Results 1 to 10 of 18
Thread: Lost ABS Coding
    May 2020
    Lost ABS Coding
    I had my car smogged back in November the next day the ECM died, the car would just turn itself off. Prior to this it had never had any issues.
    I sent the ECM out for repair to two different places was advised that the processor was failing and it could not be repaired. I bought a replacement ECM off of EBAY and took the car to the dealership to have the unit flashed to my keys. The dealership advised that they were unable to flash my ECM to my car, and they told me that the ABS was under recall but they were unable to do anything about the ABS because they could not flash the ECM. I had the car towed home and ordered another ECM with the Immobilizer deleted. Now, the car runs and drives, except the SAFE mode light is on and the ABS light and alarm wont turn off, neither of which had never been issue. I ran another scan with the new ECM and can see that ABS unit now it is not coded, and there are 4 fault codes.
    I have a scan from the day before we took it to the dealership and the ABS module codes are present, and there were no fault codes. So I tried to recode the ABS with the original long code and I keep getting "error code 31: Request out of Range"
    The ABS long code I have is 113B400D492900FF880E02E5921C00413000
    Also there appears to be three VIN's associated with the vehicle:
    The original VIN ...3VWKZ71K39M275313 --The one that DMV uses
    the VIN that was associated with the second ECM - this was entered by the dealership when they tried to flash to the immobilizer
    The VIN that is associated with the current ECM that is installed in the car with the immobilizer delete VIN# 3VWRZ71K59M056478 --- the one that shows up on the VCDS scans
    Here is a current full scan:
    Saturday,30,May,2020,23:34:37:12262
    VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
    VIN: 3VWRZ71K59M056478   License Plate:
    Mileage: 295410km-183559mi   Repair Order: 5/30/20
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWRZ71K59M056478   Mileage: 295410km-183559miles
    Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
       Part No SW: 07K 906 055 N    HW: 07K 906 055 M
       Component: 2,5l Stg 1      G   9970
       Revision: G6H02---    Serial number: VWX7Z0H824O0OX
       Coding: 0000071
       Shop #: WSC 66565 257 00032
       VCID: 392F2880855B6CA3545-806C
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       VCID: 74B1D9B4EEB9D1CB473-8020
                        Fault Status: 01100101
                        Reset counter: 220
                        Mileage: 295417 km
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 279
                        Count: 51456
                        Reset counter: 220
                        Mileage: 295417 km
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 270
                        Count: 51456
                        Reset counter: 220
                        Mileage: 295417 km
                        Count: 7
                        Count: 2
                        Count: 12800
                        Count: 195
                        Count: 51200
                        Reset counter: 220
                        Mileage: 295417 km
                        Count: 3
                        Count: 2
                        Count: 12800
                        Count: 291
                        Count: 51456
       Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 7CA1F194CAE9998B0F3-8028
       Revision: 00H54000    Serial number: 00000001046090
       Coding: 148D8F2340041500070000001C000000000873075C000120000000000000
       VCID: 323D1FAC582D9FFB95F-8066
       Component: Wischer 010908 021  0501
       Coding: 00038805
       Shop #: WSC 00066
       Component: 78 AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6M06KS4E
       Coding: 0014136
       VCID: 6C81C1D4BA89090B9F3-8038
       Subsystem 2 - Serial number: 6332MSME38747632B
       Subsystem 3 - Serial number: 6342MSME3E106419A
       Subsystem 4 - Serial number: 6351HSME174A05093
       Subsystem 5 - Serial number: 6361HSME174963468
       Subsystem 6 - Serial number: 63727SME1734424D+
       Subsystem 7 - Serial number: 63827SME17455A654
       Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
       Coding: 0000022
       VCID: 73B3DAA8E7B7D6F35E9-8026
       Part No SW: 1K0 920 954 S    HW: 1K0 920 954 S
       Component: KOMBIINSTRUMENT 3HL 1222
       Revision: V0003000    Serial number: VWX7Z0H624T0M9
       Coding: 0007203
       VCID: 3C2131948A69598B4F3-8068
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 080708F1001388
       Coding: E9807F070002022002
       VCID: 353724B0A94388C3B0D-8060
       Component: IMMO            3HL 1222
    01176 - Key
                        Mileage: 295399 km
                        Time: 00:25:06
       Revision: 72009005    Serial number: 00000010988813
       Coding: 0001205
       VCID: 6FBBD6D88B9FF213BA1-803A
                        Reset counter: 220
                        Mileage: 295399 km
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A0D07CC70FDD73B2DF-807E
                        Fault Status: 11100101
                        Mileage: 295399 km
                        Time: 00:25:06
                        Battery Volts: 12.2 V
                            DD
                        Temperature: 30.0C
                        Count: 3
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Coding: 139007885283281B0904058FB0880F0488DCA0
       VCID: 04518974B219E14B773-8050
                007 - Short to Ground
                        Fault Status: 01100111
                        Fault Frequency: 13
                        Reset counter: 217
       Revision: 72009005    Serial number: 00000785388819
       Coding: 0001204
       VCID: 70B9D5A496A1EDEBA3B-8024
    Address 56: Radio        Labels: 1K0-035-161.lbl
       Part No SW: 1K0 035 161 D    HW: 1K0 035 161 D
       Component: Radio DE2       018 0021
       Revision: 00018000    Serial number: VWZ4Z7H6376190
       Coding: 0040401
       VCID: 2019E5E406C11D6B73B-8074
       Revision: 12006001    Serial number: 00000003425340
       Coding: 0001168
       VCID: 76B5E3BCF4C5C3DB797-8022
    00934 - Electric Window Motor; Rear Left (V26)
                        Reset counter: 220
                        Mileage: 295399 km
       Coding: 0100101
       Revision: 12006001    Serial number: 00000003406364
       Coding: 0001168
       VCID: 77ABEEB8F3CFBAD3621-8022
                        Fault Status: 01111000
                        Reset counter: 220
                        Mileage: 295399 km
                        Fault Status: 01111100
                        Reset counter: 220
    End----------(Elapsed Time: 01:25, VBatt start/end: 12.3V/12.3V)-----------
    Any advise on how to fix this would be great.
    Welcome to the VCDS forum OP!
    You should of seen me and still can.
    Current Ecu is unacceptable too with FOD tuning not just immobilizer removed.
    Send me old alleged bad controller, replacements, cluster and keys.
    I can undo what everyone did with credentials submitted.
    I could observe for donation + freight.
    Keep in mind units I sell include data transfer.
    Immobilizer removal is also possible with alignment of proper VIN data in cluster so ABS marrying is permitted for proper power class.
    Can you post a picture of data plate of VIN number and conformity certificate in jam?
    Please post scan of OBD 2 data all modes and advanced ID of ECU and cluster/immobilizer.
    I can do what often dealer's or others can not.
    Here is a great success recently by same offering.
    https://forums.ross-tech.com/showthr...ge-replacement
    JPPSG!
  3. Likes Uwe, Dana liked this post
    This car almost certain has a mis-match between the VIN in the Cluster/Immo and the ECU right now. This is likely to make an MK60EC1 ABS module cranky and miserable and probably needs to be corrected.
  5. Likes Jack@European_Parts, Dana, iichel liked this post
  6. #4
    The fact it does this as you aforementioned, is it your or anyone's professional opinion & that it's a violation of NHTSA safety certificate conformity, you know, used unilaterally as an EPA/CARB conformity affirmation on ORVR or is it an unjust enrichment scheme by altering a safety device and vicariously an AECD?
    Model Jetta
    JEM
    Date of production 30.09.2008
    Model year 2009
    Sales type 1K27S3
    Engine Code CBUA
    Transmission Code KGL
    Model Jetta Variant
    JEV
    Date of production 06.09.2008
    Model year 2009
    Sales type 1K57S1
    Engine Code CBUA
    Transmission Code KPF
    Both cars are an SULEV
    Emission standard 0GT Emission standard SULEV
    Pardon me, however, if the vicarious non expiring & unlimited mileage safety recall is blocking an AECD proper safety or smog unilateral certified function, wouldn't this make VAG culpable?
    May 2020
    You have no idea what an utter disaster this whole experience has been. Everything I do that should work, only digs a deeper hole. I loved my car now it sits in my driveway.
    Here is most of what was requested. I couldn't figure out how to actually run the OBD2 scan. It just says "running" but nothing happens.
    Also, how do I insert pictures?
    Engine ID
    Saturday,30,May,2020,23:36:28:12262
    Mileage: 295410km-183559mi   Repair Order: 5/30/20 engine id
                    Address 01: Engine
    Control Module Part Number: 07K 906 055 N
      Component and/or Version: 2,5l Stg 1      G   9970
               Software Coding: 0000071
                Work Shop Code: WSC 66565
    Advanced Identification
         Identification: BPG-864
         Revision: G6H02---
         Date: 03.09.08
         Test stand number: 7825
         Manufacturer number: 0054
    Flash Status
         Programming Attempts: 3
         Successful Attempts: 2
         Programming Status: 00000000
         Required Conditions: 00000000
         Flash Tool Code: 00032 257 66565
         Flash Date: 00.00.00
    Software
         P0101
         M10M30
    Misc.
         Hardware number: 07K 906 055 M
    Car Info
         Chassis Number: 3VWRZ71K59M056478
         Engine code: CBU
    VCDS Info:
           Readiness: 06A-906-032-BGP.crd
    Control Module Part Number: 1K0 920 954 S
      Component and/or Version: IMMO            3HL 1222
               Software Coding:
                Work Shop Code: WSC 00000
         Identification: 3HL-004
         Revision: V0003000
         Date: 28.08.08
         Test stand number: 9491
         Manufacturer number: 0853
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Required Conditions: 00000001
         Flash Tool Code: 00000 000 00000
         Flash Date: --.--.--
    Software
         DKBI339
         Y012
         Z0022
    Misc.
         Hardware number: 1K0 920 954 S
         Lot Number: 000
         Type Lock: 0000
    Car Info
         Chassis Number: 3VWRZ71K09M027521
    VCDS Info:
               Software Coding:
         Revision: V0003000
         Date: 28.08.08
    Flash Status
    Software
         DKBI339
         Y012
         Z0022
    Misc.
         Lot Number: 000
         Type Lock: 0000
    Car Info
    VCDS Info:
    Immobilizer ID
    Saturday,30,May,2020,23:38:02:12262
    Mileage: 295410km-183559mi   Repair Order: 5/30/20 immo id
               Software Coding:
         Revision: V0003000
         Date: 28.08.08
    Flash Status
    Software
         DKBI339
         Y012
         Z0022
    Misc.
         Lot Number: 000
         Type Lock: 0000
    Car Info
    VCDS Info:
  8. Likes Dana liked this post
  9. #6
    Serious FOD.........
    As aforementioned let me know if you would like to partake.
    PM me email address and fill out contact form if interested to triangulate your identity & to start a paper trail of written record.
    Do not call me........
    https://europeanpartsemporium.com/contact/
  10. #7
    Quote Originally Posted by 2009Sportwagen View Post
    Please see: How to Post Pictures.
  11. Likes Dana, Jack@European_Parts liked this post
  12. #8
    May 2020
    Here are the pictures:
  13. Likes Jack@European_Parts, Dana liked this post
  14. #9
    May 2020
    DM sent to Jack.
    Thank you.
  15. #10
    Indeed.....
    Responded with PASSWORD and go here to further be authenticated.
  16. Likes Dana liked this post
