Results 1 to 2 of 2
Thread: 2006 Passat 3C Sedan diesel Climatronic issue
    Feb 2020
    Victoria, Australia
    Hello all, this is my second post and the first question is how do I find my previous post after 3 weeks?
    Now, I bought a passat diesel with a transmission fault. I have resolved the issue but apparently my climatronic system is not working. I went through the first auto-scan results before trans fix it was ok, but now zero.
    the other weird thing is If I plug in a CC module it works but not properly. I have tried 4 other modules but non of them work. I have reason to believe I disturbed something. The unfortunate thing is I cannot find the pinout for my original 3 dial controller. I tried eWin but the module shown is the later one which is the cc one.
    Can my CC climatronic module be coded or some adaptation be done for full functionality? I don't know how to create a url link to my images yet but I have attached links to similar modules. the one with 3 dials being my Og and the the 2 dial one being the
    Or is there a procedure that I'm missing with my original module?
    https://images.app.goo.gl/KwdX91EfRy8LEjeGA
    https://images.app.goo.gl/57fqnKVk31hCxjwd9
    Orignal Scan:
    Self-Diagnosis Log
    Tuesday,21,April,2020,19:50:43:41695
    Page 5
    VIN: WVWZZZ3CZ7P046973 License Plate:
    Mileage: 144473 km
    Date: 2020.04.16
    Time: 07:49:29
    Address 03: ABS Brakes Labels:. 3C0-614-095-C2.clb
    Part No SW: 3C0 614 095 S HW: 3C0 614 095 S
    Component: ESP 440 C2 H015 0004
    Revision: H015 Serial number: 0667841377
    Coding: 0015653
    Shop #: WSC 00028 028 00001
    VCID: 322814D0AD8DBE16C4-8066
    Address 08: Auto HVAC Labels: 3C0-907-044.lbl
    Part No SW: 3C0 907 044 AH HW: 3C0 907 044 AH
    Component: ClimatronicPQ46 050 0505
    Revision: 00050005 Serial number: 00000000000000
    VCID: 679EB58456CF0BBEA3-8032
    Scan after trans fix:
    Monday,25,May,2020,17:54:55:41695
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    VIN: WVWZZZ3CZ7P046973   License Plate: SCAN W ORIGINAL CONTROLLER
    Mileage: 145010km-90105mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
    VIN: WVWZZZ3CZ7P046973   Mileage: 145010km-90105miles
    08-Auto HVAC -- Status: Cannot be reached 1100
    Address 01: Engine        Labels: 03G-906-018-BKP.clb
       Part No SW: 03G 997 020 T    HW: 03G 906 018 CE
       Component: R4 2.0l PPD1.5 G    5159
       Revision: --H25---    Serial number: VWZCZ000000000
       Coding: 0000078
       Shop #: WSC 30024 959 101054
       VCID: 393A23FC70FB4D4E05-806C
    005685 - Powertrain Data Bus
                   P1635 - 009 - Missing Message from A/C Controller
                        Reset counter: 40
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 05:51:02
                        RPM: 768 /min
                        Torque: 32.0 Nm
                            0.00 %
                        Voltage: 13.79 V
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
    Readiness: N/A
       Part No SW: 02E 300 042 S    HW: 02E 927 770 AE
       Component: GSG DSG         070 1127
       Revision: 04507000    Serial number: 00000607260992
       VCID: 2306E194E277279E3F-8076
       Coding: 0015653
       Part No SW: 3C0 937 049 J    HW: 3C0 937 049 J
       Component: Bordnetz-SG     H37 1301
       Revision: 00H37000    Serial number: 00000004316264
       Coding: E0808F0700041A00000A00000F00000000085D435C0000
       VCID: 302C1ED8A3818C06B2-8064
       Subsystem 1 - Part No: 3C2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer VW461  012  0503
       Coding: 00063445
       Shop #: WSC 00028
       Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
       Component: RLS     260706 014  1201
       Coding: 00208933
       Shop #: WSC 00028
                        Reset counter: 12
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 05:50:00
                        Voltage: 13.95 V
       Part No SW: 3C0 909 605 K    HW: 3C0 909 605 K
       Component: 16 AIRBAG VW8R  029 2521
       Revision: 10029000    Serial number: 003A3PDYSKKR
       Coding: 0012598
       VCID: 2E1000A0B9B59AF6A0-807A
       Subsystem 1 - Serial number: 6332MSME123C756EL
       Subsystem 2 - Serial number: 6342MSME123B0E5DL
       Subsystem 3 - Serial number: 6351HTS6PLL6CPN2F
       Subsystem 4 - Serial number: 6361HTS6VARQ8552
       Part No SW: 3C0 953 549 E    HW: 3C0 953 549 E
       Revision: 00007000    Serial number: 3C5953507P
       Coding: 0001111
       Part No SW: 3C0 920 871     HW: 3C0 920 871
       Component: KOMBIINSTRUMENT VD1 1614
       Revision: X0006000    Serial number: 00000000000000
       Coding: 0007705
       Shop #: WSC 00921 001 1048576
       VCID: 618AAB9CB8EB758E6D-8034
       Part No SW: 3C0 907 530 Q    HW: 3C0 907 951
       Component: J533  Gateway   H13 0172
       Revision:   H13       Serial number: 3620P10126061A
       Coding: FD807F0E000202000003
       Shop #: WSC 30024 959 101032
       VCID: 2F2E1DA4BEBF93FEAB-807A
                        Reset counter: 12
                        Mileage: 145016 km
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Subsystem 1 - Part No: 3C0 905 861 F
       Component:    ELV          026 0380
       3C0905861F     ELV          026 0380
       Component: J386  TUER-SG FT    1124
       Revision: 12006001    Serial number: 00000514168804
       Coding: 0000693
       VCID: 3B3639F47AC77F5E17-806E
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.136 H07 1806
       VCID: 35222FCC5CE3A92EE1-8060
       Component:    KSG PQ46 ELV 042 0472
       Coding: 00910A0001860E763004941570085F0B007800
       Shop #: WSC 30024 959 88134
                        Reset counter: 12
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 05:50:08
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1124
       Revision: 12006001    Serial number: 00000508968729
       Coding: 0000692
       VCID: 3C343AE87FC978661E-8068
       Revision:   013
       Coding: 0000012
       VCID: 210AEB9CF86B358E2D-8074
       Part No SW: 5K0 035 190     HW: 5K0 035 190
       Component: Radio RCD510  041 0167
       Revision: 00000001    Serial number: VWZ1Z3L5186785
       Coding: 0100040004
       VCID: 6288A4907DED6E9674-8036
       Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
       Component: J388   TUER-SG HL   1113
       Revision: 11005001    Serial number: 00000000425747
       Coding: 0000144
       VCID: 3D3237EC64D3716E29-8068
       Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
       Component: J389   TUER-SG HR   1113
       Revision: 11005001    Serial number: 00000000524430
       Coding: 0000144
       VCID: 3E3030E069D56A7630-806A
    Address 76: Park Assist        Labels: 3C0-919-283.lbl
       Part No SW: 3C0 919 283 B    HW: 3C0 919 283 B
       Component: Parkhilfe 8-Kan 004 0011
       Revision: 00004000    Serial number: 82930622903028
       Coding: 0001014
       VCID: 281CF6B89B51C4C66A-807C
    End----------(Elapsed Time: 01:36, VBatt start/end: 14.0V/14.0V)-----------
    Address 01: DTCs cleared
    Scan with my 2009 CC Climatronic module:
    Monday,25,May,2020,18:06:01:41695
    Chassis Type: 3C-VW46 (3C0)
       Coding: 0000078
    Readiness: N/A
       Coding: 0015653
       Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT
       Revision: 00003001
       Coding: 0000001002
       Shop #: WSC 00066 000 00187
       VCID: 7EB0F0E0E155AA7670-802A
              U1111 00 [009] - -
              [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                        Reset counter: 12
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 06:01:51
    9479189 - Signal Line for Air Quality Sensor
              B10A4 15 [009] - Open or Short to Plus
                        Reset counter: 12
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 06:01:51
       Coding: 00063445
       Shop #: WSC 00028
       Coding: 00208933
       Shop #: WSC 00028
       Coding: 0012598
       Coding: 0001111
       Coding: 0007705
       Coding: 0000693
       Coding: 0000692
       Revision:   013
       Coding: 0000012
       Coding: 0100040004
       Coding: 0000144
       Coding: 0000144
       Coding: 0001014
    End----------(Elapsed Time: 01:19, VBatt start/end: 14.1V/14.1V)-----------
       Coding: 0000078
    Readiness: N/A
       Coding: 0015653
       Revision: 00003001
       Coding: 0000001002
              U1111 00 [009] - -
                        Reset counter: 12
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 06:01:51
                        Reset counter: 12
                        Mileage: 145016 km
                        Date: 2020.04.23
                        Time: 06:01:51
       Coding: 00063445
       Shop #: WSC 00028
       Coding: 00208933
       Shop #: WSC 00028
       Coding: 0012598
       Coding: 0001111
       Coding: 0007705
       Coding: 0000693
       Coding: 0000692
       Revision:   013
       Coding: 0000012
       Coding: 0100040004
       Coding: 0000144
       Coding: 0000144
       Coding: 0001014
    End----------(Elapsed Time: 01:20, VBatt start/end: 14.1V/14.1V)-----------
    Last edited by Uwe; 05-25-2020 at 09:09 AM. Reason: IMG -> URL becuase those images don't embed
    Quote Originally Posted by Shawa12002 View Post
    Click on your username, then in the popup that appears click on "View Forum Posts"
  3. Likes Uwe liked this post
