Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
6C 6D 72 A9 AC C0
VIN: Mileage:
05-Acc/Start Auth. -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
Address 01: Engine (J623-CVUC) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 589 C HW: 4G0 907 589 B
Component: 3.0BTD EDC17 H23 0008
Revision: 54H23---
Coding: 2A2A4032252603030000
Shop #: WSC 37635 003 1048576
ASAM Dataset: EV_ECM30BTD0118K5907589C 001010
ROD: EV_ECM30BTD0118K5907589C.rod
VCID: 41DEB525910D43631C5-8014
9880 - NOx Sensor 2 Bank 1; Heating Circuit
P22A7 00 [101] - Implausible Signal
Mileage: 54386 km
Date: 2020.05.23
Time: 17:20:50
Engine speed: 852.50 /min
Normed load value: 56.5 %
Vehicle speed: 1 km/h
Coolant temperature: 89 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.320 V
NOx sensor 2: NOx concentration: -100 ppm
Com r Lam Lin Rec Cat2 Ds: 0.2450
NOx sensor 2: feed voltage: 13760 mV
Target value of heating temperature of NOx sensor 2-Bits 0-7: 1
Com st N Ox Vld Cat2 Ds-Bits 0-7: 0
Exh st Lam Stat No Cat2 Ds-Bits 0-7: 1
Exh.gas temp.sen 4: 519.2 °C
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 AR HW: 0BK 927 156 AM
Component: 0BK 30RTDIRdW H19 1006
Revision: --H19---
Coding: 000001
VCID: 0D4659159DD5D70328D-8058
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 BA HW: 8R0 907 379 BA
Component: ESP8 quattro H09 0020
Coding: 355DCC01
Shop #: WSC 77879 028 461382
VCID: 00587021DA078A6B53B-8054
Fault Status: 00101101
Reset counter: 90
Mileage: 54110 km
Date: 2020.03.16
Time: 10:21:47
Hex Value: 0x0000
Hex Value: 0x0082
Hex Value: 0x001A
Hex Value: 0x0298
Hex Value: 0x0000
Part No SW: 8K0 907 064 GH HW: 8K0 907 064 FH
Component: BCM2 2.0 H11 0621
Coding: 01B54040000000000000
VCID: 7CA004D1B6EFEE8B0F3-8028
Subsystem 1 - Part No SW: 8K0 959 754 BM HW: 8K0 959 754 BM
Component: FBSAUDIB8 IDG H71 0083
Serial number: 3715000027263009
Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 3215000087853003
02811 - Control Module for Electronic Steering Column Lock (J764)
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:07:22
Reset counter: 104
Mileage: 54368 km
Date: 2020.05.23
Time: 12:38:32
Part No SW: 8K2 820 043 AQ HW: 8K2 820 043 AQ
Revision: D1000000 Serial number: 01130520150499
Coding: 3625028080
Shop #: WSC 06335 000 00000
VCID: 78A818C182D7C2AB6BB-802C
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00001072684901
Coding: 260000108034AFE0018140C300001D0D0F9DC70827090221000008004400010200020034000000
VCID: 7AAC02C9BCDBD0BB1DF-802E
Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 150416 H12 0050
Serial number: 90243015150407200811
Coding: 01DD13
Component: G397_RLFS H06 0004
Serial number: 20297023
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000003004151175
Subsystem 4 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H05 0012
Subsystem 6 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 8C580AA7000000000001
11 Faults Found:
02235 - Stationary Cornering Lamp (Left) (M51)
Fault Status: 00101011
Fault Frequency: 19
Reset counter: 107
Mileage: 54013 km
Date: 2020.03.14
Time: 18:31:16
01800 - Light Switch (E1)
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.18
Time: 17:42:20
03280 - Switch Position of Light-Switch Knob
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.18
Time: 17:56:16
Reset counter: 100
Mileage: 1048574 km
Reset counter: 100
Mileage: 1048574 km
Reset counter: 100
Mileage: 1048574 km
01229 - A/C Humidity Sensor (G260)
Reset counter: 100
Mileage: 1048574 km
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:50
Fault Status: 01101101
Reset counter: 67
Mileage: 54307 km
Date: 2020.05.22
Time: 13:52:06
02258 - Door Opener Transmitter
Reset counter: 63
Mileage: 54307 km
Date: 2020.05.22
Time: 13:52:10
Fault Status: 00101100
Reset counter: 104
Mileage: 54368 km
Date: 2020.05.23
Time: 12:38:06
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H48 0610
Serial number: 003JPDC38EW0
Coding: 30473531313030303030554A305238523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48C8A801B237722BDBB-801C
Serial number: 6334MSME5068731DG
Serial number: 6344MSME4E784826R
Serial number: 6352QSME51540A4EK
Serial number: 6362QSME5A54314EO
Serial number: 63732SME2E4B48425
Serial number: 63832SME58560A641
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862OE10001T
Coding: 000037
VCID: 48C8A801B2B7722BDBB-801C
Component: E221 - MFL H03 0004
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:47
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 T HW: 8R0 920 950 T
Component: KOMBIINSTR. H35 0567
Revision: 00200000 Serial number: 03F43G65G
Coding: 33A722000B012600010000
VCID: 47CAAB3DBFA97D53D21-8012
Reset counter: 104
Mileage: 54368 km
Date: 2020.05.23
Time: 12:38:07
Part No SW: 8R0 907 468 T HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0070
Revision: 1Y090032 Serial number: 3241Y154230AC2
Coding: 80CD07FF00
VCID: 50F880614AE7BAEB83B-8004
Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
Component: J367-BDMHella H07 8043
Serial number: 1073256603
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 15126005166021200410
Reset counter: 89
Mileage: 54013 km
Date: 2020.03.14
Time: 18:29:56
Bin. Bits: 10111
Voltage: 11.30 V
Count: 6
00384 - Optical Databus
Reset counter: 100
Mileage: 54124 km
Date: 2020.03.27
Time: 12:59:40
Bin. Bits: 10000
Voltage: 12.00 V
Count: 11
Bin. Bits: 00000
00456 - Control Module for Access and Start Control (J518)
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:46
Bin. Bits: 10000
Voltage: 12.10 V
Count: 7
Bin. Bits: 00000
Time: 1.90 s
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:46
Bin. Bits: 10000
Voltage: 12.10 V
Count: 7
Bin. Bits: 00000
Time: 1.90 s
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0077
Revision: AA000000 Serial number: 00000148201074
Coding: 01781300000000000000
VCID: 42DCBA29948B587B05F-8016
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:46
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000148983754
Coding: 011D02215E01440004
VCID: 4FFA831D57D9A5139A1-801A
02123 - Door Warning Light / Entry Light
Reset counter: 89
01705 - Selection Switch for Mirror-Adjust (E48)
Reset counter: 89
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:49
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 P HW: 8R0 909 144 B
Component: RCEPS H43 0510
Revision: 00001000 Serial number: 0027761902
Coding: 100000010001
ASAM Dataset: EV_RCEPSAU48X 008018
ROD: EV_RCEPSAU48X_008.rod
VCID: 45D6A13585256F4320D-8010
Revision: 00002001 Serial number: 0182353994
Coding: 013B0622A0B970948720053680040047
Subsystem 3 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 4 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
03128 - Switch 1 for Sunroof
Reset counter: 99
Mileage: 54196 km
Date: 2020.05.17
Time: 11:49:55
01514 - Regulator for Roof
Reset counter: 99
Mileage: 54196 km
Date: 2020.05.17
Time: 11:49:55
03156 - Sensor for Anti-Theft System (G578)
Reset counter: 99
Mileage: 54196 km
Date: 2020.05.17
Time: 11:49:55
03233 - Controls for Garage Door Opener (E284)
Reset counter: 67
Mileage: 54368 km
Date: 2020.05.23
Time: 11:40:05
Reset counter: 104
Mileage: 54368 km
Date: 2020.05.23
Time: 12:38:32
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813043839606
VCID: 2D06F9953D15B703C8D-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000149376373
VCID: 4EC49E1950D3AC1B917-801A
Reset counter: 104
Mileage: 54210 km
Date: 2020.05.19
Time: 13:09:48
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 N HW: 8K0 907 801 J
Component: EPB-4 H02 0005
Revision: -------- Serial number: 20000000626059
ROD: EV_ParkiBrake_AU48.rod
VCID: 3A2CC2C9FCDB10BB5DF-806E
Part No SW: 4G0 035 061 S HW: 4G0 035 061
Component: Radio U DAB H60 0154
Revision: AB001007 Serial number: 109EU0F8036106
Coding: 010103010000000001
Part No SW: 8R2 035 670 M HW: 8R2 035 670 J
Component: H-BNT-EU H50 1036
Revision: -------- Serial number: 517EX0FB001138
Coding: 1A0101060205A1EF45828B5E00000403040000000000000000
VCID: 3E24CED9E0733C9B617-806A
Subsystem 1 - Part No: 8R0 060 884 GS
Component: EUR 2020 3001
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130EQ0F3353903
Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B
Component: E0380 Bedient H02 0030
Serial number: 00000002237810
Component: CD-Database 6208
6 Faults Found:
Reset counter: 57
Mileage: 54174 km
Date: 2020.04.27
Time: 16:04:27
Text: DUA130,,D,0,0,6
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 100
Mileage: 54124 km
Date: 2020.03.27
Time: 12:57:58
Voltage: 12.00 V
Fault Frequency: 7
Reset counter: 68
Mileage: 54438 km
Date: 2020.05.31
Time: 19:46:35
Bin. Bits: 00000000 00000000
Bin. Bits: 00000000 00010000
02168 - Left Front Microphone (R140)
Reset counter: 99
Time Indication: 15
Voltage: 12.10 V
02169 - Front Right Microphone (R141)
Reset counter: 99
Time Indication: 15
Voltage: 12.10 V
03623 - Invalid Security/Release Code
Reset counter: 49
Mileage: 54013 km
Date: 2020.03.14
Time: 17:21:50
Hex Value: 0x0004
Hex Value: 0x0009
Count: 7
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000149986978
Coding: 010C02204001240004
VCID: 46D4A639B8A3645B297-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H07--- Serial number: 525PA8-J27A2M4
Coding: 1022010
VCID: 3430ECF1D23FE6CB873-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 D HW: 8R0 827 851 D
Component: J605 Master H56 0330
Revision: -------- Serial number: 8R0827851D
VCID: 3D26C9D5ED75278378D-8068
Subsystem 1 - Part No SW: 8R0 827 852 D HW: 8R0 827 852 D
Component: J756 Slave H56 0330
Serial number: 8R0827852D
Reset counter: 104
Mileage: 54368 km
Date: 2020.05.23
Time: 12:18:54
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000149986910
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8R0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0007
Serial number: 150428201311
VCID: 79AE1DC5B95DDBA3145-802C
Part No SW: 4H0 907 355 D HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0012
Revision: 00000000 Serial number: 151180717
ROD: EV_RDCMA00100.rod
VCID: 2D06F9953D95B703C8D-8078
Address C0: Act. for Ext. Noise (J943) Labels: 4G0-907-160.clb
Part No SW: 8R0 907 160 A HW: 4G0 907 160 B
Component: SAS-GEN 2 AGA H10 0008
Serial number: 150227200125
VCID: 323CEAE924ABE8FB95F-8066
End----(Elapsed Time: 02:23, VBatt start/end: 11.6V/11.8V. VIgn 11.9V)-----
