Results 1 to 6 of 6
Thread: 1999 Jetta : NO CRANK NO START
    Nov 2019
    Good afternoon,
    I have a bit of a strange pickle.
    1999 VW Jetta 2.0 4 cylinder that is a no-crank no-start case.
    I have replaced the starter.
    I have replaced the ignition cylinder.
    The battery is fully charged.
    The key fob will open and lock all doors.
    All electrical items appear to be working properly.
    Could the immobilizer be the root of my issue even thought the key FOB still works to lock/unlock the doors?
    Any other idea's would be a great starting point.
    The car was functioning properly until I drove it to work one morning and it would not start when it was time to go home. Had to have it towed.
    Thanks,
    Dave
  2. Likes Jack@European_Parts liked this post
  3. #2
    Dave WTF! are you doing?
    Scan? 1999 MK3 or 1999 MK4?
    No it's not Immobilizer related....could be, ground strap, positive feed to or starter, alarm module, wiring, relay, or fuse and even new ignition switch if not genuine?
    Did you observe the WD yet and see if relay for starter and power are making way through the track when switch is turned to crank?
    I agree with Jack. 1999 US models don't have an immobilizer, but even if it did, the immo wouldn't keep it from cranking.
    However, the Central Locking or Central Convenience module (depending on Mk.3 or Mk.4 and equipment) does have an anti-theft function that can prevent the car from cranking.
    Post an Auto-Scan please so people can see what this is and what it's made of.
  5. Likes Jack@European_Parts liked this post
  6. #4
    Regardless terminal 50 anyone, anyone.....anyone, red wire black stripe anyone?
    How about X?
    What happens ignition key off, blower motor on high and pulling back on bright lights?
    Nov 2019
    Here is the auto scan. Sorry (I just got access to this car-its a buddy's).
    It appears to be the older body style 1999 Jetta (mk3)
    Saturday,30,May,2020,11:59:35:54382
    Dealer/Shop Name: Dave and Joey's Bone-Yard
    Chassis Type: 1G - VW Golf/Jetta CHN II (1989 > 2012)
    Scan: 01 02 03 09 15 17 19 25 46
       Mileage: 275580km-171237miles
    Address 01: Engine        Labels: 06A-906-018-AEG.lbl
       Part No: 06A 906 018 JM
       Component: 2.0l R4/2V  MOTR AT V01
       Coding: 00033
       Shop #: WSC 00066
       VCID: 76B5E1A061DA7B5B797-4B1E
    6 Faults Found:
                P0300 - 35-10 -  - Intermittent
    16687 - Cylinder 3
                P0303 - 35-10 - Misfire Detected - Intermittent
    16686 - Cylinder 2
                P0302 - 35-10 - Misfire Detected - Intermittent
    16687 - Cylinder 3
    16686 - Cylinder 2
    Address 02: Auto Trans        Labels: 01M-927-733.lbl
       Part No: 01M 927 733 HM
       Component: AG4 Getriebe 01M    4544
       Coding: 00000
       VCID: 025D8D703D1257FB45F-0962
    00293 - Multi-function Switch (F125)
                25-00 - Unknown Switch Condition
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 P
       Component: ABS     20 IE CAN  0001
       Coding: 03504
       Shop #: WSC 00066
       VCID: 3E253980096AF31B617-4AE0
                16-00 - Signal Outside Specifications
       Part No: 6Q0 909 605 A
       Component: Z9 AIRBAG VW5       0003
       Coding: 23097
       Shop #: WSC 00066
       VCID: 353726AC3C5C3043B0D-4B3C
    00532 - Supply Voltage B+
    Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
       Part No: 1J0 920 900 K
       Component: A4-KOMBIINSTR. VDO V54
       Coding: 07242
       Shop #: WSC 00066
       VCID: 2A0D05D0E5E26FBB2DF-5160
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0W0699364
       IMMO-IDENTNR: VWZ7Z0W0699364
       Part No: 6N0 909 901
       Coding: 00007
       Shop #: WSC 00066
       VCID: 70B9D7B803BE556BA3B-5160
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.5V/12.5V)-----------
    No it's a MK4 with 1J0 and 06A controllers not MK3!
    Now post Terminal 50 WD for ignition switch to starter tracks and lets trace it okay?
    VIN number please?
    I will almost bet this is related to your issue "Davethewave washer"
    What does the park neutral indicator say on dash and did you try to select neutral to start the car too?
    Is shift cable in proper order or valve body to controls that initiate F125?
    Have you tried selecting neutral and clearing codes in transmission with VCDS & to see if blocks reflect a gear and if will than try to crank?
    Did you check the F125 yet?
    Never negate or dismiss scans and JPPSG........!
  9. Likes Uwe, PetrolDave liked this post
