2010 VW 2.0T Passat DSG Fault code malfunction 0010 and U0101 No com with TCM
Fauxbm
C?ID=405636
What started out as trying to find the Cigarette lighter fuse turned into my car been complete immobilized. Who would have thought!?!?
After checking a couple of fuses on the top two rows in the Driver side fuse box, I tried to start my car and got the "Error: Parking Brake Owners Manual" Also the "P" is flashing, The car will not start and I am not able to move the lever out of Park.
Luckily, I was parked in the garage when this all happened otherwise I would have been in a pickle, which I still am.
The only two codes that were "real" before pulling a couple of fuses was P2181 Cooling System (Thermostat not working correctly) and P0299 Boost Pressure regulation (known wastegate issue).
I have,
1) disconnected the battery for 24 hours
2) reset the codes
3) reset the transmission following the process of holding the peddle down for 20 seconds.
Based on list of codes below, it appears the system is confused. How do I reset it?
Any help would be appreciated.
Friday,29,May,2020,18:19:43:48585
VIN: WVWXK7AN4AE166182   License Plate:
Chassis Type: AN-VW46 (3C0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 53 56 62 65
          6D 72 77
VIN: WVWXK7AN4AE166182   Mileage: 215170km-133700miles
02-Auto Trans -- Status: Cannot be reached 1100
25-Immobilizer -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
65-Tire Pressure -- Status: Sporadic communication error 1000
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 906 026 DA    HW: 06J 906 026 DA
   Component: MED17.5 TFSI 2,0    6987
   Revision: AAH17---    Serial number: VWZCZ000000000
   Coding: 0404010A1C070160
   Shop #: WSC 05314 000 00000
   VCID: 6C81C1D61A802BFB9F3-8038
049409 - No Communication with Transmission Control Module
               U0101 - 000 -
                    Mileage: 215173 km
                    Date: 2014.10.20
                    Time: 21:16:11
                    Temperature: 21.0°C
                    Temperature: 23.0°C
                    Absolute Pres.: 980.0 mbar
Readiness: 1110 0101
Address 02: Auto Trans
Address 03: ABS Brakes        Labels:. 3C0-614-109-C4.clb
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000705664812
   Coding: 0000380
   Shop #: WSC 05311 000 00000
   VCID: 629DAFEEE8446D8B25F-8036
                    Fault Frequency: 60
                    Reset counter: 144
                    Mileage: 215172 km
                    Date: 2014.10.08
                    Time: 15:34:15
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 151
                    Hex Value: 0x0000
   Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001002
   Shop #: WSC 05311 115 00000
   ROD: EV_ClimaBasis_VW46.rod
   VCID: 75B7E4B2454AEA3370D-8020
9479441 - Control Circuit for Front Right Seat Heater
          B10A5 11 [008] - Short to Ground
                    Reset counter: 158
                    Mileage: 214019 km
                    Date: 2020.03.14
                    Time: 19:15:09
9479697 - Control Circuit for Front Left Seat Heater
          B10A6 11 [008] - Short to Ground
                    Reset counter: 158
                    Mileage: 214019 km
                    Date: 2020.03.14
                    Time: 19:15:09
   Revision: 00H54000    Serial number: 00000003866226
   Coding: 158C8F0340041A00470000000F00000000285D435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 33331AAA073EB4039E9-8066
   Subsystem 1 - Part No: 3C1 955 419 B  Labels: 1KX-955-119.CLB
   Component: Wischer 260410 006  0208
   Coding: 00046997
   Shop #: WSC 05124
00532 - Supply Voltage B+
                    Reset counter: 176
                    Mileage: 214859 km
                    Voltage: 7.15 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 144
                    Mileage: 214897 km
                    Voltage: 11.90 V
00317 - Rear Lid Control Module (J605)
                    Reset counter: 184
                    Mileage: 215173 km
                    Voltage: 9.15 V
00059 - Terminal 30 for Interior Lighting
                    Fault Status: 00101100
                    Reset counter: 184
                    Mileage: 215172 km
                    Voltage: 12.10 V
                    Reset counter: 184
                    Mileage: 214859 km
                    Voltage: 7.80 V
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__00C VW10 HI   1918
   Revision: 22014000    Serial number: 003JZP99GXW9
   Coding: 0012355
   VCID: 4BC3624A7FCECCC3F69-801E
   Subsystem 1 - Part No: 3C0 959 339 D
   Component: BF-Gewichtsens. 001 0002
   Subsystem 2 - Serial number: 00000000006FL1
   Subsystem 3 - Serial number: 0031.03.100000100000630101ÿ†63
   Subsystem 4 - Serial number: 630101ÿ†6332MTS673440890 ÿ†63
   Subsystem 5 - Serial number: 40890 ÿ†6342MTS654060980 ÿ†63
   Subsystem 6 - Serial number: 60980 ÿ†6351HTS60H5T49KJ ÿ†63
   Subsystem 7 - Serial number: T49KJ ÿ†6361HTS61J4MA6KR ÿ†63
   Subsystem 8 - Serial number: MA6KR ÿ†63727TS6K0RT49KJ ÿ†63
   Subsystem 9 - Serial number: T49KJ ÿ†63827TS642N1A6KJ ÿ
   Subsystem 10 - Serial number: 1A6KJ ÿ
                    Reset counter: 184
                    Mileage: 215173 km
                    Date: 2014.10.12
                    Time: 04:19:07
03551 - Functional Restriction of Seat Occupied Recognition
            000 - - - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 215173 km
                    Date: 2014.10.12
                    Time: 04:19:07
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Component: LENKS.MODUL   009 0135
   Revision: FF010036    Serial number: 20100504300707
   Coding: 198A270002
   VCID: 6FBBD6DA2716D0E3BA1-803A
   Coding: E20000
0516 - Databus
                    Reset counter: 144
                    Mileage: 215172 km
                    Date: 2020.05.17
                    Time: 15:34:16
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 184
                    Mileage: 214859 km
                    Time: 00:00:00
   Part No SW: 3C0 920 972 L    HW: 3C0 920 972 L
   Component: KOMBI         H03 0305
   Coding: 261F00
   Shop #: WSC 05314 115 00000
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
   VCID: 2F3B16DAE79690E3FA1-807A
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Steuergerät für Getriebe: keine Kommunikation]
                    Reset counter: 144
                    Mileage: 215172 km
                    Date: 2020.05.17
                    Time: 15:34:20
12658432 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Reifendrucküberwachung: keine Kommunikation]
                    Reset counter: 184
                    Mileage: 215172 km
                    Date: 2020.05.20
                    Time: 05:00:26
13631488 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät für Komfortsysteme: keine Kommunikation]
                    Reset counter: 184
                    Mileage: 215172 km
                    Date: 2020.05.20
                    Time: 05:00:27
13635840 - Supply voltage
          [Supply voltage too low]
                    Reset counter: 176
                    Mileage: 214859 km
                    Date: 2020.04.16
                    Time: 00:01:31
   Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
   Component: J533  Gateway   H13 0172
   Revision:   H13       Serial number: 3620P10515036B
   Coding: FD807F07021612002002
   Shop #: WSC 05311 000 08193
   VCID: 2F3B16DAEB1690E3FA1-807A
                    Reset counter: 176
                    Mileage: 214859 km
                    Reset counter: 144
                    Mileage: 215172 km
                    Reset counter: 184
                    Mileage: 215172 km
                    Reset counter: 184
                    Mileage: 215172 km
                    Reset counter: 184
                    Mileage: 215172 km
   Part No SW: 3C8 919 965     HW: 3C8 919 965
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1614128R1WB103
   VCID: 75B7E4B249CAEA3370D-8020
                    Reset counter: 176
                    Mileage: 214859 km
                    Date: 2014.09.07
                    Time: 00:01:04
   Part No SW: 3C0 959 433 AP    HW: 3C0 959 433 AP
   Component:    IMMO         052 0383
   Revision: 00052000    Serial number: VWZCZ000000000
   VCID: 78A9ED865ED8975B6BB-802C
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
02823 - Requirements for Locking the Steering Column Lock not met
                    Reset counter: 176
                    Mileage: 214859 km
                    Date: 2014.09.07
                    Time: 00:00:55
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
                    Reset counter: 176
                    Mileage: 214859 km
                    Date: 2014.09.07
                    Time: 00:00:38
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0090
   Revision: A1001003    Serial number: 7668003348
   VCID: 2615F3FEC8ECD1AB097-8072
                    Reset counter: 184
                    Reset counter: 176
   Part No SW: 3C0 959 701     HW: 3C0 959 793
   Component: TUER-SG FT    002 0305
   Revision: 13101005    Serial number: 0000837072
   Coding: 0004B5
   ASAM Dataset: EV_DCU42BroseDriveSide A03004
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 6597B4F2F5EA1AB3C0D-8030
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 A    HW: 3C0 959 795 A  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001444836
   Coding: 000490
          B11EC 54 [009] - Missing Calibration / Basic Setting
67332 - Remote Rear Lid Unlock Button
          B1210 29 [008] - Signal Implausible
                    Mileage: 197622 km
                    Date: 2019.09.28
                    Time: 15:16:28
65793 - Supply voltage
          [Front DCU undervoltage]
                    Reset counter: 176
131329 - Rear Door Control Module
          B11ED F0 [008] - Supply Voltage too Low
                    Reset counter: 176
                    Mileage: 214859 km
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.148 0703
   Revision: 1AH03726    Serial number: 00101260135601
   Coding: 0000258
   VCID: 3A2D378E2054454B5DF-806E
01288 - Terminal 30; Steering Assist
                    Fault Status: 00101011
                    Fault Priority: 9
                    Reset counter: 179
                    (no units): 2.0
                    Voltage: 8.40 V
   Component:    KSG PQ46 RDK 052 0412
   Coding: 13900E80D1032E521004141FF08A0F0E085801
                    Reset counter: 176
                    Mileage: 214859 km
                    Date: 2014.09.07
                    Time: 00:00:59
                    Reset counter: 184
                    Mileage: 215173 km
                    Date: 2014.10.12
                    Time: 04:26:22
   Part No SW: 3C0 959 702     HW: 3C0 959 792
   Component: TUER-SG BT    002 0305
   Revision: 15101005    Serial number: 0000839792
   Coding: 0004B4
   ASAM Dataset: EV_DCU52BrosePasseSide A03004
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 6695B3FE08EC11ABC97-8032
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 A    HW: 3C0 959 794 A  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001435080
   Coding: 000490
                    Reset counter: 176
                    Reset counter: 176
                    Mileage: 214859 km
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000272386
   Coding: 0000057
   VCID: 2C0101D6DA00EBFBDF3-8078
                    Fault Status: 11100100
                    Fault Frequency: 58
                    Reset counter: 144
                    Mileage: 215172 km
                    Date: 2014.10.08
                    Time: 15:34:15
                    Voltage: 11.60 V
                    Count: 75
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0035
   Revision: -----20S    Serial number: VWZ4Z7K1138354
   Coding: 0100040004
   VCID: 619FA0E2E14276933C5-8034
                    Reset counter: 133
                    Mileage: 164013 km
                    Date: 2012.12.27
                    Time: 15:59:28
                    Reset counter: 184
                    Reset counter: 184
                    Mileage: 215173 km
                    Date: 2014.10.12
                    Time: 02:25:16
   Component:    RDK              0453
   Coding: 0100101
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 G    HW: 3C9 827 383 G
   Component: J605  HECKDECKEL    0730
   Revision: 00H27001
   VCID: 353724B2094AAA33B0D-8060
   Subsystem 1 - Part No: 3C9 827 384 G
   Component: J756  HECKDECKEL    0730
   Subsystem 2 - Serial number: 1000H27001001A0156ÿ
                    Reset counter: 184
                    Mileage: 214859 km
                    Date: 2014.09.07
                    Time: 00:00:45
                    Reset counter: 184
                    Mileage: 215172 km
                    Date: 2014.10.11
                    Time: 05:00:29
02788 - Internal Communications Error
                    Reset counter: 184
                    Mileage: 215173 km
                    Date: 2014.10.12
                    Time: 04:26:04
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005271152
   Coding: 0013077
End----(Elapsed Time: 01:54, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
You need to find out why the TCM is off-line entirely. If it were mine, I'd break out the wiring diagrams and a DVOM, and check power, ground, and CAN bus connections to the TCM.
Ahhh are you sure you put the fuses back in correct locations and they are not blown?
Any empty bays?
You JPPSG yet?
Shade
South Africa
C?ID=291138
I would follow exactly what Uwe said, check the following
Powers J743: Fuse SB5, SB7, SC2
Grounds J743: Pin 16 and 19
CanH J743: Pin 10
CanL J743: Pin 15
Fauxbm
C?ID=405636
I appreciate all the recommendations. I printed out the fuse box diagram and did go through them again.
I'll go back through the specific fuses you recommended tomorrow.
Been working on my boat engine all day, I can only focus on one project at a time...
Fauxbm
C?ID=405636
I would be surprised if there was an issue as I've had zero issues with the DSG.
I did remove the plug none the less, checked visually for any damaged connectors. Cleaned the front and back with electrical cleaner and plugged it back in. I did remove and check the ground wire and reinstalled it, no change.
Next would be the DVOM process, but I'm going to go back through the fuses one more time seeing that's when the the issues started.
