Results 1 to 7 of 7
Thread: Need scan from Audi A4/5 Q5 with Adaptive Headlights (2012 - 2015 ish)
    May 2020
    TX, USA
    retrofitting adaptive headlights to my 2014 Audi Q5 but getting AFS error in DIS. Can someone send me a scan so i can check my coding for the BCM, ideally BCM PN 8K0 907 063 DJ!
    Also, i only have a single level sensor (rear left) installed. Would be helpful to know if your car has the same setup or the 2nd level sensor front left installed (or someone knows if a single sensor is fine).
    Many Thanks
    Werner
    Jan 2015
    Bosnia and Herzegovina
    please post auto scan from a car in question, maybe someone can help or shed some light...
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
    May 2020
    TX, USA
    Here you go. Active error that bothers me is 'Adaptive light error' in the DIS
    Tuesday,26,May,2020,17:58:17:16457
    VCDS Version: 20.4.1.0
    VIN: WA1CMAFP5EA033454   License Plate: MAY25
    Mileage: 104990km-65237mi   Repair Order:
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
              62 6C 6D 72 AC
    VIN: WA1CMAFP5EA033454   Mileage: 104990km-65237miles
    Address 01: Engine (J623-CPNB)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 401 J    HW: 4G0 907 401 E
       Component: 3.0TDI FSA    H14 0014
       Revision: 58H14---
       Coding: 2A2A4012052603050000
       Shop #: WSC 29413 001 1048576
       ASAM Dataset: EV_ECM30TDI0118K5907401J 002014
       ROD: EV_ECM30TDI0118K5907401J_002.rod
       VCID: 3777C4CA8E0DCD3EFA-8062
       Part No SW: 8R0 927 158 Q    HW: 0BK 927 156 AM
       Component: 0BK 30 TDIUSA H16 1007
       Revision: --H16---
       Coding: 000001
       VCID: 4B9F883AE28559DEAE-801E
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AM    HW: 8R0 907 379 AM
       Component: ESP8 quattro  H09 0030
       Coding: 231D1C03
       Shop #: WSC 06335 000 00000
       VCID: 0B1F483AAA0519DE6E-805E
       Part No SW: 8K0 907 064 HP    HW: 8K0 907 064 GP
       Component: BCM2 2.0      H13 0641
       Coding: 0DA54040000000000000
       VCID: 050B7E028C616FAE38-8050
       Serial number: 0213000293035011
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01280820132045
       Coding: 3621228000
       VCID: 3973C2F2B019DB4E0C-806C
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 69
                        Mileage: 104957 km
                        Date: 2020.05.26
                        Time: 15:00:26
                        Reset counter: 69
                        Mileage: 104990 km
                        Date: 2020.05.26
                        Time: 16:43:12
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000439094602
       Coding: 2680009100209F000020000300001D0D0F1C4700A6080261000000000000030200080034000000
       Shop #: WSC 06325 123 12345
       VCID: 7AF11DFEF59F105645-802E
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 130731  H11 0050
       Serial number: 90243014130723155619
       Coding: 01DD13
       Serial number: 21652870
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000308130164
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R72YY02
       Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H04 0012
       Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H04 0012
                        Fault Status: 01100101
                        Reset counter: 69
                        Mileage: 104990 km
                        Date: 2020.05.26
                        Time: 16:52:46
    02658 - Power Output Stage for Left Headlight (J667); Incorrectly Coded
                        Reset counter: 69
                        Mileage: 104990 km
                        Date: 2020.05.26
                        Time: 16:52:46
    02659 - Power Output Stage for Right Headlight (J668); Incorrectly Coded
                        Reset counter: 69
                        Mileage: 104990 km
                        Date: 2020.05.26
                        Time: 16:52:46
    01229 - A/C Humidity Sensor (G260)
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 69
                        Mileage: 104990 km
                        Date: 2020.05.26
                        Time: 16:52:49
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
       Component: AirbagVW-AU10 H47 0610
       Serial number: 003GPDB09P4K
       Coding: 303634313432303030304A55304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 4797B40AFEEDBDBE8A-8012
       Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
       Serial number: 5810000R130000F34T
       Serial number: 6334MSME7C712675K
       Serial number: 6344MSME7D742B76V
       Serial number: 6352QSME14354E7ET
       Serial number: 6362QSME6135386CM
       Serial number: 63732SME5C3916787
       Serial number: 63832SME5C391A489
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862MHR000GD
       Coding: 000017
       VCID: 4895B736FBF3B2C683-801C
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 982 A    HW: 8R0 920 982 A
       Component: KOMBIINSTR.   H35 0563
       Revision: 00300000    Serial number: WZE24PU8E
       Coding: 83BF22000B01D705020000
       Shop #: WSC 26348 004 104857
       Component: GW-BEM 5CAN-M H11 0056
       Revision: 1Z110028    Serial number: 2841Z138120003
       Coding: 80CF03FF00
       Shop #: WSC 06335 123 12345
       VCID: 4C9D8B26EF8B5EE6A7-8018
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 40205B28291461796306
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0076
       Revision: AA000000    Serial number: 00000072240714
       Coding: 01581B00000000000000
       VCID: 4281A51EDDCF98965D-8016
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0312714733
       Coding: 010211
       Shop #: WSC 06334 000 00000
       VCID: 3F87ACEAA63DF57E32-806A
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0313278237
       Coding: 010211
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000071679201
       Coding: 011D13205E00440004
       VCID: 4FA79C2A1E9D65FEC2-801A
       Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
       Component: RCEPS         H38 0507
       Revision: 00001000    Serial number: 0012759425
       Coding: 100000000001
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3B7FD8FAB225E95E1E-806E
       Revision: 00002001    Serial number: 0312970358
       Coding: 0126023A20BA709784A0053600040047
       Shop #: WSC 06334 123 12345
       Component: GTO BF  H01 0080
       Serial number: 00000000000000714945
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H05 0220
       Revision: 00005001    Serial number: 94813018967303
       VCID: 2D5BE6A2745177EE90-8078
       Revision:             Serial number: 0000071699308
       VCID: 4E99812E19976CF6C9-801A
       Part No SW: 8K0 907 801 M    HW: 8K0 907 801 J
       Component: EPB-4         H01 0004
       Revision: --------    Serial number: 20000000320427
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3973C2F2B819DB4E0C-806C
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 156H90D7838629
       Coding: 020007010000000001
       VCID: 244D0386279BB6A64F-8070
       Part No SW: 8R1 035 746 D    HW: 8R1 035 746 D
       Component: H-BNT-NA      H40 0738
       Revision: --------    Serial number: 204H+0D7595327
       Coding: 160200060005A1EF51028B4E00000403140000000000000000
       VCID: 3875C7F68B13C246F3-806C
       Subsystem 1 - Part No: 8R0 060 884 BD
       Component: NAR 2013/2014  0802
       Component: DU7 High  H42 0104
       Serial number: A130HM0D2804430
       Serial number: 00000001591133
       Component: CD-Database  5298
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000072214610
       Coding: 010C13204000240004
       VCID: 4689B90EF1E7A4B671-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H08---    Serial number: 525PA8-J36A3G5
       Coding: 1020010
       VCID: 346DF3C6577B2626DF-8060
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B7FD8FABA25E95E1E-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000072214726
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H09 0010
       Revision: 00000000    Serial number: 131910095
       ROD: EV_RDCMA00100.rod
       VCID: 2B5FE8BA424579DE8E-807E
    End-------------------------(Elapsed Time: 04:53)--------------------------
    Jan 2015
    here code from 09, A4
    26000011863CAFE0210048C300003D0D0F9CD388A2090221000008004000010200020030000000
    Last edited by Uwe; 05-28-2020 at 03:53 PM. Reason: CODE tags (because the dumb forum software insists on breaking up strings that long)
    GOOD CHEAP FAST
  5. Likes Uwe liked this post
    Verified VCDS User Mrclopec's Avatar
    May 2015
    Nipomo, CA
    You must have missed this bit of advice in your duplicate thread...
    Quote Originally Posted by Mrclopec View Post
    The front level sensor is REQUIRED.
    The headlights do not do the left/right dance like a VW. They will only dip and go back up so thats normal.
    The power output modules are not directly coded. They will sync with the BCM automatically once your coding is correct.
    I have a 2015 Q5 with factory AFS. You can compare my 09 coding to yours.
    From what I remember, the basic settings procedure will just put the headlights into adjustment mode for you to make manual adjustments via the adjustment points on the headlights and then when you click next/done the procedure is complete.
    None of this will work if you don't have your coding correct and all hardware installed properly.
    Break out your wiring diagram and VERIFY VERIFY VERIFY.
    I retrofit not because I settled for a car that didn't have everything. I retrofit for the challenge!
    ... why starting duplicate threads is always a bad idea
  8. Likes Uwe liked this post
    OK, closing this thread. Carry on here:
    https://forums.ross-tech.com/showthread.php?23167
