Results 1 to 3 of 3
Thread: Interface reading problem
    May 2020
    Romania
    Hello. Recently I've bought a HEX-v2 interface from my local distribuitor, but I have a problem. When I try to read some modules (just Engine, ABS Brakes tried until now), I'm receiving a message "Sorry, no coding information is available for this ECU". My car it's a VW Golf MK7.5 1.5 TSI 130HP, year of fabrication 2020. Below it's an Auto-Scan, can you tell me that can I do in this situation?
    Saturday,23,May,2020,08:34:20:46569
    VIN: WVWZZZAUZLW0xxxxx   License Plate:
    Mileage: 6576km-4086mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 08 09 10 13 15 17 19 29 39 42 44 4B 52 5F 75 D6 D7
    VIN: WVWZZZAUZLW0xxxxx   Mileage: 6576km-4086miles
    Address 01: Engine (J623-DPBA)       Labels: None
       Part No SW: 05E 906 018 AR    HW: 05E 907 309 H
       Component: R4 1.5l TFS   H20 9641
       Revision: 8AH20000
       Coding: 011900322344050860000000000000000000000000000000
       ASAM Dataset: EV_ECM15TFS01105E906018AR 003003
       ROD: EV_ECM15TFS01105E906018AR.rod
       VCID: 75B7E313354A683370D-8020
       Part No SW: 5Q0 614 517 DK    HW: 5Q0 614 517 BN
       Component: ESC           H35 0113
       Revision: 00000000    Serial number: 63199000001295
       Coding: 01FA6AA190292171477B060160CA2980560984E26006947334205078D0024B0B0000000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
       ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
       VCID: 7DA7FB330D7A307338D-8028
       Part No SW: 5G0 907 044 FQ    HW: 5G0 907 044 FQ
       Component: Climatronic   H04 2401
       Revision: 00001K10
       Coding: 000200042001100D100500400010142E
       ASAM Dataset: EV_ACClimaBHBVW37X 006151
       VCID: 7BA3F52B136E3E43069-802E
       Part No SW: 5Q0 937 084 DG    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H42 0312
       Serial number: 02001932900313
       ASAM Dataset: EV_BCMMQB 020001
       ROD: EV_BCMBOSCH_020.rod
       VCID: 005982C77A885D9B53B-8054
       Component: WWS    191111  043  0551
       Serial number:         191119103734
       Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
       Component: RLHS  051  0206
       Serial number: SBY19M11D27H00M35S53
       Coding: 0008DD
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
       Component: J527 SMLS MQB  004  0070
       Serial number: 00000019111908490098
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058419332
       Coding: 0471151801
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       VCID: 50F97287EA686D1B83B-8004
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Component: ACC BOSCH MQB H11 0682
       Coding: 2B00608119FFC728949C810560400600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D14ED72E1081BB373-8010
       Part No SW: 5Q0 959 655 BS    HW: 5Q0 959 655 BS
       Component: AirbagVW21    008 0403
       Serial number: 003FMR5X9Z9T
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       VCID: 127DB88F24E4DF0BF5F-8046
       Subsystem 1 - Part No SW: -----------    HW: 480 000 312 19
       Serial number: 35700000000B6271634C
       Subsystem 2 - Part No SW: -----------    HW: 480 003 011 19
       Serial number: 358000000000C7710246
       Subsystem 3 - Part No SW: -----------    HW: 480 402 311 19
       Component: SideSensor_Dr  004 6149
       Serial number: 35100010662FAD84830%
       Subsystem 4 - Part No SW: -----------    HW: 480 402 711 19
       Component: SideSensor_Pr  004 6149
       Serial number: 3520001082CA1986B574
       Subsystem 5 - Part No SW: -----------    HW: 480 402 611 19
       Component: FrontSensor_D  004 6149
       Serial number: 35500012062F5841C5E2
       Part No SW: 5G1 920 790 B    HW: 5G1 920 790 B
       Component: KOMBI         404 4191
       Coding: 07A401002F80000801882B011401000800000000
       VCID: 2A0D006FAC7477CB2DF-807E
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5388
       Serial number: 21111910800395
       Coding: 030100047F085700FB00025A080F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF_VW37.rod
       VCID: 70B9D2074A284D1BA3B-8024
       Component: 5-00-14-00-04
       Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-MD9  H18 0052
       Serial number: 46190003255080039456
       Coding: 2CFFFF
       Serial number: 1702733305
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH09 0014
       VCID: 47CB59DB1F26AAA3D21-8012
       Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
       Component: TSG FS002 0325
       Serial number: YE007SJP09336
       Coding: 003B0320D000040000001000
       ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001018
       ROD: EV_DCU2DriveSideMAXHKLO.rod
       VCID: 49CF5FE309325CD3C45-801C
       Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
       Component: FOND_FHSG_DRV  007 0010
       Serial number: 00000000000036205698
       Coding: 110000
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  130 1082
       Coding: 811F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B1DE173E30713B473-8020
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
       Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
       Component: FCM MQB Low   003 0367
       Serial number: 27111911604178
       Coding: 000000050900164A00100F00020000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003_VW27.rod
       VCID: 372B291B6FC6DA23A21-8062
    Address 52: Door Elect, Pass. (J387)       Labels:* Redir Fail!
       Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
       Component: TSG BFS002 0325
       Serial number: YE007SJN25761
       Coding: 003B0120DC00040000001000
       ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001018
       ROD: EV_DCU2PasseSideMAXHKLO.rod
       VCID: 48C95AE71238A5DBDBB-801C
       Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
       Component: FOND_FHSG_PSG  007 0010
       Serial number: 00000000000036167786
       Coding: 090000
       Part No SW: 3Q0 035 840 C    HW: 3Q0 035 840 C
       Component: MU-S--ER      724 0876
       Coding: 02731000FF0000004111000100080A001F0500F40120000002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2B03056BA38E6EC3D69-807E
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H61 8214
       Serial number: VWZ6ZJW3380373
       Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Component: OCULowMQBLGE  H19 0825
       Revision: --------
       Coding: 02730001EA16180D3F1CBE000045400382E608
       ASAM Dataset: EV_OCULowMQBLGE 004049
       ROD: EV_OCULowMQBLGE_004_VW25.rod
       VCID: 3D273B334DFAF07378D-8068
       Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
       Component: LED1L         H07 0008
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       Component: LED1R         H07 0008
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxRKEBODVW481.rod
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.2V)-----------
    Thank you.
    Is there something specific you are trying to accomplish?
    We do not have (and have never claimed to have) complete coding info for every module in every car.
  3. Likes PetrolDave liked this post
    May 2020
    Romania
    In Engine module I just wanted to see if there's something I can adjust, but in ABS Brakes, i was attempt to modify the ESC System Menu in my MIB2.5 and I'm affraid to modify something wrong because the Bytes are empty. This is just an example, I know it's a new engine model, started to be fabricated in September 2019 but I hope in future updates maybe I will be able to get info on that modules. This type of modules it's on VW / Skoda / Seat cars who has 1.5L engine, and it's still fabricated in the present; thinking about I'm not the only one who might need help.
