Results 1 to 5 of 5
Thread: 2013 A8 ACC issue, possible to code out ACC while keeping traditional CC?
    May 2020
    2013 A8L 3.0, came in with complaint "ACC and braking guard unavailable" displays on cluster when attempting to activate cruise control. Verified complaint, adaptive cruise is not working. Upon investigation, found aftermarket windshield installed, the heater strip for front camera is loosely attached to the window. Looks like some monkeys installed it, previous owner was probably trying to save a few bucks (can't blame them.) I think a good start would be to try plugging a new cable in to see if that works (there is a fault for the video cable) but if that doesn't do it, I would recommend installing a factory windshield and ACC alignment at the local dealership. Assuming the cable does not fix the issue, and the car does need a windshield and ACC alignment, I think we would rather try coding the ACC and braking guard features out, if that's even possible. Does anybody have experience with this type of "fix"? I would appreciate any input or ideas. Thanks
    Thursday,28,May,2020,18:32:34:61479
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    VIN: WAURGAFD5DN000911   License Plate:
    Chassis Type: FD-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 22 28 34 36 3B 3C
              42 46 47 52 53 56 5F 62 6C 6D 6F 72 7F 81 85 88 89 8B 8E 8F
              90
    VIN: WAURGAFD5DN000911   Mileage: 128680km-79958miles
    7F-Inform. Electr. II -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4H0 907 551 G    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0005
       Revision: --H07---
       Coding: 0A2A0034056E01060000
       Shop #: WSC 02313 785 00200
       ASAM Dataset: EV_ECM30TFS0214H0907551G 001006
       ROD: EV_ECM30TFS0214H0907551G.rod
       VCID: 2E10152171E762F6A0-807A
       Part No SW: 4H1 927 158 AR    HW: 0BK 927 156 AG
       Component: 0BK 30TFSIUSA H16 1005
       Revision: --H16---
       Coding: 000002
       ASAM Dataset: EV_TCMALX51011 002018
       ROD: EV_TCMALX51011_002_AU64.rod
       VCID: 004C9B999BF3248602-8054
       Part No SW: 4H0 907 379 E    HW: 4H0 907 379 E
       Component: ESP PREMIUM   H10 0352
       Coding: 80EDF30001B7CF00E200
       ASAM Dataset: EV_ESPPremi 005013
       ROD: EV_ESPPremi_005_AU64.rod
       VCID: 342407499FCB4826D6-8060
    8 Faults Found:
    0679 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [Net_QSP_02_QSP_Ist_Moment]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 2A
                        F-Type: 2E
                        Uz: 96
    0695 - Tire Pressure Warning
              C102D 00 [009] - -
                        Fault Frequency: 23
                        Reset counter: 142
                        Mileage: 128561 km
                        Date: 2020.05.15
                        Time: 16:40:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 47
                        F-Type: 0C
                        Uz: B2
    0718 - Tire Pressure Warning
              C102D 00 [009] - -
                        Fault Frequency: 23
                        Reset counter: 142
                        Mileage: 128561 km
                        Date: 2020.05.15
                        Time: 16:40:10
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 47
                        F-Type: 03
                        Uz: B2
    0736 - Function Restriction due to Faults in Other Modules
              U1113 00 [136] - -
              [Net_SARA_03_Accel_Y_b_red_not_calibrated]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 43
                        F-Type: 3F
                        Uz: 96
    0737 - Function Restriction due to Faults in Other Modules
              U1113 00 [136] - -
              [Net_SARA_03_Omega_Z_b_red_not_calibrated]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 46
                        F-Type: 3F
                        Uz: 96
    0738 - Function Restriction due to Faults in Other Modules
              U1113 00 [136] - -
              [Net_SARA_06_Accel_X_010_not_calibrated]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 23
                        F-Type: 3F
                        Uz: 96
    0739 - Function Restriction due to Faults in Other Modules
              U1113 00 [136] - -
              [Net_SARA_06_Accel_Y_010_not_calibrated]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 1A
                        F-Type: 3F
                        Uz: 96
    0740 - Function Restriction due to Faults in Other Modules
              U1113 00 [136] - -
              [Net_SARA_06_Omega_Z_010_not_calibrated]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 00
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 1B
                        F-Type: 3F
                        Uz: 96
       Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 BD
       Component: BCM2 2.0      H31 0510
       Coding: 0DA72006000000000000
       VCID: 6E90D521B96722F6E0-803A
       Serial number: 2312000002492016
       Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
       Revision: AA000000    Serial number: 00000025490837
       Coding: C018320085047201010001010101112131313333283333
       VCID: 35223A4D9CB1512EE1-8060
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 H    HW: 4H0 820 043 H
       Component: Klima 4 Zonen H20 0110
       Coding: 660122786C
       VCID: 2502EA0D241121AE51-8070
    0137 - Motor for  Right Side Window Defrost Flap
              B10D8 22 [008] - Signal Amplitude Too High
                        Fault Frequency: 27
                        Reset counter: 183
                        Mileage: 128561 km
                        Date: 2020.05.15
                        Time: 16:40:16
       Part No SW: 4H0 907 063 BP    HW: 4H0 907 063
       Component: BCM1 2.0      H12 0111
       Revision: 11012002    Serial number: 00000001432529
       Coding: 09072091073C9FE3AB000804A0003800009CD308860001218001085C3B00
       VCID: 77BEF045C63D633E33-8022
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 120202  H35 0080
       Serial number:         120218192609
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10231911
       Coding: 025523
       Component: E1 - LDS  H07 0044
       Serial number: 09 03 2012  00000326
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R18LQ02
       Serial number: 00000012031200010718
       Coding: 100000
       Serial number: 00000012031200010888
       Coding: 100000
       Subsystem 7 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA102747000000903108
       Coding: 020300
       Serial number: 1B084C16000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 E    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0190
       Revision: AA001001
       Coding: 020000
       VCID: 2208F1113D3FD69634-8076
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901206901412
       Coding: 280B02
       ROD: EV_EPHVA18AU57X0000_002_AU64.rod
       VCID: 3B362C75B295875E17-806E
       Part No SW: 4H0 907 561 B    HW: 4H0 907 561
       Component: ACC3          H17 0400
       Coding: 7E01020201
       ASAM Dataset: EV_AdaptCruisContrAU64X 002021
       ROD: EV_AdaptCruisContrAU64X_002.rod
       VCID: 2A1819314D0F0ED67C-807E
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FAULT_CIS_VIDEO_FAIL]
                        Fault Frequency: 18
                        Reset counter: 143
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:17:44
                        Control Module temperature: 46 °C
                        Voltage terminal 15: 14.319 V
                        Velocity_vehicle_reference: -0.01 m/s
       Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
       Component: Airbag10.43   H44 0041
       Revision: --------    Serial number: 003JS00191DV
       Coding: 303143303230303030314A55304C34483053
       VCID: 373E30458EBDA33EF3-8062
       Subsystem 1 - Part No SW: 4H0 959 339 A    HW: 4H0 959 339 A
       Component: BF-Gewichtss.  H03 0040
       Serial number: 5850000R1220203FCG
       Serial number: 3575HRB405T17UE4C9N+
       Serial number: 3585HRB405V17UE4D91N
       Serial number: 3515JRB400O4UH6I61LU
       Serial number: 3525JRB400O4UH6I7I1T
       Serial number: 3554VRB405P18E5GA93E
       Serial number: 3564VRB405P18E5GO11J
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90815LBT0002B
       Coding: 0000BC
       VCID: 373E304586BDA33EF3-8062
       Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
       Component: E221 - MFL  H09 0009
       Serial number: 16 01 2012  33181114
       Part No SW: 4H0 920 980 J    HW: 4H0 920 980 J
       Component: TBenUSAACC--- H71 0416
       Revision: 32081056    Serial number: 658020312592028
       Coding: 0B460801D700D705020000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU64.rod
       VCID: 3228015165DF4616C4-8066
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
       Component: Analoguhr D4  H05 0224
       Serial number: 1120224000876
       Part No SW: 4H0 907 468 G    HW: 4H0 907 468 C
       Component: J533--Gateway H08 0214
       Revision: --------    Serial number: 00000000435177
       Coding: 00CD075200
       ROD: EV_GatewUDS_AU57.rod
       VCID: 35223A4D94B1512EE1-8060
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650495098
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 A    HW: 8K0 959 663 A
       Serial number: 12054002519011200181
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H15 0013
       Serial number: 000503120001010
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       VCID: 271EE0055E1D33BE63-8072
    6 Faults Found:
    0370 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_03_CF_YAWRATE]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0373 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_03_CF_CROSS_ACC]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0359 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_YAWRATE]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0363 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_CROSS_ACC_X]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0366 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [SARA Bitte Fehlerspeicher auslesen DTC_FRAY_SARA_06_CF_CROSS_ACC_Y]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0377 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [ESP - Steuergerät nicht verfügbar DTC_FRAY_ESP_SYS_STATE]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 C    HW: 4H0 919 158 C
       Component: Klima Fond    H16 0111
       Coding: 0000000000
       ROD: EV_AirCondiHeck.rod
       VCID: 302C0B596BD37406B2-8064
       Part No SW: 4H0 907 553 E    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H17 0099
       Coding: 008002
       ROD: EV_AirSuspe_VW51.rod
    6 Faults Found:
              C10C8 00 [009] - -
                        Reset counter: 142
                        Mileage: 128680 km
                        Date: 2020.05.28
                        Time: 10:44:43
    0920 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0666 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0665 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0769 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    0648 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
       Revision: AA000000    Serial number: 00000025460311
       Coding: C0183B0085057201010001010101112131313333203333
       Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
       Component: SARA 6D red   H02 0020
       Revision: --------    Serial number: EJ1BPA3700LHXW0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 2D12122D7CE119EE99-8078
       Part No SW: 4H0 907 566 A    HW: 4G0 907 566
       Component: J769  SWA MasterH02 0040
       Revision: 00H02000    Serial number: 6PZ 010 287-07
       VCID: 2E101521B9E762F6A0-807A
       Subsystem 1 - Part No: 4H0 907 568 A
       Component: J770  SWA Slave H02 0040
       Subsystem 2 - Serial number: 6PZ 010 287-27
       Subsystem 3 - Serial number: 5F03.03.1200H020003CX25265˙
       Subsystem 4 - Serial number: X25265˙
       Part No SW: 4H0 959 793 G    HW: 4H0 959 793 G
       Component: TSG FA        H06 0261
       Revision: --------    Serial number: 0000125560872
       Coding: 011F1F005E0062C202003017
       Shop #: WSC 02312 785 00200
       VCID: 3D32226DA481896E29-8068
       Revision: 00002001    Serial number: 0172504001
       Coding: 0106023A00FA7585B0B0C7C4020301000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0080
       Serial number: 00000000000000072182
       Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.030  H07 0006
       Serial number:     WOO15187646
       Coding: 020200
       Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
       Component: Dachelektroni  H11 0080
       Serial number: A2012000000000541128
       Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS010  H05 0005
       Serial number:     WOO1000NCLV
       Subsystem 6 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84228402
       Revision: CJ007000    Serial number: 00000000040901
       Coding: 030000
       Shop #: WSC 22309 444 94312
       VCID: 1D72C2ED0441E96E09-8048
       Part No SW: 4H0 959 792 G    HW: 4H0 959 792 G
       Component: TSG BF        H06 0261
       Revision: --------    Serial number: 0000125584203
       Coding: 011F1F005E0062C202003007
       VCID: 3C342F69BF9B80661E-8068
       Revision: --------    Serial number: 00000000282125
       ROD: EV_ParkiBrake_VW51.rod
    463616 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FC_SIGNAL_ESP_QBIT_LAENGSBESCHLEUNIGUNG_QBIT]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:15
                        Voltage terminal 30: 12.1 V
                        Internal Fault ID: 185
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
       Part No SW: 4H0 035 082 D    HW: 4H0 035 082
       Component: Radio U SIRIU H53 0112
       Revision: AB001007    Serial number: 235BX0C7501569
       Coding: 020007010003000001
       Part No SW: 4H0 035 746 C    HW: 4H0 035 746
       Component: H-BNT-NA      H48 0549
       Revision: --------    Serial number: 035AM0D7511910
       Coding: 020200000001F9EF7D128B1E00000003140001000000000000
       VCID: 281CE3395B033CC66A-807C
       Component: NAR 2011  0505
       Subsystem 2 - Part No SW: 4H0 919 604 F    HW: 4˙0 919 604 F
       Component: DU8 D4 SV NB  H47 0021
       Serial number: AUZ8ZDC9300ARXA
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000073110
       Component: CD-Database  3371
    01524 - Antenna for Telephone
                        Fault Status: 00101011
                        Reset counter: 180
                        Mileage: 128611 km
                        Date: 2020.05.15
                        Time: 18:42:43
                        Voltage: 13.90 V
       Part No SW: 4H0 959 795 D    HW: 4H0 959 795 D
       Component: TSG HL        H06 0262
       Revision: --------    Serial number: 0000125499860
       Coding: 010F1F00400062C202003007
       Part No SW: 4H0 907 441 B    HW: 4H0 907 441 B
       Component: SG Rueckfahrkamera  0161
       Revision: --H05---    Serial number: 525 PA8J21D0XT
       Coding: 1080003
       VCID: 271EE005961D33BE63-8072
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 R    HW: 4H0 959 107 M
       Component: HDSG-Modul    H11 0039
       Revision: 10011001    Serial number: 061201093
       Coding: 0210044100
       ROD: EV_DeckLidContrUnit.rod
       VCID: 3D32226DAC81896E29-8068
    0051 - Hall Sensors in Motor 1 for Rear Lid
              B1211 12 [008] - Short to Plus
                        Fault Frequency: 7
                        Reset counter: 177
                        Mileage: 128627 km
                        Date: 2020.05.16
                        Time: 09:24:01
                        Voltage terminal 30: 14.41 V
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000066514
       Coding: 200000
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 6386B4156AA59F9E7F-8036
       Component: TSG HR        H06 0262
       Revision: --------    Serial number: 0000125499849
    Address 7F: Inform. Electr. II (J829)       Labels: None
       Part No SW: 4H0 035 774 D    HW: 4H0 035 774
       Component: H-BN-NA       H48 0550
       Revision: --------    Serial number: 108CU0C7503537
       Coding: 02020000000100400100000400001300E00000000000000000
       VCID: 2A181931450F0ED67C-807E
       Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
       Component: DU10 RSE  H41 0021
       Serial number: AUZ8ZDB1200N174
       Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
       Serial number: AUZ8ZDB1200N163
       Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
       Component: E499 BDT 2  H07 0019
       Serial number: 90238LC600021
       Subsystem 5 - Part No: 8R0 060 884 AD
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
       Component: GSM-LL        H08 0083
       Revision: 0L0D5013    Serial number: SN120127  0079
       ROD: EV_GSM2x3Mono_AU64.rod
       VCID: 2B161C3542F517DE87-807E
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H25 0036
       Coding: E9060000
       Shop #: WSC 09106 210 01865
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 6582AA0D6491E1AE91-8030
    0001 - Front Heater for Lane-Holding Assist
              C1101 15 [008] - Open or Short to Plus
                        Reset counter: 183
                        Mileage: 128680 km
                        Date: 2020.05.28
                        Time: 17:05:00
                        Outside air temperature: -26.5 °C
                        Voltage terminal 15: 12.9 V
                        Control Module temperature: 62.0 °C
       Serial number: 00005111156702
       Coding: 766FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 2F2E082576ED6BFEAB-807A
       Serial number: 00005111156802
       Coding: 366FF2
       Part No SW: 4H0 907 541 B    HW: 4H0 907 541
       Coding: 7E01020201
       ASAM Dataset: EV_AdaptCruisContr2AU64X 002018
       ROD: EV_AdaptCruisContr2AU64X_002.rod
       VCID: 281CE33953033CC66A-807C
    105472 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_VDC_FAIL]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        Control Module temperature: 38 °C
                        Voltage terminal 15: 12.034 V
                        Velocity_vehicle_reference: -0.00 m/s
    134656 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_AXV_ADJUSTMENT]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
                        Voltage terminal 15: 12.041 V
    136192 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_YAW_ADJUSTMENT]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:16
    140288 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_ECD_FAIL]
                        Reset counter: 179
                        Mileage: 128679 km
                        Date: 2020.05.26
                        Time: 12:02:17
                        Voltage terminal 15: 12.037 V
       Part No SW: 4G0 907 107 D    HW: 4H0 907 107
       Component: BV-SG         H30 0038
       Serial number: 005000051403127
       Coding: 02A19A020111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
    0161 - Video Cable for Image Processing
              C1107 02 [009] - Signal Failure
              [No_camera_found_on_startup]
                        Fault Frequency: 34
                        Reset counter: 143
                        Mileage: 128561 km
                        Date: 2020.05.15
                        Time: 16:39:59
                        Outside air temperature: 43.5 °C
                        Voltage terminal 15: 14.3 V
                        Control Module temperature: 54.0 °C
       Part No SW: 4H0 980 945 B    HW: 4H0 980 945 B
       Coding: 0066F609031F037E070308014240C2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L_VW51.rod
       VCID: 312A0E5D60D97D0EBD-8064
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R_VW51.rod
    End----------(Elapsed Time: 03:35, VBatt start/end: 13.1V/15.1V)-----------
    I think might be possible, but won't be at all straightforward. Just look at all the modules that are upset over the fact that the camera and image processing aren't working. In addition, there's a potential liability with coding out a safety feature like braking guard.
    Feb 2020
    New Zealand
    On my 2013 MQB golf it’s not possible as the ACC is a seperate FeC to regular CC - not sure if it’s the same on your A8 but I suspect it may.
  4. Likes PetrolDave liked this post
    Feb 2018
    SLC
    ^^^Rollux, I don't think this is a retrofit, as the VIN pulls up 8T4 - Adaptive Cruise Control.
    But you are right about it being a FEC on the MQB platform
    If you are curious about the MK100 ABS controller's Bits and Bytes >>MK100 ABS Coding (Google Drive)<< NOT 100% ACCURATE, INFORMATION ONLY
    I don't think it's an FEC on that A8. I believe the D4 A8 pre-dates the introduction of FECs, but I'm not 100% certain.
