Results 1 to 4 of 4
Thread: vw crafter van unable to access security to do DPF UK
    May 2020
    Chassis Type: 2F (2F - VW Crafter Chassis Cab (LT3 / 2006 > 2016))
    Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
              B0 B1 B2 B3 B4 B5 B6 C1
    VIN: WV1ZZZ2FZA7007031
    Address 91: LT3 Engine        Labels: Redir Fail!
       Part No SW: 076 906 022 P    HW: 076 906 022 G
       Component: R5 2,5L EDC A020SG  9022
       Revision: 24H34---    Serial number: VWXDZ0J1011348
       Coding: 0003032
       Shop #: WSC 60259 001 1048576
       VCID: 2019E65FE6C8BFCB73B-8074
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Load: 0.0 %
                        Voltage: 0.00 V
                        Hex Value: 0xFF00
                        Bin. Bits: 00000000
                        Temperature: -90.0C
    001378 - System Voltage
                   P0562 - 000 - Too Low - Intermittent
                        Voltage: 13.91 V
                        Temperature: -90.0C
                        Temperature: -90.0C
                        Absolute Pres.: 0.0 mbar
                        Torque: 0.0 Nm
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
       Component: IMMO          0805  0815
       Revision: 00805000    Serial number: VWXDZ0J1011348
       VCID: 6D87CF6B619AA2A388D-8038
    Address 94: LT3 Airbag
       Part No HW: 9064461442
       Shop #: WSC 00118 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3331.rod (*)
       VCID: 55F7878BE58A0A6350D-8000
    Address 95: LT3 ESP
       Part No SW: 9069022800    HW: 0004460153
       ASAM Dataset: 3 4101
       ROD: CRFT_ESP_3_36946.rod (*)
       VCID: 04518ACF5E9043EB773-8050
    4296 - Voltage supply: Open circuit
                MIL ON - Test Complete - Stored
    4283 - Voltage supply: Lower limit not reached
    Address 96: LT3 Instruments
       Part No SW: 9069026400    HW: 9069012000
       ASAM Dataset: 32 787
       ROD: CRFT_KOMBI_32_787.rod
    Address 99: LT3 Ign. Switch
       Part No HW: 9065455808
       ASAM Dataset: 67 257
       ROD: CRFT_EZS_67_257.rod (*)
    9001 - Voltage: Lower limit not reached
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0805  0815
       Revision: 00805000    Serial number: 12345678901234
       Shop #: WSC 53558 001 1048576
    00172 - Key 2 not learned
                002 - Lower Limit Exceeded
    Address 9B: LT3 Driver Door
       Part No HW: 9068204126
       ASAM Dataset: 33 773
       ROD: CRFT_FTUHR_33_773.rod (*)
    9021 - Voltage: Lower limit not reached
    Address B0: LT3 Roof Display
       Part No SW: 9069021000    HW: 9069010900
       ASAM Dataset: 21 3
       ROD: CRFT_DBE_21_3.rod (*)
       VCID: 7BA3F133236E3C13069-802E
    9090 - Interior monitoring: Data wire short circuit
                Test Complete - Active/Stored
    Address B1: LT3 Upper Console
       Part No HW: 9065453907
       ASAM Dataset: 67 3
       ROD: CRFT1_OBF_67_3.rod (*)
    9036 - Supply voltage: Limit value exceeded
    9021 - Instrument Cluster Control Module (J285): No communication
    Address B4: LT3 Central Elec.
       Part No SW: 9064420700    HW: 9065453601
       ASAM Dataset: 33 260
       ROD: CRFT_EZE_33_260.rod (*)
    90A6 - Fuel level sensor: Short to Plus
    9021 - Bulb for Right Taillamp (M2): Short to GND
    9036 - Bulb for right brake light (M10): Short to GND
    9039 - Back-up lights: Short to GND
    9093 - Voltage: Lower limit not reached
    90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
    Address B6: LT3 Steering Wheel
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 065590C768AC71FB697-8052
    End----------(Elapsed Time: 01:15, VBatt start/end: 12.6V/12.5V)-----------
    May 2020
    VCDS Version: 20.4.1.0 (x64) HEX-V2 CB: 0.4508.4
    VIN: WV1ZZZ2FZA7007031 License Plate:
    Mileage: Repair Order: egr
    Mode 03: Emission related fault codes
    Address 7E8: 3 Faults Found:
    P2BAD - NOx Emissions Exceeded: Unknown Cause
    P2BAB - NOx Emissions Exceeded: Incorrect EGR Flow
    P2BAC - NOx Emissions Exceeded: Deactivation of EGR
    May 2020
    EGR ERROR CODES VW CRAFTER VAN UK
    None of these faults indicate a problem with the DPF.
    PS: Threads merged.
