- Joined
- Jan 9, 2019
- Messages
- 273
- Reaction score
- 89
- Location
- Groningen, The Netherlands
- VCDS Serial number
- C?ID=148044
Hi guys,
I have a strange problem with a Jetta MK5 of a friend of mine. We did retrofit a Discover Media PQ B type and all works fine only navigation doesn't function as it should be.
GPS Signal has been checked and is perfect, so it finds directly fix.
SD card has been checked and works perfect
Problem we encountered is that after entering destination, the route is calculated good. But when driving, the map is not sliding. It is only updating via GPS fix every 30 or 40 seconds. Also rerouting after driving wrong direction is not functioning.
It looks like it does not get speed signal. But when I check with my VCDS and open module 5F measure block and check vehicle speed, as soon as I drive it gives speed information.
I have updated the 1K0 Q type gateway to AD version. I only forgot to clear the errors in module 01 after gateway update...
Tuesday,26,May,2020,19:59:47:51200
VCDS Version: 20.4.0.1
Dealer/Shop Name: Haarsma
VIN: WVWZZZ1KZ8M006945 License Plate: OANE
Mileage: 215630km-133986mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZ8M006945 Mileage: 215630km-133986miles
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 1136
Revision: --H07--- Serial number: VWX7Z0G524I0BY
Coding: 0000071
Shop #: WSC 66565 257 00032
VCID: 79F3C70D3011524E45-802C
7 Faults Found:
005712 - Powertrain Data Bus
P1650 - 000 - Missing Message from Instrument Cluster - Intermittent
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.54 V
Bin. Bits: 00101000
Torque: 0.0 Nm
Torque: 351.4 Nm
005785 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics - Intermittent
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.54 V
Bin. Bits: 11101000
Bin. Bits: 00000000
(no units): 0.0
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.54 V
Bin. Bits: 11101000
Bin. Bits: 00000000
(no units): 0.0
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - Intermittent
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.54 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
006272 - Powertrain Data Bus
P1880 - 000 - Missing Message from Diagnostic Gateway - Intermittent
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.54 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
005685 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller - Intermittent
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.54 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 16.0
053273 - Control Module for Instrument Cluster
U1019 - 000 - Missing Signal for Oil Level/Temperature - Intermittent
Mileage: 215630 km
Time: 18:57:34
Voltage: 12.46 V
Bin. Bits: 11001000
Bin. Bits: 00000000
(no units): 0.0
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
VCID: 3F8769156EB5BC7E3B-806A
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
VCID: 78F5C2090B1B4B463A-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Revision: 00H54000 Serial number: 00000000676395
Coding: 00010E2700041500470A00000F000000000959035C000100000000000000
VCID: 6FE7F9557E550CFEEB-803A
Component: Wischer 040707 020 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 2J AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD17ZGXC
Coding: 0012874
VCID: 3D7B131D64B9AE6E29-8068
Subsystem 1 - Serial number: 6332MSME181A30453
Subsystem 2 - Serial number: 6342MSME185823649
Subsystem 3 - Serial number: 6351HSME0D641C08B
Subsystem 4 - Serial number: 6361HSME0D630D4FM
Part No SW: 1K0 953 549 AP HW: 1K0 953 549 AP
Component: Lenksäulenmodul 036 0070
Coding: 0000041
VCID: 0005AAE953CB038602-8054
Part No SW: 1K0 920 864 B HW: 1K0 920 864 B
Component: KOMBIINSTRUMENT 3HL 1212
Revision: V0002000 Serial number: VWX7Z0G524I0BY
Coding: 0019103
Shop #: WSC 80093 222 69422
VCID: 2B5F2D458ACD30DE87-807E
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H16 0233
Revision: H16 Serial number: 2720K08703001E
Coding: E9807F06400602001002
VCID: 69D3974D40B1E2CEB5-803C
Component: IMMO 3HL 1212
Address 37: Navigation
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1133
Revision: 32008001 Serial number: 00000074978619
Coding: 0000180
VCID: 3B7F1D057AADA05E17-806E
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 356B0B3D5C89762EE1-8060
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 80900A0001060C7F2D04840560084F03E0FCA0
VCID: 030FA5E542DD189E1F-8056
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1133
Revision: 32008001 Serial number: 00000152178605
Coding: 0000180
VCID: 3C7D1E197FA3A7661E-8068
Address 56: Radio
Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
Component: J388 TUER-SG HL 1120
Revision: 11006001 Serial number: 00000001742066
Coding: 0000144
Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
Component: J389 TUER-SG HR 1120
Revision: 11006001 Serial number: 00000001747769
Coding: 0000144
Shop #: WSC 36362 001 1048576
VCID: 3E79141169BFB57630-806A
Address 77: Telephone
End-------------------------(Elapsed Time: 01:57)--------------------------
