Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Gateway not supported
    Near Philadelphia, PA, USA
    Yes that is correct, that it is Ground / Negative pins.
    They are purposely longer so that when you plug in, they are the first to make contact. They are longer so that when you unplug, they are the last to make contact. The electronics in the interface are always at the ground (-) potential of the vehicle so nothing in the interface gets zapped!
  2. Likes Uwe liked this post
  3. #12
    United States
    Quote Originally Posted by Devagman View Post
    Hi Dana,
    I tried this right now and still the same results, nothing different pops up.
    Greets,
    Jerry
    Thanks for debugging. When you have a moment please send the resulting files located in C:\Ross-Tech\VCDS\Debug for review. If they don't reveal the problem we will let you know so you can move forward working with your distributor.
  4. Likes Uwe liked this post
  5. #13
    May 2020
    it was the cable! they send me a new one and everything worked fine! but it ask me to register before 15 uses again! Do i need to register again?
  6. Likes Uwe liked this post
  7. #14
    Yes. Registration data is stored in the cable itself, so it does need to be registered.
