Gateway not supported
Devagman
C?ID=405793
Hi VAG friends,
I receive the hex v2 yesterday (i’m new not a upgrade) from randstadcarsolutions which is the official dealer from the benelux. I have registrated the vcds and it shows valid when i click the about button, i try to connect it on multiple cars and still everytime the same “gateway not supported” and can gateway 19 said no controller found. I tried everything even the usb drivers & settings.
On my car the test is all oke and ready to use And the volt is 12.5v i also tried with idle on, engine hood open everthing (golf 7 gti 2013 5G/AU)
I want to use it so badddd and now its not possible
Please help me out
Greets
Jerry
Please plug it into your Golf 7 and tell/show us exactly what you get when you do [Options] -> [Test].
Also tell us what other cars you have tested it on.
Devagman
C?ID=405793
Portstatus: OK
Interface: Found!
Type: HEX-V2
Version:
CB: 0.4513.4
FW: 0.256
Status: Ready
CAN: Testing, K1: OK, K2: OK
VBat: 12,17V, VIgn: 12,17V
This is the result when I test
"CAN: Testing" is not good. That's an indication it can't communicate with your car's gateway.
If it does this in multiple cars that are new enough to have CAN gateways, you may have a defective interface.
Devagman
C?ID=405793
Yes the audi and polo from 2011, and 2009, so you think its the Hex v2 itself?
If it's the same in all of these cars, then I would guess so.
I have sent an e-mail to your distributor with a link to this thread. I suggest you contact him too. I am confident he will make it right for you.
Dana
Western PA, USA
Hi Jerry,
I replied to your e-mail with one last suggestion (debug level 1024) before you send the interface to your distributor.
Best,
Dana
Devagman
C?ID=405793
Hi Dana,
I tried this right now and still the same results, nothing different pops up.
Greets,
Jerry
Devagman
C?ID=405793
I also see that from the 16 port,(hex v2 interface) the 2 in the mid or sticking out and the rest of the 14 or on the same place/angle..is this how it should be?
NEtech
C?ID=56995
Yes that is correct, that it is Ground / Negative pins.
Bruce
Near Philadelphia, PA, USA
They are purposely longer so that when you plug in, they are the first to make contact. They are longer so that when you unplug, they are the last to make contact. The electronics in the interface are always at the ground (-) potential of the vehicle so nothing in the interface gets zapped!
Dana
Western PA, USA
Hi Dana,
Greets,
Jerry
Thanks for debugging. When you have a moment please send the resulting files located in C:\Ross-Tech\VCDS\Debug for review. If they don't reveal the problem we will let you know so you can move forward working with your distributor.
Devagman
C?ID=405793
it was the cable! they send me a new one and everything worked fine! but it ask me to register before 15 uses again! Do i need to register again?
Yes. Registration data is stored in the cable itself, so it does need to be registered.
