Results 1 to 3 of 3
Thread: VW Touareg 2007 Tyre filling connection 007 short to ground-intermittent
    May 2020
    England
    There doesn't seem to be much info about this fault,
    it has been looked into thoroughly in the past changing the filler valve didn't cure it,
    changing the module also didn't cure it,
    so my guy who had been through the wiring diagram could only cure it by bypassing the valve and wiring in a resistor,
    that cured it for sometime but now its back, any ideas?
    Thanks.....
    Address 34: Level Control Labels: 7Lx-907-553-34.clb
    Part No: 7L0 907 553 G
    Component: LUFTFDR.-CDC- 3C3P1 3112
    Coding: 0015521
    Shop #: WSC 01544 002 1048576
    VCID: 372B2D37035B40D3A21-5184
    00311 - Tire Filling Connection
    Also if anyone can shed some light on the lamda sensor fault too, that would be great.
    Monday,25,May,2020,15:43:29:27718
    VIN: WVGZZZ7LZ8D017168   License Plate:
    Chassis Type: 7L (6N0)
    Scan: 01 02 03 05 08 09 15 16 17 18 19 22 34 37 46 55 56 68 69 76
              77
    VIN: WVGZZZ7LZ8D017168   Mileage: 293400km-182310miles
    68-Wiper Electr. -- Status: OK 0000
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 7L0 907 401 F    HW: 7L0 907 401 D
       Component: 3.0L V6TDI  G001AG  0040
       Revision: --H04---    Serial number: VWX3Z0G3634463
       Coding: 0011775
       Shop #: WSC 12334 024 00000
       VCID: 2E050853FC01811BF17-5184
    009236 - Oxygen (Lambda) Sensor B1 S1 Voltage too Low / Air Leakage / Sample Error
                   P2414 - 002 -
                        Fault Status: 01110010
                        Fault Frequency: 14
                        Mileage: 292570 km
                        Date: 2020.05.07
                        Time: 04:21:46
                        RPM: 756 /min
                        Torque: 105.3 Nm
                        Duty Cycle: 1.0 %
                        Duty Cycle: 21.9 %
                        (no units): 0.0
                        (no units): 64.0
    008598 - Oxygen (Lambda) Sensor B1 S1
                   P2196 - 002 - Signal too High (Rich)
                        Mileage: 292584 km
                        Date: 2020.05.07
                        Time: 06:30:56
                        RPM: 1596 /min
                        Torque: 0.0 Nm
                        Speed: 47.0 km/h
                        Duty Cycle: 1.0 %
                        Duty Cycle: 23.9 %
                        (no units): 0.0
                        (no units): 80.0
       Part No SW: 09D 927 750 FA    HW: 09D 927 750 FA
       Component: AL 750 6A           0992
       Revision: 00H61000    Serial number:
       Coding: 0004456
       Shop #: WSC 31414 790 00001
       VCID: 72BDDC2328B9E5FB55F-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
       Part No SW: 7L0 907 379 K    HW: 7L0 907 379 K
       Component: ESP ALLRAD MK25E1   0302
       Revision: 00H53001
       Coding: 0004482
       VCID: 41DF43EF5DCF0E631C5-8014
       Part No SW: 3D0 909 137 D    HW: 5WK 485 05
       Component: 20 Kessy            6840
       Revision: 68406418    Serial number: VWX3Z0G3634463
       Coding: 0147688
       VCID: 2809FE4BDEB5DF2B3BB-807C
    00190 - Driver's Door Handle Touch Sensor (G415)
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 AD
       Component: CLIMAtronic R/L     4326
       Coding: 0000530
       VCID: 72BDDC2328E9E5FB55F-8026
                014 - Defective
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
       Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
       Component: J519                2000
       Revision: -0004---    Serial number: --------------
       Coding: 600004002B221C000000000000000000
       VCID: 005986EB1645C76B53B-8054
    Address 15: Airbags        Labels: 7L0-959-655.lbl
       Part No SW: 7L0 959 655     HW: 7L0 959 655
       Component: J234  37 VW8T       0250
       Revision: 92011025    Serial number: 0039P0025JL+
       Coding: 0013111
       VCID: 7AADF40370999DBB1DF-802E
       Part No: 7L6 953 549 F
       Component: J527                3601
       Coding: 0010011
       VCID: 42DD4CE358C9157B05F-8016
    Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
       Part No SW: 7L6 920 985 Q    HW: 7L6 920 985 Q
       Component: J285 KOMBI-INST.    7520
       Revision: KHH06V02
       Coding: 0007401
       Shop #: WSC 01184 210 175833
       VCID: 4BC361C76FC3D433F69-801E
                        Reset counter: 196
                        Mileage: 292890 km
                        Date: 2020.05.16
                        Time: 09:42:31
    Address 18: Aux. Heat        Labels: 7L6-819-008.clb
       Part No: 7L6 815 071 G
       Component: Standheizung E1MAC  0425
       Coding: 0000000
       VCID: 363520330441B9DBB97-8062
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 7L6 920 985 Q
       Component: J533  GW-K-CAN TP20 7520
       Coding: 7FE2E78BC8056003
       VCID: 70B9D62B26A5D7EBA3B-8024
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0119
       VCID: 7F5B05176BEBB8932A1-5160
       Coding: 0015521
    Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
       Part No: 7L6 919 887 P
       Component:      Navigation     0019
       Coding: 0000101
       VCID: 53F379A7B7F38CF3BE9-8006
       Part No: 7L6 959 933
       Component: 13 HSG              7124
       Coding: 0000085
       VCID: 7F5B05176BEBB8932A1-4B1E
       Subsystem 1 - Part No: 7L0 959 701 S
       Component: Tuersteuergeraet FS 6302
       Subsystem 2 - Part No: 7L0 959 702 S
       Component: Tuersteuergeraet BF 6302
       Subsystem 3 - Part No: 7L0 959 703 D
       Subsystem 4 - Part No: 7L0 959 704 D
       Subsystem 5 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
       Subsystem 6 - Part No: 7L6 951 171 B
       Component:    Innenraumsensor  0020
    00485 - Drivers Outside Door Handle Central Locking Button (E369)
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
       Component: AFS-Steuergeraet    0001
       Revision:   H02       Serial number:
       Coding: 1288451
       VCID: 392F2B0F351F56A3545-806C
       Component: AFS-Lst.-Modul l    X008
       Coding: 00000019
       Component: AFS-Lst.-Modul r    X008
       Coding: 00000019
    Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
       Part No: 7L6 035 186 G
       Component:        Radio        0019
       Coding: 0012432
       VCID: 372B2D37034B40D3A21-8062
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L6 955 119 A
       Component: J400__ Front Wiper  5101
       Coding: 0000341
       VCID: 38292E0B0E554FABABB-806C
       Component: RLS     220819 054  0403
       Coding: 00209069
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
       Component: ANHAENGERELEKTRONIK 8854
       VCID: 38292E0B0E154FABABB-806C
       Part No: 7L0 919 283 F
       Component: 0E Einparkhilfe     1107
    Address 77: Telephone        Labels: 3C0-035-730.lbl
       Part No SW: 7L6 035 730     HW: 7L6 035 730
       Component: Telefon             2209
       Revision: 00011000    Serial number: 0000000028905
       Coding: 0020041
       Shop #: WSC 00591 210 83198
       VCID: 6B83C1470F833433969-803E
    End----------(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.1V)-----------
    16.4905 S, 151.7375 W
    The fault code above means the [J197-Adaptive suspension control unit] sees a shorted wire to ground to the [E472-Tyre pressure operating unit].
    So if replacing the J197 and the E472 did not fix the concerns, it sounds like an 'overlay' harness will be the next logical step.
    Be sure you have checked these steps too.... Testing - Open Circuits, Short to Ground or Positive, etc....
    Just wanting to explain things a bit here and to help others understand the details:
    • The [E472] is connected to the [J197-Adaptive suspension control unit] via three wires.
    • There are two 'normally open' (NO) switches in the E472, with Pin-2 being the common.
    • The T4v connector is on the E472, located in the front passenger footwell.
    • The E472 is sometimes called the "Tire Inflation 'Cut-off' Control Head".
    • The J197 is located in the right side of the rear cargo area, behind the trim cover.
    We do recommend the use of the Official Factory Repair Information.
    Hope this helps,
    drpeter
    Peter is correct.
    OP remove FOD and perform repair that comports with RTFB please.
  4. Likes DrPeter liked this post
