Retro fit xenon headlights issues.
Chrisp4632
Berkshire, UK
C?ID=317266
Hey new to the group and still learning my round VCDS and in need of some help please ,
im currently retro fitting Xenon headlights into my Audi A4 B7 2007 and im having issues with my BCM module (8E0907279M),original Module in the car will not accept any changes in 09 cent elec -coding-07,change from 1001to 10021 screen resets but changes do not apply.
so i have changed this to a newer BCM (8E0907379N) which now works fine however i have the following fault codes below..
i have tried to start vin learning process 09 cent elec-10 adaptation-channel 81-new value 46992 ,however when i hit Test it flashes up disabled in the top left?
i have also tried different new values listed in the rosstec site and still getting the same message flashing up.
any ideas what to do next?
please see auto scan below.
VIN: WAUZZZ8E57A095142   License Plate: 0E56ECJ
Mileage: 192830km-119819mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E57A095142   Mileage: 192830km-119819miles
Address 01: Engine        Labels: 03G-906-018-BRD.clb
   Part No SW: 03G 906 018 AQ    HW: 03G 906 018 AQ
   Component: R4 2.0l PPD1.3 G    9973
   Revision: --H33---    Serial number:
   Coding: 0000072
   Shop #: WSC 00067 210 90957
   VCID: 74B1DA3602BB31BB473-8020
Readiness: N/A
   Part No SW: 8E0 910 517 H    HW: 8E0 614 517 BF
   Component: ESP8 FRONT      H06 0140
   Coding: 0004405
   Shop #: WSC 06335 000 00000
   VCID: 2C0102569A0B297BDF3-8078
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2833
   Coding: 00000
   VCID: 6B83C14A5A95EE43969-513C
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  ECE 0907
   Coding: 10001
   Shop #: WSC 06325
   VCID: 3D273F127461B0F378D-4B00
            30-00 - Open or Short to Plus
01794 - Control Module - Incorrect Chassis (VIN) Number
            35-00 - -
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H12 3730
   Revision: 91H12373    Serial number: 0036M0G3G6J5
   Coding: 0031612
   VCID: 3B23310A6F65BEC3469-806E
   Subsystem 1 - Serial number: 6332DRB403D2CD26Y
   Subsystem 2 - Serial number: 6342DRB403D5888F1
   Subsystem 3 - Serial number: 6352ARB4018ABBAD3
   Subsystem 4 - Serial number: 6362ARB4018C65FA/
   Subsystem 5 - Serial number: 63729RB401A1CA7BZ
   Subsystem 6 - Serial number: 63829RB401A1CAA6Y
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0701
   Coding: 05042
   Shop #: WSC 06335
   VCID: 41DF43E20899D4131C5-4B00
01304 - Radio
            49-00 - No Communications
01301 - Control Module for Voice Recognition (J507)
   Part No SW: 8E0 920 951 E    HW: 8E0 920 951 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0006414
   Shop #: WSC 57714 001 104857
   VCID: 2C0102569A1B297BDF3-5184
01304 - Radio
   Coding: 0006414
01304 - Radio
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0804
   Coding: 00001
   VCID: 6B83C14A5A95EE43969-50F4
   Part No: 8E0 959 433 CH
   Component: Komfortgerát T3B    4135
   Coding: 07151
   Shop #: WSC 06335
   VCID: 79AFEB0220C94CD3145-4B00
   Subsystem 1 - Part No: 8E2959802F
   Component: Tõrsteuer.FS BRM 0606
   Subsystem 2 - Part No: 8E2959801F
   Component: Tõrsteuer.BF BRM 0606
Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
   Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
   Component: Parkhilfe 8-Kan H06 0010
   Revision: 00H06000    Serial number: 00067802120731
   Coding: 0000114
   VCID: 323D1C2EB80F7F8B95F-5184
downtime
C?ID=280813
Edit, no dealer needed, for the error below check this one:
http://wiki.ross-tech.com/wiki/index.php/01794
I think you need to fix this first to get any coding in.
Chrisp4632
Berkshire, UK
C?ID=317266
i have tried all of thease and as mentioned above it displayes disabled when i hit test no matter what new value i type in
downtime
C?ID=280813
Is there a need for security access login first before running the vehicle data learning procedure?
Chrisp4632
Berkshire, UK
C?ID=317266
it does say pin? at the top left on channel 81
No, I don't think so, but the B7 VIN learning has been a problem of late.
Try reading the channel repeatedly, or try setting Blk_Int on the Options screen to a different value than the default. Try 25. Try 150. There have been a few threads. We'd love to get to the bottom of it, but have yet to get our hands on a car that exhibits the problem, and by no means all of them do!
Chrisp4632
Berkshire, UK
C?ID=317266
Just an update : so I decided to go get another one but this time from a 2011 seat exeo from the breakers and everything is now fine no issues getting it coded and vin learning took 30sec to sort, so looks like the other BCM module I got was faulty.
