Hi everyone, think im missing something and would appreciate a fresh set of eyes...
Recovered in, cranks no start, no spark has fuel, customer pulled off, engine went flat or into a dead spot then stalled and wouldn’t restart, voltage codes mainly relate to flat battery, this has been replaced with new, coil codes is where I’ve pulled them off, likewise crank sensor was swapped, have low pressure fuel to pump and Hpfp desired and actual seem to be in spec, compression tested and have 130 psi on each cylinder and the distance between cam marks is 124 mm, not had the pleasure of this engine... any thoughts or info would be great!��
Monday,01,June,2020,11:25:57:57278
VCDS Version: 19.6.1.0 (x64)
VIN: TRUZZZ8J6C1012138 License Plate:
Chassis Type: 8J (7N0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 47 52 56 61
VIN: TRUZZZ8J6C1012138 Mileage: 51860km-32224miles
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8J0 907 115 BC HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH18--- Serial number: AUX7Z0KDFND0ED
Coding: 0113000C18070060
Shop #: WSC 01236 785 00200
VCID: 6ED79E827948BB3F7B-803A
7 Faults Found:
000564 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition) - MIL ON
Fault Status: 11100000
Mileage: 51862 km
Date: 2020.05.26
Time: 01:15:12
Load: 0.0 %
Temperature: 24.0°C
Temperature: 27.0°C
Absolute Pres.: 1030.0 mbar
Voltage: 12.319 V
000566 - Manifold Pressure / Boost Sensor (G31)
P0236 - 000 - Implausible Signal - Intermittent
Mileage: 51862 km
Date: 2020.05.26
Time: 01:56:26
RPM: 292 /min
Load: 59.6 %
Temperature: 26.0°C
Temperature: 29.0°C
Voltage: 11.176 V
000852 - Ignition Control Circuit for Cylinder 4
P0354 - 000 - Malfunction - Intermittent
Mileage: 51862 km
Date: 2020.05.26
Time: 03:16:45
RPM: 286 /min
Load: 59.6 %
Temperature: 27.0°C
Temperature: 29.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 11.176 V
000849 - Ignition Control Circuit for Cylinder 1
P0351 - 000 - Malfunction - Intermittent
Mileage: 51862 km
Date: 2020.05.26
Time: 03:17:05
RPM: 289 /min
Load: 59.6 %
Temperature: 27.0°C
Temperature: 29.0°C
Voltage: 10.922 V
000802 - Engine Speed Sensor (G28)
P0322 - 000 - No Signal - Intermittent
Mileage: 51862 km
Date: 2020.05.26
Time: 03:32:37
Load: 0.0 %
Temperature: 27.0°C
Temperature: 28.0°C
Voltage: 11.049 V
000851 - Ignition Control Circuit for Cylinder 3
P0353 - 000 - Malfunction - Intermittent
Mileage: 51862 km
Date: 2020.05.26
Time: 04:01:15
RPM: 292 /min
Load: 58.8 %
Temperature: 27.0°C
Temperature: 30.0°C
Voltage: 11.176 V
000850 - Ignition Control Circuit for Cylinder 2
P0352 - 000 - Malfunction - Intermittent
Mileage: 51862 km
Date: 2020.05.26
Time: 04:01:15
RPM: 292 /min
Load: 58.8 %
Temperature: 27.0°C
Temperature: 30.0°C
Voltage: 11.176 V
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 614 517 E HW: 8J0 614 517 E
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0083216
VCID: 2F694386BEC2F23730-807A
Reset counter: 66
Mileage: 51861 km
Date: 2020.05.23
Time: 13:20:43
Count: 2117
Count: 128
Count: 32000
Reset counter: 66
Mileage: 51862 km
Count: 128
Count: 837
Count: 297
Count: 37632
Part No SW: 8J0 820 043 BA HW: 8J0 820 043 BA
Component: J255 Klima 1 Zone 0110
Revision: 00H09006 Serial number: 00000001202706
Coding: 1574148
VCID: 66C7E6A251B8737F03-8032
Fault Frequency: 6
Reset counter: 106
Mileage: 51861 km
Date: 2020.05.25
Time: 12:48:35
Voltage: 11.20 V
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 66
Mileage: 51862 km
Date: 2020.05.26
Time: 00:00:01
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 R HW: 8P0 907 063 R
Component: BCM PQ35 H 110 0667
Revision: AG110667
Coding: 46000B2FA805F1202070E8E000000104528A56AA1000C9285C000E400045
Shop #: WSC 01236 758 00200
VCID: 43811F36C24A6657C4-8016
Subsystem 1 - Part No SW: 8J2 955 119 A HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: Wischer AU354 H09 0070
Coding: 00FD10
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H0 H03 0030
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -t Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K005N4GY
Coding: 0011636
VCID: 79FDBDDE3006EC87DE-802C
Subsystem 1 - Serial number: 6332DRB40E0DD00F
Subsystem 2 - Serial number: 6342DRB40E09D29C0
Subsystem 3 - Serial number: 63747RB4067B0F67Z
Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
Component: J0527 037 0070
Coding: 0000011
VCID: 75E5B1EE1C1E88E7BA-8020
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 T HW: 8J0 920 980 T
Component: KOMBIINSTR. VDO H03 0650
Revision: D0H03002 Serial number: 224DK002001753
Coding: 0260428
Shop #: WSC 12345 067 57207
VCID: 428F1A321D506F5FCF-8016
Reset counter: 40
Mileage: 51862 km
Date: 2020.05.26
Time: 20:37:11
00532 - Supply Voltage B+
Reset counter: 40
Mileage: 51862 km
Date: 2020.05.26
Time: 20:37:51
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 021211F1001936
Coding: 355101
VCID: 3B7167D6BABA1E978C-806E
03406 - Control Module for Battery Monitoring
Reset counter: 66
Mileage: 51861 km
Date: 2020.05.25
Time: 12:48:09
Revision: D0H03002 Serial number: AUX7Z0KDFND0ED
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 D
Component: 256 VSG TT H18 0150
VCID: 408B103A135C7D4FD9-8014
Address 42: Door Elect, Driver Labels: None
Part No SW: 8J7 959 801 N HW: 8J7 959 801 N
Component: Tuer-SG 004 0102
Coding: 0000565
VCID: 47990B2636724A7718-8012
Part No: 8J0 909 144 P
Component: EPS_ZFLS Kl. 235 3305
Revision: 00H22000
VCID: 3D7569CE64AE10A7B2-8068
000 - - - MIL ON
Battery Volts: 10.8 V
PD
Temperature: 28.0°C
Count: 2
Steering Angle: 0.00°
SteerAng n.Init
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000039624
Coding: 0136137
Shop #: WSC 18125 000 1048576
VCID: 2545A1AEEC3EB867CA-8070
Fault Status: 00101100
Reset counter: 106
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8J7 959 802 N HW: 8J7 959 802 N
Coding: 0000564
VCID: 489B081A3B6C450F11-801C
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8J0 035 195 G HW: 8J0 035 195 G
Component: R Symphony2+ H08 0281
Revision: 00H08000 Serial number: AUZ1Z4L3353691
Coding: 0130101
VCID: 306B40FAA3FCEDCF29-8064
Reset counter: 106
Mileage: 51862 km
Date: 2020.05.26
Time: 20:31:28
Component: Batt.regelung H43 1623
Coding: F326015A
VCID: 71ED85FEA876A4C766-8024
02071 - Local Databus
Fault Status: 01101100
Reset counter: 66
Mileage: 51861 km
Date: 2020.05.25
Time: 12:48:14
End-------------------------(Elapsed Time: 01:59)--------------------------
