Results 1 to 10 of 11
Thread: 2020 Q5 Radio "Alternate Frequency" Feature
    May 2020
    Jamaica
    My manual indicates the radio may automatically switch to an alternate FM frequency when an FM station gets too weak. How may I activate that option using my new V2 interface?
    Quote Originally Posted by the_dread View Post
    Isn't AF a standard feature of RDS?
  3. Likes DV52, corradokid liked this post
    Dave: You are correct - of course.
    But the MIB units sometimes allow for the stripped-out AF information to be suppressed if not wanted. The software switch is in Byte 13, Bit 1 on MQB MIB/MMI units - see below
  5. Likes PetrolDave, jyoung8607, Uwe liked this post
  6. #4
    May 2020
    Jamaica
    Thanks very much, Dave. Would you kindly indicate the Control Unit, etc. that I need to select to get to that screen? Already have the new V2 interface & the latest s/ware.
    Dec 2016
    DE
    5F is the module that coding is found.
  8. Likes PetrolDave liked this post
  9. #6
    May 2020
    Jamaica
    Thanks, TBAx.
    I'll try it then drive out of station range to test & let you know the result.
  10. #7
    May 2020
    Jamaica
    I found the Byte/bit and it was labeled exactly as you indicated. I tried to change the coding but got a message the the module did not respond (accompanies by a red X). The vcds s/ware then froze and I had to close it and restart.
    FYI - The bit was not selected (temporary?).
    - Does deselecting that bit (persistent?) cause the radio to auto-search for the stronger frequency?
    - What does "temporary" mean?
    I've saved the adaptation map & will share it as soon as I know how to post the Excel file.
  11. #8
    May 2020
    Jamaica
    ;SW:8W0-035-840-E   HW:8W0-035-840-E ---  Information Electr.
    ;Component:MU-S--ER      722 0962, Coding:012406000000000013220002001A00232F0018E60170010002
    ;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_AU73.rod
    ;Thursday,11,June,2020,14:55:11:49463
    ;VCDS Version: Release 20.4.1  Data version: 20200331 DS317.0
    ;VCID: 38292DB852DF98BBABB-806C
    IDE00346-Summertime-automatic,none ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,No ,3
    IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
    IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,Yes ,3
    IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
    IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
    IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
    IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
    IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
    IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
    IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
    IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
    IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
    IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
    IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
    IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
    IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
    IDE02502-Confirmation of installation change,36 2D ,2
    IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,23
    IDE03471-ENG249824-Vehicle configuration-AliBox,OFF ,30
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG263540-Vehicle configuration-correction_e_mileage,0 ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,OFF ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG261211-Vehicle configuration-internet_over_WLAN_default_setting,OFF ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,Deactivated ,30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE04292-Roadside assistance mode,Corresponding setting in MMI ,1
    IDE04294-Number attempted dialing attempts for roadside assistance,3 ,1
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,0 ,40
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,17 ,40
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),5 ,40
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),5 ,40
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),5 ,40
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,0 ,40
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,0 ,40
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,0 ,40
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,0 ,40
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,6 ,40
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,0 ,40
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,0 ,40
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,0 ,40
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,0 ,40
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,0 ,40
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,0 ,40
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,0 ,40
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,0 ,40
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,0 ,40
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,0 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,0 ,40
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,0 ,40
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,5 ,40
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,0 ,40
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,0 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,0 ,40
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,0 ,40
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,0 ,40
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,0 ,40
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,0 ,40
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,0 ,40
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,5 ,40
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,0 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
    IDE11122-Country identification: country of sale HMI,-- ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    MAS00951-Bluetooth,On ,1
    MAS01968-Fan,normal ,1
    MAS03782-WLAN,On ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated ,60
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,activated ,60
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,activated ,60
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated ,60
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated ,60
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated ,60
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated ,60
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated ,60
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,not activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15 ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15 ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15 ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_4 ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,not activated ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15 ,64
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,not activated ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,not activated ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15 ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15 ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15 ,64
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,activated ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated ,64
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Terminal 15 ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15 ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,not activated ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15 ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,not activated ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,not activated ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15 ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15 ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Terminal 15 ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15 ,64
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available ,8
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15 ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available ,8
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15 ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15 ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Not available ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Not available ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15 ,8
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,OFF ,10
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,20 ,12
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,5 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,11 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,27 %,12
    ENG117808-p_HMI_Display,10 %,1
    Elapsed Time: 00:43
  12. #9
    the_dread: Hi
    If I parse the long-code string in the admap data above through my handy-dandy converter -I get this:
    Byte	Hex	Binary
    0	01	00000001
    1	24	00100100
    2	06	00000110
    3	00	00000000
    4	00	00000000
    5	00	00000000
    6	00	00000000
    7	00	00000000
    8	13	00010011
    9	22	00100010
    10	00	00000000
    11	02	00000010
    12	00	00000000
    13	1A	00011010
    14	00	00000000
    15	23	00100011
    16	2F	00101111
    17	00	00000000
    18	18	00011000
    19	E6	11100110
    20	01	00000001
    21	70	01110000
    22	01	00000001
    23	00	00000000
    24	02	00000010
    I've highlighted the Bit in question on Byte 13 - as you can see, it's currently set "high".
    So - I'm not quite sure that I understand what you are attempting to do, but the descriptors for this Bit in my reply to Dave indicates that this software switch has an active "permanent" state when the value of Bit 1 is zero; I mean the term "permanent" as an equivalence to "persistent" (as indicated in the screen in my post). To borrow your words - Bit 1 =0, will "cause the radio [to use] the stronger frequency" in all conditions when an AF is detected by the RDS information - I believe.
    It's unclear to me what exactly happens if this Bit is set high (i.e. value=1) as in your admap - but the descriptor "Temporary" in the yellow screen suggests that under certain conditions the AF that's stipped-off the RDS data stream is inhibited. Is this what you want- are you trying to suppress AF? What problem are you attempting to fix?
  13. Likes Uwe liked this post
  14. #10
    May 2020
    Jamaica
    Hi Don,
    Thanks for your response. I apologise for my late reply.
    I'm trying to activate the AF feature (that I read about in my manual) so that the radio will search for an alternate frequency whenever the frequency I've selected gets weak. The radio currently does not do this.
    It seems, from your description, that the setting of "0" may achieve that objective.
    the_dread
  15. Likes DV52 liked this post
