2012 1.8 Cda Audi TT no go
Schoonerzero
C?ID=79822
Hi everyone, think im missing something and would appreciate a fresh set of eyes...
Recovered in, cranks no start, no spark has fuel, customer pulled off, engine went flat or into a dead spot then stalled and wouldn’t restart, voltage codes mainly relate to flat battery, this has been replaced with new, coil codes is where I’ve pulled them off, likewise crank sensor was swapped, have low pressure fuel to pump and Hpfp desired and actual seem to be in spec, compression tested and have 130 psi on each cylinder and the distance between cam marks is 124 mm, not had the pleasure of this engine... any thoughts or info would be great!��
Monday,01,June,2020,11:25:57:57278
VCDS Version: 19.6.1.0 (x64)
VIN: TRUZZZ8J6C1012138   License Plate:
Chassis Type: 8J (7N0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 47 52 56 61
VIN: TRUZZZ8J6C1012138   Mileage: 51860km-32224miles
Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
   Part No SW: 8J0 907 115 BC    HW: 8P0 907 115 Q
   Component: 1.8l R4/4V TFSI     0020
   Revision: AAH18---    Serial number: AUX7Z0KDFND0ED
   Coding: 0113000C18070060
   Shop #: WSC 01236 785 00200
   VCID: 6ED79E827948BB3F7B-803A
7 Faults Found:
000564 - Boost Pressure Regulation
               P0234 - 000 - Limit Exceeded (Overboost Condition) - MIL ON
                    Fault Status: 11100000
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 01:15:12
                    Temperature: 24.0°C
                    Temperature: 27.0°C
                    Absolute Pres.: 1030.0 mbar
                    Voltage: 12.319 V
000566 - Manifold Pressure / Boost Sensor (G31)
               P0236 - 000 - Implausible Signal - Intermittent
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 01:56:26
                    RPM: 292 /min
                    Load: 59.6 %
                    Temperature: 26.0°C
                    Temperature: 29.0°C
                    Voltage: 11.176 V
000852 - Ignition Control Circuit for Cylinder 4
               P0354 - 000 - Malfunction - Intermittent
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 03:16:45
                    RPM: 286 /min
                    Load: 59.6 %
                    Temperature: 27.0°C
                    Temperature: 29.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 11.176 V
000849 - Ignition Control Circuit for Cylinder 1
               P0351 - 000 - Malfunction - Intermittent
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 03:17:05
                    RPM: 289 /min
                    Load: 59.6 %
                    Temperature: 27.0°C
                    Temperature: 29.0°C
                    Voltage: 10.922 V
000802 - Engine Speed Sensor (G28)
               P0322 - 000 - No Signal - Intermittent
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 03:32:37
                    Temperature: 27.0°C
                    Temperature: 28.0°C
                    Voltage: 11.049 V
000851 - Ignition Control Circuit for Cylinder 3
               P0353 - 000 - Malfunction - Intermittent
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 04:01:15
                    RPM: 292 /min
                    Load: 58.8 %
                    Temperature: 27.0°C
                    Temperature: 30.0°C
                    Voltage: 11.176 V
000850 - Ignition Control Circuit for Cylinder 2
               P0352 - 000 - Malfunction - Intermittent
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 04:01:15
                    RPM: 292 /min
                    Load: 58.8 %
                    Temperature: 27.0°C
                    Temperature: 30.0°C
                    Voltage: 11.176 V
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 E    HW: 8J0 614 517 E
   Component: ESP MK60E1          0010
   Revision: 00H60001
   Coding: 0083216
   VCID: 2F694386BEC2F23730-807A
                    Reset counter: 66
                    Mileage: 51861 km
                    Date: 2020.05.23
                    Time: 13:20:43
                    Count: 2117
                    Count: 128
                    Count: 32000
                    Reset counter: 66
                    Mileage: 51862 km
                    Count: 128
                    Count: 837
                    Count: 297
                    Count: 37632
   Part No SW: 8J0 820 043 BA    HW: 8J0 820 043 BA
   Component: J255  Klima 1 Zone  0110
   Revision: 00H09006    Serial number: 00000001202706
   Coding: 1574148
   VCID: 66C7E6A251B8737F03-8032
                    Reset counter: 106
                    Mileage: 51861 km
                    Date: 2020.05.25
                    Time: 12:48:35
                    Voltage: 11.20 V
                    Reset counter: 66
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 00:00:01
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 R    HW: 8P0 907 063 R
   Component: BCM PQ35  H   110 0667
   Revision: AG110667
   Coding: 46000B2FA805F1202070E8E000000104528A56AA1000C9285C000E400045
   Shop #: WSC 01236 758 00200
   VCID: 43811F36C24A6657C4-8016
   Subsystem 1 - Part No SW: 8J2 955 119 A    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H09 0070
   Coding: 00FD10
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor H0  H03 0030
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -t Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K005N4GY
   Coding: 0011636
   VCID: 79FDBDDE3006EC87DE-802C
   Subsystem 1 - Serial number: 6332DRB40E0DD00F
   Subsystem 2 - Serial number: 6342DRB40E09D29C0
   Subsystem 3 - Serial number: 63747RB4067B0F67Z
   Part No SW: 1K0 953 549 DB    HW: 1K0 953 549 DB
   Component: J0527           037 0070
   Coding: 0000011
   VCID: 75E5B1EE1C1E88E7BA-8020
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 980 T    HW: 8J0 920 980 T
   Component: KOMBIINSTR. VDO H03 0650
   Revision: D0H03002    Serial number: 224DK002001753
   Coding: 0260428
   Shop #: WSC 12345 067 57207
   VCID: 428F1A321D506F5FCF-8016
                    Reset counter: 40
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 20:37:11
00532 - Supply Voltage B+
                    Reset counter: 40
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 20:37:51
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 021211F1001936
   Coding: 355101
   VCID: 3B7167D6BABA1E978C-806E
03406 - Control Module for Battery Monitoring
                    Reset counter: 66
                    Mileage: 51861 km
                    Date: 2020.05.25
                    Time: 12:48:09
   Revision: D0H03002    Serial number: AUX7Z0KDFND0ED
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 D
   Component: 256 VSG TT      H18 0150
   VCID: 408B103A135C7D4FD9-8014
Address 42: Door Elect, Driver        Labels: None
   Part No SW: 8J7 959 801 N    HW: 8J7 959 801 N
   Component: Tuer-SG         004 0102
   Coding: 0000565
   VCID: 47990B2636724A7718-8012
   Part No: 8J0 909 144 P
   Component: EPS_ZFLS Kl. 235    3305
   Revision: 00H22000
   VCID: 3D7569CE64AE10A7B2-8068
            000 - - - MIL ON
                    Battery Volts: 10.8 V
                        PD
                    Temperature: 28.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0160
   Revision: PROD_01     Serial number: 00000000039624
   Coding: 0136137
   Shop #: WSC 18125 000 1048576
   VCID: 2545A1AEEC3EB867CA-8070
                    Fault Status: 00101100
                    Reset counter: 106
Address 52: Door Elect, Pass.        Labels: None
   Part No SW: 8J7 959 802 N    HW: 8J7 959 802 N
   Coding: 0000564
   VCID: 489B081A3B6C450F11-801C
   Part No SW: 8J0 035 195 G    HW: 8J0 035 195 G
   Component: R Symphony2+    H08 0281
   Revision: 00H08000    Serial number: AUZ1Z4L3353691
   Coding: 0130101
   VCID: 306B40FAA3FCEDCF29-8064
                    Reset counter: 106
                    Mileage: 51862 km
                    Date: 2020.05.26
                    Time: 20:31:28
   Component: Batt.regelung H43 1623
   Coding: F326015A
   VCID: 71ED85FEA876A4C766-8024
02071 - Local Databus
                    Reset counter: 66
                    Mileage: 51861 km
                    Date: 2020.05.25
                    Time: 12:48:14
End-------------------------(Elapsed Time: 01:59)--------------------------
What happens if you clear the fault codes from 01-Engine? Do the coil faults come back right away? Do they come back after cycling the ignition? Do they come back after a start attempt?
Have you looked in the wiring diagrams for something that the coils have in common with the G31 and G28 sensors? Maybe a ground?
Schoonerzero
C?ID=79822
Thanks for replying Uwe, all the codes clear and stay cleared after cycle, this was after a days nagging head against wall, it ckp is only two pin checked ohms, even swapped it for new, ecu sees rpm, coils have good eng earth, eng has good earth to battery, good 12v, but scoped all four triggers to ecu, no pulse, so go back to timing, relunctant to undo interference bolt and bend cover getting it off needlessly, check cam timing distance which appears in at the lower tolerance, turns over at 270 live data, has 130 psi on all 4 pots, seems to turn over fast, try not to listen to stories about chains, go back to it was driving away just after start up from warm, cut out no restart, think have I gone too deep, check IMmo, appears ok for engine start (cap com go, guidance go....etc, engine....no!) sorry, go back to wiring, all commons to all coils seem ok, currently at pull ecu out of antitheft to checknpowers and grounds but at the same time wondering about timing chains..... even take plugs out again and stick a camera down the bores, shiny valves and no visible signs of impact damage.
Does the engine ecu check one revaluation before firing the coils or should the pulse be instant?
And I’m right in thinking ckp spark and cmp injectors?
HMC
C?ID=28246
Hi Shoonerzero,
" And I’m right in thinking ckp spark and cmp injectors? ". No that is not correct, the ckp and cmp are parts of the whole engine management system, which provides injection and ignition as an integrated system. The fast cranking is a concern, 130 PSI doesn't seem a lot. Do you have signals from CKP and CMP? Have you checked for obstructions in the induction or exhaust?
Regards HMC
Rollux
New Zealand
C?ID=380572
9.6:1 compression ratio should have a lot higher comp than 130psi, more like 170
Schoonerzero
C?ID=79822
Hi Shoonerzero,
Regards HMC
Hi, yep induction is clear, all pipes to tb are off, put camera into inlet, shut off flaps are there and actuate, have a new cmp to subbsitute later, but yes still thinking the chains moved
PetrolDave
Westbury, UK
C?ID=1423
The only time I've had an engine crank fast was after the timing belt failed and some valves hit pistons (1 week after the timing belt had been changed but the idler pulley had not and it failed), definitely worth checking that the timing is correct and that all the valves are seating correctly.
Schoonerzero
C?ID=79822
Tell me about it, but normally there’d be nothing on at least on one pot, it’s only a bit fast, not really fast, if you see what I mean, and this morning have re re re checked, crank mark on mark, inlet is 61mm from raised guide and cams marks are 124mm apart sooo... it still seems not timing
:banghead:
Schoonerzero
C?ID=79822
:banghead:
Dash cluster !! IMmo flags saying one thing but not releaseing engine ecu, unrepairable
