2013 A8 ACC issue, possible to code out ACC while keeping traditional CC?
es.biggs
C?ID=165177
2013 A8L 3.0, came in with complaint "ACC and braking guard unavailable" displays on cluster when attempting to activate cruise control. Verified complaint, adaptive cruise is not working. Upon investigation, found aftermarket windshield installed, the heater strip for front camera is loosely attached to the window. Looks like some monkeys installed it, previous owner was probably trying to save a few bucks (can't blame them.) I think a good start would be to try plugging a new cable in to see if that works (there is a fault for the video cable) but if that doesn't do it, I would recommend installing a factory windshield and ACC alignment at the local dealership. Assuming the cable does not fix the issue, and the car does need a windshield and ACC alignment, I think we would rather try coding the ACC and braking guard features out, if that's even possible. Does anybody have experience with this type of "fix"? I would appreciate any input or ideas. Thanks
Thursday,28,May,2020,18:32:34:61479
VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
VIN: WAURGAFD5DN000911   License Plate:
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 22 28 34 36 3B 3C
          42 46 47 52 53 56 5F 62 6C 6D 6F 72 7F 81 85 88 89 8B 8E 8F
          90
VIN: WAURGAFD5DN000911   Mileage: 128680km-79958miles
7F-Inform. Electr. II -- Status: OK 0000
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 4H0 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0005
   Revision: --H07---
   Coding: 0A2A0034056E01060000
   Shop #: WSC 02313 785 00200
   ASAM Dataset: EV_ECM30TFS0214H0907551G 001006
   ROD: EV_ECM30TFS0214H0907551G.rod
   VCID: 2E10152171E762F6A0-807A
   Part No SW: 4H1 927 158 AR    HW: 0BK 927 156 AG
   Component: 0BK 30TFSIUSA H16 1005
   Revision: --H16---
   Coding: 000002
   ROD: EV_TCMALX51011_002_AU64.rod
   VCID: 004C9B999BF3248602-8054
Address 03: ABS Brakes (J104)       Labels: 4H0-907-379.clb
   Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
   Component: ESP PREMIUM   H10 0352
   Coding: 80EDF30001B7CF00E200
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ESPPremi 005013
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 342407499FCB4826D6-8060
8 Faults Found:
0679 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [Net_QSP_02_QSP_Ist_Moment]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 2A
                    F-Type: 2E
                    Uz: 96
0695 - Tire Pressure Warning
          C102D 00 [009] - -
                    Fault Frequency: 23
                    Reset counter: 142
                    Mileage: 128561 km
                    Date: 2020.05.15
                    Time: 16:40:10
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 47
                    F-Type: 0C
                    Uz: B2
0718 - Tire Pressure Warning
          C102D 00 [009] - -
                    Fault Frequency: 23
                    Reset counter: 142
                    Mileage: 128561 km
                    Date: 2020.05.15
                    Time: 16:40:10
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 47
                    F-Type: 03
                    Uz: B2
0736 - Function Restriction due to Faults in Other Modules
          U1113 00 [136] - -
          [Net_SARA_03_Accel_Y_b_red_not_calibrated]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 43
                    F-Type: 3F
                    Uz: 96
0737 - Function Restriction due to Faults in Other Modules
          U1113 00 [136] - -
          [Net_SARA_03_Omega_Z_b_red_not_calibrated]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 46
                    F-Type: 3F
                    Uz: 96
0738 - Function Restriction due to Faults in Other Modules
          U1113 00 [136] - -
          [Net_SARA_06_Accel_X_010_not_calibrated]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 23
                    F-Type: 3F
                    Uz: 96
0739 - Function Restriction due to Faults in Other Modules
          U1113 00 [136] - -
          [Net_SARA_06_Accel_Y_010_not_calibrated]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 1A
                    F-Type: 3F
                    Uz: 96
0740 - Function Restriction due to Faults in Other Modules
          U1113 00 [136] - -
          [Net_SARA_06_Omega_Z_010_not_calibrated]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 00
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 1B
                    F-Type: 3F
                    Uz: 96
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
   Component: BCM2 2.0      H31 0510
   Coding: 0DA72006000000000000
   VCID: 6E90D521B96722F6E0-803A
   Serial number: 2312000002492016
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Component: MEM-BFS       H08 0153
   Revision: AA000000    Serial number: 00000025490837
   Coding: C018320085047201010001010101112131313333283333
   VCID: 35223A4D9CB1512EE1-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
   Component: Klima 4 Zonen H20 0110
   Coding: 660122786C
   ROD: EV_AirCondiFront_001_AU64.rod
   VCID: 2502EA0D241121AE51-8070
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [008] - Signal Amplitude Too High
                    Fault Frequency: 27
                    Reset counter: 183
                    Mileage: 128561 km
                    Date: 2020.05.15
                    Time: 16:40:16
   Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0111
   Revision: 11012002    Serial number: 00000001432529
   Coding: 09072091073C9FE3AB000804A0003800009CD308860001218001085C3B00
   VCID: 77BEF045C63D633E33-8022
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 120202  H35 0080
   Serial number:         120218192609
   Coding: 0045F7
   Subsystem 2 - Part No SW: 8K0 955 559 C    HW: 8K0 955 559 C  Labels: 8K0-955-559.CLB
   Component: RLS  H04 0003
   Serial number: 10231911
   Coding: 025523
   Subsystem 3 - Part No SW: 4H0 941 531 B    HW: 4H0 941 531 B
   Component: E1 - LDS  H07 0044
   Serial number: 09 03 2012  00000326
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R18LQ02
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000012031200010718
   Coding: 100000
   Subsystem 6 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000012031200010888
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0300
   Serial number: WA102747000000903108
   Coding: 020300
   Subsystem 8 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 1B084C16000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 E    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0190
   Revision: AA001001
   Coding: 020000
   VCID: 2208F1113D3FD69634-8076
   Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
   Revision: 11001001    Serial number: 55901206901412
   Coding: 280B02
   ROD: EV_EPHVA18AU57X0000_002_AU64.rod
   VCID: 3B362C75B295875E17-806E
   Part No SW: 4H0 907 561 B    HW: 4H0 907 561
   Component: ACC3          H17 0400
   Coding: 7E01020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 002021
   ROD: EV_AdaptCruisContrAU64X_002.rod
   VCID: 2A1819314D0F0ED67C-807E
93440 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [FAULT_CIS_VIDEO_FAIL]
                    Fault Frequency: 18
                    Reset counter: 143
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:17:44
                    Control Module temperature: 46 °C
                    Voltage terminal 15: 14.319 V
                    Velocity_vehicle_reference: -0.01 m/s
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H44 0041
   Revision: --------    Serial number: 003JS00191DV
   Coding: 303143303230303030314A55304C34483053
   VCID: 373E30458EBDA33EF3-8062
   Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
   Component: BF-Gewichtss.  H03 0040
   Serial number: 5850000R1220203FCG
   Serial number: 3575HRB405T17UE4C9N+
   Serial number: 3585HRB405V17UE4D91N
   Serial number: 3515JRB400O4UH6I61LU
   Serial number: 3525JRB400O4UH6I7I1T
   Serial number: 3554VRB405P18E5GA93E
   Serial number: 3564VRB405P18E5GO11J
   Revision: --------    Serial number: 90815LBT0002B
   Coding: 0000BC
   VCID: 373E304586BDA33EF3-8062
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H09 0009
   Serial number: 16 01 2012  33181114
   Part No SW: 4H0 920 980 J    HW: 4H0 920 980 J
   Component: TBenUSAACC--- H71 0416
   Revision: 32081056    Serial number: 658020312592028
   Coding: 0B460801D700D705020000
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU64.rod
   VCID: 3228015165DF4616C4-8066
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1120224000876
   Part No SW: 4H0 907 468 G    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0214
   Revision: --------    Serial number: 00000000435177
   Coding: 00CD075200
   ROD: EV_GatewUDS_AU57.rod
   VCID: 35223A4D94B1512EE1-8060
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650495098
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 A    HW: 8K0 959 663 A
   Serial number: 12054002519011200181
Address 22: AWD (J492)       Labels: 4H0-907-163.clb
   Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
   Component: 4 Wheel Drive H15 0013
   Serial number: 000503120001010
   ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
   VCID: 271EE0055E1D33BE63-8072
0370 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_03_CF_YAWRATE]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0373 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_03_CF_CROSS_ACC]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0359 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_YAWRATE]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0363 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_CROSS_ACC_X]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0366 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_CROSS_ACC_Y]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0377 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [ESP - Steuergerät nicht verfügbar DTC_FRAY_ESP_SYS_STATE]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
   Part No SW: 4H0 919 158 C    HW: 4H0 919 158 C
   Component: Klima Fond    H16 0111
   Coding: 0000000000
   ROD: EV_AirCondiHeck.rod
   VCID: 302C0B596BD37406B2-8064
   Part No SW: 4H0 907 553 E    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0099
   Coding: 008002
   ROD: EV_AirSuspe_VW51.rod
403200 - Function Shut-Off Active
          C10C8 00 [009] - -
                    Reset counter: 142
                    Mileage: 128680 km
                    Date: 2020.05.28
                    Time: 10:44:43
0920 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0666 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0665 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0769 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
   Revision: AA000000    Serial number: 00000025460311
   Coding: C0183B0085057201010001010101112131313333203333
Address 3B: Sensor Elect. (J849)       Labels: None
   Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
   Component: SARA 6D red   H02 0020
   Revision: --------    Serial number: EJ1BPA3700LHXW0
   ASAM Dataset: EV_SARA 009017
   ROD: EV_SARA_009.rod
   VCID: 2D12122D7CE119EE99-8078
Address 3C: Lane Change        Labels: Redir Fail!
   Part No SW: 4H0 907 566 A    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0040
   Revision: 00H02000    Serial number: 6PZ 010 287-07
   VCID: 2E101521B9E762F6A0-807A
   Subsystem 1 - Part No: 4H0 907 568 A
   Component: J770  SWA Slave H02 0040
   Subsystem 2 - Serial number: 6PZ 010 287-27
   Subsystem 3 - Serial number: 5F03.03.1200H020003CX25265ÿ
   Subsystem 4 - Serial number: X25265ÿ
   Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
   Component: TSG FA        H06 0261
   Revision: --------    Serial number: 0000125560872
   Coding: 011F1F005E0062C202003017
   Shop #: WSC 02312 785 00200
   VCID: 3D32226DA481896E29-8068
   Revision: 00002001    Serial number: 0172504001
   Coding: 0106023A00FA7585B0B0C7C4020301000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0080
   Serial number: 00000000000000072182
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.030  H07 0006
   Serial number:     WOO15187646
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2012000000000541128
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS010  H05 0005
   Serial number:     WOO1000NCLV
   Subsystem 6 - Part No SW: 3AA 962 243     HW: 3AA 962 243
   Component: GEB.F.Heckoef  H12 0719
   Serial number: 84228402
   Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
   Component: BOSE-G3-C7    H07 0160
   Revision: CJ007000    Serial number: 00000000040901
   Coding: 030000
   Shop #: WSC 22309 444 94312
   VCID: 1D72C2ED0441E96E09-8048
   Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
   Component: TSG BF        H06 0261
   Revision: --------    Serial number: 0000125584203
   Coding: 011F1F005E0062C202003007
   VCID: 3C342F69BF9B80661E-8068
   Revision: --------    Serial number: 00000000282125
   ROD: EV_ParkiBrake_VW51.rod
463616 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:15
                    Voltage terminal 30: 12.1 V
                    Internal Fault ID: 185
                    Network management state: normal
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    General Inspection Function: not active
                    Internal Parking Brake state: static
                    Status of parking brake button: Not operated
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
   Part No SW: 4H0 035 082 D    HW: 4H0 035 082
   Component: Radio U SIRIU H53 0112
   Revision: AB001007    Serial number: 235BX0C7501569
   Coding: 020007010003000001
   Part No SW: 4H0 035 746 C    HW: 4H0 035 746
   Component: H-BNT-NA      H48 0549
   Revision: --------    Serial number: 035AM0D7511910
   Coding: 020200000001F9EF7D128B1E00000003140001000000000000
   VCID: 281CE3395B033CC66A-807C
   Subsystem 1 - Part No: 8R0 060 884 AD
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4ÿ0 919 604 F
   Component: DU8 D4 SV NB  H47 0021
   Serial number: AUZ8ZDC9300ARXA
   Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0065
   Serial number: 00000000073110
   Subsystem 4 - Part No: 8R0 060 961 B
   Component: CD-Database  3371
01524 - Antenna for Telephone
                    Fault Status: 00101011
                    Reset counter: 180
                    Mileage: 128611 km
                    Date: 2020.05.15
                    Time: 18:42:43
                    Voltage: 13.90 V
   Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
   Component: TSG HL        H06 0262
   Revision: --------    Serial number: 0000125499860
   Coding: 010F1F00400062C202003007
   Part No SW: 4H0 907 441 B    HW: 4H0 907 441 B
   Component: SG Rueckfahrkamera  0161
   Revision: --H05---    Serial number: 525 PA8J21D0XT
   Coding: 1080003
   VCID: 271EE005961D33BE63-8072
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0039
   Revision: 10011001    Serial number: 061201093
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3D32226DAC81896E29-8068
0051 - Hall Sensors in Motor 1 for Rear Lid
          B1211 12 [008] - Short to Plus
                    Fault Frequency: 7
                    Reset counter: 177
                    Mileage: 128627 km
                    Date: 2020.05.16
                    Time: 09:24:01
                    Voltage terminal 30: 14.41 V
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Part No SW: 4H0 907 412     HW: 4H0 907 412
   Component: ALM           H05 0004
   Revision: --------    Serial number: 000000066514
   Coding: 200000
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6386B4156AA59F9E7F-8036
   Component: TSG HR        H06 0262
   Revision: --------    Serial number: 0000125499849
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 D    HW: 4H0 035 774
   Component: H-BN-NA       H48 0550
   Revision: --------    Serial number: 108CU0C7503537
   Coding: 02020000000100400100000400001300E00000000000000000
   VCID: 2A181931450F0ED67C-807E
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDB1200N174
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDB1200N163
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238LC600021
   Subsystem 5 - Part No: 8R0 060 884 AD
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H08 0083
   Revision: 0L0D5013    Serial number: SN120127  0079
   ROD: EV_GSM2x3Mono_AU64.rod
   VCID: 2B161C3542F517DE87-807E
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H25 0036
   Coding: E9060000
   Shop #: WSC 09106 210 01865
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6582AA0D6491E1AE91-8030
0001 - Front Heater for Lane-Holding Assist
          C1101 15 [008] - Open or Short to Plus
                    Reset counter: 183
                    Mileage: 128680 km
                    Date: 2020.05.28
                    Time: 17:05:00
                    Outside air temperature: -26.5 °C
                    Voltage terminal 15: 12.9 V
                    Control Module temperature: 62.0 °C
Address 88: Multicont. Seat Driver (J873)       Labels:* None
   Part No SW: 4H0 907 182 H    HW: 4H0 907 182 H
   Component: IVB           H07 0042
   Serial number: 00005111156702
   Coding: 766FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F2E082576ED6BFEAB-807A
Address 89: Multicont. Seat Pass. (J872)       Labels:* None
   Serial number: 00005111156802
   Coding: 366FF2
   Part No SW: 4H0 907 541 B    HW: 4H0 907 541
   Coding: 7E01020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
   ROD: EV_AdaptCruisContr2AU64X_002.rod
   VCID: 281CE33953033CC66A-807C
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_VDC_FAIL]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 12.034 V
                    Velocity_vehicle_reference: -0.00 m/s
134656 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_AXV_ADJUSTMENT]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
                    Voltage terminal 15: 12.041 V
136192 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_YAW_ADJUSTMENT]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:16
140288 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
          [FAULT_CIS_ECD_FAIL]
                    Reset counter: 179
                    Mileage: 128679 km
                    Date: 2020.05.26
                    Time: 12:02:17
                    Voltage terminal 15: 12.037 V
   Part No SW: 4G0 907 107 D    HW: 4H0 907 107
   Component: BV-SG         H30 0038
   Serial number: 005000051403127
   Coding: 02A19A020111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
0161 - Video Cable for Image Processing
          C1107 02 [009] - Signal Failure
          [No_camera_found_on_startup]
                    Fault Frequency: 34
                    Reset counter: 143
                    Mileage: 128561 km
                    Date: 2020.05.15
                    Time: 16:39:59
                    Outside air temperature: 43.5 °C
                    Voltage terminal 15: 14.3 V
                    Control Module temperature: 54.0 °C
   Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
   Coding: 0066F609031F037E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 312A0E5D60D97D0EBD-8064
   Part No SW: 4H0 980 946 B    HW: 4H0 980 946 B
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End----------(Elapsed Time: 03:35, VBatt start/end: 13.1V/15.1V)-----------
I think might be possible, but won't be at all straightforward. Just look at all the modules that are upset over the fact that the camera and image processing aren't working. In addition, there's a potential liability with coding out a safety feature like braking guard.
Rollux
New Zealand
C?ID=380572
On my 2013 MQB golf it’s not possible as the ACC is a seperate FeC to regular CC - not sure if it’s the same on your A8 but I suspect it may.
Somnus
SLC, USA
C?ID=215931
^^^Rollux, I don't think this is a retrofit, as the VIN pulls up 8T4 - Adaptive Cruise Control.
But you are right about it being a FEC on the MQB platform
I don't think it's an FEC on that A8. I believe the D4 A8 pre-dates the introduction of FECs, but I'm not 100% certain.
