Results 1 to 2 of 2
Thread: Sep 2010 Polo GTI DRL issues
    Verified VCDS User Marty_t's Avatar
    May 2020
    Australia
    Hi This is my first post so I hope I do it properly.
    My secondhand Sep 2010 polo GTI came with the default DRL setup which has low beam on and parking lights on. After disconnecting the light switch TFL pin T17/3 and turning off the Parking light using VCDS I had all the DRL stuff turned off.
    I then tried to turn the fog lights on as DRL using VCDS but all attempts to change any DRL settings seemed to do nothing.
    I thought it may be because the TFL pin was disconnected. I reconnected the TFL pin and the low beam came back on and I was unable to change it using VCDS. I checked the current flow diagrams and found that TFL is hard wired through fuse SB56 to the low beam lights, but the fuse was already removed so my problem still exists.
    Is it possible to get the BCM DRL settings working. Does my BCM and chassis wiring support the functions I keep seeing people post.
    I have purchased a Ross Tech VCDS HEX-V2, EManuals for the car, and spent many many hours looking through forums and can't find an answer that is not a bodge job. The BCM is supposed to control this stuff so I'm not intending to just hard wire around the lack of VCDS control.
    Posting my latest scan hear hopefully!
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 02 03 04 08 09 15 17 19 25 44 56
    VIN: WVWZZZ6RZBY079083   Mileage: 120160km-74663miles
    Address 01: Engine (J623-CAVE)       Labels:. 03C-907-309-V1.clb
       Part No SW: 03C 906 027 AR    HW: 03C 906 027 AR
       Component: 1.4l R4 TSI   H12 9971
       Revision: L2H12---    Serial number:
       Coding: 00250012002400000000
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ECM14TSI01103C906027AR 001014
       ROD: EV_ECM14TSI01103C906027AR.rod
       VCID: 71BFD325E1217D33AC5-8024
    Readiness: 0000 0001
       Part No SW: 0AM 300 050 K    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 2669
       Revision: 00043014    Serial number: CU501307257711
       Shop #: WSC 10144 001 1048576
       VCID: 313F13252D313D33EC5-513C
    Address 03: ABS Brakes
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
       Part No SW: 6R0 820 045 J    HW: 6R0 820 045 J
       Component: Climatic       25 0660
       Revision: 00 11 25
       VCID: 35372735D5491113B0D-8060
       Part No SW: 6R0 937 087 F    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0221
       Revision: BF046001    Serial number: 0345 225103199
       Coding: 24B02BB808A1000000380000342B0CD000C0410F60020000200000000000
       Shop #: WSC 00788 648 00255
       VCID: 40D946E19A8BA4BB13B-8014
       Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  006 0903
       Serial number: KU0-KU005.08.1010916
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  006 0902
       Serial number: KU0-KU020.07.1014446
       Coding: 08BC30
       Subsystem 3 - Part No SW: 5K0 959 542     HW: 5K0 959 542   Labels: 3C8-959-537.CLB
       Serial number: 0039079
       Coding: 830000
       Subsystem 4 - Part No SW: 6R0 959 811 F    HW: 6R0 959 811 F
       Component: J388__TSG_HL  006 0902
       Serial number: KU0-KU017.08.1013499
       Coding: 08BC32
       Subsystem 5 - Part No SW: 6R0 959 812 F    HW: 6R0 959 812 F
       Component: J389__TSG_HR  006 0902
       Serial number: KU0-KU016.08.1011223
       Coding: 08BC32
       Part No SW: 6R0 959 655 M    HW: 6R0 959 655 M
       Component: VW10Airbag00F H09 0020
       Revision: --------    Serial number: 003GZ0004YJP
       Coding: 003046
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4CC162D1A64370DBFF3-8018
       Serial number: 3572SRB40000C7CC525D
       Serial number: 3582SRB40000C7CC8A3N
       Serial number: 3515RRB40696T8MI9G2-
       Serial number: 3525RRB40696T8MILOLX
       Part No SW: 6R0 920 870     HW: 6R0 920 870
       Component: KOMBI         H07 0304
       Coding: 740A00
       VCID: 72BDDC29E427462B55F-8026
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 0221
       Coding: 002300
       VCID: 70B9D621EAAB743BA3B-8024
       Component: IMMO          H07 0304
       VCID: 6A8DC449CCF78EEBEDF-803E
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 11241
       Shop #: WSC 00788
       VCID: 2F3B155D3E552BC3FA1-807A
       Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
       Component: Radio RCD510  051 0207
       Revision: 00000001    Serial number: VWZ1Z3L8062059
       Coding: 01000400020000
       Shop #: WSC 00020 790 00000
       VCID: 2313E96D6BDD9FA36E9-8076
    End----(Elapsed Time: 01:44, VBatt start/end: 11.8V/11.7V. VIgn 11.6V)-----
    Hope I got the scan post correct. I'm a first time user of any car forum!
    Any help will be most appreciated.
  2. Likes Uwe liked this post
  3. #2
    Aug 2016
    Eindhoven, NB, NL
    Your GTI has the BCM H+, meaning it doesn't control its lights via the BCM. So enabling the foglights as DRL is not going to work, I'm afraid.
