Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: 9645 - Reductant - P20E8 00 [101] - Pressure too Low
    Dec 2019
    England UK
    Hi guys,
    This error came up while I was driving home from work a few days ago. It basically said that there was a system fault with the AdBlue and that I had 650 miles before no restart. I wasn't that far from home so I managed to get home without a problem. Then, when I started the car the next day, the error didn't come back up. The error came on again when I was driving later on. I read online that I should top the AdBlue to the brim and see if the error comes back on. So I filled the tank up and the error is still present. After doing a scan the faults below have been identified.
    I have read on other posts that a replacement AdBlue pump fixes the issue. I was just hoping to get some clarification before going down that road.
    My car is a 2014 Audi A6 C7 2.0 Ultra with 160+k miles.
    Any help would be much appreciated.
    Friday,29,May,2020,10:53:51:46370
    VIN: WAUZZZ4G9EN186797   License Plate:
    Mileage: 262130km-162880mi   Repair Order:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 55 5F 62 6D
              72 AC
    VIN: WAUZZZ4G9EN186797   Mileage: 262130km-162880miles
    AC-Reductant Control -- Status: Malfunction 0010
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FE    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 7709
       Revision: 85H23---
       Coding: 12194012242401080000
       ASAM Dataset: EV_ECM20TDI01104L906021FE 001006
       ROD: EV_ECM20TDI01104L906021FE_001.rod
       VCID: 6D8734E61D1AAC4388D-8038
    16931 - Control Circuit for Reductant Heating 1
              P20B9 00 [036] - Open Circuit
                        Mileage: 262048 km
                        Date: 2020.05.28
                        Time: 23:46:36
                        Engine speed: 722.00 /min
                        Normed load value: 56.9 %
                        Coolant temperature: 59 °C
                        Intake air temperature: 56 °C
                        Voltage terminal 30: 13.560 V
                        Extern.temp.sens.1 bank 1: raw value: 23.0 °C
                        Particle filter outlet temp.sens.1 bank 1: raw value: 41.2 °C
                        Sensor for reducing agent tank temperature: temperature: 24.7 °C
                        Heating circuit 1 for reducing agent metering: activation-Bits 0-7: 0
                        Sensor for reducing agent fill level: voltage: 2860.0 mV
    9645 - Reductant
                        Mileage: 262050 km
                        Date: 2020.05.28
                        Time: 23:50:06
                        Engine speed: 1208.00 /min
                        Normed load value: 29.4 %
                        Vehicle speed: 44 km/h
                        Coolant temperature: 76 °C
                        Intake air temperature: 55 °C
                        Voltage terminal 30: 14.260 V
                        Extern.temp.sens.1 bank 1: raw value: 17.5 °C
                        Pressure sensor for reducing agent: measured pressure: -500 hPa
                        Sensor for reducing agent tank temperature: temperature: 25.4 °C
                        Reducing agent pump: activation: 50.00 %
                        Sensor for reducing agent fill level: voltage: 3035.0 mV
       Coding: 06A09F016005F9809B00
       VCID: 3A2DCFBA1CD4CBFB5DF-806E
       Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
       Component: BCM2 2.0      H36 0551
       Coding: 03B93046000000000000
       VCID: 7AAD0FBA5CD40BFB1DF-802E
       Serial number: 0214000131000005
       Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
       Component: KLIMA 2 ZONEN H14 0096
       Serial number: 11071400110164
       Coding: 3422090821
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 5F9B5E2EE7B6CED30A1-800A
       Part No SW: 4H0 907 063 CE    HW: 4H0 907 063 E
       Revision: 19012002    Serial number: 00000001557965
       Coding: 2600201040349F600481008000001D0C0F9D870827090201000004606100
       VCID: 6D8734E61D9AAC4388D-8038
       Component: WWS57X 140625  H37 0080
       Serial number:         140707090428
       Coding: 0045F7
       Serial number: 22905820
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 BE    HW: 4G0 941 531 BE
       Component: E1 - LDS  H07 0044
       Serial number: 09 07 2014  00000925
       Serial number: B959CA37000000000001
       Revision: 11001001    Serial number: 61061420200637
       Coding: 08C208
       VCID: 71BF2896012248A3AC5-8024
       Revision: --------    Serial number: 003JG00JNN9Q
       Coding: 3032343631324E303235554A305234473053
       VCID: 3635DB8A28CC2F9BB97-8062
       Serial number: 3575HRB405F2MKOU91A2
       Serial number: 3585HRB400C50RHSIOMI
       Serial number: 3515JRB400C52M10IHAX
       Serial number: 3525JRB400852M10K8KX
       Serial number: 3554VRB401652LJSN92Y
       Serial number: 3564VRB400E52LJSNH05
       Revision: 00000000    Serial number: 20140717000347
       Coding: 000015
       VCID: 3039ED92CA2801ABE3B-8064
       Subsystem 1 - Part No SW: 4G0 951 528 C    HW: 4G0 951 528 C
       Part No SW: 4G8 920 983 C    HW: 4G8 920 983 C
       Component: TDieGb        H54 0519
       Revision: 27222219    Serial number: 658111214MT1000
       Coding: 33AD12000B412600010000
       ASAM Dataset: EV_RBD4K 004046
       ROD: EV_RBD4K_AU57.rod
       VCID: 3537DC8635CA2483B0D-8060
       Part No SW: 4G0 907 468 AD    HW: 4G0 907 468 AC
       Revision: --------    Serial number: 00000001480129
       Coding: 00CD074400
       VCID: 72BD279A042473BB55F-8026
       Serial number: 1331113903
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 14051400000000000410
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA720B6V8G
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3333E29E3BBE3AB39E9-8066
       Coding: 011C16004001620002080002
       VCID: 47CBA64E5FA6A613D21-8012
       Part No SW: 4G0 909 144 M    HW: 4G0 909 144 G
       Component: RCEPS         H41 0011
       Revision: 00001000    Serial number: 0016774951
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009010
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0341753728
       Coding: 013B0622A0B930408320090400010F470000000000000000000000000000
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 193
                        Mileage: 259501 km
                        Date: 2020.04.23
                        Time: 16:42:19
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 224
                        Mileage: 259501 km
                        Date: 2020.04.23
                        Time: 20:33:53
       Coding: 011C16004401620002080002
       VCID: 46D5AB4A58ACBF1B297-8012
       Revision: --------    Serial number: 00000001143406
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D07F4E6DD9A6C43C8D-8078
       Serial number: 140715-0002-122
       Coding: 112296101000A300
       ROD: EV_HeadlRegulBasic.rod
       Part No SW: 4G0 035 192 H    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H55 0801
       Coding: 0101010101415B47082B060301010000010000
       VCID: 270B06CEFFE64613321-8072
       Subsystem 1 - Part No: 8X0 919 884 G
       Component: P24-50-13.06  0001
       Subsystem 2 - Part No SW: 4G0 919 603 B    HW: 4G0 919 603 B
       Component: DU6 Basic  H43 0084
       Serial number: 9464G$0E2670176
       Subsystem 3 - Part No SW: 4G2 919 710 B    HW: 4G2 919 710 B
       Serial number: 90349NGG000BT
    02444 - Disk Drive Load / Eject Malfunction
                        Reset counter: 253
                        ON Time: 5417 h
       VCID: 49CFA07649B25063C45-801C
       Part No SW: 4G9 959 107 B    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0143
       Revision: 14003001    Serial number: 191400929
       Coding: 097205C010
       ROD: EV_HDSGAu571.rod
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0010
       Revision: 00000000    Serial number: 141841034
       ROD: EV_RDCMA00100.rod
       VCID: 2B03FAFEE38E6273D69-807E
    262403 - Control Circuit for Reductant Heating 1
              P20B9 00 [008] - Open Circuit
                        Reset counter: 13
                        Voltage terminal 30A: 12.5 V
                        Voltage terminal 30B: 12.5 V
                        Voltage terminal 87: 12.3 V
                        Reductant_pwm_duty_cycle: 0.0 %
                        Reductant_speed_pump_motor: 0 /min
                        Reductant_pump_output_stage_temperature: 21 °C
                        Reductant_heater_control_1_output_stage_temperature: 21 °C
                        Reductant_tank_temperature_sensor_actual_value: 24 °C
                        Reductant_temperature_ambient: 77 °C
                        Reductant_current_pump_motor_A: 0.0 A
                        Reductant_current_pump_motor_B: 0.0 A
                        Reductant_current_pump_motor_C: 0.0 A
                        Reductant_heater_control_1_actual_power_value: 0.0 A
                        Reductant_heater_control_2_actual_power_value: 0.0 A
                        Reductant_transfer_pump_current: 0.0 A
                        Reductant_pressure_sensor_actual_value: -500 mbar
                        Reductant_voltage_sensor_supply: 5.0 V
                        Reductant_voltage_sensor_gnd: 0.0 V
                        Reductant_level_sensor_actual_raw_voltage: 2.6 V
                        KL15 on: On
                        DIAG_Opt_H: On
                        Tank_L_SC: On
                        Lines_L_SC: OFF
                        DIAG_Lines_H: OFF
                        DIAG_Lines_L: OFF
                        DIAG_Tank_H: On
                        DIAG_Tank_L: OFF
                        MO_SCR_Dosierpumpe_Zustand: 00
                        MO_SCR_Tankheizung: OFF
                        MO_SCR_Leitungsheizung: OFF
                        MO_SCR_Transferpumpe: OFF
                        reserviert 1 0: On
                        Reserviert 2: OFF
                        Can signal MO_SCR_Dosierpumpe_Soll: 0.0 %
    End----------(Elapsed Time: 01:41, VBatt start/end: 12.1V/12.1V)-----------
    16.4905° S, 151.7375° W
    You can have a look with VCDS in the Advanced Measuring Values for the AdBlue Pump Pressure, it is displayed in [hPa].
    Use the 'word' filter at the top of the pop-up box of the descriptions, use "pressure sensor", the first one should be it.
    [*IDE03132*],176,,Pressure sensor for reducing agent: measured pressure,IDENTICAL,hPa
    Typically the reading is around 5-bar (with the pump/engine running) or in this case if my math is correct, 5,000-hPa.
    Hope this helps and let us know what you find!
    drpeter
  3. Likes Uwe, Jack@European_Parts liked this post
    Dec 2019
    England UK
    Hi DrPeter,
    Thanks for the reply. I have has a look at the log again and there is a reading for the pressure "Pressure sensor for reducing agent: measured pressure: -500 hPa".
    Is this the one you are looking for? Or should I get a fresh reading using the method you just explained?
    Quote Originally Posted by TheRenegade View Post
    Hi DrPeter,
    Hi, Ah, okay ... That was the value in your freeze frame.
    I was suggesting to have a look at the 'live' pressure, with VCDS in the Advanced Measuring Values. That way you can 'see' the current pressure and if it actually reads the expected ~5 bar. Come to think of it it maybe around 6 bar.. maybe? Either case it should not read a negative with the pump running.
    You can use the [Output Tests] to run the pump too and select the [Measuring Values] for the "Pressure sensor for reducing agent" value.
    Also, [-500 hPa] seems weird. It is possible the sensor would read atmospheric pressure, then you should see about [1000 hPa] at sea level. Perhaps the pump is okay and the "Pressure sensor for reducing agent" is faulty?
    Let us know what you see for the 'live' "Pressure sensor for reducing agent".
    Thanks,
    drpeter
    Dec 2019
    England UK
    So this is the first chance I have had to go and do something with the car. I managed to do what you asked (I hope)!
    https://i.imgur.com/6Xb3Xsa.png
    The car was turned on and I'd left it running for about 10 - 15 minutes be fore doing this.
    Uhm... The forum can't pull and display images from your C:\ drive.
    Please see How to Post Pictures.
  9. Likes Jack@European_Parts liked this post
  10. #7
    Dec 2019
    England UK
    LOL, sorry. I thought I had done it properly. Oh well,try again...
  11. #8
    Feb 2020
    New Zealand
    Also note that the Adblue nozzle is heated to over 100deg to prevent crystal deposits in the nozzle. You have an open circuit fault for the heater Circuit, so I would check that also.
    It is not difficult to remove the nozzle and run a pump test. You should end up with approx 40-50ml in a container at the end of the test. You can also see if the heater is working or the nozzle is blocked (should have 3 jets out of it)
  12. Likes Jack@European_Parts, Uwe liked this post
  13. #9
    Dec 2019
    England UK
    Quote Originally Posted by Rollux View Post
    Thanks for that, I'll have a look later today or in the morning. Just before I go hunting for it, is this the location of the nozzle?
  14. #10
    Feb 2020
    New Zealand
    Sorry, I can’t tell from that pic
