Results 1 to 8 of 8
Thread: Audi SQ5 8R 2015 Towbar coding Problem
    Nov 2016
    I've installed a Westfalia towbar with the dedicated Audi wiring kit.
    According to the official spec my car should have had Trailer Prep but I couldn't find the plug so I've followed the instructions for a non-prepped car.
    This involves tapping into CanBus and power.
    The supplied trailer module is showing a green solid LED which indicates that it is wired up correctly.
    I've applied the following codes (which I found on the net):
    * 01 - Engine [Coding - 07]->[Long Coding Helper]->Byte 5, Bit 4 Changed from 0 to 1 (via check box "Trailer Installed")
    * 03 - ABS Brakes [Security Access - 16] (Enter code presented by program) [Coding - 07]->[Long Coding Helper]->Byte 1, Bit 7 Changed from 0 to 1 (via check box "Trailer Hitch Installed")
    * 09 - Cent. Elect [Coding - 07]->[Long Coding Helper]->Byte 18, Bit 5 Changed from 0 to 1 (via check box "Trailer Hitch Installed")
    * 10 - Park/Steer Assist [Coding - 07]->[Long Coding Helper]->Byte 0, Bits 0-3 Changed from 0000 to 0001 [Trailer Hitch Not Installed to Trailer Hitch Installed (Manually Removable) via pull-down list]
    * 19 - CAN Gateway ->[Installation List]->Tick 69 - Trailer
    * 5F - Information Elec [Coding - 07]->[Long Coding Helper]->Byte 10, Bit 5 Changed from 0 to 1
    * 6C - Back-up Cam [Coding - 07]-> xx?0xxx: +1 = Trailer Hitch installed
    * 69 - Trailer - No change required (unless wrongly coded before install)
    These were the settings i needed to do on a Q5, i do not have any info a SQ5 is different, but if you just follow the checkboxes in VCDS nothing should go wrong (5F can also be changed in the hidden green menu instead of doing VCDS coding (check trailer hitch in Car > extdevicelist ), 6C is optional, if you don't have a backup cam you wont have this module.
    However, when I scanned the car it came up with a sea of red!
    The engine will start and run for a couple of seconds and then cuts out.
    I disconnected the battery before doing the wiring .
    I've attached a scan and would appreciate any advice.
    Thanks
    Russ
    Monday,25,May,2020,11:01:07:63302
    VCDS Version: 20.4.1.0 (x64)
    VIN: WAUZZZ8R8FA079650   License Plate:
    Mileage: 58010km-36045mi   Repair Order: scan2
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
              56 5C 5F 62 69 6C 6D 72 A9 C0
    VIN: WAUZZZ8R8FA079650   Mileage: 58010km-36045miles
    05-Acc/Start Auth. -- Status: Cannot be reached 1100
    20-High Beam Assist. -- Status: Malfunction 0010
    46-Central Conv. -- Status: Cannot be reached 1100
    5C-Lane Maintain. -- Status: Malfunction 0010
    A9-Struct. Borne Sound -- Status: Malfunction 0010
    C0-Act. for Ext. Noise -- Status: Malfunction 0010
    Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 589     HW: 4G0 907 589
       Component: 3.0BTD EDC17  H25 0004
       Revision: 57H25---
       Coding: 2A2A4032257603020000
       Shop #: WSC 06208 123 12345
       ASAM Dataset: EV_ECM30BTD0118K5907589 001007
       ROD: EV_ECM30BTD011_AU48.rod
       VCID: 7EF275E8E100337679-802A
    4327 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Coolant temperature: 15 °C
                        Intake air temperature: 24 °C
                        Voltage terminal 30: 11.320 V
                        ACC target acceleration: 0.007 m/s²
                        ACC control module received status-Bits 0-7: 7
                        Active brake system error status-Bits 0-7: 48
                        Status of ACC/CCS acceleration interface-Bits 0-7: 3
                        Acceleration: 0.000 m/s²
                        Engine status: COENG_READY
    4330 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:44:39
                        Coolant temperature: 16 °C
                        Intake air temperature: 25 °C
                        Voltage terminal 30: 10.320 V
                        ACC control module received status-Bits 0-7: 4
                        Active brake system error status-Bits 0-7: 1
                        Status of ACC/CCS acceleration interface-Bits 0-7: 0
              U0428 00 [039] - -
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        CAN TimeOut meter - battery manager-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 244
                        CAN TimeOut meter - gateway-Bits 0-7: 0
                        CAN TimeOut meter - steering angle-Bits 0-7: 0
                        CAN TimeOut meter - parking brake-Bits 0-7: 0
                        CAN TimeOut meter - transmission-Bits 0-7: 0
    4720 - Body Control Module (Central Electric 2)
              U0141 00 [039] - No Communications
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:53
                        selected gear-Bits 0-7: 0
    5523 - Engine Start Blocked by Immobilizer
              P1570 00 [038] - -
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Immobilizer snapshot A-Sia Error Snap A: 39 00 1D
                        Immobilizer snapshot B-Sia Error Snap B: 0A 00 00
       Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H19 1007
       Revision: --H19---
       VCID: 000E0B109BF445860B-8054
    2543 - Transmission Control Unit
              P1701 00 [167] - Locked
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Voltage terminal 30: 11.458 V
                        Immobilizer Snapshot 1-Param 0: 2F
                        Immobilizer Snapshot 1-Param 1: 00
                        Immobilizer Snapshot 1-Param 2: 1C
                        Immobilizer Snapshot 1-Param 3: 0A
                        Immobilizer Snapshot 1-Param 4: 00
                        Immobilizer Snapshot 1-Param 5: 00
                        Status data bus communication diagnostic interface-State Deashboard received: not received
                        Status data bus communication diagnostic interface-State ECM received: not received
                        Status data bus communication diagnostic interface-State ESP received: not received
                        Status data bus communication diagnostic interface-State Gateway received: not received
                        Status data bus communication diagnostic interface-State Parking Brake received: not received
                        Status data bus communication diagnostic interface-State Steering Angle received: not received
                        Status data bus communication diagnostic interface-State Steering Assist received: not received
    12560 - Body Control Module (Central Electric 2)
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Voltage terminal 30: 11.460 V
                        Engine speed: 0 /min
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
       Coding: 24DDCC01
       Shop #: WSC 06335 123 12345
       VCID: 0E122528D9A023F689-805A
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:44:39
                        Hex Value: 0x0000
                        Hex Value: 0x0782
                        Hex Value: 0x001A
                        Hex Value: 0x0282
                        Hex Value: 0x0000
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:44:44
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x0022
                        Hex Value: 0x1B8A
                        Hex Value: 0x0000
    01794 - Control Module - Incorrect Chassis (VIN) Number
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:44:46
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x0045
                        Hex Value: 0x138B
                        Hex Value: 0x0000
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:44:46
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x002F
                        Hex Value: 0x238B
                        Hex Value: 0x0000
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:44:46
                        Hex Value: 0x0000
                        Hex Value: 0x0082
                        Hex Value: 0x002F
                        Hex Value: 0x238B
                        Hex Value: 0x0000
    Address 05: Acc/Start Auth.
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Revision: D1000000    Serial number: 01211120141279
       Coding: 3625028000
       Shop #: WSC 06335 000 00000
       VCID: 78FE63F0CB240D4633-802C
       Revision: 08016001    Serial number: 00000951648401
       Coding: 260000108074AFE00581404300001D0D0F9D670827090201000008004400030100000034000000
       Shop #: WSC 50664 002 104857
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 140825  H12 0050
       Serial number: 90243015140820021300
       Coding: 01DD13
       Serial number: 23488562
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001511146557
       Serial number: 37488D57000000000001
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:45:32
    Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
       Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
       Component: ACC3          H11 0100
       Coding: 007D8A
       VCID: 377CA0CC86BAC23EFA-8062
    00456 - Control Module for Access and Start Control (J518)
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:53
                        Temperature: 31.0°C
                        Voltage: 11.39 V
                        Hex Value: 0x008A
                        Lateral Accel.: 0.00 m/s^2
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Temperature: 31.0°C
                        Voltage: 11.39 V
                        Hex Value: 0x00C9
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        Temperature: 31.0°C
                        Voltage: 11.39 V
                        Hex Value: 0x005D
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        Temperature: 31.0°C
                        Voltage: 11.39 V
                        Hex Value: 0x00BE
    01316 - ABS Control Module
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        Temperature: 31.0°C
                        Voltage: 11.39 V
                        Hex Value: 0x00C0
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H48 0610
       Serial number: 003JPDC21U3M
       Coding: 30473431313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 489ED330F344BDC683-801C
       Serial number: 6334MSME4A6B2B05M
       Serial number: 6344MSME4A596417K
       Serial number: 6352QSME5C484164L
       Serial number: 6362QSME5C4B216CV
       Serial number: 63732SME3449245C%
       Serial number: 63832SME714B487A9
       Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
       Revision: --------    Serial number: 90372NKI000FS
       Coding: 0000FF
       VCID: 4486C700C76C99A66F-8010
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        Fault Status: 01100101
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        (no units): 62.0
                        Text: 3E820000FFFFFFFFFF
                        Current: 0.000 A
                        Raw, Index/Key Err.: 255 255 255
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 951     HW: 8R0 920 951
       Component: KOMBIINSTR.   H35 0567
       Revision: 00100000    Serial number: 03I32JJCF
       Coding: 33E7220047012600010000
       VCID: 74E657C0D74C69261F-8020
       Revision: 1Z120030    Serial number: 3041Z14B190417
       Coding: 80CD07FF00
       VCID: 4C96EF20EF3C51E6A7-8018
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 4899974903
       Serial number: 14311000484011200410
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:54
                        Bin. Bits:    10001
                        Voltage: 11.40 V
                        Count: 6
                        Bin. Bits:    00000
                        Time: 25.40 s
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:54
                        Bin. Bits:    10001
                        Voltage: 11.40 V
                        Count: 6
                        Bin. Bits:    00000
                        Time: 25.40 s
       Revision: AA001002
       Coding: 02022064747464545425363E00
       VCID: 7CF67FE0FF1C216657-8028
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.23
                        Time: 16:33:55
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0077
       Revision: AA000000    Serial number: 00000124832453
       Coding: 01781B00000000000000
       VCID: 428AC118DD7897965D-8016
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
       Serial number: 0334371538
       Coding: 010312
       Shop #: WSC 06334 123 12345
       VCID: 3F8CC8ECA68AFA7E32-806A
       Component: SWA Slave  H05 0071
       Serial number: 0334316078
       Coding: 010312
    340484 - Databus
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
       Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
       Component: RCEPS         H41 0509
       Revision: 00001000    Serial number: 0009187955
       Coding: 100001010001
       ASAM Dataset: EV_RCEPSAU48X 008016
       ROD: EV_RCEPSAU48X_008.rod
    4205828 - Steering angle sensor
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Write only channel
    5258753 - Steering End Stops Not Learned
              C10AC F0 [137] - Unknown Error Elaboration
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Write only channel
    3161616 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Write only channel
    Address 46: Central Conv.
       Revision: 00005001    Serial number: 94813037454706
       VCID: 2D5082A474E678EE90-8078
    Address 52: Door Elect, Pass.
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 20000000545768
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A7AB9F8BDA8DF5605-806E
    333824 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Voltage terminal 30: 11.5 V
                        Internal Fault ID: 50
                        Network management state: normal
                        Function light in parking brake button: OFF
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        ACC requested apply: not active
                        Auto Adjust: not active
                        General Inspection Function: not active
                        Internal Parking Brake state: static
                        Status of parking brake button: Not operated
                        Status ParkingBrake left: Open
                        Status ParkingBrake right: Open
    330240 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Internal Fault ID: 96
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    330496 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Internal Fault ID: 97
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
    335360 - Function Restricted due to Missing Message(s)
              U1111 00 [137] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Internal Fault ID: 209
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109K60E7992209
       Coding: 010103010000000001
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:42:10
                        Bin. Bits: 00000000 00000001
    Address 5C: Lane Maintain.        Labels: None
       Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
       Component: J759 HC             0040
       Revision: 00H08006    Serial number: 600214B2000165
       Coding: 0002204
       VCID: 377CA0CC46BAC23EFA-8062
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
                        Fault Status: 00101101
                        Reset counter: 75
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
       Part No SW: 8R2 035 666 L    HW: 8R2 035 666 H
       Component: H-BN-EU       H48 1036
       Revision: --------    Serial number: 515K10E7503269
       Coding: 1A0101060205A9EF7D80CB5E00000403E40000020000000000
       Shop #: WSC 50664 002 1048576
       Subsystem 1 - Part No: 8R0 060 884 GA
       Component: EUR 2019  2802
       Component: DU7 High  H42 0104
       Serial number: A130KZ0E3196812
       Serial number: 00000002055351
       Component: CD-Database  5950
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:56
                        Text: DUA130,Front,M,0,0,6
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:58
                        Bin. Bits: 00100000 00000000
                        Bin. Bits: 00000000 00000000
    03623 - Invalid Security/Release Code
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:55
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
    Address 62: Door, Rear Left
       Part No SW: 8K0 907 383 D    HW: 8K0 907 383 D
       Component: ConWys Trailer H09 0100
       Revision: 1G001001    Serial number: 00000173782896
       Coding: 0100000000000000
       Shop #: WSC 00375 223 87350
       VCID: 3560AAC49CB6302EE8-8060
    Address 6C: Back-up Cam.
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H56 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D70B2E4A486E86E20-8068
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H56 0330
       Serial number: 8R0827852D
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:51
    Address 72: Door, Rear Right
       Part No SW: 8R0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0007
       Serial number: 141021202723
       VCID: 79F866F4F82E144E4C-802C
    0005 - Incorrect Vehicle Type
              U10D9 00 [009] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 8R0 907 160     HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0002
       Serial number: 141021200750
       VCID: 71E85ED4A05E5C0EF4-8024
              U10D9 00 [009] - -
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 10:41:52
    End-------------------------(Elapsed Time: 04:28)--------------------------
    Jan 2015
    Bosnia and Herzegovina
    Did you check that all modules are plugged in? Also check fuses, since you connected wires there are some modules not communicating especially Address 05: Acc/Start Auth.
    Cannot be reached, hence the car won't run...
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  3. Likes Uwe, PetrolDave liked this post
    Nov 2016
    Quote Originally Posted by m87a View Post
    Thanks for your quick response.
    Fuses all OK, modules all plugged in but....
    Both the canbus wires from the connector had broken downstream of my soldered splices. The splices were fine but I must have been a bit rough squeezing the wires back into the connector cover.
    I repaired the breaks and at least the car runs!
    I cleared all the DTCs and then re-scanned see below.
    I also went through my coding again to make sure it had all been entered correctly:
    10 Park/steer assist - can't connect with the module.
    5F - Byte 10 does not show bit 5 (stops at 4)
    There's still bits disconnected so I expected some errors to remain but not sure what is the problem with 10 and 5F?
    Any ideas?
    Russ
    Monday,25,May,2020,15:42:09:63302
    Mileage: 58010km-36045mi   Repair Order: scan3
       Revision: 57H25---
              U1113 00 [039] - -
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:24
                        Coolant temperature: 26 °C
                        Intake air temperature: 28 °C
                        Voltage terminal 30: 11.480 V
                        Status of ACC/CCS acceleration interface-Bits 0-7: 4
       Revision: --H19---
       Coding: 24DDCC01
       Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
       Component: BCM2 2.0      H15 0711
       Coding: 05B54040000000000000
       VCID: 000E0B1093F445860B-8054
       Serial number: 3214000163027010
       Coding: 3625028000
       Coding: 01DD13
       Coding: 02005C
       Coding: 007D8A
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:25
                        Temperature: 33.0°C
                        Voltage: 11.52 V
                        Hex Value: 0x005D
       Coding: 0000FF
       Coding: 80CD07FF00
       Revision: AA001002
       Coding: 010312
       Coding: 010312
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000126845640
       Coding: 011D12215E01440004
       VCID: 4FACF82C1E2A6AFEC2-801A
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:24
                        Write only channel
       Revision: 00002001    Serial number: 0352486413
       Coding: 013B0E22A0B930958720053680040047
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
    03073 - Rear Lid Closed Sensor 1
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:25
    02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:25
    02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:25
       Component: TSG BF        H02 0510
       Revision:             Serial number: 0000126704127
       VCID: 4E92E528192063F6C9-801A
       Coding: 0002204
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:30
                        Reset counter: 35
                        Mileage: 58016 km
                        Date: 2020.05.25
                        Time: 15:18:28
                        Hex Value: 0x0004
                        Hex Value: 0x000B
                        Count: 6
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000126688328
       Coding: 010C12204001240004
       VCID: 4682DD08F150ABB671-8012
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H09---    Serial number: 525PA8-J49A6JS
       Coding: 1030010
       VCID: 346697C057CC2926DF-8060
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000126699217
    End-------------------------(Elapsed Time: 04:45)--------------------------
    Jan 2015
    Check coding in 13, drive a car a little, learn steering limits, move the steering wheel all the way to the left, hold it there then to the right hold it there, for 5F coding go to coding2 and manually enter bit that you want after coding reboot 5F hold and press power button for 10sec, as for 10 Park/steer assist it's not in your gateway list and also it doesn't appear to be present on your car so no coding 10 .
    GOOD CHEAP FAST
  6. Likes Uwe liked this post
    Apr 2018
    ITALY
    I would have never bet they can sell a SQ5 without parking sensors
    my Golf left the factory with 18 ECUs. now she has 27. and counting
    Jan 2015
    well it's easy to add it so...
    GOOD CHEAP FAST
    VCDS Distributor NEtech's Avatar
    Easy the car has PR-7X8 (Park distance control in front and rear plus rear view camera system).
    It is managed by [09] and [6C].
    @RussJ, I don't know why you think the car has Address [10], if you look at an AutoScan before retrofit, I am sure, there was also no [10].
    [10] was possible up to 2012 (included), I think.
    Explanation: Copy the changed coding and insert as new coding:
    [Controller No.] > ”New coding”
    [13] > 007D83
    [3C] > 010322
    [5C] > 0102204
  10. Likes m87a, Uwe, PetrolDave, darkchina811 liked this post
  11. #8
    Nov 2016
    Apologies for the delay in updating - I had some other urgent non-car stuff to sort out.
    To be honest I didn't check to see what modules were originally present , just blindly followed the code I found on the internet and assumed that since the model year was the same as mine, everything would work.
    Lesson learned!
    I re-coded as per NETech's suggestion which cleared most of the errors. I also had to do an "end stop learning" process to clear a warning light.
    So, all is now working as it should, except an error code in "Information Electric" caused by a slightly dubious SatNav map update I did a while ago.
    Many thanks to everyone who helped me out - this forum is great.
    Russ
  12. Likes darkchina811, m87a liked this post
