GRA-CCS Retrofit VW Polo 6R 2015 problem coding
bila
CZ
C?ID=48629
Hi, can you help me with this error?
I think problem will be coding ABS or DSG ?
Under text, log from car...
Windows Based VAG/VAS Emulator Running on Windows 7 x64
 VCDS Version: Release 20.4.0(x64) Data version: 20200331 DS317.0
  VIN: WVWZZZ6RZFY272789 Mileage: 26394km-16400miles
 Dealer/Shop Name: B-CARS
 Workshop Code: 123 05701 005701
Self-Diagnosis Log
 Monday,25,May,2020,21:00:36:58466
 VIN: WVWZZZ6RZFY272789 License Plate: XXXXX
 Chassis Type: 6R-VW26 (6C0)
Mileage: 26394km-16400mi Repair Order:
  Scan: 01 02 03 08 09 15 17 19 44 5F
 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000
 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000
CAN Converter 01:
 Address 01: Engine (J623-CJZC) Labels:. 04E-907-309-V1.clb
 Part No SW: 04E 906 027 BB HW: 04E 907 309 AF
 Component: 1.2l R4 TSI H21 8228
 Revision: R4H21---
 Coding: 01250012232411080000
 Shop #: WSC 05701 123 05701
 ASAM Dataset: EV_ECM12TFS01104E906027BB 001006
 ROD: EV_ECM12TFS01104E906027BB.rod
 VCID: E582D5DBE48524AE11-80B0
 17149 - Check Coding of ECUs on Powertrain Data Bus
 P1647 00 [167] - -
 [Checking coding/versions ofcontrol modules in drivetrain]
 Mileage: 26394 km
 Date: 2020.05.25
 Time: 00:17:41
 Coolant temperature: 49 °C
 Intake air temperature: 37 °C
 Voltage terminal 30: 11.072 V
 Mass flow through throttle valve: 0.0 kg/h
 Readiness: 1110 0001
Self-Diagnosis Log
 Page 2
Self-Diagnosis Log
Page 3
 PartNoSW:0CW300046P HW:0AM927769K
 Component: GSG DQ200-MQB H43 6220
 Revision: 00043014 Serial number: CU501502026349
 Shop #: WSC 00788 648 00255
 ROD: EV_TCMDQ200021_VW26.rod
 VCID: C7DE3F537E4916BE03-8092
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
 Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
 Component: ESP9.0i H03 0003
 Serial number: 08502556150208
 Coding: 21DD2885892A33C2111B1071005A841491CC88080005CB098F00
 ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
 VCID: B3267B831AD18A1E4F-80E6
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
 PartNoSW:6C0820045A HW:6C0820045A
 Component: AC Manuell    H03 0108
 Serial number: 1502091B-1120
 Coding: 200000001000100000
 ROD: EV_ACManueKMMValeoPQ26.rod
 VCID: 9D72BD3B8C552C6E89-80C8
Self-Diagnosis Log
 Page 4
 Address 09: Cent. Elect. (J519) Labels:* Redir Fail!
 Part No SW: 6C0 937 087 B    HW: 6C0 937 087
 Component: BCM PQ26 Me4R H07 0065
 Serial number: 001088030212
 Coding: 000018404253005B4B844000400703081000590251010000000000000000
 ASAM Dataset: EV_BCMA0 004008
 ROD: EV_MQBA0.rod
 VCID: AD126DFBFCF5DCEE19-80F8
 Drivers Door Control Module:
 Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
 Component: J386__TSG_FT 003 8612
 Serial number: KU0KU028011550284170
 Coding: 0400A0
 Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
 Component: J387__TSG_BT 003 8612
 Serial number: KU0KU026011550264500
 Coding: 1400A0
 Subsystem 3 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
 Component: J388__TSG_HL 003 8611
 Serial number: KU0KU008021550390528
 Coding: 0400A0
 Subsystem 4 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
 Component: J389__TSG_HR 003 8611
 Serial number: KU0KU002021550334887
 Coding: 1400A0
Component: SideSensor_Df 151 0800 Serial number: 3575H00A718F7F9301E+
Subsystem 2 - Part No SW: ----------- HW: 410 822 601 15
Self-Diagnosis Log
 Page 5
 Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
 PartNoSW:6C0959655A HW:6C0959655A
 Component: VW20Airbag00Z 001 0330
 Revision: -------- Serial number: 003LM0090JK8
 Coding: 88C0C000000000005C000000000800000000
 ROD: EV_AirbaVW20BPAVW26X.rod VCID: B12A718BE0CDB80E3D-80E4
 Subsystem 1 - Part No SW: ----------- HW: 410 822 601 15
  Component: SideSensor_Pf 151 0800 Serial number: 3585H000628BA47310EI
 Subsystem 3 - Part No SW: ----------- HW: 442 151 102 15
 Component: SideSensor_Dr 1CA 0148 Serial number: 3517A00A1183C040933.
 Subsystem 4 - Part No SW: ----------- HW: 442 151 202 15
 Component: SideSensor_Pr 1CA 0148 Serial number: 3527A00AF18F2620D18M
 PartNoSW:6C0920730A HW:6C0920730A
 Component: KOMBI         110 0290
 Coding: 0725090821000008000808000000000000000000
 VCID: 9F0E873386593E7E9B-80CA
Self-Diagnosis Log
 Page 6
 Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
 Part No SW: 6C0 909 901     HW: 6C0 937 087
 Component: GW MQB A0     H07 0065
 Revision: -------- Serial number: 001088030212
 Coding: 030000047F0A560071000000000000010001010000000000000000000000
 ASAM Dataset: EV_GatewA0Lear 001001
 ROD: EV_GatewA0Lear_001_VW26.rod
 Subsystem 1 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
 Component: J367-BDM H08 0223
 Serial number: 52044J17082821557867
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
 Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
 Component: EPS_TRW_ALow 313 3232
 Serial number: CGA10922
 Coding: 000700
 Shop #: WSC 53768 002 1048576
 ASAM Dataset: EV_SteerAssisUDSTRW 016026
 ROD: EV_SteerAssisUDSTRW.rod
 VCID: ED92ADFB3C751CEE59-80B8
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
 PartNoSW:6C0035869B HW:6C0035869B
 Component: MU-E--ER 820 6230
 Serial number: 15121400010208
 Coding: 02620000BE00000041110001000000001F0000840000010001
 ASAM Dataset: EV_MUEnt4CGen2LGE 001017
 ROD: EV_MUEnt4CGen2LGE_VW26.rod
 VCID: AA1866E7CD1BCBD6FC-80FE
End----------(Elapsed Time: 00:43, VBatt start/end: 13.2V/13.2V)-----------
Admin Note: Please do not use the [Print] function in VCDS to post data here. The formatting for a sheet-fed printer is less than optimal here. Please post the native text that VCDS produces, either by using the [Copy] function in VCDS, or by opening a saved file with Notepad and pasting the contents here.
bila
CZ
C?ID=48629
Some idea ?
AINils
Germany (AIB)
C?ID=56975
CCS is SWAP based feature in Polo 6C. So you have to buy SWAP code and your dealer have to activate it with ODIS Online
bila
CZ
C?ID=48629
Yes, I know it.. but we have same car with same engine, abs, dsg and other unit same.. I cannot coding ABS unit, same HW and SW number and unit send me "reject coding".. do you know what I can do with this?
I hope it will be only in abs ...
golfi_vend
Tartu, Estonia
C?ID=195131
You can't code cruise on this model....period.
bila
CZ
C?ID=48629
Are you sure? Why
