Results 1 to 10 of 11
Thread: 2012 Audi S3 ABS Issues
    May 2020
    South Africa
    Quote Originally Posted by Shade View Post
    Thank you, thank you. It worked.
    Hi Everybody
    thanks for letting me join the forum i am a newbie and require some help please
    I have a 2012 Audi S3 and it been parked off since nov last year.
    I am no expert but like to try DIY.
    my dash had lit up like a christmas tree,so i started trouble shooting hardware.
    I started by changing the left rear wheel speed sensors, then checked wiring harnesses, changed wheel bearings etc all to try figure out the issue.
    I did a dsg service and repaired my megatronix which turned out to be fine as i thought my box was the issue, in the end a gearbox specialist for DSGs. said my abs module is affecting DSG.
    So had to replace my pump with a used ABS pump, but find the same module part number, which took months as new is crazy expensive.
    I then sent in my ECU and abs module for a check and the ECU was fine and the abs pump module was defective.
    I managed to get the original long code accepted and all adaptions done but still the abs light is on and esp etc even after adaptations are done.
    Would anyone be so kind to put me out my pain please?
    full scan below: not sure how to put in the freeze pane sorry
    Tuesday,26,May,2020,18:01:36:05766
    VCDS Version: 20.4.0.1 (x64)
    VIN: WAUZZZ8P4CA077386   License Plate:
    Chassis Type: 8P-AU35 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 47 4C 52 55 56 77
    VIN: WAUZZZ8P4CA077386   Mileage: 144620km-89862miles
    02-Auto Trans -- Status: Malfunction 1010
    04-Steering Angle -- Status: Sporadic communication error 1000
    44-Steering Assist -- Status: Malfunction 1010
    4C-Tire Pressure II -- Status: Sporadic communication error 1000
    Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 8P0 907 115 AQ    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0010
       Revision: 5BH20---    Serial number: AUX7Z0K9FNI0MT
       Coding: 0103000C1C0F0060
       Shop #: WSC 78134 027 46855
       VCID: 010F67EE581F8C8E0D-8054
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage - MIL ON
                        Fault Status: 11100100
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:18:20
                        Temperature: 27.0C
                        Temperature: 20.0C
                        Absolute Pres.: 860.0 mbar
                        Voltage: 12.446 V
    000051 - Turbocharger Bypass Valve Control Circuit
                   P0033 - 004 - Malfunction / Open Circuit
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:33:38
                        RPM: 1110 /min
                        Load: 26.3 %
                        Temperature: 28.0C
                        Temperature: 21.0C
                        Voltage: 11.938 V
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 008 -  - Intermittent
                        Mileage: 144614 km
                        Date: 2020.04.25
                        Time: 21:17:59
                        RPM: 1423 /min
                        Load: 14.9 %
                        Temperature: 30.0C
                        Temperature: 14.0C
                        Absolute Pres.: 850.0 mbar
                        Voltage: 14.224 V
    Readiness: 0100 0101
       Part No SW: 02E 300 013     HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2201
       Revision: 05151112    Serial number: 00001005240361
       Shop #: WSC 06314 000 00000
       VCID: 4E958CD2D9C1A3F6C0-801A
    18223 - Pressure Control Valve 1
                P1815 - 008 - Short to Plus - Intermittent
                        Fault Frequency: 255
                        Reset counter: 40
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 02:22:07
    17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
                P0702 - 001 -  - Intermittent
                        Fault Status: 00100001
                        Reset counter: 8
                P0702 - 002 -  - Intermittent
                        Reset counter: 8
                        Mileage: 144614 km
                        Date: 2020.04.21
                        Time: 18:35:37
       Revision: 00H31001
       Coding: 1342401209290101C80E02EC901F80A1000410
       Shop #: WSC 00020 790 12345
       VCID: 7BF31506FAF3E65E57-802E
    03841 - RPM Sensor Rear Left: Incorrect Signal
                        Reset counter: 18
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:20:12
                        Count: 3
                        Count: 14
                        Count: 29440
                        Count: 71
                        Count: 43776
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 18
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:20:12
                        Count: 3
                        Count: 14
                        Count: 29440
                        Count: 8193
                        Count: 43776
    02186 - Engine <-> ADR Interface
                        Reset counter: 18
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:20:12
                        Count: 3
                        Count: 14
                        Count: 29440
                        Count: 8206
                        Count: 43776
       Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
       Component: KlimavollautomatH09 0180
       Revision: 000488      Serial number: 8P0820043BM
       VCID: 78F90A0A0BC5CD463A-802C
    65535 - Internal Control Module Memory Error
                        Fault Status: 00100011
                        Reset counter: 55
                        Mileage: 144548 km
                        Date: 2020.03.09
                        Time: 17:07:34
                        Temperature: 36.0C
    01177 - Engine Control Unit
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:03:51
    00532 - Supply Voltage B+
                        Reset counter: 58
                        Voltage: 6.70 V
                        Reset counter: 58
                        Time: 00:00:30
                        Temperature: 19.0C
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 N    HW: 8P0 907 063 N
       Component: BCM PQ35  M   110 0667
       Revision: AJ110667
       Coding: 46000A2FA007F200207241E00100094C407E26AA306DD928E40008840040
       Shop #: WSC 01661 996 98713
       VCID: 3F8BA116AE6B3A7E3B-806A
       Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer AU350  H11 0050
       Coding: 00DD13
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 024C2D
       Component: Innenraumuebe  H04 0020
       Subsystem 5 - Part No: 1K0 907 719 C
       Component: Neigungssenso  005 0003
    16 Faults Found:
    01134 - Alarm Horn (H12)
                        Reset counter: 15
                        Mileage: 144534 km
                        Date: 2020.03.08
                        Time: 18:10:48
                        Voltage: 12.65 V
                            Term 50 Off
    00927 - Terminal 30 (Right)
                        Fault Status: 00101011
                        Reset counter: 55
                        Mileage: 144534 km
                        Time: 31:63:63
                            Term 15 Off
                        Voltage: 12.30 V
                            Term 50 Off
                        Fault Frequency: 91
                        Reset counter: 55
                        Mileage: 144542 km
                        Date: 2020.03.09
                        Time: 16:02:49
                        Voltage: 13.70 V
                            Term 50 Off
    01516 - Terminal 30; Left
                        Reset counter: 55
                        Mileage: 144542 km
                        Date: 2020.03.09
                        Time: 16:34:02
                        Voltage: 13.60 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 56
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:04
                        Voltage: 12.20 V
                            Term 50 Off
                        Fault Frequency: 60
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:26
                        Voltage: 12.10 V
                            Term 50 Off
                        Fault Frequency: 89
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:26
                        Voltage: 12.10 V
                            Term 50 Off
                        Fault Frequency: 88
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:27
                        Voltage: 12.10 V
                            Term 50 Off
                        Fault Frequency: 35
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:28
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:02:26
                        Voltage: 12.15 V
                            Term 50 Off
                        Reset counter: 58
                        Mileage: 144565 km
                        Date: 2020.04.20
                        Time: 07:43:17
                            Term 15 Off
                        Voltage: 7.90 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 58
                        Mileage: 144565 km
                        Date: 2020.04.20
                        Time: 07:50:53
                            Term 15 Off
                        Voltage: 7.25 V
                            Term 50 Off
    01598 - Drive Battery Voltage
                        Reset counter: 58
                        Mileage: 144566 km
                        Date: 2020.04.20
                        Time: 00:05:51
                        Voltage: 13.80 V
                            Term 50 Off
    00323 - Vehicle Inclination Sensor (G384)
                        Reset counter: 58
                        Mileage: 144580 km
                        Date: 2020.04.20
                        Time: 00:32:26
                            Term 15 Off
                        Voltage: 6.70 V
                            Term 50 Off
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 58
                        Mileage: 144580 km
                        Time: 31:63:63
                        Voltage: 17.75 V
                            Term 50 Off
                        Reset counter: 58
                        Mileage: 144580 km
                        Date: 2020.04.20
                        Time: 00:00:05
                        Voltage: 11.15 V
                            Term 50 Off
    Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
       Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
       Component: Airbag AU1042 H09 0250
       Revision: --------    Serial number: 003JU004DLRV
       Coding: 303142413039303030384A55305238503053
       ROD: EV_Airba10AURB4.rod
       VCID: 52AD98A205F9C716E4-8006
       Serial number: 34928RB4000065EC00DW
       Serial number: 35028RB4000065EA2C4R
       Serial number: 35128RB4000065EC03ET
       Serial number: 35228RB4000065EA296S
       Serial number: 35547RB400006747AB7W
       Serial number: 35647RB400006747A38Q
    13635840 - Supply voltage
                        Reset counter: 58
                        Time: 00:00:00
       Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
       Coding: 0014142
       VCID: 4685B4F231B16BB678-8012
       Component: E0221           H06 0030
    Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
       Part No SW: 8P0 920 932 P    HW: 8P0 920 932 P
       Component: KOMBIINSTR. VDO H02 0150
       Revision: D0H02002    Serial number: 2249K002001325
       Coding: 0273828
       Shop #: WSC 80093 222 69422
       VCID: 418FA7EE189F4C8E4D-8014
                        Fault Status: 00101010
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:01:06
                        Reset counter: 40
                        Mileage: 144580 km
                        Date: 2020.04.20
                        Time: 00:32:40
       Revision:   H42       Serial number: 210911F2001960
       Coding: 350101
       VCID: 3567C33E9C57F02EE1-8060
                        Fault Status: 00110100
                        Reset counter: 56
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:02
                        Reset counter: 55
                        Mileage: 144542 km
                        Date: 2020.03.09
                        Time: 16:02:49
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:02
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:02
    03109 - Tire Pressure Monitoring Control Module 2 (J793)
                        Reset counter: 55
                        Mileage: 144542 km
                        Date: 2020.03.09
                        Time: 16:02:53
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 4587B3FE0CB760AE71-8010
                        Fault Frequency: 113
                        Reset counter: 36
                        Mileage: 3618101 km
                        Time Indication: 4
                        Work Shop Code: 00768
                        Raw, Form. N/A: 000 000 000
    00625 - Vehicle Speed Signal
                        Fault Status: 01110001
                        Reset counter: 36
                        Mileage: 3618101 km
                        Time Indication: 4
       Revision: D0H02002    Serial number: AUX7Z0K9FNI0MT
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
       Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
       Component: Tuer-SG         H04 0101
       Coding: 0000532
       VCID: 499FBFCE20AF84CE95-801C
    00100 - Drivers Interior Locking Button (E308)
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 234    3201
       Revision: 00H20000
       VCID: 3461FE3A572DE926D6-8060
                        Fault Frequency: 47
                        Reset counter: 20
                        Mileage: 144625 km
                        Date: 2020.05.26
                        Time: 17:57:01
                        Voltage: 11.88 V
                            DD
                        Temperature: 18.0C
    16351 - Control Module - Programming Error
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 15
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:39
                        Battery Volts: 12.2 V
                            DU
                        Temperature: 29.0C
                        Hex Value: 0x0000
                        Hex Value: 0x4800
                        Count: 63304
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:00:39
                        Voltage: 12.25 V
                            DU
                        Temperature: 29.0C
                        RPM: 1498 /min
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
    02391 - Terminal 30 Reference
                        Reset counter: 55
                        Voltage: 12.25 V
                            PD
                        Temperature: 20.0C
                        Speed: 50.0 km/h
                        Torque: 0.0 Nm
                        Torque: 0.000 Nm
       Part No SW: 8P3 035 382 E    HW: 8P3 035 382 E
       Component: AB2 SUBWOOFERBOXH31 0160
       Revision: 00007       Serial number: 92157116284631
       VCID: 3567C33E5C57F02EE1-8060
                        Reset counter: 58
                        Mileage: 144580 km
                        Date: 2020.04.20
                        Time: 00:32:45
                        Temperature: 23.0C
       Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
       Coding: 0003604
       VCID: 4A9D80C225A98FD69C-801E
    00106 - Signal Central Locking SAVE/LOCK Passenger Side
       Component: ****LWR12**** H02 0011
       Serial number: 111016-0002-069
       Coding: 1161A51010002000
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428DA8E2D599579654-8016
    8 Faults Found:
    0068 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:11:58
    0074 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 36
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:03:50
    0076 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 55
                        Time: 00:00:00
    0078 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 69
                        Reset counter: 55
                        Mileage: 144542 km
                        Date: 2020.03.09
                        Time: 16:02:49
    0082 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 24
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:03:50
    0084 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 22
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:04:27
    0086 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Fault Frequency: 42
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:01:35
    0088 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:12:02
       Part No SW: 8P0 035 186 AB    HW: 8P0 035 186 AB
       Component: R Concert2+     H05 0293
       Revision: 00H05000    Serial number: AUZ1Z3L2352079
       Coding: 0710111
       VCID: 72ED38226DB9A71604-8026
       Part No SW: 8P1 862 335 A    HW: 8P1 862 335
       Component: FSE_256x BT     H44 0660
       Revision: 00000000    Serial number: 00000005456350
       Coding: 0001292
                        Reset counter: 58
                        Mileage: 144580 km
                        Date: 2020.04.20
                        Time: 00:01:48
                        Reset counter: 58
                        Mileage: 144580 km
                        Date: 2020.04.20
                        Time: 00:02:34
    End-------------------------(Elapsed Time: 02:48)--------------------------
    I have tried even a code from a golf 6 R no luck either.
    Aug 2016
    Eindhoven, NB, NL
    Can you please clear all codes and make a new scan? This is unreadable with all these intermittent errors
  3. Likes Uwe liked this post
    Since this is not another 2011 Golf, I've split this question into its own thread.
    May 2020
    South Africa
    will do thanks
    May 2020
    South Africa
    So cleared all the codes and drove the car as is...
    heres the new scan requested- please helps Gents, thanks?
    Wednesday,27,May,2020,19:57:29:05766
    VIN: WAUZZZ8P4CA077386   Mileage: 144630km-89868miles
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:18:20
                        Temperature: 27.0C
                        Temperature: 20.0C
                        Voltage: 12.446 V
                        Mileage: 144614 km
                        Date: 2020.04.22
                        Time: 00:33:38
                        RPM: 1110 /min
                        Load: 26.3 %
                        Temperature: 28.0C
                        Temperature: 21.0C
                        Voltage: 11.938 V
                        Mileage: 144614 km
                        Date: 2020.04.25
                        Time: 21:17:59
                        RPM: 1423 /min
                        Load: 14.9 %
                        Temperature: 30.0C
                        Temperature: 14.0C
                        Voltage: 14.224 V
    Readiness: 0000 0101
       Revision: 00H31001
                        Reset counter: 20
                        Mileage: 144625 km
                        Date: 2020.05.27
                        Time: 19:23:11
                        Count: 3
                        Count: 14
                        Count: 13056
                        Count: 71
                        Count: 50432
                        Reset counter: 20
                        Mileage: 144625 km
                        Date: 2020.05.27
                        Time: 19:23:11
                        Count: 3
                        Count: 14
                        Count: 13056
                        Count: 8193
                        Count: 50432
                        Reset counter: 20
                        Mileage: 144625 km
                        Date: 2020.05.27
                        Time: 19:23:11
                        Count: 3
                        Count: 14
                        Count: 13056
                        Count: 8206
                        Count: 50432
                        Reset counter: 55
                        Mileage: 144548 km
                        Date: 2020.03.09
                        Time: 17:07:34
                        Temperature: 36.0C
                        Reset counter: 55
                        Mileage: 144550 km
                        Date: 2020.03.10
                        Time: 00:03:51
                        Reset counter: 58
                        Voltage: 6.70 V
                        Reset counter: 58
                        Time: 00:00:30
                        Temperature: 19.0C
       Coding: 0014142
       Coding: 0273828
       Coding: 350101
       Coding: 0000005
       Coding: 0000532
       Revision: 00H20000
                        Reset counter: 21
                        Mileage: 144638 km
                        Date: 2020.05.27
                        Time: 19:45:00
                        Voltage: 14.00 V
                            DU
                        Temperature: 34.0C
                        RPM: 755 /min
    Address 46: Central Conv.
       Coding: 0003604
       Coding: 0710111
       Coding: 0001292
    End-------------------------(Elapsed Time: 02:22)--------------------------
    United States
    Hello Matthew,
    I'm in the process of updating your forum status and moving this to the Car Repair Support section. After doing so I'll see if I can make any suggestions that help.
    United States
    After reviewing the scans and e-mail I believe 1K0 907 379 BJ was the factory installed 03-ABS module and the reusing the original coding should be perfectly fine. If you happen to have a scan saved with the original 03-ABS module installed please post it because I suspect the current coding is incorrect.
  9. Likes Uwe, iichel, PetrolDave, Fredrick Awuor liked this post
  10. #8
    United States
    Please use the original coding from the oldest scan but I searched and located 3 RHD 8P chassis cars with this CDLC engine and believe a solid baseline (no VIN Bytes) is:
    16008000090000006800010090000081380000
    For that reason I believe yours was likely factory coded to something more like:
    1642801209290001680E01EC901F00813F0000
    .. but I'm not sure if I got Byte 16 (TPMS and similar) configured perfectly.
    Either way, the existing coding in the above scans is not correct so if an earlier scan cannot be located my coding would be worth a shot and we can fine tune it as needed based on the next current condition scan.
  11. #9
    United States
    PR-Code list for WAUZZZ8P4CA077386
    Per our most recent e-mail conversation I asked the OP to post the original condition scan in conjunction with the newest condition scan but there was a concern with TPMS. For that reason I'm posting the complete PR-Code list obtained using PL24:
    Vehicle Identification No. WAUZZZ8P4CA077386
    Model audi s3 qu. 2.0 A3
    Date of production 04.11.2011
    Model year 2012
    Sales type 8P1S4L
    Engine Code CDLC
    Transmission Code NJE
    Axle drive 6A
    Equipment ZN
    Roof color T9
    Carpet color code
    Exterior color / Paint Code T9 / Y9C
    Seat combination no.
    Number of Z-Orders
    Special editions E0A Without special action equipment
    Lockable wheel bolts 1PD Wheel bolts with anti-theft protection (unlockable)
    Vehicle class differentiation powertrains/platform parts 0HC Vehicle class differentiation -8P0-
    Tailpipes 0P1 Rear side exhaust tailpipe
    Hill start assist UG1 Hill start assist
    Emission standard 7MG Emission standard EU5
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UE Airbag for driver and front passenger
    Activated carbon canister/gasoline particulate filter 1E1 Activated carbon canister
    Label for central electric system 0W2 Label for central electric system English-speaking countries
    Storage compartment package QE0 Without storage compartment package/box
    Exterior mirror adjustment 6XC Exterior mirrors: power-adjustable
    Follow-on warranty EA0 Without subsequent warranty
    Left exterior mirror 5SJ Left exterior mirror, convex
    Right exterior mirror 6TS Right exterior mirror, aspherical, large viewing field
    Drive type 1X1 Four-wheel drive
    Ambient temperature display 9Y1 Ambient temperature display
    Equipment lines A9D Version ambition
    Rear brakes 1KW Disc brakes in rear
    batteries J0L Battery 340 A (70 Ah)
    Front brakes 1ZK Disc brakes in front
    Components with special surface 6FC exterior mirror housing aluminum
    Beverage holders 4M0 Without beverage holder
    Battery/alternator capacities NY2 Increased battery capacity
    Component sets for country-specific prescriptive standards B2E Component parts set, complying with vehicle type for South Africa, various parts
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AT Electronic stability control (ESC)
    Owner's manuals 0VF Information kit in English
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Heated washer nozzles 9T0 Without heated washer nozzles
    CD-ROM/DVD/SD card 7QA Without CD/DVD for navigation
    CD changer/CD player 7A0 Without CD changer/CD player
    Driving mode selection 2H0 Without "drive select"
    General operating license additions C00 Operating permit, initial registration
    Cd-enhancing underbody panel 2D0 Without cd enhancing underbody panel
    Roof rails/roof rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FE Tilting and sliding glass sunroof with sunbshade
    Shock absorption in rear UB5 Rear shock absorption for sports version
    Decorative films/emblems 6F3 Emblems
    Shock absorption in front G12 Shock absorption in front
    Load-through hatch/ski bag 3X0 without load through system
    Tank filler neck for unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    Installation differentiation for vehicle parts 0ES Installation differentiation for transmission DQ250 -- vehicle components --
    Theft protection system 7AL Anti-theft alarm system, interior monitoring, backup horn and towing protection
    Inserts 5TG Decorative inserts, brushed, matte aluminum
    Scuff plates 7M2 Scuff plates in door apertures with "S" emblem
    Park distance control 7X0 Without park distance control
    Electric interface for external use UF0 Without electric interface
    Differentiation for manufacturing process 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    Hood prop/tailgate vent lock 5NC Standard tailgate vent lock
    Pedal cluster VF1 pedal cluster
    Headlight activation 8K1 Separate daytime running light
    Vehicle tracking system 7G0 Without preparation for VTS (Vehicle Tracing System)
    Alternators 8GU Alternator 140 A
    Weight category for rear axle 0YC Weight range 3 installation control only, no requirement forecast
    Weight category for front axle L30 Suspension range 30 installation control only, no requirement forecast
    Base engine TA2 4-cylinder SI engine 2.0 l unit 06F.D
    cruise control system 8T2 Electronic cruise control system (CCS)
    Garage door opener VC0 without Garage door opener
    Transmission specification G0R 6-speed automatic transmission for four-wheel drive
    Rear trim panel 6V1 Rear trim panel (ECE)
    Manufacturer A51 Audi AG
    Rear spoiler 5J3 Roof spoiler
    Wiper and washer system for rear windows 8M1 Rear window wiper washer system with intermittent wipe
    Molded headliner 6NJ Standard molded headliner
    Rear seats 3NZ Rear bench seat, not split, split backrest, folding
    Heating system/air conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Main headlamps 8BP Bi-functional headlamp with gas discharge lamp
    Customized installation FC1 Customized installation
    Dashboard inserts U1A Instrument cluster with km/h speedometer, clock, tachometer and trip odometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Body forms K8G Hatchback
    Luggage compartment floor covering 6SS Luggage compartment floor covering
    Cassette/CD storage compartment 4W0 without cassette / CD tray
    Cool box 1W0 Without refrigerator/glove compartment cooling system
    Child seats QA0 without child seat
    Climate zones 0Y2 Tropical zones
    Head restraints in rear 3Q6 Three rear head restraints
    Head restraints 3J1 Hight-adjustable head restraints for front seats
    Fuel tank material treatment 2LC Fuel tank with special material treatment (coextrusion)
    Fuel filling volume 1Z2 Increase in initial standard fuel filling
    Fuel quality 0U1 Fuel quality 95-91 RON
    Fuel systems 1A5 Fuel system for fuel-injected SI engine
    Body measures 5C0 Without special body measures
    Child seat anchors in front 3G0 Without child seat anchora in front (ISOFIX)
    License plate carrier in front 6W6 License plate carrier in front
    Paint preservation/transport protection 5K5 Transport protection film with additional transport protection measures
    Lighting package (lighting) QQ5 With additional lights (interior lighting)
    Steering system setup L0R Right-hand drive
    Steering system 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H9 Backrest release for front seats with Easy Entry feature
    Lumbar support in backrests 7P0 Without lumbar support in seat backrests
    steering wheels 2PK Leather-wrapped multi-function sports steering wheel with tiptronic
    Driving on the left/right side AV0 Driving on the left
    Loudspeaker installation 9VD active loudspeakers
    Headlight range control 8Q3 Dynamic headlight range control (self-adjusting while driving)
    Center armrest 6E3 Center armrest in front
    Variants FN0 "S" variant
    Multi-function display/trip computer 9Q7 Multi-function display/trip computer
    Engine cooling 8Z6 Hot country
    Engine specification D81 4-cylinder SI engine 2.0 l/188 kW (16V) turbo FSI, homogeneous base engine is TA2
    Navigation system 7Q0 without navigation system
    rear fog lamp 8TB rear fog lamp
    Front fog lamps/additional headlamps 8WB Front fog lamps
    Model upgrade measures GP0 Vehicles without special upgrade measures
    Rear floor panel platform module 4P0 Rear floor panel module, type 1
    Platform group class 7PE Platform group class 5
    Audi Sport/ Quattro GmbH FQ1 Wheels of Audi Sport/ Quattro GmbH
    Quality class AQ0 Standard-production quality
    Wheels C1B Alloy wheels 7.5J x 18
    Radios 8UD Radio "concert"
    Smoker's/non-smoker's version 9JD Smoker's package, ashtray in front
    Tire pressure monitoring system 7K6 Tire pressure monitoring system
    tire HM4 Tires 225/40 R18 92Y xl
    Tire suppliers V0A Tires without specification of tire brand
    Spare wheel/breakdown kit 1G8 Breakdown kit
    Type of tire VG6 Type of tire: design 2
    Side airbag 4X3 Side airbag in front, with curtain airbag
    Gearshift knob/gearshift handle 7F9 Gearshift knob/handle in plastic/leather
    Self pick-up/special control A00 No self-collection
    Special labels 0SS Labels in English and French
    Seat in front, left 3TG Sports comfort seat in front, left
    Seat in front, right 3SG Sports comfort seat, front, right
    Seat belt reminder 9P1 Seat belt reminder, electric contact in buckle
    Center seat belts in rear 3C7 3-point seat belt for center rear seat
    seat covers N3U Seat trim covers in leather/fabric
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A0 without seat heater
    Safety certificates 1QF Special labels safety certificate for South Africa
    Safety head restraint system 3K3 with safety head restraint system
    Start-stop system/regenerative braking 7L3 Without start-stop system without regenerative braking
    Voice control system/voice control QH0 without voice control
    Side and rear windows 4KC Side and rear windows in heat-insulating glass
    Sun blind for rear/side windows 3Y6 Sunshade for rear window
    Outlet 7B0 without socket
    Bumper 2JU Standard bumpers
    Rear stabilizer bar 0BE Rear stabilizer bar
    Front stabilizer bar 0AE Front stabilizer bar
    Control of production/pre-production FA0 Control of series production
    Heavy-duty/sports version 2UC Sports version
    Headlamp washer system 8X1 Headlamp washer system
    Intermittent windshield wiper control/ light/rain sensor 8N1 Windshield wiper intermittent control
    Special approval measures 3M3 Passenger car design
    Protection frame (rollover bar) 2Y0 Without protection frame
    Nameplate set 0NA Without nameplate set (without model designation)
    Door and tailgate/trunk lid locking mechanism 4K4 Central locking w/ radio remote control
    Type-approval testing countries/ countries with specific requirements B53 Type approval country South Africa
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Transport protection NT1 Transit coating (type 2)
    doors 0A1 2 doors
    TV reception/digital radio reception QV0 Without TV reception/digital radio reception
    Front-end underbody cladding 1SB Additional front underbody guard
    Identification labels 1EY Special identification label with weight data, but without general operating permit (ROW)
    Type signs 2Z1 Type sign at rear and "Quattro" nameplates respectively
    First aid kit/warning triangle 1T3 First aid kit with warning triangle
    Telephone/telematics 9ZX Telephone preparation for cellphone
    Maintenance contract EW0 Without maintenance contract
    Wind deflector 7S0 Without windbreak
    LongLife Service Regime QG1 LongLife Service Regime
    Thermal energy storage system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield 4GP Windshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
    Washer fluid level indicator 8W1 Washer fluid level indicator
    Additional tires (snow tires) 2WA without spare tyre
    floor mats 0TD Front and rear floor mats
    Decorative trims 4ZP Decorative trims
    Additional child seat anchorage 3B0 Without additional child seat anchors
    Additional dust seals 6U0 Without additional seals outside
    Auxiliary heater 9M0 Without auxiliary heater/parking heater
  12. Likes Uwe liked this post
  13. #10
    May 2020
    South Africa
    [snip]
    Hi Everybody
    Sorry been so busy this week.
    Big update, my abs and esp lights are off finally thanks to DANA!!!
    Only small issue is the TPMS light is on, maybe i need to reset my pressures stored? or should the portion of the code (bits) be changed?
    Dana has asked me to provide a new scan.
    I will do this today.
  14. Likes Uwe liked this post
