Results 1 to 7 of 7
Thread: 2014 Q7 A/C
    May 2020
    Australia
    2014 Q7 A/C
    After removing the engine to fix the oil leak at the rear timing cover, I re-installed the engine/trans assembly With only the steering position sensor issue at the time which I sorted thanks to the Ross Tech help, I am trying to get the A/C recharged but I can't get the compressor to cut in with bottle pressure in the system. I have tested fans, cleared the code for the compressor control valve (N280 I think?) because I had it disconnected but can't find what is stopping the compressor from loading up. I don't know if I have to play with adaptations because of the disconnection? I haven't adjusted any adaptations other than the steer angle sensor since refitting the engine.
    Can anyone see something that I've missed?
    Tuesday,26,May,2020,20:27:00:15263
    VCDS Version: 20.4.1.0 (x64)
    VIN: WAUZZZ4L8ED035825   License Plate:
    Chassis Type: 4L-AU56 (4F0)
    Scan: 01 02 03 05 08 09 10 15 16 17 18 19 28 42 46 47 4F 52 55 56
              5F 62 69 6C 6D 6F 72
    VIN: WAUZZZ4L8ED035825   Mileage: 109640km-68127miles
    Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
       Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
       Component: 3.0TDI EDC17  X41 0003
       Revision: 53X41---    Serial number:
       Coding: 2A2A4012A52701020000
       Shop #: WSC 31414 790 00001
       ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
       ROD: EV_ECM30TDI0114L1910401H.rod
       VCID: 23451C742AEE679E36-8076
       Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
       Component: AL1000 AISIN  002 2447
       Coding: 001578
       Shop #: WSC 07763 002 1048576
       ASAM Dataset: EV_TCMAL991031 002112
       ROD: EV_TCMAL991031_002.rod
       VCID: 76E31520C9FCA23621-8022
    Address 03: ABS Brakes        Labels:. 4L0-910-517-V2.clb
       Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
       Component: ESP ALLRAD MK25E1   0020
       Revision: 00H02001
       Coding: 2196577
       Shop #: WSC 60575 001 1048576
       VCID: 3467EF285700F026DF-8060
       Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
       Component: FBSAUDIC6 ELV   H08 0200
       Revision: 00H08000    Serial number: 10603702127564
       Coding: 0000151
       VCID: 2541026CECDA99AE58-8070
       Subsystem 1 - Part No: 4F0 910 132 C
       Component: FBSAUDIC6 EZS   H04 0020
       Subsystem 2 - Part No: 4F0 910 335 B
       Component: FBSAUDIC6 KSG   H03 0020
    00190 - Driver's Door Handle Touch Sensor (G415)
                007 - Short to Ground
                        Fault Status: 01110111
                        Reset counter: 73
                        Mileage: 108279 km
                        Date: 2020.03.16
                        Time: 21:13:55
    00193 - Rear Right Door Handle Touch Sensor (G418)
                        Reset counter: 73
                        Mileage: 108279 km
                        Date: 2020.03.16
                        Time: 21:13:55
       Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AN
       Component: KLIMA 4 ZONEN H15 0070
       Revision: 00---031    Serial number: 00000000423985
       Coding: 01029456
       VCID: 2541026C2CDA99AE58-8070
       Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
       Component: ILM Fahrer      H31 0400
       Coding: 0023121
       VCID: 6FED20447EA693FEE2-803A
       Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AU716   H13 0110
       Coding: 00064792
       Shop #: WSC 31414
       Coding: 00150059
       Shop #: WSC 31414
    Address 10: Park/Steer Assist (J446)       Labels:| 4L0-919-475-7X2.clb
       Part No SW: 4L0 919 475 A    HW: 4H0 919 475 C
       Component: PARKHILFE 8K  H07 0011
       Revision: 11001001    Serial number: 55961409700521
       Coding: 29031F
       ASAM Dataset: EV_EPHVA18AU7160000 001001
       ROD: EV_EPHVA18AU7160000.rod
       VCID: 3467EF289F00F026DF-8060
       Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
       Component: 70 AIRBAG AUDI8RH45 0230
       Revision: 06H45000    Serial number: 00399D6066R-
       Coding: 0014128
       VCID: 2E53FD40B92CDAF6A9-807A
       Subsystem 1 - Serial number: 6332QSME743D4F46V
       Subsystem 2 - Serial number: 6342QSME773D0C4CY
       Subsystem 3 - Serial number: 6352QSME743D4E44U
       Subsystem 4 - Serial number: 6362QSME4D404946M
       Subsystem 5 - Serial number: 63734SME093D3F4AF
       Subsystem 6 - Serial number: 63834SME093D325E8
       Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
       Component: J0527               0830
       Revision: 00H09000    Serial number: 90026140790135
       Coding: 0102142
       VCID: 285F0B589BC884C663-807C
       Component: E0221           H03 0040
    Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
       Part No SW: 4L0 920 933 H    HW: 4L0 920 933 H
       Component: KOMBIINSTR.   H35 0332
       Revision: 00000000    Serial number: X2M50GA4F
       Coding: B356630400000008010704
       VCID: 326BE9306D14FE16CD-8066
    Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
       Part No SW: 4L0 910 105     HW: 4L0 815 071 H
       Component: Heizgeraet      H10 0140
       Revision: 0000000A    Serial number: 00000009024928
       Coding: 0000101
       VCID: 60CF5378B3783C866B-8034
       Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
       Component: GW-BEM 4CAN-M H06 0058
       Revision: LB700037    Serial number: 3700L144050AB8
       Coding: 00CF07
       VCID: 3E73CD00A94C2A7639-806A
       Subsystem 1 - Part No SW: 8K0 915 181 D    HW: 8K0 915 181 D
       Component: J367-BDM  H07 0125
       Serial number: 31078N18284121930888
       Serial number: 14099000795021200181
    Address 28: HVAC, Rear        Labels: None
       Part No SW: 4L0 910 158     HW: 4L0 919 158 AD
       Component: KLIMABETAETIGUNGH06 0060
       Revision: 00---011    Serial number: 00000030331375
       Coding: 0000006
       VCID: 68DF4B585B4844C6A3-803C
       Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
       Component: TSG FA        H12 0362
       Revision:             Serial number: 0000098720514
       Coding: 011C52204041440004
       VCID: 489FABD8FB8864C683-801C
    02126 - Central Locking Button; Exterior Door Handle
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 124
                        Mileage: 108279 km
                        Date: 2020.03.16
                        Time: 21:15:02
    01705 - Selection Switch for Mirror-Adjust (E48)
                        Fault Frequency: 61
                        Reset counter: 132
                        Mileage: 109385 km
                        Date: 2020.04.17
                        Time: 17:49:31
       Part No SW: 4L0 910 289 K    HW: 4L0 907 289 K
       Component: Komfortgeraet   H12 0130
       Revision: 0130 ---    Serial number: 01945611960000
       Coding: 3277197
       VCID: 387FDB184B681446F3-806C
       Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
       Component: BOSE G3 Q7    H04 0160
       Revision: CH004001    Serial number: 00000000038977
       Coding: 030000
       VCID: 29590E5C40C2BDCE7C-807C
       Part No SW: 4F0 910 280     HW: 4F0 907 280
       Component: ILM Beifahrer   H16 0100
       Revision:             Serial number: 00000000741415
       Coding: 0011001
       VCID: 5EB36D80890C0A7659-800A
       Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
       Component: TSG BF        H12 0362
       Revision:             Serial number: 0000098728995
       VCID: 479DA8E4F6966BBE8A-8012
       Part No SW: 8X0 907 357 C    HW: 8X0 907 357 B
       Serial number: 140414-0002-061
       Coding: 1147A71010000500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 428BB9F0D5B44E965D-8016
       Part No SW: 4G1 035 053 J    HW: 4G1 035 053
       Component: Radio U Basic H41 0133
       Revision: AB001007    Serial number: 227D60E7991279
       Coding: 040003010000000000
       VCID: 2643056051DC92B651-8072
       Part No SW: 4L2 035 764 G    HW: 4L2 035 764 G
       Component: H-BNT-RW      H48 0793
       Revision: --------    Serial number: 222DS0E7516117
       Coding: 180A0106000483EF010023456F6320035C0000000000000000
       Subsystem 1 - Part No: 8R0 060 884 BN
       Component: ROW 2014  0605
       Component: DU7 High  H42 0104
       Serial number: A130DA0E3001143
       Subsystem 3 - Part No SW: 4L0 919 614 C    HW: 4L0 919 614 C
       Component: E0380 Bedient  H01 0060
       Serial number: 00000002177647
       Component: CD-Database  5571
       Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
       Component: TSG HL        H11 0362
       Revision:             Serial number: 0000099877752
       Coding: 010850204041230004
       VCID: 4683A5E0F19C72B671-8012
    Address 69: Trailer (J345)       Labels:. 4E0-907-383.clb
       Part No SW: 4E0 907 383 J    HW: 4E0 907 383 J
       Revision: 2A001001    Serial number: 00000193421681
       Coding: 0300000000000000
       Shop #: WSC 12345 123 12345
       VCID: 3169E63C6812C50EB4-8064
       Part No SW: 4L0 907 428     HW: 7P6 907 441 D
       Component: TopView       H05 0293
       Revision: 11001001    Serial number: 82330JF0142720
       Coding: 020C010001000100000102000000
       ASAM Dataset: EV_CamSysteCorneViewAUDI 004005
       ROD: EV_CamSysteCorneViewAUDI.rod
       VCID: 6ED33D40B1AC9AF6E9-803A
       Part No SW: 4L0 910 945     HW: 4L0 827 851 F
       Component: ValeoHeckdeckel H58 0500
       Revision: --H58001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CD737484FB068E6C7-8038
       Subsystem 2 - Serial number: 6ó
       Subsystem 3 - Serial number: RD12.04.14--H58001002F0398˙
       Subsystem 4 - Serial number: 2F0398˙
       Part No SW: 4L0 910 290     HW: 4L0 907 290
       Component: ILM HINTEN 2    H08 0080
       Revision: AAH08080    Serial number: 0096855861----
       Coding: 0000001
       VCID: 65C1426CAC5A59AE98-8030
       Component: TSG HR        H11 0362
       Revision:             Serial number: 0000099875827
    End-------------------------(Elapsed Time: 03:43)--------------------------
    HQ
    General info that may be helpful.
    No codes in HVAC, so lets see if you have a shut down code... engine at idle, should be in 08-08-002.
    Some HVAC system do have basic settings, but if everything is to factory design, it will relearn after letting the engine idle for 20 or so minutes in most cases.
    Jef
  3. Likes Uwe liked this post
    May 2020
    Australia
    Jef, thanks for your reply, advice and information links.
    I can't believe how powerful this tool is, I've been working on electronic gear since Detroit and Cummins went that way and this thing is making me look like an idiot!
    I needed your direction to find any shut down codes, I have no labels at all when I'm in HVAC MVB, just data - sometimes. When I get to that location you directed me to I have 4 boxes of 0.0, so I'm guessing no shut down codes. There is no drop down box for a list to select from.
    When I check engine MVB, compressor torque shows 25Nm and requested 4.2Nm.
    I wasn't game to change any boxes in basic setting to have a look.
    This thing has run for 20 or more a number of times while I'm trying to diagnose and nothing has changed.
    My last check will be an incandescent bulb plugged in at the compressor - will a standard test light be suitable or is a bigger wattage globe needed?
    I appreciate your help.
    Geoff
    HQ
    If 08-08-002 is showing a value of 0.0 in the first field, that means the HVAC control module is wanting to run the compressor... pretty much "all systems are a go" type thing. Now having said that, if the compressor itself has an issue, then no AC. Pretty much like having a bad light bulb in the bathroom.... you can flip the switch on/off all day long, still going to be dark in there.
    Hook up your A/C gauges, what are the pressures when trying to run the system?
    Jef
  6. Likes Uwe liked this post
    May 2020
    Australia
    Thanks Jef,
    I have approx 70 pound high and low side, which is pretty close to what the electronics tell me as well.
    I reckon it's the compressor as you've said, a standard test light with an incandescent bulb to complete the last test at the plug on the compressor do or does it need a higher wattage globe?
    Thanks for your help.
    Geoff
    HQ
    From Peter's HVAC stick post:
    Typical N280-Refrigerant Regulating Valve resistance (on working vehicle) = 10-12 Ω
    I can't say I know what watt bulb that would be..... lets see.. Ohms law says say 13V and 11Ω would be a bit over 1A and around 15watt, so ya got a 15watt bulb I guess?
    Jef
    May 2020
    Australia
    Jeff, thanks for your assistance and giving me a better understanding on the A/C system control operation.
    It all pointed to the compressor as you highlighted, I replaced that and recharged the system last night - and I get 6 degrees C at the vent and on a cool afternoon.
    VERY happy.
    Ross Tech support is invaluable.
    Much appreciated.
  10. Likes PetrolDave, Jef, Uwe liked this post
