Results 1 to 10 of 10
Thread: Transmission Error Codes Audi Q5 2012
    Feb 2020
    Costa Rica
    For a few weeks now I am getting intermittent an error message when starting up the car, a 2012 Audi Q5. It says on the Dashboard
    "Gearbox malfunction - You can continue driving"
    This goes away after a few seconds and won't come back while the car is turned on. A few days ago I went down a gravel road and the message came on and went away several times, right after this during the same trip back on a normal road the message did not come back all day.
    Any ideas ?
    Here is the scan from the car
    Friday,29,May,2020,16:11:46:50509
    VCDS Version: 20.4.1.0 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAUZZZ8R1CA000640   License Plate:
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2E 36 42 46 47 52 53 55
              56 62 6D 72 77
    VIN: WAUZZZ8R1CA000640   Mileage: 97430km-60540miles
    Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8R0 907 115 D    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0005
       Revision: E1H19---
       Coding: 01210010240F0060
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_ECM20TFS8R0907115D A01005
       ROD: EV_ECM20AVS.rod
       VCID: 3522048094843B2EE8-8060
       Part No SW: 8R0 927 156 Q    HW: 0B5 927 156 F
       Component: 0B5 20TFSIRdW H10 0009
       Revision: --H10---    Serial number: 0000001537
       Coding: 000001
       Shop #: WSC 06335 000 00000
       ROD: EV_TCMDL501.rod
       VCID: 49DA7870E87C4FCE9C-801C
    8030 - Cooling Oil Valve
              P179D 00 [104] - Electrical Malfunction
                        Reset counter: 40
                        Mileage: 95166 km
                        Date: 2020.03.24
                        Time: 09:47:52
                        Engine speed: 973 /min
                        Transmission input speed: 973 /min
                        Transmission output speed: 0 /min
                        Engine torque: 0 Nm
                        Transmission fluid temperature: 80 °C
                        Accelerator position: 0.0 %
                        Clutch status: Beide Kupplungen offen
    10047 - Hydraulic Pressure Sensor 1 (G193)
              P1775 00 [096] - Adaptation Limit Reached
                        Reset counter: 38
                        Mileage: 97083 km
                        Date: 2020.05.24
                        Time: 12:35:31
                        Engine speed: 1629 /min
                        Transmission input speed: 1629 /min
                        Transmission output speed: 466 /min
                        Engine torque: 28 Nm
                        Transmission fluid temperature: 86 °C
                        Accelerator position: 6.0 %
                        Clutch status: Kupplung 2 kann Moment übertragen
    10048 - Hydraulic Pressure Sensor 2 (G194)
              P1765 00 [109] - Adaptation Limit Reached
                        Fault Frequency: 31
                        Reset counter: 40
                        Mileage: 95165 km
                        Date: 2020.03.24
                        Time: 08:50:04
                        Engine speed: 750 /min
                        Transmission input speed: 750 /min
                        Engine torque: 20 Nm
                        Transmission fluid temperature: 103 °C
                        Clutch status: Kupplung 1 kann Moment übertragen
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
       Component: ESP8 quattro  H06 0110
       Coding: 025548
       VCID: 45C27440CC64ABAE78-8010
       Part No SW: 8K0 907 064 CT    HW: 8K0 907 064 CT
       Component: BCM2 2.0      H05 0435
       Coding: 010500
       VCID: 0444A94487DE52A62F-8050
       Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0511000012888008
       Serial number: 2311000042906011
       Part No SW: 8T1 820 043 AP    HW: 8T1 820 043 AP
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C0000000    Serial number: 01190320110978
       Coding: 64012000
       VCID: 7F4E26A8EE38317E72-802A
                        Fault Status: 00101101
                        Reset counter: 153
                        Mileage: 95153 km
                        Date: 2020.03.23
                        Time: 18:12:18
                        Reset counter: 153
                        Mileage: 95153 km
                        Date: 2020.03.23
                        Time: 18:12:18
                        Temperature: 21.0°C
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H30 0392
       Revision: 09030001    Serial number: 00000000832680
       Coding: 2600D0914074AF010001000000001D0D0F1C470802010161000000
       VCID: 3A3817BCB59AD45605-806E
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 110225  H11 0050
       Serial number: 90243014110221132222
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 11329209
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001103111257
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    01800 - Light Switch (E1)
                        Reset counter: 163
                        Mileage: 95144 km
                        Date: 2020.03.20
                        Time: 09:17:00
    03280 - Switch Position of Light-Switch Knob
                        Reset counter: 163
                        Mileage: 95144 km
                        Date: 2020.03.20
                        Time: 09:17:00
                        Reset counter: 153
                        Mileage: 95153 km
                        Date: 2020.03.23
                        Time: 18:12:00
    02258 - Door Opener Transmitter
                        Reset counter: 153
                        Mileage: 95153 km
                        Date: 2020.03.23
                        Time: 18:12:00
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0080
       Revision: 11001001    Serial number: 12501106902156
       Coding: 100105
       VCID: 78BCCDB4CB16064633-802C
    02069 - Front Parking Aid Sensors
                        Fault Status: 00101011
                        Reset counter: 153
                        Mileage: 95153 km
                        Date: 2020.03.23
                        Time: 18:12:32
                        Temperature: 21.0°C
    01625 - Front Parking Aid Warning Chime (H22)
                        Fault Status: 00101001
                        Reset counter: 155
                        Mileage: 95144 km
                        Date: 2020.03.20
                        Time: 09:39:13
                        Temperature: 30.0°C
                        Fault Status: 00100110
                        Reset counter: 177
                        Mileage: 95141 km
                        Date: 2020.03.19
                        Time: 12:07:56
                        Temperature: 33.0°C
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003JPD08MM0Q
       Coding: 30463331313030303030554A304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48DC7D74F376B6C683-801C
       Serial number: 6334MSME5C546277L
       Serial number: 6344MSME5D322C02D
       Serial number: 6352QSME4E1D2240H
       Serial number: 6362QSME411D3D52K
       Serial number: 63732SME63043162O
       Serial number: 63832SME3D095074+
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KCF001UL
       Coding: 000033
       VCID: 3D321CA0A4B4E36E20-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 900 M    HW: 8R0 920 900 M
       Component: KOMBIINSTR.   H12 0258
       Revision: 00000000    Serial number: EJR33773C
       Coding: 0317220002000008010001
       Shop #: WSC 06335 123 12345
       VCID: 3B3612B8BAA0ED5E1E-806E
       Part No SW: 8T0 907 468 AC    HW: 8T0 907 468 J
       Component: GW-BEM 6CAN   H06 0117
       Revision: HB800053    Serial number: 5300H11221822D
       Coding: 00C303
       VCID: 0248AF5C9DCA5C961D-8056
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650747217
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Revision: AA001002
       Coding: 02012064747464545425363E
       VCID: 33263A9892F0251EC6-8066
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 393A08B0B09CDF4E0C-806C
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0075
       Revision: AA000000    Serial number: 00001002353664
       Coding: 00581300000000000000
       VCID: 42C86F5CDD4A9C965D-8016
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000012324122
       Coding: 011D02205E00440004
       VCID: 4AD8477CE57A44D695-801E
       Revision: 00002001    Serial number: 0144947150
       Coding: 017E062220B974948530053280000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000374174
       Subsystem 2 - Part No: 8K0 951 177
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Subsystem 5 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F2E36E87ED801FEA2-807A
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000005468253
       VCID: 49DA7870E07C4FCE9C-801C
       Revision: 00000003    Serial number: 10000000754004
       VCID: 3424398497FE2226DF-8060
       Part No: 8K0 907 357 D
       Coding: 0000006
       VCID: 3620038C41823036E1-8062
       Part No SW: 8T1 035 195 AC    HW: 8T1 035 195 AC
       Component: Symphony3 US  H07 0351
       Revision: 00000010    Serial number: AUZ5Z4K1312115
       Coding: 040200820105850003DB070800
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
                        Fault Frequency: 15
                        Reset counter: 181
                        Mileage: 95144 km
                        Date: 2020.03.20
                        Time: 09:58:39
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000114070859
       Coding: 010C02204000240004
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Component: J605  Master  H51 0330
       Revision: --------    Serial number: 8R0827851B
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Component: J756  Slave  H51 0330
       Serial number: 8R0827852B
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000114070788
       Part No SW: 8T0 862 335 E    HW: 8T0 862 335 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005276443
       Coding: 0010390
       VCID: 3C3411A47FAEEA6617-8068
    End----------(Elapsed Time: 02:09, VBatt start/end: 12.1V/12.2V)-----------
    Feb 2020
    New Zealand
    There is a TSB on the oil control valve that allows oil to flow through the cooler (on the Q7, at least). It requires a new valve and loom extension.
    Feb 2020
    Costa Rica
    Thank you
    TSB ? - Technical Service Bulletin ?
    Feb 2020
    New Zealand
    yep. Not sure if is applicable to the Q5 but have done several Q7s with the same trans
    Feb 2020
    Costa Rica
    Thank you very much , but I am lost. Need more guidance please.
    Feb 2019
    Q5 Gearbox malfunction - cooling valve
    Hi As well as checking out the valve and connectors, I would suggest you first check the transmission oil level, followed by 16 way multipoint connnector cable plug and socket on the transmission for signs of corrosion/water contamination. if the level is OK and NO signs of water contamination/corrosion at the cable connector, I would follow the suggestions on the TSB.
    If there is light corrosion, clean the connectors and retry, if it's heavy with signs of radiator coolant, clean as best you can and follow the full transmission service suggestions below. If this is the first occasion of alarm, even though there may be light corrosion, it's unlikely that the transmission oil will be severely contaminated, in which I would suggest carrying out a calibration of the transmission, with transmission temperature between 40 and 60C. If however, there is heavy corrosion at the plug and the problem returns after replacing the valve, then suggest you carry out a full transmission service, changing the oil and filters, followed by a further calibration.
    A quick and simple way of checking if the transmission oil is badly contaminated, is to remove the black plastic collar around the transmission ECU, where the multipoint connector screws into. To remove it, firstly remove the multipoint cable plug. There is a single screw locating the collar, remove the screw and turn the collar approx. 1/4 turn (Anti clockwise to what I can remember) and pull the collar out. If the oil is badly contaminated, there is likely to be a white sludge build up around the bottom of the collar. If you find this, carry out a full transmission service, making sure the pan is removed, washed out and both filters changed. Just changing the oil and filters, will NOT fully clean the sludge out of the transmission.
    Hope the above is of help and good luck
    Quote Originally Posted by Hexed666 View Post
    Any ideas ?
  7. Likes Rollux liked this post
    Feb 2020
    Costa Rica
    First, Thank you so much for your message and time invested
    Today I did a check on the connector, all is clean, dry and there is no corrosion. For this I had to jack up the car on one side. Then I went to a friendly place where they change oil and had them check the oil level in the gearbox. This also was fine. Yesterday night I erased all the codes and during my drive to the shop no warning message came on, however, when they checked the oil level, the guys there asked me to turn on the car and right there, the message came back. After this I went to another shop specialized in transmissions and the owner there had this own diagnostic computer hooked up to the car. The memory showed the same error / codes from the day before and when we went into the values of the oil cooling valve, voltage and temperature showed both fine.We could even see the temperature going up and down a little as the fan from the radiator kicks in. The temperature was around 85 celsius. The transmission guy is really good I think, he did 2 transmission for me before, not on Audi. He told me that this could be an intermittent error and I would have to come back wednesday morning to drive the car around with him looking at live data.. It was to late to do this.
    In your post you mentioned to check out the valve, how can I do this ? I understand this is inside the gear box ? Is this correct ? I have been browsing the web but couldn't find anything what I can understand. Is there a way to adjust this or measure the valve with the VCDS software ?
    Thank you again
  9. #8
    Feb 2019
    Hi and thanks for the update. No, this is an external valve which is usually on the RHS of the transmission. It is a black plastic valve ,which diverts water through the transmission oil cooler. You can identify it by the 3/8" water hoses and the 2 wire electrical connector. I don't want to sound patronizing, but the transmission oil level (specifically the mechatronics section of the transmission), is being checked on a level surface and with the engine running and level plug out ? - if in doubt check out on-you tube. Good news that there is no corrosion at the multipoint connector, but would double check 2 wire solenoid (cooling) valve. Also check the transmission wiring loom connectors for possible dry connection.
    Hope this helps
    Good luck
  10. #9
    Feb 2020
    Costa Rica
    Thanks again to everybody
    Here is today's update.
    This morning I went back to the transmission shop, they hooked up their computer again and we went for a long drive, uphill, downhill and so on, but there was NO CODE whats or ever. Yesterday night, after several Gearbox messages I hooked up the VCDS again and tried a few things. First, the moment starting up the car, the messages appeared, then I cleared all codes. Second, the next start up, there where no more codes on the dash but I did still a scan without having a message and the Scan revealed the hydraulic pressure error, but only in the software, not on the dash. Then put the car in gear and the gearbox message on the dashboard came right back together with the Cooling oil valve in the software. So, now it is clear that the Cooling Oil Valve is causing the dashboard message. At the shop today, the guys there are sure that the cooling oil valve is an error caused by the 0B5 DL501 Q5 Transmission Circuit Board. They think a weak or lose connection there is the cause and the board will fix this guaranteed. They checked live temperature, volts and god knows what else but all was fine. The valve indicated in the Thread above is external, probably an easy fix if it would be bad. Now how can i be sure ? The tranny shop is really good, they do only transmissions and on all fancy cars, I know them for years, they fixed cars for me before, warranty their work and so on. However, I don't trust them 100% !
    Now here is the kicker, yesterday after all that screwing around with the car, lights on and such, I thought I hook up the charger to the battery, to make sure the battery is fine, I had some bad experience before. I have a fancy smart charger for AGM batteries, the car has a Optima Red Top installed. Right away after the charger was connected, the display showed only 51% of charge, no problem there, I left the charger slow charging all night and the battery was good this morning. All morning, running errands, doing the diagnostics I had no error message ! Could it be that low battery voltage caused all this ?
  11. #10
    Can't be ruled out, but I doubt it.
