trying to adjust my headlights following the procedure via Address 09, Basic Settings, Group 11 as described here http://wiki.ross-tech.com/wiki/inde...ngs_in_BCM1/09-Cent._Elect._(J519)_controller
When i do that the first field shows 'Wait' all the time. I read somewhere about this but can't find it anymore.
Any help is appreciated
Werner
Werner
Tuesday,26,May,2020,17:58:17:16457
VCDS Version: 20.4.1.0
VIN: WA1CMAFP5EA033454 License Plate: MAY25
Mileage: 104990km-65237mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72 AC
VIN: WA1CMAFP5EA033454 Mileage: 104990km-65237miles
Address 01: Engine (J623-CPNB) Labels:. 059-907-401-V2.clb
Part No SW: 8K5 907 401 J HW: 4G0 907 401 E
Component: 3.0TDI FSA H14 0014
Revision: 58H14---
Coding: 2A2A4012052603050000
Shop #: WSC 29413 001 1048576
ASAM Dataset: EV_ECM30TDI0118K5907401J 002014
ROD: EV_ECM30TDI0118K5907401J_002.rod
VCID: 3777C4CA8E0DCD3EFA-8062
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 Q HW: 0BK 927 156 AM
Component: 0BK 30 TDIUSA H16 1007
Revision: --H16---
Coding: 000001
VCID: 4B9F883AE28559DEAE-801E
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V2.clb
Part No SW: 8R0 907 379 AM HW: 8R0 907 379 AM
Component: ESP8 quattro H09 0030
Coding: 231D1C03
Shop #: WSC 06335 000 00000
VCID: 0B1F483AAA0519DE6E-805E
Part No SW: 8K0 907 064 HP HW: 8K0 907 064 GP
Component: BCM2 2.0 H13 0641
Coding: 0DA54040000000000000
VCID: 050B7E028C616FAE38-8050
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 0213000293035011
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01280820132045
Coding: 3621228000
VCID: 3973C2F2B019DB4E0C-806C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 69
Mileage: 104957 km
Date: 2020.05.26
Time: 15:00:26
Reset counter: 69
Mileage: 104990 km
Date: 2020.05.26
Time: 16:43:12
Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000439094602
Coding: 2680009100209F000020000300001D0D0F1C4700A6080261000000000000030200080034000000
Shop #: WSC 06325 123 12345
VCID: 7AF11DFEF59F105645-802E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 130731 H11 0050
Serial number: 90243014130723155619
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 21652870
Coding: 02005C
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000308130164
Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0030
Serial number: 0000002274555R72YY02
Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H04 0012
Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
H04 0012
Fault Status: 01100101
Reset counter: 69
Mileage: 104990 km
Date: 2020.05.26
Time: 16:52:46
02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
Reset counter: 69
Mileage: 104990 km
Date: 2020.05.26
Time: 16:52:46
02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
Reset counter: 69
Mileage: 104990 km
Date: 2020.05.26
Time: 16:52:46
01229 - A/C Humidity Sensor (G260)
014 - Defective
Fault Status: 01101110
Reset counter: 69
Mileage: 104990 km
Date: 2020.05.26
Time: 16:52:49
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H47 0610
Serial number: 003GPDB09P4K
Coding: 303634313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 4797B40AFEEDBDBE8A-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R130000F34T
Serial number: 6334MSME7C712675K
Serial number: 6344MSME7D742B76V
Serial number: 6352QSME14354E7ET
Serial number: 6362QSME6135386CM
Serial number: 63732SME5C3916787
Serial number: 63832SME5C391A489
Part No SW: 8K0 953 568 Q HW: 8K0 953 568 Q
Component: Lenks.Modul H03 0003
Revision: C0062331 Serial number: 90862MHR000GD
Coding: 000017
VCID: 4895B736FBF3B2C683-801C
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 982 A HW: 8R0 920 982 A
Component: KOMBIINSTR. H35 0563
Revision: 00300000 Serial number: WZE24PU8E
Coding: 83BF22000B01D705020000
Shop #: WSC 26348 004 104857
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0056
Revision: 1Z110028 Serial number: 2841Z138120003
Coding: 80CF03FF00
Shop #: WSC 06335 123 12345
VCID: 4C9D8B26EF8B5EE6A7-8018
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 40205B28291461796306
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000072240714
Coding: 01581B00000000000000
VCID: 4281A51EDDCF98965D-8016
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 8T0 907 566 B HW: 8T0 907 566 B
Component: SWA Master H05 0071
Serial number: 0312714733
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3F87ACEAA63DF57E32-806A
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 8T0 907 568 B HW: 8T0 907 568 B
Component: SWA Slave H05 0071
Serial number: 0313278237
Coding: 010211
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0510
Revision: Serial number: 0000071679201
Coding: 011D13205E00440004
VCID: 4FA79C2A1E9D65FEC2-801A
Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H38 0507
Revision: 00001000 Serial number: 0012759425
Coding: 100000000001
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B7FD8FAB225E95E1E-806E
Revision: 00002001 Serial number: 0312970358
Coding: 0126023A20BA709784A0053600040047
Shop #: WSC 06334 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000714945
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H05 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H05 0220
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813018967303
VCID: 2D5BE6A2745177EE90-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0510
Revision: Serial number: 0000071699308
VCID: 4E99812E19976CF6C9-801A
Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb
Part No SW: 8K0 907 801 M HW: 8K0 907 801 J
Component: EPB-4 H01 0004
Revision: -------- Serial number: 20000000320427
ROD: EV_ParkiBrake_AU48.rod
VCID: 3973C2F2B819DB4E0C-806C
Part No SW: 4G0 035 082 G HW: 4G0 035 082
Component: Radio U SIRIU H60 0133
Revision: AB001007 Serial number: 156H90D7838629
Coding: 020007010000000001
VCID: 244D0386279BB6A64F-8070
Part No SW: 8R1 035 746 D HW: 8R1 035 746 D
Component: H-BNT-NA H40 0738
Revision: -------- Serial number: 204H+0D7595327
Coding: 160200060005A1EF51028B4E00000403140000000000000000
VCID: 3875C7F68B13C246F3-806C
Subsystem 1 - Part No: 8R0 060 884 BD
Component: NAR 2013/2014 0802
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130HM0D2804430
Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
Component: E0380 Bedient H02 0030
Serial number: 00000001591133
Component: CD-Database 5298
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0510
Revision: Serial number: 0000072214610
Coding: 010C13204000240004
VCID: 4689B90EF1E7A4B671-8012
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H08--- Serial number: 525PA8-J36A3G5
Coding: 1020010
VCID: 346DF3C6577B2626DF-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B7FD8FABA25E95E1E-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0510
Revision: Serial number: 0000072214726
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H09 0010
Revision: 00000000 Serial number: 131910095
ROD: EV_RDCMA00100.rod
VCID: 2B5FE8BA424579DE8E-807E
End-------------------------(Elapsed Time: 04:53)--------------------------
