2013, Audi A3 - ACC: unavailable
deej
C?ID=90894
Hi Guys, New here but have been stalking for some years ... what a great tool ! A good enough reason not stray from VAG I would say :) This is not your everyday fault and so am hoping someone out there can throw some light...
The issue here is that I have an adaptive cruise problem and showing the 'ACC: unavailable' message. I have done the common sense stuff such as cleaning the sensor lens surface and removing/reconnecting the plug with some wishful thinking switch cleaner. The cable and harness around all look in great condition. I use the function on a daily basis and know that one day it was working and the next day woke up and it was not - no knocks or possibility of accidental damage - The sensor is all secure and mounted solid.
Getting connected - [13] Distance control module reports as below. With ignition on, engine not running the faults clear. As soon as the engine is running the faults appear.
Now I have got a used replacement sensor with identical part number but from a 2013 Golf which I recoded - 00200301FE0309 as per the Audi one here. But realised it's a bumper off job to fit it so want to cover the bases as far as possible before getting int that. Also a component protection fault appeared as a new fault after coding the replacement. I wasn't sure what to expect with it not being installed in the correct position and not being driven a short way to clear any other faults? Any adaptation required? It would be great to get a steer with this.
I should also point out that the 'Unknown Error Elaboration error' was not showing before I showed the car the replacement sensor -
Tuesday,26,May,2020,19:50:44:40478
VCDS Version: 20.4.1.0 (x64)
VIN: WAUZZZ8VXDA014468   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WAUZZZ8VXDA014468   Mileage: 198098km-123092miles
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H21 4941
   Revision: 83H21---
   Coding: 02190012034501082000
   Shop #: WSC 64020 000 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021DS 002008
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 79F21639F8474C4E4C-802C
17156 - Databus
          U1123 00 [044] - Received Error Message
                    Fault Frequency: 9
                    Mileage: 198010 km
                    Date: 2020.05.25
                    Time: 13:20:53
                    Engine speed: 771.50 /min
                    Normed load value: 25.1 %
                    Coolant temperature: 51 °C
                    Intake air temperature: 42 °C
                    Ambient air pressure: 1030 mbar
                    Voltage terminal 30: 14.580 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 4
                    Acceleration: 0.000 m/s²
   Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
   Component: ESC           H75 0437
   Coding: 10F18AA220210A70017B060601CB290851045080608094F2F479503485
   ROD: EV_Brake1UDSContiMK100IPB_008.rod
   VCID: 7DFA0229EC6F706E60-8028
   Part No SW: 8V0 820 043 A    HW: 8V0 820 043 A
   Component: AC Automat    H11 0031
   Revision: 20018000    Serial number: 00000000018610
   Coding: 00100104002000011000000000001100
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
   VCID: 3064EB1D6BBD4D06BB-8064
   Serial number: 27580F46000000000001
459526 - Databus
                    Fault Frequency: 10
                    Reset counter: 115
                    Mileage: 198010 km
                    Date: 2020.05.25
                    Time: 13:16:01
   Part No SW: 5Q0 937 084 AH    HW: 5Q0 937 084 P
   Component: BCM MQBAB M+  H14 0137
   Serial number: 00011226400237
   Coding: 07040846C20102FD03044004B31407A80000000000000000000000000000
   Shop #: WSC 40475 002 1048576
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7EF80525E1696B7679-802A
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 120620  041 0580
   Serial number:         120808050532
   Coding: 0A47F7
   Serial number: 20652154
   Coding: 00006C
   Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
   Serial number: 24 07 2012  00000527
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY120510H04
   Serial number: 00000000000055156479
939534 - Humidity sensor
          B1281 04 [009] - Internal System Fault
                    Fault Frequency: 19
                    Reset counter: 115
                    Mileage: 198010 km
                    Date: 2020.05.25
                    Time: 13:16:01
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  009 0026
   Revision: --------    Serial number: 60831225704299
   Coding: 0000040001
   ASAM Dataset: EV_EPHVA14AU3700000 002015
   VCID: 3776D0018ED39A3EFA-8062
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 J    HW: 5Q0 907 567 G
   Component: ACC3          H08 0396
   Serial number: 16051375030494
   Coding: 00200301FE0309
   Shop #: WSC 59851 001 1048576
   ASAM Dataset: EV_ACCBoschMQB 001023
   ROD: EV_ACCBoschMQB_AU37.rod
   VCID: 4280B1D5D511CF965D-8016
0048 - Internal Fault
          B200F F0 [104] - Unknown Error Elaboration
                    Reset counter: 113
                    Mileage: 198010 km
                    Date: 2020.05.25
                    Time: 14:54:01
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 12.0 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1117 - Automatic Distance Control
          B10E7 F0 [040] - Disconnected
                    Fault Frequency: 6
                    Reset counter: 155
                    Mileage: 198010 km
                    Date: 2020.05.25
                    Time: 13:18:31
                    Voltage terminal 15: 14.3 V
   Part No SW: 5Q0 959 655 L    HW: 5Q0 959 655 L
   Component: AirbagVW20    009 0349
   Serial number: 003GER00BKGL
   ROD: EV_AirbaVW20SMEVW37X_VW48.rod
   VCID: 4992A6F9E8271CCE9C-801C
   Subsystem 1 - Part No SW: -----------    HW: 480 001 110 12
   Serial number: 3576700000058348FB0$
   Subsystem 2 - Part No SW: -----------    HW: 480 001 110 12
   Serial number: 35867000000F5248FB03
   Subsystem 3 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3516502AD0D19C32F0BP
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 12
   Serial number: 3526502BB0D53541134+
   Subsystem 5 - Part No SW: -----------    HW: 480 400 409 12
   Serial number: 3556502B10C5C1A0F0EL
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 409 12
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502B10D19C33D2DK
   Subsystem 7 - Part No SW: -----------    HW: 480 401 207 12
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502B50B3DFC0719R
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 609 13
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C511D1521226Q
   Part No SW: 8V0 953 521 D    HW: 5Q0 953 549 A
   Revision: --------    Serial number: 31081200010614
   Coding: E408
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 3B7ECC31B2FBBE5E1E-806E
   Part No SW: 8V0 920 970 K    HW: 8V0 920 970 K
   Component: KOMBI         H22 0490
   Coding: 27840100278046000100E800000000
   VCID: 448CB7CDCF05C1A66F-8010
   Part No SW: 5Q0 907 530 J    HW: 5Q0 907 530 F
   Component: GW MQB High   122 1126
   Revision: --------    Serial number: 0000121503
   Coding: 030100F40B0876005B000258080B00000001000000000000000000000000
   ASAM Dataset: EV_GatewLear 008010
   ROD: EV_GatewLear_008.rod
   VCID: 3874D33D83CD9546F3-806C
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 10 10 2012  D0125013
   Serial number: 6626888301
   Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
   Component: TSG FS        H12 0006
   Serial number: 25081200011217
   Coding: 001C0E205C01040100001003
   VCID: 3F86B821A6E3A27E32-806A
   Coding: 81
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D7AC229ACEFB06E20-8068
   Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
   Component: TSG BFS       H12 0006
   Serial number: 27091200010118
   Coding: 001C06205E01040100001003
   VCID: 3E78C525A1E9AB7639-806A
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 A    HW: 8V0 035 874
   Component: MU-S-ND-ER    039 0370
   Serial number: A7F02009120398
   Coding: 01730001FF0A000021111101000A00002F0004460100010006
   ASAM Dataset: EV_MUStd6C3PASE 002020
   ROD: EV_MUStd6C3PASE.rod
   VCID: 3A70C935BDC1875605-806E
   Subsystem 1 - Part No SW: 8V0 919 866     HW: -----------
   Component:  ECE 2012/13  --- 0010
   Subsystem 2 - Part No SW: 8V0 919 603 A    HW: 8V0 919 603 A
   Component: DU Std  H47 0013
   Serial number: AUZ8Z9CG20011M
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
   Component: ControlUnit_B  H33 0037
   Serial number: C1000003091200010033
End-------------------------(Elapsed Time: 03:33)--------------------------
downtime
C?ID=280813
Dealer job to remove CP.
What comes to original ACC module. Faulty module?
This is not a 2012 car. It's clearly a 2013:
WAUZZZ8VXDA0xxxxx
I've adjusted the thread topic to reflect that. :)
Looks like the old ACC sensor in the scan above has failed.
I agree with downtime; CP removal is a dealer job (or at least someone with factory ODIS software and access to the factory servers) and then the replacement sensor needs to be calibrated, which requires special targets and measurement gear. So it's not a DYI project.
deej
C?ID=90894
Thanks downtime - The scan in the post is from the original module. But before seeing the replacement module there was just 1117 - Automatic Distance Control - B10E7 F0 [040] - Disconnected - The fault clears with engine not running but come on immediately after engine starts.
deej
C?ID=90894
Thanks Uwe, Well the date of first registration is 26/11/2012 - So clearly made before 2013 :) - The MY is 2013 ...It's just one of the early ones I guess. I'll remember to be clearer next time to avoid the confusion.
I'll update about the CP removal for those interested.
Model year is what matters when it comes to diagnostic info. I saw a mention of Component Protection and was like, "What, a 2012 A3 doesn't have that!" :D
FYI my previous Audi was built in JUNE 2006, but the VIN stated it was a 2007 model - the MY changeover happens in mid year around the time of the factory summer break.
deej
C?ID=90894
Update on this one. All sorted. My local independent - Quattro-Tech removed 'component protection' at a very reasonable price which includes an on-line check that the part now fitted was not from a stolen vehicle. The used sensor was from a Golf 7 on the same MQB platform so no real surprise no alignment was required as I mounted it with the adjusting bracket it came with untouched. For interest I found this DIY aligning routine and wondered if anyone had given it a shot? ...https://www.audi4ever.com/blog/eintrag/25254-blog/
