv6 4motion. I'm trying to find and enable the car locking when I walk away from it. I know its in VCDS SOMEWHERE. Also, I'm adding emergency lights on the front doors. They sit at the bottom of the door panel. In all but the SEL these are reflectors. I have the harnesses, but where can I find the pinouts for the door harness? Any help is appreciated.
    Posting a full unedited VCDS Auto-Scan would be a great help
  3. Likes Uwe liked this post
    Jul 2017
    I'm at work at the moment, but here's one from a bit ago. Nothing has changed though (other than remote windows enabled and LED fogs)
    Sunday,05,January,2020,01:42:42:41190
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
    VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: 1V2KR2CA8JC567568   License Plate:
    Mileage: 88572km-55036mi   Repair Order:
    Chassis Type: CA-VW41 (3Q0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 3C 42 44 4B 52 5F 6C 75
              D6 D7
    VIN: 1V2KR2CA8JC567568   Mileage: 88572km-55036miles
    Address 01: Engine (0-32-CDVC)       Labels:. 03H-907-309-V1.clb
       Part No SW: 03H 906 026 E    HW: 03H 907 309 K
       Component: VR6 3.6l FSI  H21 6024
       Revision: 52H21000
       Coding: 012A00124424010870000000000000000000000000000000
       Shop #: WSC 03302 444 00000
       ASAM Dataset: EV_ECM36FSI01103H906026E 001005
       ROD: EV_ECM36FSI01103H906026AG.rod
       VCID: 2708F3CDDF671A5FA8D-8073
       CAN Converter 01:
    Readiness: 0000 0100
       Part No SW: 09G 927 158 A    HW: 09G 927 158
       Component: AISIN AQ8     206 3387
       Coding: 0000000100000000000000000000000000000000
       Shop #: WSC 09003 957 00200
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 313C1D95E1A354EF769-8065
       Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
       Component: ESC           H25 0413
       Revision: 00000000    Serial number: 50958000000417
       Coding: 44FC6B8D84261A73C57C0306A2CB6922D62158A3C045967E00415058C28A4200002F641C12141A118DDB45506CC8CF
       ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
       VCID: 76B6EE89484D33D7E3B-8023
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 208
                        Mileage: 88230 km
                        Date: 2019.12.11
                        Time: 14:01:41
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0467740447
       Coding: 1F20000723
       VCID: 3E2636A920FDBB97FBB-806B
              U1400 00 [008] - -
                        Reset counter: 211
                        Mileage: 88230 km
                        Date: 2019.12.14
                        Time: 14:12:49
                        ZAT_pressed: OFF
                        Control Module Voltage: 7.486 V
                        Vehicle speed: 0.0 km/h
                        Engine speed: 0.0 /min
                        Coding information: coded
                        Driver door: Open
                        Front Passenger Door: closed
                        Left rear door: closed
                        Right rear door: closed
                        Active_LF_scans: Init
                        SPN_Byte 0: 00
                        SPN_Byte 1: 00
                        SPN_Byte 2: 00
    Address 08: Auto HVAC (J301)       Labels:* None
       Part No SW: 3CN 907 426 E    HW: 3CN 907 426 E
       Component: AC Manuell    H04 2002
       Revision: 00001K00
       Coding: 1602000620001800100020404200000C
       ASAM Dataset: EV_ACManueBHBVW416 001002
       ROD: EV_ACManueBHBVW416.rod
       VCID: 45D45945452BE84FBA1-8011
       Fresh Air Blower Back:
       Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
       Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H36 0253
       Serial number: 8015015902ˇˇˇˇ
       ROD: EV_BCMBOSCH_018.rod
       VCID: 06569E4938AD2357F3B-8053
       Subsystem 1 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  047 0105
       Serial number: S7Y18M02D13H15M04S13
       Coding: 00382D
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 168
                        Mileage: 88230 km
                        Date: 2019.12.11
                        Time: 14:06:11
    204546 - Remote key 2
                        Reset counter: 168
                        Mileage: 88230 km
                        Date: 2019.12.11
                        Time: 14:05:25
       Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
       Component: Airbag VW21   006 0713
       Revision: --------    Serial number: 003SUM5CHKEM
       Coding: 8CCCDC00000000005000001A420800000065
       ROD: EV_AirbaVW21TS6VW48X.rod
       VCID: 0B40AF7D23CF5E3FAC5-805F
       Occupant Detection:
       Component: Occ.Detection  H13 0022
       Serial number: IBH0000J180008X3TO0%
       Coding: 303030
       Subsystem 2 - Part No SW: -----------    HW: 454 001 212 17
       Serial number: 35700000000EDC286B2/
       Subsystem 3 - Part No SW: -----------    HW: 454 001 401 18
       Serial number: 358000000002D6ECCB22
       Subsystem 4 - Part No SW: -----------    HW: 454 801 001 18
       Serial number: 351002768FD12000000K
       Subsystem 5 - Part No SW: -----------    HW: 454 801 401 18
       Serial number: 3520068E401130000004
       Subsystem 6 - Part No SW: -----------    HW: 454 800 201 18
       Serial number: 35500DAC97612000000U
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 454 800 201 18
       Component: FrontSensor_P  304 0149
       Serial number: 35600A7E17112000000E
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 18021820241001
       Coding: 0410
       VCID: 0748934D3FA73A5F88D-8053
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 3CN 920 850 A    HW: 3CN 920 850 A
       Component: KOMBI         380 0310
       Coding: 0BA4171DAB88CF0502086B0850000000A0000000
       VCID: 3D2431A52DFBA08FE21-8069
       Component: GW MQB High   518 5323
       Serial number: 26011800840079
       Coding: 030500347F087300FB0320481E0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 382A20B102D985A7317-806D
       Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0103
       Serial number: 28180000051590091439
       Coding: 30FFFF
       Serial number: 3047705600
       Component: Haldex4Motion H52 7084
       Serial number: HA1-00007.12.17
       Coding: 0301
       VCID: 4CC26C616641190765F-8019
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000012734010
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW41.rod
       VCID: 3330179D1BBF66FF045-8067
       Component: HRE_Master    H12 0080
       Serial number: 0468858943
       Coding: 01011103
       ROD: EV_HREntryHella_VW27.rod
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0468952901
       Coding: 010111
       Serial number: 170218A0080489
       Coding: 003013200000020000000000
       VCID: 43D0475D4B1FD67F945-8017
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000228640
       Coding: 011000
       Revision: 00000000    Serial number: 0002358811
       Coding: 01000310004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
       VCID: 40DA48515A09CD67897-8015
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Serial number: 03031800841812
       Coding: 000000070100135200010000000000000000000000000000000000000000
       VCID: 72BED29924252FF7CF3-8027
       Serial number: 060318A00801Q9
       VCID: 42DE42595405DF779F3-8017
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000226286
       Coding: 091000
       Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
       Component: MU-S-S-US     722 0867
       Coding: 02140600FF00000051220001001808001F0500C40120050002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2E0606E9F09D4B176BB-807B
       Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
       Component: ABT_Std-2  H50 8130
       Serial number: VWZ6ZJV0245693
              B11CF 53 [009] - Deactivated
                        Reset counter: 168
                        Mileage: 88230 km
                        Date: 2019.12.11
                        Time: 14:02:04
                        Voltage terminal 30: 14.8 V
                        SDARS_tuner_status_2-Audio Signal: Available
                        SDARS_tuner_status_2-Antenna current: 102 mA
                        SDARS_tuner_status_2-Reception quality: optimum_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
       Coding: 01150602A0002017300040
       VCID: 392C25B539D39CAFCE9-806D
       Component: OCULowMQBUS   009 0570
       Coding: 02140602C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
       Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
       Component: LED1L         H06 0003
       ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
       VCID: 7BA0FFBD736F6EBF9C5-802F
       Component: LED1R         H06 0003
       ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/12.2V)-----------
    Jul 2017
    If you need a newer one (for verification) I can maybe go run one on lunch.
