Results 1 to 4 of 4
Thread: Parking 6 sensor to 4 sensor coding advice
    May 2020
    Mongolia
    Hello guys, i am having 2 problems. First the new bumper has 4 parking sensor and old one had 6 sensor is there anyway i can do coding to change the new parkimg system work thus disable paralel parking function just normal ones. And second i cannot do my G85 calibration tried many times even on ODIS steering angle stays zero but on VCDS it shows my current steering angle please advice guys
    Jul 2014
    Tallinn, Estonia
    There are tools to cut the missing holes and the sensor mountings are normally available to buy.
    Post an autoscan.
    May 2020
    Mongolia
    here is an autoscan please advice on steering angle calibration not done, its got synchronisation failed error
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 1B 20 22 28 36 3B 3C
              42 44 46 47 52 53 55 56 5F 62 65 6C 6D 72 82 85 8B 8E 8F 90
              BA
    VIN: WUAZZZ4G9EN906203   Mileage: 101316km-62954miles
    1B-Active Steering -- Status: Malfunction 0010
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CRDB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 560     HW: 4H0 906 014
       Component: 4.0l V8TFSI / H62 0012
       Revision: NCH62---
       Coding: 122A00326546130A1000
       Shop #: WSC 34556 001 1048576
       ASAM Dataset: EV_ECM40TFS0114G0906560 001013
       ROD: EV_ECM40TFS0114G0906560.rod
       VCID: 6582AF4164DAE2AE91-8030
    Readiness: 1110 1101
       Part No SW: 4G0 927 158 BD    HW: 0BK 927 156 AM
       Component: 0BK 40TFSIRdW H18 1007
       Revision: --H18---
       Coding: 000001
       VCID: 71AACB11A0123E0EFD-8024
       Part No SW: 4G0 907 379 P    HW: 4G0 907 379 P
       Component: ESP PREMIUM   H09 0100
       Coding: 84BF990121FD9980CB00
       ASAM Dataset: EV_ESPPremiAU57X 004036
       VCID: 3E30202DA1CC917630-806A
    0859 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
              [DSASanityCheck_SteeringAngleCalculation]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:36:57
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 35
                        Uz: B3
    0732 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [SCL_QSP_Ist_Moment_Error]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:36:56
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 01
                        F-Type: 08
                        Uz: B3
       Part No SW: 4H0 907 064 FP    HW: 4H0 907 064 EP
       Component: BCM2 2.0      H36 0551
       Coding: 05A92F06000000000000
       VCID: 7CB4EA25FF5043665E-8028
       Part No SW: 4G0 820 043 AM    HW: 4G0 820 043 AM
       Component: KLIMA 4 ZONEN H14 0096
       Serial number: 27081400041298
       Coding: 680200B81D
       ASAM Dataset: EV_AirCondiComfoUDS 004003
       ROD: EV_AirCondiComfoUDS_004.rod
       VCID: 6A98DC7D8DC4CDD6BC-803E
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:43
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 15.5 ∞C
                        Temperature after evaporator: 15.46 ∞C
                        Engine speed: 0 /min
       Revision: 11012002    Serial number: 00000001924718
       Coding: 0907201009749FF2B98100C7A0001800CF9CC708AE080221800108546F01
       VCID: 6FAECD69BE2628FEEB-803A
       Component: WWS57X 140801  H37 0080
       Serial number:         140808054202
       Coding: 0045F7
       Serial number: 23116056
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BG    HW: 4G0 941 531 BG
       Component: E1 - LDS  H07 0044
       Serial number: 22 08 2014  00000288
       Subsystem 4 - Part No SW: 4G0 907 410     HW: 4H0 907 410
       Component: EHL2 V07.03  H30 0030
       Serial number: 0000002274537R1NV603
       Serial number: 00000013111500010000
       Coding: 100000
       Serial number: 00000013111500010210
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA108752000008577284
       Coding: 020300
       Serial number: 8C28C347000000000001
    Address 10: Park/Steer Assist (J791)       Labels:| 4H0-919-475-7X5.clb
       Part No SW: 4H0 919 475 AH    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0091
       Revision: --------    Serial number: 56231423700295
       Coding: B82B1B
       Shop #: WSC 34447 004 1048576
       ASAM Dataset: EV_EPHVA2CAU57X0000 002012
       ROD: EV_EPHVA2CAU57X0000.rod
       VCID: 78BCF635C3686F463A-802C
    8 Faults Found:
    1111828 - Front Left Parking Aid Sensor
              B10F7 14 [009] - Open or Short to Ground
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:36
    1112596 - Front Right Parking Aid Sensor
              B10FA 14 [009] - Open or Short to Ground
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:36
    1112084 - Front Left Center Parking Aid Sensor
              B10F8 14 [009] - Open or Short to Ground
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:36
    1112340 - Front Right Center Parking Aid Sensor
              B10F9 14 [009] - Open or Short to Ground
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:36
    1111572 - Side Front Left Parking Aid Sensor
              B10F6 14 [009] - Open or Short to Ground
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:39
    1112852 - Side Front Right Parking Aid Sensor
              B10FB 14 [009] - Open or Short to Ground
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:39
    13637413 - Databus
              [Bremsensteuerger‰t - ESP_01.ESP_Systemstatus - Fehlerspeicher auslesen]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:43
    13679386 - Databus
              [Steuerger‰t f¸r Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                        Reset counter: 229
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:28:38
       Part No SW: 4G0 907 561 A    HW: 4G0 907 561
       Component: ACC3          H19 0410
       Coding: 7E04010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002010
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 281CE67553483FC66A-807C
    105472 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_VDC_FAIL]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:42
                        Control Module temperature: 25 ∞C
                        Voltage terminal 15: 13.913 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
    138752 - Function Restriction due to Implausible Message(s)
              U1112 00 [009] - -
              [FAULT_CIS_ADS_SOLL_INIT]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:43
                        Voltage terminal 15: 13.904 V
    144896 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_US_FAIL]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:38
                        Control Module temperature: 27 ∞C
                        Voltage terminal 15: 13.883 V
    Address 14: Susp. Elect.        Labels: None
       Part No SW: 4G0 907 376     HW: 4G0 907 376 A
       Component: J250 DRC FahrwerH01 0040
       Revision: 00000000    Serial number: 00894015436900
       Coding: 0000000
       Shop #: WSC 27088 001 1048576
       VCID: 6B96D9794A3ED4DEC7-803E
    02646 - Plausibility of Level Control System
                        Fault Status: 11101000
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:51
       Revision: --------    Serial number: 003JG00JZ0JP
       Coding: 30323436313330303339554A304C34473053
       VCID: 3620380D89FC5936E8-8062
       Serial number: 3575HRB40512OKC2E0C%
       Serial number: 3585HRB40512MSOCA9N1
       Serial number: 3515JRB400Q52MR8AQ2V
       Serial number: 3525JRB401652N82AA6K
       Serial number: 3554VRB40084UPLECA21
       Serial number: 3564VRB40084UPLEPGQ2
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372NHS00084
       Coding: 0000FD
       VCID: 373E350986F6A03EF3-8062
       Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
       Serial number: 14 07 2014  E0039913
       Part No SW: 4G0 920 931 B    HW: 4G0 920 931 B
       Component: TBenRdwAccNv  H58 0622
       Revision: 29460237    Serial number: 658190814596008
       Coding: 138F110BAFD50008000400
       ASAM Dataset: EV_RBD4K 004048
       ROD: EV_RBD4K_AU57.rod
       VCID: 2502EF41245A22AE51-8070
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001539501
       Coding: 00ED074800
       VCID: 72A8C41DA514051604-8026
       Serial number: 9824134103
       Voltage stabilizer:
       Serial number: 14052100000000000255
       Part No SW: 8K0 907 144 M    HW: 8K0 907 144 M
       Component: DYNAMIKLENK.  H06 0730
       Coding: 010100
       VCID: 393A3331B0E2B64E05-806C
                        Fault Status: 00100101
                        Reset counter: 229
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:27:34
                        Count: 40
                        Count: 1
                        Hex Value: 0x05CA
                        Hex Value: 0x05CA
                        Hex Value: 0x138D
                        Hex Value: 0x8900
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:27:34
                        Count: 56
                        Count: 1
                        Hex Value: 0x0088
                        Hex Value: 0x891A
                        Hex Value: 0xFFFF
                        Hex Value: 0x0000
                        Reset counter: 229
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:27:34
                        Count: 47
                        Count: 52
                        Hex Value: 0xF234
                        Hex Value: 0x781A
                        Hex Value: 0x00F8
                        Hex Value: 0xC73F
       Revision: AA001002
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H17 0200
       Serial number: 002608140001022
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
    0121 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
              [Steuerger‰t f¸r aktive Lenkung Bitte Fehlerspeicher auslesen  ----------    --- DTC_CAN_SCU_ANGLE_DES]
                        Reset counter: 2
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:42
    0122 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
              [Steuerger‰t f¸r aktive Lenkung Bitte Fehlerspeicher auslesen  ----------    --- DTC_CAN_SCU_ADS_DES]
                        Reset counter: 2
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:42
    0377 - Function Restriction due to Faults in Other Modules
              U1113 00 [137] - -
              [ESP - Steuerger‰t nicht verf¸gbar DTC_FRAY_ESP_SYS_STATE]
                        Reset counter: 2
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:42
    0117 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Lenkradwinkelsensor Bitte Fehlerspeicher auslesen  DTC_CAN_LWI_CENTRAL_ERROR]
                        Reset counter: 42
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:27:34
       Part No SW: 4G0 919 158 N    HW: 4G0 919 158 N
       Component: KLIMA FOND    H08 0096
       Serial number: 27081400040217
       Coding: 20
       ASAM Dataset: EV_ClimaContrUnitRearUDS 004002
       VCID: 3A382C3DBDE4BD560C-806E
       Revision: AA000000    Serial number: 00000114663653
       VCID: 77BEF509C676603E33-8022
       Component: SARA 6D red   H03 0056
       Revision: --------    Serial number: EJ1BPA7E0157K5
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 373E35098EF6A03EF3-8062
       Part No SW: 4G0 907 566 K    HW: 4G0 907 566
       Component: J769  SWA MasterH05 0020
       Revision: 00H05000    Serial number: 6PZ 010 287-09
       Coding: 0000105
       VCID: 373E350946F6A03EF3-8062
       Subsystem 1 - Part No: 4G0 907 568 K
       Component: J770  SWA Slave H05 0020
       Subsystem 2 - Serial number: 6PZ 010 287-29
       Subsystem 3 - Serial number: 5F28.06.1400H05000AMS14766ˇ
       Subsystem 4 - Serial number: S14766ˇ
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0507
       Coding: 011F1E015E00628002080013
       VCID: 45C24FC1CC1AC2AE71-8010
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0024901731
       Coding: 011101010000
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       VCID: 332601199A8E4C1ECF-8066
    4205828 - Steering angle sensor
              B1168 54 [008] - Missing Calibration / Basic Setting
                        Reset counter: 229
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:27:34
                        Write only channel
    4208000 - Steering Angle Sensor
              B1168 F1 [008] - Synchronization Failed
                        Reset counter: 229
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:28:38
                        Write only channel
              [Lenkungsendanschl‰ge nicht angelernt]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:26:57
                        Write only channel
       Revision: 00002001    Serial number: 0344930782
       Coding: 013A0E20A0B97095833009840E0112470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000238065
       Subsystem 2 - Part No: 4G0 951 177
       Subsystem 3 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J245 PS20.008  H02 0007
       Serial number:     WOO3176199A
       Coding: 901F00
       Subsystem 4 - Part No SW: 4G0 947 135 L    HW: 4G0 947 135
       Serial number: 0000000AP00008651712
       Subsystem 5 - Part No SW: 4G9 959 591     HW: 8V3 959 591
       Component: J394 PS20.008  H02 0007
       Serial number:     WOO31761822
       Coding: 801F00
    01134 - Alarm Horn (H12)
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:45
       Revision: CJ007001    Serial number: 00000000133324
       Coding: 030000
       VCID: 1D72C7A1040AEA6E09-8048
       Part No SW: 4G8 959 792 H    HW: 4G8 959 792 F
       Component: TSG BF        H04 0507
       Coding: 011F1E015E00628002080002
       VCID: 44C452C5C720FBA666-8010
       Revision: --------    Serial number: 00000001174527
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D1217617CAA1AEE99-8078
       Serial number: 140827-0001-030
       Coding: 1122A6601002B300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 061 N    HW: 4G0 035 061
       Component: Radio U DAB   H60 0139
       Revision: AB001007    Serial number: 109H30E7961906
       Coding: 010103010000000001
       VCID: 281CE6755B483FC66A-807C
       Part No SW: 4G0 035 670 M    HW: 4G0 035 670 J
       Component: H-BNT-EU      H53 0814
       Revision: --------    Serial number: 190H30E7595453
       Coding: 070100010303EDEF7DB2CB3E00000003080001000000000000
       VCID: 2D12176174AA1AEE99-8078
       Subsystem 1 - Part No: 8R0 060 884 BT
       Component: EUR 2014  1903
       Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
       Component: DU8 C7 SV  H43 0021
       Serial number: AUZ8ZDED005CGU6
       Subsystem 3 - Part No SW: 4G1 919 612 Q    HW: 4G1 919 612 Q
       Serial number: 90349NHT000DV
       Component: CD-Database  5950
    01524 - Antenna for Telephone
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:54
                        Voltage: 13.80 V
       Part No SW: 4G8 959 795 H    HW: 4G8 959 795 F
       Coding: 010F1C004000628002080002
       VCID: 47DE45C9F616D0BE83-8012
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 B    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0820
       Serial number: 10000000010197
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2A181C7D4D440DD67C-807E
       Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
       Component: TopView       H07 0330
       Revision: 11001001    Serial number: 82330JF0171925
       Coding: 0203000101010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
       ROD: EV_CamerSysteTopViewAUDI.rod
       VCID: 2E10106D71AC61F6A0-807A
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 232400058
       Coding: 097205C010
       ROD: EV_HDSGAu571.rod
       VCID: 35223F0194FA522EE1-8060
    0114 - Load Space Cover
              B12EF 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:43
                        Voltage terminal 30: 13.94 V
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 K    HW: 4G0 919 604 K
       Component: HeadUpDisplay 006 0203
       Coding: C70000
       ASAM Dataset: EV_HUDContiC7 001023
       ROD: EV_HUDContiC7.rod
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H27 0038
       Coding: 6A060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2600E84D595C29B658-8072
       Part No SW: 4G0 907 541 A    HW: 4G0 907 541
       Component: ACC3          H19 0400
       Coding: 7E04010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002008
       ROD: EV_AdaptCruisContr2AU57X_002.rod
              U1113 00 [009] - -
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:42
                        Voltage terminal 15: 13.915 V
                        Velocity_vehicle_reference: -0.00 m/s
              U1112 00 [009] - -
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:43
                        Voltage terminal 15: 13.900 V
              U1113 00 [009] - -
              [FAULT_CIS_US_FAIL]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:38
                        Control Module temperature: 26 ∞C
                        Voltage terminal 15: 13.875 V
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H32 0041
       Serial number: 005000120608147
       Coding: 04C0BB1B1111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0028 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [ESP_ESP_01_Signal_Error]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:43
                        Voltage terminal 15: 13.9 V
                        Control Module temperature: 29.0 ∞C
    0165 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [QSP_Signal_Error]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:36
                        Outside air temperature: 16.0 ∞C
                        Voltage terminal 15: 13.8 V
                        Control Module temperature: 0.0 ∞C
    0173 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [APS_Signal_Error_Master]
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:29:38
                        Control Module temperature: 30.0 ∞C
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 312A0B1160927E0EBD-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
       VCID: 3228041D65944516C4-8066
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H07 0008
       Revision: 00001001    Serial number: 97812004095101
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X.rod
    1294 - Actuator 1 for Drivetrain Mounts
              C1131 07 [009] - Mechanical Failure
                        Reset counter: 189
                        Mileage: 101316 km
                        Date: 2020.05.30
                        Time: 12:25:45
    End----(Elapsed Time: 02:59, VBatt start/end: 14.0V/14.0V. VIgn 0.0V)------
    May 2020
    Mongolia
    Quote Originally Posted by siLc View Post
    Post an autoscan.
    Actually the front bumper and parking sensor with wiring harness all has changed. I do have previous parking sensors some of them can i change or add two side ones as you suggested do i need to chamge wiring also?
