2012 Audi S3 ABS Issues
MLGCUP177
South Africa
C?ID=232795
Thank you, thank you. It worked.
Hi Everybody
thanks for letting me join the forum i am a newbie and require some help please:facepalm::)
I have a 2012 Audi S3 and it been parked off since nov last year.
I am no expert but like to try DIY.
my dash had lit up like a christmas tree,so i started trouble shooting hardware.
I started by changing the left rear wheel speed sensors, then checked wiring harnesses, changed wheel bearings etc all to try figure out the issue.
I did a dsg service and repaired my megatronix which turned out to be fine as i thought my box was the issue, in the end a gearbox specialist for DSGs. said my abs module is affecting DSG.
So had to replace my pump with a used ABS pump, but find the same module part number, which took months as new is crazy expensive.
I then sent in my ECU and abs module for a check and the ECU was fine and the abs pump module was defective.
I managed to get the original long code accepted and all adaptions done but still the abs light is on and esp etc even after adaptations are done.
Would anyone be so kind to put me out my pain :cry:please?
full scan below: not sure how to put in the freeze pane sorry:confused:
Tuesday,26,May,2020,18:01:36:05766
VCDS Version: 20.4.0.1 (x64)
VIN: WAUZZZ8P4CA077386   License Plate:
Chassis Type: 8P-AU35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 47 4C 52 55 56 77
VIN: WAUZZZ8P4CA077386   Mileage: 144620km-89862miles
04-Steering Angle -- Status: Sporadic communication error 1000
44-Steering Assist -- Status: Malfunction 1010
4C-Tire Pressure II -- Status: Sporadic communication error 1000
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8P0 907 115 AQ    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0010
   Revision: 5BH20---    Serial number: AUX7Z0K9FNI0MT
   Coding: 0103000C1C0F0060
   Shop #: WSC 78134 027 46855
   VCID: 010F67EE581F8C8E0D-8054
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage - MIL ON
                    Fault Status: 11100100
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:18:20
                    Load: 0.0 %
                    Temperature: 27.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 860.0 mbar
                    Voltage: 12.446 V
000051 - Turbocharger Bypass Valve Control Circuit
               P0033 - 004 - Malfunction / Open Circuit
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:33:38
                    RPM: 1110 /min
                    Load: 26.3 %
                    Temperature: 28.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -  - Intermittent
                    Mileage: 144614 km
                    Date: 2020.04.25
                    Time: 21:17:59
                    RPM: 1423 /min
                    Load: 14.9 %
                    Temperature: 30.0°C
                    Temperature: 14.0°C
                    Absolute Pres.: 850.0 mbar
                    Voltage: 14.224 V
Readiness: 0100 0101
   Part No SW: 02E 300 013     HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2201
   Revision: 05151112    Serial number: 00001005240361
   Shop #: WSC 06314 000 00000
   VCID: 4E958CD2D9C1A3F6C0-801A
18223 - Pressure Control Valve 1
            P1815 - 008 - Short to Plus - Intermittent
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 02:22:07
17086 - Transm. Control Module Electrical Malf. (SAE) or Control Module Defective (VAG)
            P0702 - 001 -  - Intermittent
                    Fault Status: 00100001
                    Reset counter: 8
            P0702 - 002 -  - Intermittent
                    Reset counter: 8
                    Mileage: 144614 km
                    Date: 2020.04.21
                    Time: 18:35:37
   Revision: 00H31001
   Coding: 1342401209290101C80E02EC901F80A1000410
   Shop #: WSC 00020 790 12345
   VCID: 7BF31506FAF3E65E57-802E
03841 - RPM Sensor Rear Left: Incorrect Signal
                    Reset counter: 18
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:20:12
                    Count: 3
                    Count: 14
                    Count: 29440
                    Count: 71
                    Count: 43776
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 18
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:20:12
                    Count: 3
                    Count: 14
                    Count: 29440
                    Count: 8193
                    Count: 43776
02186 - Engine <-> ADR Interface
                    Reset counter: 18
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:20:12
                    Count: 3
                    Count: 14
                    Count: 29440
                    Count: 8206
                    Count: 43776
   Part No SW: 8P0 820 043 BM    HW: 8P0 820 043 BM
   Component: KlimavollautomatH09 0180
   Revision: 000488      Serial number: 8P0820043BM
   VCID: 78F90A0A0BC5CD463A-802C
                    Fault Status: 00100011
                    Reset counter: 55
                    Mileage: 144548 km
                    Date: 2020.03.09
                    Time: 17:07:34
                    Temperature: 36.0°C
01177 - Engine Control Unit
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:03:51
00532 - Supply Voltage B+
                    Reset counter: 58
                    Voltage: 6.70 V
                    Reset counter: 58
                    Time: 00:00:30
                    Temperature: 19.0°C
   Part No SW: 8P0 907 063 N    HW: 8P0 907 063 N
   Component: BCM PQ35  M   110 0667
   Revision: AJ110667
   Coding: 46000A2FA007F200207241E00100094C407E26AA306DD928E40008840040
   Shop #: WSC 01661 996 98713
   VCID: 3F8BA116AE6B3A7E3B-806A
   Subsystem 1 - Part No SW: 8P2 955 119 F    HW: 8P2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H11 0050
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
   Subsystem 3 - Part No: 8P0 951 177
   Component: Innenraumuebe  H04 0020
   Subsystem 5 - Part No: 1K0 907 719 C
   Component: Neigungssenso  005 0003
16 Faults Found:
01134 - Alarm Horn (H12)
                    Reset counter: 15
                    Mileage: 144534 km
                    Date: 2020.03.08
                    Time: 18:10:48
                        Term 15 On
                    Voltage: 12.65 V
                        Term 50 Off
00927 - Terminal 30 (Right)
                    Fault Status: 00101011
                    Reset counter: 55
                    Mileage: 144534 km
                    Time: 31:63:63
                        Term 15 Off
                    Voltage: 12.30 V
                        Term 50 Off
01316 - ABS Control Module
                    Fault Frequency: 91
                    Reset counter: 55
                    Mileage: 144542 km
                    Date: 2020.03.09
                    Time: 16:02:49
                        Term 15 On
                    Voltage: 13.70 V
                        Term 50 Off
01516 - Terminal 30; Left
                    Reset counter: 55
                    Mileage: 144542 km
                    Date: 2020.03.09
                    Time: 16:34:02
                        Term 15 On
                    Voltage: 13.60 V
                        Term 50 Off
                    Fault Frequency: 7
                    Reset counter: 56
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:04
                        Term 15 On
                    Voltage: 12.20 V
                        Term 50 Off
                    Fault Frequency: 60
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:26
                        Term 15 On
                    Voltage: 12.10 V
                        Term 50 Off
                    Fault Frequency: 89
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:26
                        Term 15 On
                    Voltage: 12.10 V
                        Term 50 Off
                    Fault Frequency: 88
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:27
                        Term 15 On
                    Voltage: 12.10 V
                        Term 50 Off
                    Fault Frequency: 35
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:28
                        Term 15 On
                    Voltage: 12.10 V
                        Term 50 Off
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:02:26
                        Term 15 On
                    Voltage: 12.15 V
                        Term 50 Off
                    Reset counter: 58
                    Mileage: 144565 km
                    Date: 2020.04.20
                    Time: 07:43:17
                        Term 15 Off
                    Voltage: 7.90 V
                        Term 50 Off
                    Fault Frequency: 7
                    Reset counter: 58
                    Mileage: 144565 km
                    Date: 2020.04.20
                    Time: 07:50:53
                        Term 15 Off
                    Voltage: 7.25 V
                        Term 50 Off
01598 - Drive Battery Voltage
                    Reset counter: 58
                    Mileage: 144566 km
                    Date: 2020.04.20
                    Time: 00:05:51
                        Term 15 On
                    Voltage: 13.80 V
                        Term 50 Off
                    Reset counter: 58
                    Mileage: 144580 km
                    Date: 2020.04.20
                    Time: 00:32:26
                        Term 15 Off
                    Voltage: 6.70 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 58
                    Mileage: 144580 km
                    Time: 31:63:63
                        Term 15 On
                    Voltage: 17.75 V
                        Term 50 Off
                    Reset counter: 58
                    Mileage: 144580 km
                    Date: 2020.04.20
                    Time: 00:00:05
                        Term 15 On
                    Voltage: 11.15 V
                        Term 50 Off
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 S    HW: 8P0 959 655 S
   Component: Airbag AU1042 H09 0250
   Revision: --------    Serial number: 003JU004DLRV
   Coding: 303142413039303030384A55305238503053
   ROD: EV_Airba10AURB4.rod
   VCID: 52AD98A205F9C716E4-8006
   Serial number: 34928RB4000065EC00DW
   Serial number: 35028RB4000065EA2C4R
   Serial number: 35128RB4000065EC03ET
   Serial number: 35228RB4000065EA296S
   Serial number: 35547RB400006747AB7W
   Serial number: 35647RB400006747A38Q
13635840 - Supply voltage
                    Reset counter: 58
                    Time: 00:00:00
   Component: J0527           H37 0070
   Coding: 0014142
   VCID: 4685B4F231B16BB678-8012
   Component: E0221           H06 0030
   Part No SW: 8P0 920 932 P    HW: 8P0 920 932 P
   Component: KOMBIINSTR. VDO H02 0150
   Revision: D0H02002    Serial number: 2249K002001325
   Coding: 0273828
   Shop #: WSC 80093 222 69422
   VCID: 418FA7EE189F4C8E4D-8014
                    Fault Status: 00101010
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:01:06
                    Reset counter: 40
                    Mileage: 144580 km
                    Date: 2020.04.20
                    Time: 00:32:40
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 210911F2001960
   Coding: 350101
   VCID: 3567C33E9C57F02EE1-8060
                    Fault Status: 00110100
                    Reset counter: 56
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:02
                    Reset counter: 55
                    Mileage: 144542 km
                    Date: 2020.03.09
                    Time: 16:02:49
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:02
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:02
03109 - Tire Pressure Monitoring Control Module 2 (J793)
                    Reset counter: 55
                    Mileage: 144542 km
                    Date: 2020.03.09
                    Time: 16:02:53
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 4587B3FE0CB760AE71-8010
                    Fault Frequency: 113
                    Reset counter: 36
                    Mileage: 3618101 km
                    Time Indication: 4
                    Work Shop Code: 00768
                    Raw, Form. N/A: 000 000 000
00625 - Vehicle Speed Signal
                    Fault Status: 01110001
                    Reset counter: 36
                    Mileage: 3618101 km
                    Time Indication: 4
   Revision: D0H02002    Serial number: AUX7Z0K9FNI0MT
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0000532
   VCID: 499FBFCE20AF84CE95-801C
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
00100 - Drivers Interior Locking Button (E308)
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 234    3201
   Revision: 00H20000
   Shop #: WSC 02069 000 90108
   VCID: 3461FE3A572DE926D6-8060
                    Fault Frequency: 47
                    Reset counter: 20
                    Mileage: 144625 km
                    Date: 2020.05.26
                    Time: 17:57:01
                    Voltage: 11.88 V
                        DD
                    Temperature: 18.0°C
16351 - Control Module - Programming Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 15
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:39
                    Battery Volts: 12.2 V
                        DU
                    Temperature: 29.0°C
                    Hex Value: 0x0000
                    Hex Value: 0x4800
                    Count: 63304
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:00:39
                    Voltage: 12.25 V
                        DU
                    Temperature: 29.0°C
                    RPM: 1498 /min
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
02391 - Terminal 30 Reference
                    Reset counter: 55
                    Voltage: 12.25 V
                        PD
                    Temperature: 20.0°C
                    Speed: 50.0 km/h
                    Torque: 0.0 Nm
                    Torque: 0.000 Nm
                        Term 15 On
   Part No SW: 8P3 035 382 E    HW: 8P3 035 382 E
   Component: AB2 SUBWOOFERBOXH31 0160
   Revision: 00007       Serial number: 92157116284631
   VCID: 3567C33E5C57F02EE1-8060
                    Reset counter: 58
                    Mileage: 144580 km
                    Date: 2020.04.20
                    Time: 00:32:45
                    Temperature: 23.0°C
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0003604
   VCID: 4A9D80C225A98FD69C-801E
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
00106 - Signal Central Locking SAVE/LOCK Passenger Side
   Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0011
   Serial number: 111016-0002-069
   Coding: 1161A51010002000
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428DA8E2D599579654-8016
8 Faults Found:
0068 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:11:58
0074 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 36
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:03:50
0076 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 6
                    Reset counter: 55
                    Time: 00:00:00
0078 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 69
                    Reset counter: 55
                    Mileage: 144542 km
                    Date: 2020.03.09
                    Time: 16:02:49
0082 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 24
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:03:50
0084 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 22
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:04:27
0086 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Fault Frequency: 42
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:01:35
0088 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:12:02
Address 56: Radio        Labels: 8J0-035-1xx-56.clb
   Part No SW: 8P0 035 186 AB    HW: 8P0 035 186 AB
   Component: R Concert2+     H05 0293
   Revision: 00H05000    Serial number: AUZ1Z3L2352079
   Coding: 0710111
   VCID: 72ED38226DB9A71604-8026
   Part No SW: 8P1 862 335 A    HW: 8P1 862 335
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005456350
   Coding: 0001292
                    Reset counter: 58
                    Mileage: 144580 km
                    Date: 2020.04.20
                    Time: 00:01:48
                    Reset counter: 58
                    Mileage: 144580 km
                    Date: 2020.04.20
                    Time: 00:02:34
End-------------------------(Elapsed Time: 02:48)--------------------------
I have tried even a code from a golf 6 R no luck either.
iichel
Netherlands, eastern part
C?ID=284912
Can you please clear all codes and make a new scan? This is unreadable with all these intermittent errors
Since this is not another 2011 Golf, I've split this question into its own thread.
MLGCUP177
South Africa
C?ID=232795
So cleared all the codes and drove the car as is...
heres the new scan requested- please helps Gents, thanks:thanks:?
Wednesday,27,May,2020,19:57:29:05766
VIN: WAUZZZ8P4CA077386   Mileage: 144630km-89868miles
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:18:20
                    Load: 0.0 %
                    Temperature: 27.0°C
                    Temperature: 20.0°C
                    Voltage: 12.446 V
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:33:38
                    RPM: 1110 /min
                    Load: 26.3 %
                    Temperature: 28.0°C
                    Temperature: 21.0°C
                    Voltage: 11.938 V
                    Mileage: 144614 km
                    Date: 2020.04.25
                    Time: 21:17:59
                    RPM: 1423 /min
                    Load: 14.9 %
                    Temperature: 30.0°C
                    Temperature: 14.0°C
                    Voltage: 14.224 V
Readiness: 0000 0101
   Revision: 00H31001
                    Reset counter: 20
                    Mileage: 144625 km
                    Date: 2020.05.27
                    Time: 19:23:11
                    Count: 3
                    Count: 14
                    Count: 13056
                    Count: 71
                    Count: 50432
                    Reset counter: 20
                    Mileage: 144625 km
                    Date: 2020.05.27
                    Time: 19:23:11
                    Count: 3
                    Count: 14
                    Count: 13056
                    Count: 8193
                    Count: 50432
                    Reset counter: 20
                    Mileage: 144625 km
                    Date: 2020.05.27
                    Time: 19:23:11
                    Count: 3
                    Count: 14
                    Count: 13056
                    Count: 8206
                    Count: 50432
                    Reset counter: 55
                    Mileage: 144548 km
                    Date: 2020.03.09
                    Time: 17:07:34
                    Temperature: 36.0°C
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:03:51
                    Reset counter: 58
                    Voltage: 6.70 V
                    Reset counter: 58
                    Time: 00:00:30
                    Temperature: 19.0°C
Unable to communicate with address 09. Are you sure the doors are unlocked?
   Coding: 0014142
   Coding: 0273828
   Coding: 350101
   Coding: 0000005
   Coding: 0000532
   Revision: 00H20000
                    Reset counter: 21
                    Mileage: 144638 km
                    Date: 2020.05.27
                    Time: 19:45:00
                    Voltage: 14.00 V
                        DU
                    Temperature: 34.0°C
                    RPM: 755 /min
Address 46: Central Conv.
   Coding: 0003604
   Coding: 0710111
   Coding: 0001292
End-------------------------(Elapsed Time: 02:22)--------------------------
Dana
Western PA, USA
Hello Matthew,
I'm in the process of updating your forum status and moving this to the Car Repair Support section. After doing so I'll see if I can make any suggestions that help.
Dana
Western PA, USA
After reviewing the scans and e-mail I believe 1K0 907 379 BJ was the factory installed 03-ABS module and the reusing the original coding should be perfectly fine. If you happen to have a scan saved with the original 03-ABS module installed please post it because I suspect the current coding is incorrect.
Dana
Western PA, USA
Please use the original coding from the oldest scan but I searched and located 3 RHD 8P chassis cars with this CDLC engine and believe a solid baseline (no VIN Bytes) is:
16008000090000006800010090000081380000
For that reason I believe yours was likely factory coded to something more like:
1642801209290001680E01EC901F00813F0000
.. but I'm not sure if I got Byte 16 (TPMS and similar) configured perfectly.
Either way, the existing coding in the above scans is not correct so if an earlier scan cannot be located my coding would be worth a shot and we can fine tune it as needed based on the next current condition scan.
Dana
Western PA, USA
PR-Code list for WAUZZZ8P4CA077386
Per our most recent e-mail conversation I asked the OP to post the original condition scan in conjunction with the newest condition scan but there was a concern with TPMS. For that reason I'm posting the complete PR-Code list obtained using PL24:
Vehicle Identification No.WAUZZZ8P4CA077386
Modelaudi s3 qu. 2.0 A3
Date of production04.11.2011
Model year2012
Sales type8P1S4L
Engine CodeCDLC
Transmission CodeNJE
Axle drive6A
EquipmentZN
Roof colorT9
Carpet color code
Exterior color / Paint CodeT9 / Y9C
Seat combination no.
Number of Z-Orders
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PDWheel bolts with anti-theft protection (unlockable)
Vehicle class differentiation powertrains/platform parts0HCVehicle class differentiation -8P0-
Tailpipes0P1Rear side exhaust tailpipe
Hill start assistUG1Hill start assist
Emission standard7MGEmission standard EU5
Trailer hitch1D0Without trailer hitch
airbag4UEAirbag for driver and front passenger
Activated carbon canister/gasoline particulate filter1E1Activated carbon canister
Label for central electric system0W2Label for central electric system English-speaking countries
Storage compartment packageQE0Without storage compartment package/box
Exterior mirror adjustment6XCExterior mirrors: power-adjustable
Follow-on warrantyEA0Without subsequent warranty
Left exterior mirror5SJLeft exterior mirror, convex
Right exterior mirror6TSRight exterior mirror, aspherical, large viewing field
Drive type1X1Four-wheel drive
Ambient temperature display9Y1Ambient temperature display
Equipment linesA9DVersion ambition
Rear brakes1KWDisc brakes in rear
batteriesJ0LBattery 340 A (70 Ah)
Front brakes1ZKDisc brakes in front
Components with special surface6FCexterior mirror housing aluminum
Beverage holders4M0Without beverage holder
Battery/alternator capacitiesNY2Increased battery capacity
Component sets for country-specific prescriptive standardsB2EComponent parts set, complying with vehicle type for South Africa, various parts
vehicle tools and jack1S1vehicle tools and jack
Brake systems1ATElectronic stability control (ESC)
Owner's manuals0VFInformation kit in English
Brake pad wear indicator9U1Brake pad wear indicator
Heated washer nozzles9T0Without heated washer nozzles
CD-ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Driving mode selection2H0Without "drive select"
General operating license additionsC00Operating permit, initial registration
Cd-enhancing underbody panel2D0Without cd enhancing underbody panel
Roof rails/roof rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FETilting and sliding glass sunroof with sunbshade
Shock absorption in rearUB5Rear shock absorption for sports version
Decorative films/emblems6F3Emblems
Shock absorption in frontG12Shock absorption in front
Load-through hatch/ski bag3X0without load through system
Tank filler neck for unleaded fuel/fuel type2G7Filler neck module 1 with insert
Installation differentiation for vehicle parts0ESInstallation differentiation for transmission DQ250 -- vehicle components --
Theft protection system7ALAnti-theft alarm system, interior monitoring, backup horn and towing protection
Inserts5TGDecorative inserts, brushed, matte aluminum
Scuff plates7M2Scuff plates in door apertures with "S" emblem
Park distance control7X0Without park distance control
Electric interface for external useUF0Without electric interface
Differentiation for manufacturing process0FAStandard manufacturing sequence
window regulator4R4Power windows with comfort operation and circuit breaker
Hood prop/tailgate vent lock5NCStandard tailgate vent lock
Pedal clusterVF1pedal cluster
Headlight activation8K1Separate daytime running light
Vehicle tracking system7G0Without preparation for VTS (Vehicle Tracing System)
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
Alternators8GUAlternator 140 A
Weight category for rear axle0YCWeight range 3 installation control only, no requirement forecast
Weight category for front axleL30Suspension range 30 installation control only, no requirement forecast
Base engineTA24-cylinder SI engine 2.0 l unit 06F.D
cruise control system8T2Electronic cruise control system (CCS)
Garage door openerVC0without Garage door opener
Transmission specificationG0R6-speed automatic transmission for four-wheel drive
Rear trim panel6V1Rear trim panel (ECE)
ManufacturerA51Audi AG
Rear spoiler5J3Roof spoiler
Wiper and washer system for rear windows8M1Rear window wiper washer system with intermittent wipe
Molded headliner6NJStandard molded headliner
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating system/air conditioning system9AKClimatronic with impact pressure control, CFC-free
Main headlamps8BPBi-functional headlamp with gas discharge lamp
Customized installationFC1Customized installation
Dashboard insertsU1AInstrument cluster with km/h speedometer, clock, tachometer and trip odometer
Breakaway interior rearview mirror4L6Breakaway interior rearview mirror, auto-dimming
Body formsK8GHatchback
Luggage compartment floor covering6SSLuggage compartment floor covering
Cassette/CD storage compartment4W0without cassette / CD tray
Cool box1W0Without refrigerator/glove compartment cooling system
Child seatsQA0without child seat
Climate zones0Y2Tropical zones
Head restraints in rear3Q6Three rear head restraints
Head restraints3J1Hight-adjustable head restraints for front seats
Fuel tank material treatment2LCFuel tank with special material treatment (coextrusion)
Fuel filling volume1Z2Increase in initial standard fuel filling
Fuel quality0U1Fuel quality 95-91 RON
Fuel systems1A5Fuel system for fuel-injected SI engine
Body measures5C0Without special body measures
Child seat anchors in front3G0Without child seat anchora in front (ISOFIX)
License plate carrier in front6W6License plate carrier in front
Paint preservation/transport protection5K5Transport protection film with additional transport protection measures
Lighting package (lighting)QQ5With additional lights (interior lighting)
Steering system setupL0RRight-hand drive
Steering system1N3Speed-related variable steering assist (Servotronic)
Backrest release3H9Backrest release for front seats with Easy Entry feature
Lumbar support in backrests7P0Without lumbar support in seat backrests
steering wheels2PKLeather-wrapped multi-function sports steering wheel with tiptronic
Driving on the left/right sideAV0Driving on the left
Loudspeaker installation9VDactive loudspeakers
Headlight range control8Q3Dynamic headlight range control (self-adjusting while driving)
Center armrest6E3Center armrest in front
VariantsFN0"S" variant
Multi-function display/trip computer9Q7Multi-function display/trip computer
Engine cooling8Z6Hot country
Engine specificationD814-cylinder SI engine 2.0 l/188 kW (16V) turbo FSI, homogeneous base engine is TA2
Navigation system7Q0without navigation system
rear fog lamp8TBrear fog lamp
Front fog lamps/additional headlamps8WBFront fog lamps
Model upgrade measuresGP0Vehicles without special upgrade measures
Rear floor panel platform module4P0Rear floor panel module, type 1
Platform group class7PEPlatform group class 5
Audi Sport/ Quattro GmbHFQ1Wheels of Audi Sport/ Quattro GmbH
Quality classAQ0Standard-production quality
WheelsC1BAlloy wheels 7.5J x 18
Radios8UDRadio "concert"
Smoker's/non-smoker's version9JDSmoker's package, ashtray in front
Tire pressure monitoring system7K6Tire pressure monitoring system
tireHM4Tires 225/40 R18 92Y xl
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G8Breakdown kit
Type of tireVG6Type of tire: design 2
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/gearshift handle7F9Gearshift knob/handle in plastic/leather
Self pick-up/special controlA00No self-collection
Special labels0SSLabels in English and French
Seat in front, left3TGSports comfort seat in front, left
Seat in front, right3SGSports comfort seat, front, right
Seat belt reminder9P1Seat belt reminder, electric contact in buckle
Center seat belts in rear3C73-point seat belt for center rear seat
seat coversN3USeat trim covers in leather/fabric
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety certificates1QFSpecial labels safety certificate for South Africa
Safety head restraint system3K3with safety head restraint system
Start-stop system/regenerative braking7L3Without start-stop system without regenerative braking
Voice control system/voice controlQH0without voice control
Side and rear windows4KCSide and rear windows in heat-insulating glass
Sun blind for rear/side windows3Y6Sunshade for rear window
Outlet7B0without socket
Bumper2JUStandard bumpers
Rear stabilizer bar0BERear stabilizer bar
Front stabilizer bar0AEFront stabilizer bar
Control of production/pre-productionFA0Control of series production
Heavy-duty/sports version2UCSports version
Headlamp washer system8X1Headlamp washer system
Intermittent windshield wiper control/ light/rain sensor8N1Windshield wiper intermittent control
Special approval measures3M3Passenger car design
Protection frame (rollover bar)2Y0Without protection frame
Nameplate set0NAWithout nameplate set (without model designation)
Door and tailgate/trunk lid locking mechanism4K4Central locking w/ radio remote control
Type-approval testing countries/ countries with specific requirementsB53Type approval country South Africa
Carrier frequency for remote control5D1Carrier frequency 433.92 to 434.42 Mhz
Partition3CAwithout partition
Transport protectionNT1Transit coating (type 2)
doors0A12 doors
TV reception/digital radio receptionQV0Without TV reception/digital radio reception
Front-end underbody cladding1SBAdditional front underbody guard
Identification labels1EYSpecial identification label with weight data, but without general operating permit (ROW)
Type signs2Z1Type sign at rear and "Quattro" nameplates respectively
First aid kit/warning triangle1T3First aid kit with warning triangle
Telephone/telematics9ZXTelephone preparation for cellphone
Maintenance contractEW0Without maintenance contract
Wind deflector7S0Without windbreak
LongLife Service RegimeQG1LongLife Service Regime
Thermal energy storage system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield4GPWindshield in heat-insulating glass with sunshield and viewing window for vehicle identification number
Washer fluid level indicator8W1Washer fluid level indicator
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TDFront and rear floor mats
Decorative trims4ZPDecorative trims
Additional child seat anchorage3B0Without additional child seat anchors
Additional dust seals6U0Without additional seals outside
Auxiliary heater9M0Without auxiliary heater/parking heater
MLGCUP177
South Africa
C?ID=232795
[snip]
Hi Everybody
Sorry been so busy this week.
Big update, my abs and esp lights are off finally thanks to DANA!!!:thanks::thanks::thanks::thumbs:
Only small issue is the TPMS light is on, maybe i need to reset my pressures stored? or should the portion of the code (bits) be changed?
Dana has asked me to provide a new scan.
I will do this today.
MLGCUP177
South Africa
C?ID=232795
Hi Everybody
Okay another update LOL
After my last post, I went to drive the S3.
did a full scan too:
Thursday,04,June,2020,07:07:33:05766
VIN: WAUZZZ8P4CA077386   Mileage: 144670km-89893miles
4C-Tire Pressure II -- Status: Cannot be reached 1100
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:18:20
                    Load: 0.0 %
                    Temperature: 19.0°C
                    Temperature: 21.0°C
                    Voltage: 11.557 V
                    Mileage: 144614 km
                    Date: 2020.04.22
                    Time: 00:33:38
                    RPM: 6322 /min
                    Load: 95.6 %
                    Speed: 109.0 km/h
                    Temperature: 78.0°C
                    Temperature: 12.0°C
                    Voltage: 13.843 V
                    Mileage: 144614 km
                    Date: 2020.04.25
                    Time: 21:17:59
                    RPM: 1423 /min
                    Load: 14.9 %
                    Temperature: 30.0°C
                    Temperature: 14.0°C
                    Voltage: 14.224 V
                    Load: 0.0 %
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
   Revision: 00H31001
   Coding: 1642801209290001680E01EC901F00813F0000
                    Reset counter: 22
                    Mileage: 144656 km
                    Date: 2020.06.04
                    Time: 06:36:35
                    Count: 14
                    Count: 13056
                    Count: 8193
                    Count: 50176
                    Count: 65281
                    Reset counter: 55
                    Mileage: 144548 km
                    Date: 2020.03.09
                    Time: 17:07:34
                    Temperature: 36.0°C
                    Reset counter: 55
                    Mileage: 144550 km
                    Date: 2020.03.10
                    Time: 00:03:51
                    Reset counter: 58
                    Voltage: 6.70 V
                    Reset counter: 58
                    Time: 00:00:30
                    Temperature: 19.0°C
   Revision: AJ110667
   Coding: 00DD13
   Coding: 024C2D
                    Reset counter: 22
                    Mileage: 144656 km
                    Date: 2020.06.04
                    Time: 06:36:34
                        Term 15 On
                    Voltage: 13.95 V
                        Term 50 Off
   Coding: 0014142
   Coding: 0273828
   Coding: 350101
                    Reset counter: 22
                    Mileage: 144656 km
                    Date: 2020.06.04
                    Time: 06:36:39
   Coding: 0000005
   Coding: 0000532
   Revision: 00H20000
   Coding: 0003604
   Coding: 0710111
   Coding: 0001292
End-------------------------(Elapsed Time: 02:32)--------------------------
TPMS malfunction error still.
Tried to reset the tyre pressures no luck!
So drove around some more to charge the battery.
Reconnected to ABS module and started looking at BIT 16 and Bit 17.
tried unticking the BIT 16 both boxes for Hill hold and TPMS system as my build sticker shows my car does not have TPMS;but the two coding changes was not accepted.
then tried BIT 17 worked on option for TPMS via cluster and use this coding update, coding accepted.
Final Code: 1642801209290001680E01EC901F00813F0400
I then restarted the car and NO error any more!:):):):):):):D
ABS horror story over!
Thanks Dana and the other peeps from Ross tech, they have been Super helpful, i wont be burning my car anymore LOL!
:thanks:
