Hi Guys, New here but have been stalking for some years ... what a great tool ! A good enough reason not stray from VAG I would say This is not your everyday fault and so am hoping someone out there can throw some light...
The issue here is that I have an adaptive cruise problem and showing the 'ACC: unavailable' message. I have done the common sense stuff such as cleaning the sensor lens surface and removing/reconnecting the plug with some wishful thinking switch cleaner. The cable and harness around all look in great condition. I use the function on a daily basis and know that one day it was working and the next day woke up and it was not - no knocks or possibility of accidental damage - The sensor is all secure and mounted solid.
Getting connected - [13] Distance control module reports as below. With ignition on, engine not running the faults clear. As soon as the engine is running the faults appear.
Now I have got a used replacement sensor with identical part number but from a 2013 Golf which I recoded - 00200301FE0309 as per the Audi one here. But realised it's a bumper off job to fit it so want to cover the bases as far as possible before getting int that. Also a component protection fault appeared as a new fault after coding the replacement. I wasn't sure what to expect with it not being installed in the correct position and not being driven a short way to clear any other faults? Any adaptation required? It would be great to get a steer with this.
I should also point out that the 'Unknown Error Elaboration error' was not showing before I showed the car the replacement sensor -
Tuesday,26,May,2020,19:50:44:40478
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8VXDA014468 License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8VXDA014468 Mileage: 198098km-123092miles
Address 01: Engine (J623-CRBC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 DS HW: 04L 907 309 D
Component: R4 2,0L EDC H21 4941
Revision: 83H21---
Coding: 02190012034501082000
Shop #: WSC 64020 000 1048576
ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
ROD: EV_ECM20TDI01104L906021DS_002.rod
VCID: 79F21639F8474C4E4C-802C
17156 - Databus
U1123 00 [044] - Received Error Message
Fault Frequency: 9
Mileage: 198010 km
Date: 2020.05.25
Time: 13:20:53
Engine speed: 771.50 /min
Normed load value: 25.1 %
Coolant temperature: 51 °C
Intake air temperature: 42 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 14.580 V
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 10F18AA220210A70017B060601CB290851045080608094F2F479503485
ROD: EV_Brake1UDSContiMK100IPB_008.rod
VCID: 7DFA0229EC6F706E60-8028
Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
Component: AC Automat H11 0031
Revision: 20018000 Serial number: 00000000018610
Coding: 00100104002000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
VCID: 3064EB1D6BBD4D06BB-8064
Serial number: 27580F46000000000001
459526 - Databus
Fault Frequency: 10
Reset counter: 115
Mileage: 198010 km
Date: 2020.05.25
Time: 13:16:01
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AH HW: 5Q0 937 084 P
Component: BCM MQBAB M+ H14 0137
Serial number: 00011226400237
Coding: 07040846C20102FD03044004B31407A80000000000000000000000000000
Shop #: WSC 40475 002 1048576
ROD: EV_BCMBOSCH_013.rod
VCID: 7EF80525E1696B7679-802A
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 120620 041 0580
Serial number: 120808050532
Coding: 0A47F7
Component: G397_RLFS H06 0002
Serial number: 20652154
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 Q HW: 8V0 941 531 Q
Serial number: 24 07 2012 00000527
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0313
Serial number: 000000000ZY120510H04
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000055156479
939534 - Humidity sensor
B1281 04 [009] - Internal System Fault
Fault Frequency: 19
Reset counter: 115
Mileage: 198010 km
Date: 2020.05.25
Time: 13:16:01
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
Component: PARKHILFE 4K 009 0026
Revision: -------- Serial number: 60831225704299
Coding: 0000040001
ASAM Dataset: EV_EPHVA14AU3700000 002015
VCID: 3776D0018ED39A3EFA-8062
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 J HW: 5Q0 907 567 G
Component: ACC3 H08 0396
Serial number: 16051375030494
Coding: 00200301FE0309
Shop #: WSC 59851 001 1048576
ASAM Dataset: EV_ACCBoschMQB 001023
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 4280B1D5D511CF965D-8016
0048 - Internal Fault
B200F F0 [104] - Unknown Error Elaboration
Reset counter: 113
Mileage: 198010 km
Date: 2020.05.25
Time: 14:54:01
Control Module temperature: 18 °C
Voltage terminal 15: 12.0 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1117 - Automatic Distance Control
B10E7 F0 [040] - Disconnected
Fault Frequency: 6
Reset counter: 155
Mileage: 198010 km
Date: 2020.05.25
Time: 13:18:31
Voltage terminal 15: 14.3 V
Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
Component: AirbagVW20 009 0349
Serial number: 003GER00BKGL
ROD: EV_AirbaVW20SMEVW37X_VW48.rod
VCID: 4992A6F9E8271CCE9C-801C
Subsystem 1 - Part No SW: ----------- HW: 480 001 110 12
Serial number: 3576700000058348FB0$
Subsystem 2 - Part No SW: ----------- HW: 480 001 110 12
Serial number: 35867000000F5248FB03
Subsystem 3 - Part No SW: ----------- HW: 480 400 910 12
Serial number: 3516502AD0D19C32F0BP
Subsystem 4 - Part No SW: ----------- HW: 480 400 910 12
Serial number: 3526502BB0D53541134+
Subsystem 5 - Part No SW: ----------- HW: 480 400 409 12
Serial number: 3556502B10C5C1A0F0EL
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 409 12
Component: PedP_Sensor_D 001 6149
Serial number: 2286502B10D19C33D2DK
Subsystem 7 - Part No SW: ----------- HW: 480 401 207 12
Component: PedP_Sensor_P 001 6149
Serial number: 2296502B50B3DFC0719R
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 401 609 13
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C511D1521226Q
Address 16: Steering wheel (J527) Labels:. 5Q0-953-549.clb
Part No SW: 8V0 953 521 D HW: 5Q0 953 549 A
Revision: -------- Serial number: 31081200010614
Coding: E408
ROD: EV_SMLSKLOMQB_009_AU37.rod
VCID: 3B7ECC31B2FBBE5E1E-806E
Part No SW: 8V0 920 970 K HW: 8V0 920 970 K
Component: KOMBI H22 0490
Coding: 27840100278046000100E800000000
VCID: 448CB7CDCF05C1A66F-8010
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 122 1126
Revision: -------- Serial number: 0000121503
Coding: 030100F40B0876005B000258080B00000001000000000000000000000000
ASAM Dataset: EV_GatewLear 008010
ROD: EV_GatewLear_008.rod
VCID: 3874D33D83CD9546F3-806C
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Serial number: 10 10 2012 D0125013
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 6626888301
Part No SW: 5Q0 959 593 A HW: 5Q0 959 593
Component: TSG FS H12 0006
Serial number: 25081200011217
Coding: 001C0E205C01040100001003
VCID: 3F86B821A6E3A27E32-806A
Coding: 81
ROD: EV_SteerAssisMQB_008.rod
VCID: 3D7AC229ACEFB06E20-8068
Part No SW: 5Q0 959 592 A HW: 5Q0 959 592
Component: TSG BFS H12 0006
Serial number: 27091200010118
Coding: 001C06205E01040100001003
VCID: 3E78C525A1E9AB7639-806A
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-STD1.clb
Part No SW: 8V0 035 874 A HW: 8V0 035 874
Component: MU-S-ND-ER 039 0370
Serial number: A7F02009120398
Coding: 01730001FF0A000021111101000A00002F0004460100010006
ASAM Dataset: EV_MUStd6C3PASE 002020
ROD: EV_MUStd6C3PASE.rod
VCID: 3A70C935BDC1875605-806E
Subsystem 1 - Part No SW: 8V0 919 866 HW: -----------
Component: ECE 2012/13 --- 0010
Subsystem 2 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9CG20011M
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000003091200010033
End-------------------------(Elapsed Time: 03:33)--------------------------
