Results 1 to 9 of 9
Thread: 2012 1.8 Cda Audi TT no go
    Jul 2018
    Hi everyone, think im missing something and would appreciate a fresh set of eyes...
    Recovered in, cranks no start, no spark has fuel, customer pulled off, engine went flat or into a dead spot then stalled and wouldn’t restart, voltage codes mainly relate to flat battery, this has been replaced with new, coil codes is where I’ve pulled them off, likewise crank sensor was swapped, have low pressure fuel to pump and Hpfp desired and actual seem to be in spec, compression tested and have 130 psi on each cylinder and the distance between cam marks is 124 mm, not had the pleasure of this engine... any thoughts or info would be great!��
    Monday,01,June,2020,11:25:57:57278
    VCDS Version: 19.6.1.0 (x64)
    VIN: TRUZZZ8J6C1012138   License Plate:
    Chassis Type: 8J (7N0)
    Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 47 52 56 61
    VIN: TRUZZZ8J6C1012138   Mileage: 51860km-32224miles
    Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
       Part No SW: 8J0 907 115 BC    HW: 8P0 907 115 Q
       Component: 1.8l R4/4V TFSI     0020
       Revision: AAH18---    Serial number: AUX7Z0KDFND0ED
       Coding: 0113000C18070060
       Shop #: WSC 01236 785 00200
       VCID: 6ED79E827948BB3F7B-803A
    7 Faults Found:
    000564 - Boost Pressure Regulation
                   P0234 - 000 - Limit Exceeded (Overboost Condition) - MIL ON
                        Fault Status: 11100000
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 01:15:12
                        Load: 0.0 %
                        Temperature: 24.0C
                        Temperature: 27.0C
                        Absolute Pres.: 1030.0 mbar
                        Voltage: 12.319 V
    000566 - Manifold Pressure / Boost Sensor (G31)
                   P0236 - 000 - Implausible Signal - Intermittent
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 01:56:26
                        RPM: 292 /min
                        Load: 59.6 %
                        Temperature: 26.0C
                        Temperature: 29.0C
                        Voltage: 11.176 V
    000852 - Ignition Control Circuit for Cylinder 4
                   P0354 - 000 - Malfunction - Intermittent
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 03:16:45
                        RPM: 286 /min
                        Load: 59.6 %
                        Temperature: 27.0C
                        Temperature: 29.0C
                        Absolute Pres.: 1020.0 mbar
                        Voltage: 11.176 V
    000849 - Ignition Control Circuit for Cylinder 1
                   P0351 - 000 - Malfunction - Intermittent
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 03:17:05
                        RPM: 289 /min
                        Load: 59.6 %
                        Temperature: 27.0C
                        Temperature: 29.0C
                        Voltage: 10.922 V
    000802 - Engine Speed Sensor (G28)
                   P0322 - 000 - No Signal - Intermittent
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 03:32:37
                        Load: 0.0 %
                        Temperature: 27.0C
                        Temperature: 28.0C
                        Voltage: 11.049 V
    000851 - Ignition Control Circuit for Cylinder 3
                   P0353 - 000 - Malfunction - Intermittent
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 04:01:15
                        RPM: 292 /min
                        Load: 58.8 %
                        Temperature: 27.0C
                        Temperature: 30.0C
                        Voltage: 11.176 V
    000850 - Ignition Control Circuit for Cylinder 2
                   P0352 - 000 - Malfunction - Intermittent
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 04:01:15
                        RPM: 292 /min
                        Load: 58.8 %
                        Temperature: 27.0C
                        Temperature: 30.0C
                        Voltage: 11.176 V
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 614 517 E    HW: 8J0 614 517 E
       Component: ESP MK60E1          0010
       Revision: 00H60001
       Coding: 0083216
       VCID: 2F694386BEC2F23730-807A
                        Reset counter: 66
                        Mileage: 51861 km
                        Date: 2020.05.23
                        Time: 13:20:43
                        Count: 2117
                        Count: 128
                        Count: 32000
                        Reset counter: 66
                        Mileage: 51862 km
                        Count: 128
                        Count: 837
                        Count: 297
                        Count: 37632
       Part No SW: 8J0 820 043 BA    HW: 8J0 820 043 BA
       Component: J255  Klima 1 Zone  0110
       Revision: 00H09006    Serial number: 00000001202706
       Coding: 1574148
       VCID: 66C7E6A251B8737F03-8032
                        Fault Frequency: 6
                        Reset counter: 106
                        Mileage: 51861 km
                        Date: 2020.05.25
                        Time: 12:48:35
                        Voltage: 11.20 V
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 66
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 00:00:01
       Part No SW: 8P0 907 063 R    HW: 8P0 907 063 R
       Component: BCM PQ35  H   110 0667
       Revision: AG110667
       Coding: 46000B2FA805F1202070E8E000000104528A56AA1000C9285C000E400045
       Shop #: WSC 01236 758 00200
       VCID: 43811F36C24A6657C4-8016
       Subsystem 1 - Part No SW: 8J2 955 119 A    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer AU354  H09 0070
       Coding: 00FD10
       Subsystem 2 - Part No: 8J0 951 177
       Component: DWA-Sensor H0  H03 0030
    Address 15: Airbags        Labels: 8J0-959-655.lbl
       Part No SW: 8J0 959 655     HW: 8J0 959 655
       Component: -t Airbag 9.43  H03 0020
       Revision: 93H03002    Serial number: 0036K005N4GY
       Coding: 0011636
       VCID: 79FDBDDE3006EC87DE-802C
       Subsystem 1 - Serial number: 6332DRB40E0DD00F
       Subsystem 2 - Serial number: 6342DRB40E09D29C0
       Subsystem 3 - Serial number: 63747RB4067B0F67Z
       Part No SW: 1K0 953 549 DB    HW: 1K0 953 549 DB
       Component: J0527           037 0070
       Coding: 0000011
       VCID: 75E5B1EE1C1E88E7BA-8020
    Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
       Part No SW: 8J0 920 980 T    HW: 8J0 920 980 T
       Component: KOMBIINSTR. VDO H03 0650
       Revision: D0H03002    Serial number: 224DK002001753
       Coding: 0260428
       Shop #: WSC 12345 067 57207
       VCID: 428F1A321D506F5FCF-8016
                        Reset counter: 40
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 20:37:11
    00532 - Supply Voltage B+
                        Reset counter: 40
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 20:37:51
       Part No SW: 7N0 907 530 N    HW: 1K0 907 951
       Component: J533  Gateway H43 1623
       Revision:   H43       Serial number: 021211F1001936
       Coding: 355101
       VCID: 3B7167D6BABA1E978C-806E
    03406 - Control Module for Battery Monitoring
                        Reset counter: 66
                        Mileage: 51861 km
                        Date: 2020.05.25
                        Time: 12:48:09
       Revision: D0H03002    Serial number: AUX7Z0KDFND0ED
    Address 26: Auto Roof        Labels: 8J7-959-255.lbl
       Part No: 8J7 959 255 D
       Component: 256 VSG TT      H18 0150
       VCID: 408B103A135C7D4FD9-8014
    Address 42: Door Elect, Driver        Labels: None
       Part No SW: 8J7 959 801 N    HW: 8J7 959 801 N
       Component: Tuer-SG         004 0102
       Coding: 0000565
       VCID: 47990B2636724A7718-8012
       Part No: 8J0 909 144 P
       Component: EPS_ZFLS Kl. 235    3305
       Revision: 00H22000
       VCID: 3D7569CE64AE10A7B2-8068
                000 - - - MIL ON
                        Battery Volts: 10.8 V
                            PD
                        Temperature: 28.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
    Address 47: Sound System        Labels: 8J0-035-223.lbl
       Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
       Component: J525 Amp High   H04 0160
       Revision: PROD_01     Serial number: 00000000039624
       Coding: 0136137
       Shop #: WSC 18125 000 1048576
       VCID: 2545A1AEEC3EB867CA-8070
                        Fault Status: 00101100
                        Reset counter: 106
    Address 52: Door Elect, Pass.        Labels: None
       Part No SW: 8J7 959 802 N    HW: 8J7 959 802 N
       Coding: 0000564
       VCID: 489B081A3B6C450F11-801C
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
    Address 56: Radio        Labels: 8J0-035-1xx-56.clb
       Part No SW: 8J0 035 195 G    HW: 8J0 035 195 G
       Component: R Symphony2+    H08 0281
       Revision: 00H08000    Serial number: AUZ1Z4L3353691
       Coding: 0130101
       VCID: 306B40FAA3FCEDCF29-8064
                        Reset counter: 106
                        Mileage: 51862 km
                        Date: 2020.05.26
                        Time: 20:31:28
       Component: Batt.regelung H43 1623
       Coding: F326015A
       VCID: 71ED85FEA876A4C766-8024
    02071 - Local Databus
                        Fault Status: 01101100
                        Reset counter: 66
                        Mileage: 51861 km
                        Date: 2020.05.25
                        Time: 12:48:14
    End-------------------------(Elapsed Time: 01:59)--------------------------
    What happens if you clear the fault codes from 01-Engine? Do the coil faults come back right away? Do they come back after cycling the ignition? Do they come back after a start attempt?
    Have you looked in the wiring diagrams for something that the coils have in common with the G31 and G28 sensors? Maybe a ground?
    Jul 2018
    Thanks for replying Uwe, all the codes clear and stay cleared after cycle, this was after a days nagging head against wall, it ckp is only two pin checked ohms, even swapped it for new, ecu sees rpm, coils have good eng earth, eng has good earth to battery, good 12v, but scoped all four triggers to ecu, no pulse, so go back to timing, relunctant to undo interference bolt and bend cover getting it off needlessly, check cam timing distance which appears in at the lower tolerance, turns over at 270 live data, has 130 psi on all 4 pots, seems to turn over fast, try not to listen to stories about chains, go back to it was driving away just after start up from warm, cut out no restart, think have I gone too deep, check IMmo, appears ok for engine start (cap com go, guidance go....etc, engine....no!) sorry, go back to wiring, all commons to all coils seem ok, currently at pull ecu out of antitheft to checknpowers and grounds but at the same time wondering about timing chains..... even take plugs out again and stick a camera down the bores, shiny valves and no visible signs of impact damage.
    Does the engine ecu check one revaluation before firing the coils or should the pulse be instant?
    And I’m right in thinking ckp spark and cmp injectors?
    Jul 2014
    Hi Shoonerzero,
    " And I’m right in thinking ckp spark and cmp injectors? ". No that is not correct, the ckp and cmp are parts of the whole engine management system, which provides injection and ignition as an integrated system. The fast cranking is a concern, 130 PSI doesn't seem a lot. Do you have signals from CKP and CMP? Have you checked for obstructions in the induction or exhaust?
    Regards HMC
    Feb 2020
    New Zealand
    9.6:1 compression ratio should have a lot higher comp than 130psi, more like 170
  6. Likes PetrolDave liked this post
    Jul 2018
    Quote Originally Posted by HMC View Post
    Hi Shoonerzero,
    " And Im right in thinking ckp spark and cmp injectors? ". No that is not correct, the ckp and cmp are parts of the whole engine management system, which provides injection and ignition as an integrated system. The fast cranking is a concern, 130 PSI doesn't seem a lot. Do you have signals from CKP and CMP? Have you checked for obstructions in the induction or exhaust?
    Regards HMC
    Hi, yep induction is clear, all pipes to tb are off, put camera into inlet, shut off flaps are there and actuate, have a new cmp to subbsitute later, but yes still thinking the chains moved
    Quote Originally Posted by Rollux View Post
    The only time I've had an engine crank fast was after the timing belt failed and some valves hit pistons (1 week after the timing belt had been changed but the idler pulley had not and it failed), definitely worth checking that the timing is correct and that all the valves are seating correctly.
  9. Likes Uwe liked this post
  10. #8
    Jul 2018
    Tell me about it, but normally thered be nothing on at least on one pot, its only a bit fast, not really fast, if you see what I mean, and this morning have re re re checked, crank mark on mark, inlet is 61mm from raised guide and cams marks are 124mm apart sooo... it still seems not timing
  11. #9
    Jul 2018
    Quote Originally Posted by Schoonerzero View Post
    Dash cluster !! IMmo flags saying one thing but not releaseing engine ecu, unrepairable
