Results 1 to 3 of 3
Thread: Audi tt power steering angle fault
    Oct 2016
    could someone help with this fault. abs light and steering yellow light. steering is stiff. faults for steering angle in abs. i have done steering angle reset and it programs sucessfull, but fault remains. i have changed steering angle sensor, steering module and abs module and ignition switch. i have done numerous attempts to program angle sensor while driving following all instructions from rosstech, but fault exists. all fuses checked and all part numbers checked with audi. can anyone help with this fault please. ignore radio faults is missing and airbag faults because been stripped to change parts.scan attached
    Wednesday,06,May,2020,13:39:39:28694
    Dealer/Shop Name: autoelec
    VIN: TRUZZZ8J181024074   License Plate: HG57OOX
    Mileage: 240210km-149259mi   Repair Order: AUDI TT
    Chassis Type: 8J (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56
    VIN: TRUZZZ8J181024074   Mileage: 240210km-149259miles
       Part No SW: 8J0 907 115 N    HW: 8J0 907 115
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH16---    Serial number: AUX7Z0G8FNE0NN
       Coding: 0113000318070060
       Shop #: WSC 01236 785 00200
       VCID: 372B2CB3B34A85DF38D-8062
    Readiness: 0110 0001
    Address 03: ABS Brakes        Labels: 8J0-614-517.clb
       Part No SW: 8J0 614 517     HW: 8J0 614 517
       Component: ESP MK60E1          0130
       Revision: 00H52001
       Coding: 0017424
       Shop #: WSC 01236 758 00200
       VCID: 6A8DC5C7B078E837773-803E
                        Reset counter: 48
                        Mileage: 240211 km
                        Date: 2020.02.22
                        Time: 03:20:15
                        Count: 192
                        Count: 12545
                        Count: 297
                        Count: 47616
       Part No SW: 8J0 820 043 AF    HW: 8J0 820 043 AF
       Component: J255  Klima 1 Zone  0080
       Revision: 00H07004    Serial number: 00000001061493
       Coding: 1573892
    01273 - Fresh Air Blower (V2)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 48
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:08:15
                        Temperature: 11.0C
                        (no units): 210.0
                        (no units): 230.0
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 K    HW: 8P0 907 279 K
       Component: Bordnetz-SG     H54 2501
       Revision: 00H54000    Serial number: 00000007652611
       Coding: 01040E8280141C00471800001800000000085E075C210802000000000000
       VCID: 45D7567BF9A6E74FBA1-8010
       Subsystem 1 - Part No: 8J2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer AU354   H08 0060
       Coding: 00064784
       Shop #: WSC 01236
    01800 - Light Switch (E1)
                        Reset counter: 48
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:08:00
                        Voltage: 11.50 V
    Address 15: Airbags        Labels: 8J0-959-655.lbl
       Part No SW: 8J0 959 655     HW: 8J0 959 655
       Component: -t Airbag 9.43  H02 0020
       Revision: 93H02002    Serial number: 0036K001Y6C$
       Coding: 0011636
       VCID: 79AFEA8BC5DE53AF8E9-802C
       Subsystem 1 - Serial number: 6332DRB405D48995-
       Subsystem 2 - Serial number: 6342DRB405C9D091X
       Subsystem 3 - Serial number: 63747RB402E9BD91%
                        Fault Status: 11100001
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:08:22
    01587 - Igniter 2 for Airbag; Drivers Side (N250)
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:08:22
    01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
                009 - Open or Short to Ground - MIL ON
                        Fault Status: 11101001
                        Reset counter: 48
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:08:24
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
                        Fault Status: 11101010
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:17:06
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:17:06
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Component: J0527           H36 0070
       Coding: 0000011
       Shop #: WSC 01236 551 00000
       VCID: 41DF426BED8ECB6F869-8014
    Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
       Part No SW: 8J0 920 980 E    HW: 8J0 920 980 E
       Component: KOMBIINSTR. VDO H22 0130
       Revision: D0H22001    Serial number: 2248G001007064
       Coding: 0004428
       Shop #: WSC 01223 210 00003
       VCID: 333318A3A73269FF045-8066
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K079128355
       Coding: E9801F061002024101
       VCID: 303917AF562452E7797-8064
    01304 - Radio
                        Reset counter: 48
                        Mileage: 240206 km
                        Date: 2020.02.22
                        Time: 00:08:33
       Revision: D0H22001    Serial number: AUX7Z0G8FNE0NN
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX1.lbl
       Part No: 8J8 959 801 C
       Component: Tuer-SG         H02 0060
       Coding: 0000565
       VCID: 3D273E9B9176AF8FE21-8068
       Part No: 8J2 909 143 C
       Component: EPS_ZFLS Kl.157 H08 1903
       Shop #: WSC 42176 002 1048576
       VCID: 313F12AB5D2E5BEF769-8064
    02546 - Steering Limit Stop
                        Mileage: 240200 km
                        Temperature: 46.0C
                        Voltage: 11.70 V
                        Voltage: 11.50 V
    Address 46: Central Conv.        Labels:. 8J0-959-433.lbl
       Part No: 8J0 959 433 B
       Component:    KSG          H11 0080
       Coding: 9890322201183F3F8505488AD437
       Shop #: WSC 56823 003 1048576
       VCID: 353726BBA94677CF2A1-8060
       Subsystem 2 - Component: DWA-Sens. No Answer
    01134 - Alarm Horn (H12)
    03156 - Sensor for Anti-Theft System (G578)
    Address 47: Sound System        Labels: 8J0-035-223.lbl
       Part No SW: 8J0 035 223 B    HW: 8J0 035 223 B
       Component: J525 Amp Std    H03 0120
       Revision: 00H03001    Serial number: 93802003627406
       Coding: 0106117
       VCID: 2313E8E317D2F97FF45-8076
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX1.lbl
       Part No: 8J8 959 802 C
       Coding: 0000565
       VCID: 3E2539979C70B497FBB-806A
    Address 56: Radio
    End----(Elapsed Time: 01:04, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
    Jan 2020
    Germany (Auto-Intern)
    Hi, where did you carry out the basic setting, in address 03 or 44? If I am not mistaken, the steering angle sensor is part of the steering, so address 44 if it is a generation "3" steering.
    16.4905 S, 151.7375 W
    If the G85-Steering Angle Sensor is loosing 30-power intermittently, the fault code [01826] is stored and the ESP/TCS warning is displayed.
    As long as the ABS wheel speed sensors are functioning correctly (see Measuring Value Block group 001), typically a short test drive will re-initialize the G85 sensor and it can be calibrated with the Basic Settings.
    I would suggest to check the Measuring Value Block group (007) in the [44-Steering Assist] controller, the following information should be seen:
    MVB-007 (Key on, engine running while moving the steering wheel)
    Field (1) Steering Angle Sensor (G85) = Typically should read the actual sensor's value in () [Check the 'lock-to-lock' readings, should be equal from 0]
    Field (3) Calibration Status (G85) = "Yes" or "No"
    Field (4) Initialization Status = "SteerAng Init" or "SteerAng n.Init"
    You should be able to successfully perform the Basic Settings of the G85 when field (1) is active and field (3) says "SteerAng Init". During a 'parking lot' road test, have someone monitor MVB-007, it may show something, like the G85 stops reading, etc...
    I would also suggest to check the power and ground to the J527-Steering Column Control Module, along with the connections of the G85 sensor.
    Official Factory Repair Information
    ps.. There are two different J527 controllers as per the www.PartsLink24.com and based on the VIN / build date, you should be using [8P0 953 549 F]. The G85 is a [1K0 959 654], both are for vehicles up to (25,05,2009) build dates.
    Hope this helps,
    drpeter
  4. Likes Uwe liked this post
