Hello all, new to VW group and new to here. I bought a VCDS to help diagnose a no A/C problem on my 2011 Sportwagen.
I bought sight unseen (auction) so i'm not sure when this started. I ran two autoscans, this one first:
Some of these may be artificial, so I cleared codes, then drove today attempting to use the A/C which is still non-functional. This is the auto scan after today:
In addition, ive ran a couple other tests.
1. Tested both coolant fans through VCDS
2. Rented an A/C manifold gauge set to check high and low side pressures, as the original HVAC code was for low coolant pressure. Outside ambient temp is 74.9 F. Results were ~ 42 psi (2.8 bar) on both low and high sides, regardless of whether A/C button is selected or not.
4. Ran some advanced measuring values both with and without A/C selected. Results: VCDS shows 0.820 amps to compressor, refrigerant pressure is 2.8 bar, and compressor shut-off requirement reads "Compressor active: no shut-off condition is present"
Based on this I'm thinking that the problem is probably the RCV solenoid. Am I off base here or on the right track?
Wednesday,27,May,2020,20:02:35:53470
VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VWPL7AJ5BM634911 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 3VWPL7AJ5BM634911 Mileage: 118950km-73912miles
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 030 B HW: 03L 906 019 DA
Component: R4 2.0l TDI G000AG 9983
Revision: 12H08--- Serial number:
Coding: 0050078
Shop #: WSC 29058 003 1048576
VCID: 2D070CEB911C3383C8D-8078
Readiness: 0 0 0 1 1
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 9136
Revision: 05151112 Serial number: 00001007022022
Shop #: WSC 00066 000 00000
VCID: 1869CD3F0E9EA62B8BB-804C
Part No SW: 1K0 907 379 BC HW: 1K0 907 379 BC
Component: ESP MK60EC1 H30 0106
Revision: 00H30001
Coding: 114B600C492500FE881406E5921A0042B70000
VCID: 74B1D98F3EB6224B473-8020
Reset counter: 240
Mileage: 118581 km
Date: 2020.05.03
Time: 00:03:37
Count: 2
Count: 12
Count: 29184
Count: 16390
Count: 50176
Count: 767
02214 - Tire Pressure Warning
Reset counter: 242
Mileage: 116795 km
Count: 32768
Count: 4608
Count: 16401
Count: 50945
Count: 1032
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
Shop #: WSC 00066 000 00147
ROD: EV_ClimaBasis_VW36.rod
VCID: 75B7E48B354C3B4370D-8020
B10AB F0 [008] - Too Low
Intermittent - Confirmed - Tested Since Memory Clear3
Reset counter: 250
Mileage: 118706 km
Date: 2020.05.09
Time: 04:33:49
Part No SW: 5K0 937 084 E HW: 5K0 937 084 E
Component: BCM PQ35 B 011 1035
Revision: BG011001
Coding: 2D380E1F902F3EC4008800816000004401000086535D8560648020000040
VCID: 3431198F7E36624B873-8060
Subsystem 1 - Part No: 1K1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 11101 21 0512
Coding: 009795
Reset counter: 212
Mileage: 118958 km
Date: 2020.05.27
Time: 08:02:00
Term 15 On
Voltage: 11.90 V
01516 - Terminal 30; Left
Fault Status: 00101011
Reset counter: 252
Mileage: 118958 km
Date: 2020.05.21
Time: 00:39:58
Term 15 Off
Voltage: 12.35 V
01800 - Light Switch (E1)
Reset counter: 232
Mileage: 118068 km
Date: 2020.03.19
Time: 16:07:01
Term 15 Off
Voltage: 12.25 V
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R00YWH0
Coding: 00003044
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 392F28BB59D49F23545-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005C8V500
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME271A5555ZZZX
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME26757056ZZZW
Serial number: 3511HSME7A053B23ZZZM
Serial number: 3521HSME16073B23ZZZF
Serial number: 35527SME071B5123ZZZ6
Serial number: 35627SME09235323ZZZ4
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 007 0080
Revision: -------- Serial number: 90440JHK000BO
Coding: 188A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5E387284A305B797-8022
Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB
Serial number: 0149688
Coding: 820000
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Reset counter: 40
Time: 00:00:00
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H03 0406
Coding: 270F01
VCID: 2F3B16E397904193FA1-807A
Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 A HW: 1K0 907 951
Component: J533 Gateway H25 5603
Revision: H25 Serial number: 04101001200237
Coding: ED807F0600160300002002
VCID: 2E050BE79C1A489BF17-807A
01304 - Radio
Fault Status: 00110100
Reset counter: 251
Mileage: 116789 km
Date: 2020.02.02
Time: 02:28:32
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223R9N2D06
VCID: 7EA5FBA70CFA781B217-802A
Component: IMMO H03 0406
VCID: 6A8DC7F76CF2E4BBEDF-803E
Part No SW: 3C0 959 701 B HW: 3C0 959 793
Component: TUER-SG FT 002 0307
Revision: 13101005 Serial number: 0001429876
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 270BFEC3BF6019D3321-8072
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005194982
Coding: 000490
B11EC 54 [008] - Missing Calibration / Basic Setting
Reset counter: 213
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 313F109B8D245763EC5-8064
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H25 5603
Coding: 050B0500
VCID: 6FBBD6E357900193BA1-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
02071 - Local Databus
Fault Status: 00101100
Fault Frequency: 36
Reset counter: 240
Mileage: 108057 km
Date: 2020.07.13
Time: 18:12:56
Part No SW: 3C0 959 702 B HW: 3C0 959 792
Component: TUER-SG BT 002 0307
Revision: 15101005 Serial number: 0001420621
Coding: 0004B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 2809FDFFB27E16AB3BB-807C
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005247493
Coding: 000490
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: MIB2-S-R-CN 036 0317
Revision: -----001 Serial number: VWZ6Z2R7180959
Coding: 1600044004000A
Shop #: WSC 21862 418 140358
VCID: 46D5534718AAE0DB297-8012
10 Faults Found:
00625 - Vehicle Speed Signal
Reset counter: 40
Mileage: 27780 km
Date: 2021.08.01
Time: 08:55:25
Reset counter: 237
Time: 12:30:06
Reset counter: 0
Time: 12:30:03
00849 - S-contact at Ignition/Starter Switch (D)
Reset counter: 40
Time: 12:30:57
Reset counter: 237
Time: 12:30:06
Reset counter: 237
Mileage: 27780 km
Date: 2021.08.01
Time: 08:55:23
01704 - Terminal 58 (Dimming)
Reset counter: 40
Time: 12:30:57
00876 - Treble Speaker Rear Left (R14)
Fault Status: 01101011
Reset counter: 1
Mileage: 2 km
Date: 2020.02.01
Time: 01:37:39
00875 - Treble Speaker Front Right (R22)
Reset counter: 1
Mileage: 2 km
Date: 2020.02.01
Time: 01:37:39
00874 - Treble Speaker Front Left (R20)
Reset counter: 1
Mileage: 2 km
Date: 2020.02.01
Time: 01:37:39
Part No SW: 7P6 035 730 C HW: 7P6 035 730 C
Component: TELEFON H05 0440
Revision: 1B001001 Serial number: 00007668418833
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 323D1F9784A26C7B95F-8066
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Fault Frequency: 177
Reset counter: 212
Mileage: 116925 km
Date: 2020.02.05
Time: 05:33:53
9457171 - Right audio channel for speech/telephone
B104E 13 [009] - Short to GND
Reset counter: 142
Mileage: 116925 km
Date: 2020.02.05
Time: 05:33:51
0022 - Radio
U1066 00 [008] - No Communication
[Steuergerät Radio (RNS): kein Signal/Kommunikation]
Fault Frequency: 7
Reset counter: 251
Mileage: 116789 km
Date: 2020.02.02
Time: 02:28:29
End----(Elapsed Time: 01:33, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Wednesday,27,May,2020,20:50:02:53470
Mileage: 118950km-73912mi Repair Order:
Coding: 0050078
Revision: 00H30001
Revision: 00009001
Coding: 0000001002
Revision: BG011001
Coding: 009795
Coding: 00003044
Coding: 188A140000
Coding: 820000
Coding: 270F01
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H17000
Coding: 050B0500
Coding: 0004B4
Slave Passenger:
Coding: 000490
10 Faults Found:
Reset counter: 40
Mileage: 27780 km
Date: 2021.08.01
Time: 08:55:25
Reset counter: 237
Time: 12:30:06
Reset counter: 0
Time: 12:30:03
Reset counter: 40
Time: 12:30:57
Reset counter: 237
Time: 12:30:06
Reset counter: 237
Mileage: 27780 km
Date: 2021.08.01
Time: 08:55:23
Reset counter: 40
Time: 12:30:57
Reset counter: 252
Mileage: 2 km
Date: 2020.02.01
Time: 01:37:39
00856 - Radio Antenna
Reset counter: 212
Mileage: 118958 km
Date: 2020.05.27
Time: 08:31:20
Reset counter: 252
Mileage: 2 km
Date: 2020.02.01
Time: 01:37:39
ROD: UHVNA.rod
Reset counter: 212
Mileage: 118958 km
Date: 2020.05.27
Time: 08:46:05
Reset counter: 212
Mileage: 118958 km
Date: 2020.05.27
Time: 08:46:05
End----------(Elapsed Time: 01:28, VBatt start/end: 12.4V/12.2V)-----------
Thursday,28,May,2020,17:56:28:53470
VIN: 3VWPL7AJ5BM634911 Mileage: 118970km-73924miles
Coding: 0050078
Revision: 00H30001
Fault Status: 01100010
Reset counter: 212
Mileage: 118962 km
Date: 2020.05.28
Time: 03:55:51
Count: 32768
Count: 4608
Count: 16401
Count: 50944
Count: 1023
Revision: 00009001
Coding: 0000001002
Revision: BG011001
Coding: 009795
Coding: 00003044
Coding: 188A140000
Coding: 820000
Coding: 270F01
Coding: 0004B5
Slave Driver:
Coding: 000490
Revision: 00H17000
Coding: 050B0500
Coding: 0004B4
Slave Passenger:
Coding: 000490
10 Faults Found:
Reset counter: 40
Mileage: 27780 km
Date: 2021.08.01
Time: 08:55:25
Reset counter: 237
Time: 12:30:06
Reset counter: 0
Time: 12:30:03
Reset counter: 40
Time: 12:30:57
Reset counter: 237
Time: 12:30:06
Reset counter: 237
Mileage: 27780 km
Date: 2021.08.01
Time: 08:55:23
Reset counter: 40
Time: 12:30:57
Reset counter: 252
Mileage: 2 km
Date: 2020.02.01
Time: 01:37:39
Reset counter: 212
Mileage: 118958 km
Date: 2020.05.27
Time: 08:31:20
Reset counter: 212
Mileage: 118960 km
Date: 2020.05.28
Time: 03:53:53
ROD: UHVNA.rod
Fault Frequency: 9
Reset counter: 213
Mileage: 118958 km
Date: 2020.05.27
Time: 08:46:05
Reset counter: 212
Mileage: 118958 km
Date: 2020.05.27
Time: 08:46:05
End----------(Elapsed Time: 01:27, VBatt start/end: 12.4V/12.3V)-----------
