Retrofitted Discover Media PQ into Golf5/Jetta5
dieseltje
Groningen, The Netherlands
C?ID=148044
Hi guys,
I have a strange problem with a Jetta MK5 of a friend of mine. We did retrofit a Discover Media PQ B type and all works fine only navigation doesn't function as it should be.
GPS Signal has been checked and is perfect, so it finds directly fix.
SD card has been checked and works perfect
Problem we encountered is that after entering destination, the route is calculated good. But when driving, the map is not sliding. It is only updating via GPS fix every 30 or 40 seconds. Also rerouting after driving wrong direction is not functioning.
It looks like it does not get speed signal. But when I check with my VCDS and open module 5F measure block and check vehicle speed, as soon as I drive it gives speed information.
I have updated the 1K0 Q type gateway to AD version. I only forgot to clear the errors in module 01 after gateway update...
Tuesday,26,May,2020,19:59:47:51200
VCDS Version: 20.4.0.1
Dealer/Shop Name: Haarsma
VIN: WVWZZZ1KZ8M006945   License Plate: OANE
Mileage: 215630km-133986mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ8M006945   Mileage: 215630km-133986miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 PM    HW: 03G 906 021 AN
   Component: R4 1,9L EDC G000SG  1136
   Revision: --H07---    Serial number: VWX7Z0G524I0BY
   Coding: 0000071
   Shop #: WSC 66565 257 00032
   VCID: 79F3C70D3011524E45-802C
7 Faults Found:
005712 - Powertrain Data Bus
               P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 00101000
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
005785 - Powertrain Data Bus
               P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 11101000
                    Bin. Bits: 00000000
                    (no units): 0.0
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 11101000
                    Bin. Bits: 00000000
                    (no units): 0.0
049478 - No Communication with Diagnostic Gateway
               U0146 - 000 -  - Intermittent
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
006272 - Powertrain Data Bus
               P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
005685 - Powertrain Data Bus
               P1635 - 000 - Missing Message from A/C Controller - Intermittent
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.54 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 16.0
053273 - Control Module for Instrument Cluster
               U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
                    Mileage: 215630 km
                    Time: 18:57:34
                    Load: 0.0 %
                    Voltage: 12.46 V
                    Bin. Bits: 11001000
                    Bin. Bits: 00000000
                    (no units): 0.0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   Shop #: WSC 00066 000 00000
   VCID: 3F8769156EB5BC7E3B-806A
   Part No SW: 1K0 907 044 BR    HW: 1K0 907 044 BR
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 78F5C2090B1B4B463A-802C
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000000676395
   Coding: 00010E2700041500470A00000F000000000959035C000100000000000000
   VCID: 6FE7F9557E550CFEEB-803A
   Component: Wischer 040707 020  0501
   Coding: 00038805
   Shop #: WSC 00066
   Component: 2J AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD17ZGXC
   Coding: 0012874
   VCID: 3D7B131D64B9AE6E29-8068
   Subsystem 1 - Serial number: 6332MSME181A30453
   Subsystem 2 - Serial number: 6342MSME185823649
   Subsystem 3 - Serial number: 6351HSME0D641C08B
   Subsystem 4 - Serial number: 6361HSME0D630D4FM
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 036 0070
   Coding: 0000041
   VCID: 0005AAE953CB038602-8054
   Part No SW: 1K0 920 864 B    HW: 1K0 920 864 B
   Component: KOMBIINSTRUMENT 3HL 1212
   Revision: V0002000    Serial number: VWX7Z0G524I0BY
   Coding: 0019103
   Shop #: WSC 80093 222 69422
   VCID: 2B5F2D458ACD30DE87-807E
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 2720K08703001E
   Coding: E9807F06400602001002
   Shop #: WSC 12345 123 12345
   VCID: 69D3974D40B1E2CEB5-803C
   Component: IMMO            3HL 1212
Address 37: Navigation
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000074978619
   Coding: 0000180
   VCID: 3B7F1D057AADA05E17-806E
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.069 H08 1901
   VCID: 356B0B3D5C89762EE1-8060
   Coding: 80900A0001060C7F2D04840560084F03E0FCA0
   VCID: 030FA5E542DD189E1F-8056
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000152178605
   Coding: 0000180
   VCID: 3C7D1E197FA3A7661E-8068
Address 56: Radio
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000001742066
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000001747769
   Coding: 0000144
   Shop #: WSC 36362 001 1048576
   VCID: 3E79141169BFB57630-806A
Address 77: Telephone
End-------------------------(Elapsed Time: 01:57)--------------------------
dieseltje
C?ID=148044
I have also a video of the problem.
We also tested this Discover Media into my own car, and then all works as should be. So problem is somewhere in the car's canbus signal
downtime
C?ID=280813
What kind of wiring harness you have?
dieseltje
C?ID=148044
standard Kufatec. why?
I can access the unit with VCDS so canbus is connected correct.
Radio switches on/off with contact
downtime
C?ID=280813
Ok. I would start by fixing the gateway installation list. Remove 37 navigation, 56 radio and add 5F multimedia unit. See if that makes the situation any better.
Clear all DTCs. Run a fresh autoscan after that and post it here.
What is your can gateway part number? Your friend has 1K0 but what is yours? It could be that the gateway is too old to support the unit. Then I’ve seen instrument cluster as one factor as well. If you have too old cluster it affects the MIB functionality. And this is on Golf. Passat seems to be much easier.
golfi_vend
Tartu, Estonia
C?ID=195131
If he had newer GW, the lsit would fix itself.
You really need to have them selected when fixing gw list.
But for this to function properly, You also need newer gw. Sonething from 7n0 907 530 Bx series. And You really need newer cluster and basically everything from mk6 201x+. :D
Spacewalker
C?ID=159607
ABS is tool old,
This unit not support only GPS signal, it also need ABS speed
do simple test
disconnect CAN, power up unit, and drive
check GPS status , and you will see that even with 10/10 satelites, GPS position will not move
dieseltje
C?ID=148044
I guess that indeed ABS signal is old. Just spoke to an other guy who has also a DM in his Golf mk5. Cluster is a Black/white one from Scirrocco. He has the same issue.
If I exchange the rear speedsensors, the one with part number 1J0 927 807 for the type that I have in my Passat B6. 1K0 927 807, would that upgrade the signal ?
rhinopower
C?ID=58979
As above. Will need to try latest available abs pump
dieseltje
C?ID=148044
Thanks guys. There seems to be a firmware modification that solves the problem
Spacewalker
C?ID=159607
problem is not in abs sensors but the signal that is being sent via can bus from abs...
.....Problem is not ECU , only signal send from ECU
so conclusion is ??
no matter if HW , or SW - unit
m87a
Bosnia and Herzegovina
C?ID=156900
so conclusion is ??
You mean ECU or ABS? So even if you update to mk60ec1 there is still this problem?
If true I was interested to know what this solution was...
rhinopower
C?ID=58979
I did DM install on a Eos on Sunday, 2007 with me7.1.1 ecu, mk60 pump revision AC and 2d colour cluster. No issues at all with navigation.
Spacewalker
C?ID=159607
AC is a good one
AINils
Germany (AIB)
C?ID=56975
I did same retrofit in my Golf with these components. All is working perfectly, also Speed Signal. Actually there's Red GTI Dashboard so no Media and Navigation information in Dashboard. In the next few weeks there will be a Scirocco 3D Dash
Adresse 03: Bremsenelektronik Labeldatei:. DRV\1K0-614-517-MK60AT.clb
Teilenummer SW: 1K0 614 517 AC HW: 1K0 614 517 AC
Bauteil: ESP FRONT MK60-AT 0102
Revision: 00H14001
Codierung: 0037506
Betriebsnr.: WSC 01279 785 00200
VCID: E89CE8F1DB4D7F0FB1-80BC
Adresse 19: Diagnoseinterface (J533) Labeldatei: Keine
Teilenummer SW: 7N0 907 530 BM HW: 7N0 907 530 AK
Bauteil: J533 Gateway H57 1691
Revision: H57 Seriennummer: 130513F1001321
Codierung: 350002
Betriebsnr.: WSC 00046 000 00000
VCID: FCB4A4A17FD5C3AF45-80A8
Adresse 5F: Informationselek. I (J794) Labeldatei:| 5G0-035-MIB-STD2.clb
Teilenummer SW: 5C0 035 680 G HW: 5C0 035 680 G
Bauteil: MU-S-ND-ER H40 0468
Seriennummer: VWZAZ2S5384210
Codierung: 02730001AA00000011111106008808001F0103C4002001004F
Betriebsnr.: WSC 02431 666 28888
ASAM Datensatz: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: A502A1C5A4DFA2674A-80F0
That's not working with Black/white Dash you'll need to have 5F and 37 active in Gateway List! If not there are no Navigation hints in MFA
Spacewalker
C?ID=159607
your one is
MK60-AT is also good
he use Mk70 - this is extremally basic pump
AINils
Germany (AIB)
C?ID=56975
I know but want to share these information for the rest of people. You´re right his MK70 is crap
dieseltje
C?ID=148044
Yesterday worked on a Golf mk5 GTI with MK60 ABS and I retrofitted also DM B type. No issues indeed.
So MK70 ABS is the problem. Hope the software fix will solve the problem in the other car with MK70 ABS
