Results 1 to 5 of 5
Thread: Audi S3 8V haldex module fault
    Unverified
    May 2020
    Kent, UK
    Hi, does anyone know if the haldex gen 5 module is plug and play?
    WHat makes you think the Haldex is faulty and/or you want to replace it?
    We always ask for a full unedited VCDS Auto-Scan so we can see how the car is equipped/configured.
    Unverified
    May 2020
    Kent, UK
    I have tested the earth and power cables and all have power running through. I have opened the haldex module and found corrosion inside.
    The haldex pump has been changed and receiving no communication with 4wd clutch control module.
    Sorry I cant post a full scan as don't have scanner I took it to a garage to be scanned.
    Unverified
    May 2020
    Kent, UK
    Also since opening and checking the module and trying to clean it up i have more errors. The traction light on, no adaptive cruise control and no hill assist. Would the haldex module cause this?
    Since you don't have VCDS you're probably asking in the wrong place, I would suggest you join an Audi forum - Google "audi owners forum uk" for several options.
  6. Likes Uwe liked this post
