Hi this is our first post so please bare with us if I do anything wrong, a customer has bought the caddy to us after fitting a replacement abs module to the van and not having the old coding from the old unit, it’s not something we’ve had much success with in the past so hoping somebody may be able to help us on here with the correct coding,
Thanks in advance
Thanks in advance
Thursday,28,May,2020,15:36:46:63026
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WV1ZZZ2KZEX007371 License Plate: RE63 WJL
Mileage: 261430km-162445mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZEX007371 Mileage: 261430km-162445miles
01-Engine -- Status: Sporadic communication error 1000
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 1010
25-Immobilizer -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 TF HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000
Coding: 00114010030500080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TF 003002
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 7DB2096FEC075CA7CC-8028
Part No SW: 1K0 907 379 BK HW: 1K0 907 379 BK
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Shop #: WSC 35110 377 08192
VCID: 7CB4046BFF1D55AFFB-8028
Reset counter: 75
Date: 2014.10.19
Time: 04:18:07
Count: 3
Count: 20992
Count: 195
Count: 49664
Part No SW: 5K0 937 085 AA HW: 5K0 937 085 AA
Component: BCM PQ35 B+ 122 0173
Revision: BB122001
Coding: 411A583A8025182A088000829000006403017288524F0160648000000040
VCID: 72A82A53AD5913DFA1-8026
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 13051 26 0512
Coding: 009795
6 Faults Found:
00890 - Switch for Heated Rear Window (E230)
Reset counter: 73
Voltage: 14.30 V
Reset counter: 115
Mileage: 261434 km
Date: 2014.10.16
Time: 23:35:27
Voltage: 14.15 V
Reset counter: 113
Mileage: 261421 km
Date: 2014.06.10
Time: 00:01:57
Voltage: 9.65 V
Fault Frequency: 57
Reset counter: 113
Voltage: 12.15 V
Fault Status: 00101010
Reset counter: 113
Mileage: 261421 km
Date: 2014.08.25
Time: 02:00:36
Voltage: 11.70 V
Reset counter: 113
Mileage: 261421 km
Date: 2014.08.25
Time: 02:00:38
Voltage: 11.70 V
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02A H07 0013
Revision: -------- Serial number: 003HL00HV25A
Coding: 000000000000000000000000000000003241
VCID: 3522D14F94B744E744-8060
12656896 - Databus
[Bremse8 Time Out Error]
Reset counter: 113
Mileage: 261421 km
Date: 2020.01.18
Time: 00:54:55
12674816 - Databus
[VIN Time Out Error]
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:55:52
Part No SW: 5K0 953 521 BH HW: 5K0 953 569 C
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130523101086
Coding: 1080060000
ROD: EV_SMLSNGVOLWS.rod
VCID: 73A62F57DA431AD7AA-8026
117012 - Databus
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:52:47
Part No SW: 2K0 920 966 A HW: 2K0 920 966 A
Component: KOMBI H04 0809
Coding: 480001
Shop #: WSC 09550 758 180955
VCID: 2E10FE2371E1773F05-807A
6 Faults Found:
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Motor: keine Kommunikation]
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:55:52
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Bremse: keine Kommunikation]
Reset counter: 113
Mileage: 261421 km
Date: 2020.01.18
Time: 00:54:54
12664832 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für BCM / Bordnetz / el. ZE: keine Kommunikation]
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:52:52
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Airbag: keine Kommunikation]
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:55:52
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Lenksäulenelektronik: keine Kommunikation]
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:55:52
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Steuergerät für Komfortsysteme: keine Kommunikation]
Fault Frequency: 7
Reset counter: 113
Mileage: 261419 km
Date: 2019.12.02
Time: 14:52:52
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 280513F1000478
Coding: 357404
VCID: 79BA1D7FF02F6087E0-802C
8 Faults Found:
Fault Status: 00110100
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:55:53
Reset counter: 113
Mileage: 261421 km
Date: 2014.06.10
Time: 00:01:56
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:55:53
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:55:53
Reset counter: 73
Mileage: 261419 km
Date: 2014.04.24
Time: 14:52:59
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:52:60
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:52:60
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:55:53
Component: IMMO H04 0809
VCID: 6A9832338D89DB1F19-803E
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 03 0174
Coding: 0000000
VCID: 76A0164301310FFF8D-8022
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
VCID: 393ADD7F70AFA087A0-806C
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:55:53
Voltage: 12.25 V
DU
Temperature: 14.0°C
RPM: 1498 /min
Reset counter: 113
Mileage: 261419 km
Date: 2014.04.24
Time: 14:55:53
Voltage: 12.25 V
DU
Temperature: 14.0°C
RPM: 1498 /min
Reset counter: 113
Mileage: 261421 km
Date: 2014.06.10
Time: 00:54:55
Voltage: 11.50 V
DU
Temperature: 10.0°C
RPM: 992 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
000 - - - MIL ON
Fault Status: 11100000
Battery Volts: 10.7 V
PD
Temperature: 26.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75A2114F1C3704E784-8020
Part No SW: 5K0 035 156 A HW: 5K0 035 156 A
Component: Radio H52 0107
Revision: R0000000 Serial number: VWZAZ1N6261062
Coding: 0500020001
VCID: 2502010F2C173467F4-8070
00625 - Vehicle Speed Signal
Reset counter: 115
Mileage: 261421 km
Date: 2014.06.10
Time: 00:54:52
00849 - S-contact at Ignition/Starter Switch (D)
Reset counter: 115
Mileage: 261419 km
Date: 2014.04.24
Time: 14:53:16
00856 - Radio Antenna
Fault Status: 00110111
Reset counter: 115
Mileage: 261430 km
Date: 2014.10.16
Time: 23:27:52
Fault Status: 00111011
Reset counter: 115
Mileage: 261430 km
Date: 2014.10.16
Time: 23:28:03
End----(Elapsed Time: 01:01, VBatt start/end: 12.2V/12.0V. VIgn 12.0V)-----
