Results 1 to 4 of 4
Thread: Please help multiple faulty codes jetta mk5
    New User pegasus19's Avatar
    May 2020
    Hi is my first time in the forum, and im trying to fix multiples faulty codes in my jetta 2.5 , im rookie using the Ross-tech software and i dont know what to do, i run the scan and after that i cleared the faulty codes but unfortunately somes faulty codes dont go away please help
    Sunday,31,May,2020,16:12:56:11845
    VCDS Version: 20.4.1.0
    VIN: 3VWEG71K07M156490   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWEG71K07M156490   Mileage: 213020km-132364miles
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 Q    HW: 07K 906 032 Q
       Component: 2.5l R5/4V      G   9650
       Revision: --H01---    Serial number: VWZ7Z0G9050816
       Coding: 0000003
       Shop #: WSC 00999 444 64523
       VCID: 377D92044663C13EFA-8062
    005699 - Please check DTC Memory of Electric Load Controller
                   P1643 - 001 -
                        Fault Status: 01100001
                        Fault Frequency: 23
                        Mileage: 212991 km
                        Time: 00:45:25
                        Temperature: 19.0C
                        Temperature: 18.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.192 V
    049489 - No Communications with Airbag Control Module
                   U0151 - 008 -  - Intermittent
                        Mileage: 212991 km
                        Time: 00:53:54
                        Temperature: 48.0C
                        Temperature: 49.0C
                        Voltage: 6.350 V
    001110 - EVAP System
                   P0456 - 001 - Very Small Leak Detected
                        Mileage: 213025 km
                        Time: 18:54:58
                        RPM: 1268 /min
                        Load: 18.8 %
                        Speed: 48.0 km/h
                        Temperature: 58.0C
                        Temperature: 27.0C
                        Voltage: 14.351 V
    Readiness: 0000 1000
       Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
       Component: AQ 250 6F           0920
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 000F39D8532D46860B-8054
       Revision: 00H11001
       Coding: 0021122
       Shop #: WSC 01279 785 00200
       VCID: 73E56614129B6D1E06-8026
       Part No: 1K0 820 047 GS
       Component: Climatic PQ35   120 0606
       VCID: 7BF54E343ACB255E5E-802E
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000000610733
       Coding: 14058E234004150007140000001400000008730B5C0000
       VCID: 6BD57E744AABB5DECE-803E
       Component: Wischer 240307 020  0501
       Coding: 00038805
       Revision: 05034000    Serial number: 003B6M01AYZ-
       Coding: 0013889
       VCID: 6CD77D684FA5B2E6C7-8038
       Subsystem 2 - Serial number: 6332MSME162E7045A
       Subsystem 3 - Serial number: 6342MSME170D2677F
       Subsystem 4 - Serial number: 6351HSME0C5706300
       Subsystem 5 - Serial number: 6361HSME0C592825B
       Subsystem 6 - Serial number: 63727SME0C380538%
       Subsystem 7 - Serial number: 63827SME0C3566294
       Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
       Component: J0527           056 0101
       Coding: 0000021
       Shop #: WSC 33619 002 1048576
       VCID: 7CF74D283FC5226657-8028
    00895 - Cruise Control Switch (E45)
                014 - Defective
       Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
       Component: KOMBIINSTRUMENT 3HL 1610
       Revision: V0003000    Serial number: VWZ7Z0G9050816
       Coding: 0022207
       Shop #: WSC 00066 067 57207
       VCID: 387F91384B7DCE46F3-806C
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 280207F2002663
       Coding: 3FBF034007001002
       VCID: 2F6DAA64BE3309FEA2-807A
       Component: IMMO            3HL 1610
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000062078224
       Coding: 0001205
    That looks like only the first part of the Auto-Scan - the data for module #42 is incomplete and the data for modules #44 to #72 is missing?
  3. Likes Uwe liked this post
    May 2020
    hi, im sorry for that, let me copy and paste again the scan,
       Coding: 0000003
                   P1643 - 001 -
                        Fault Frequency: 23
                        Mileage: 212991 km
                        Time: 00:45:25
                        Temperature: 19.0C
                        Temperature: 18.0C
                        Voltage: 12.192 V
                        Mileage: 212991 km
                        Time: 00:53:54
                        Temperature: 48.0C
                        Temperature: 49.0C
                        Voltage: 6.350 V
                        Mileage: 213025 km
                        Time: 18:54:58
                        RPM: 1268 /min
                        Load: 18.8 %
                        Speed: 48.0 km/h
                        Temperature: 58.0C
                        Temperature: 27.0C
                        Voltage: 14.351 V
       Coding: 0000072
       Revision: 00H11001
       Coding: 0021122
       Coding: 00038805
       Coding: 0013889
       Coding: 0000021
                014 - Defective
       Coding: 0022207
       Coding: 0001205
       VCID: 3B758E347A4BE55E1E-806E
                        Fault Status: 00100101
                        Reset counter: 210
                        Mileage: 213022 km
                        Fault Status: 00111000
                        Fault Frequency: 7
                        Reset counter: 212
                        Mileage: 213024 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.069 H07 1806
       Shop #: WSC 00000 028 00001
       VCID: 3467A50857152A26DF-8060
       Component:    KSG PQ35 RDK 052 0218
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 040735C847355AA62F-8050
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000551378224
       Coding: 0001204
       VCID: 3C778D287F45E26617-8068
                        Fault Status: 01100101
                        Reset counter: 173
                        Mileage: 213022 km
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 B    HW: 1K0 035 161 B
       Component: Radio DE2       014 0017
       Revision: 00014000    Serial number: VWZ4Z7G6233389
       Coding: 0040401
       VCID: 1E3367A0C999907619-804A
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000001210080
       Coding: 0001168
       VCID: 3E7387206959F07639-806A
       Component:    RDK              0440
       Coding: 0100101
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000001233851
       Coding: 0001168
       VCID: 3F8DFA246E53F97E32-806A
    End-------------------------(Elapsed Time: 02:09)--------------------------
  6. Likes PetrolDave liked this post
