Results 1 to 10 of 18
Thread: 2012 Audi A6 3.0 TDI (C7) s-tronic - Gearbox malfunction: You can continue to drive
    May 2020
    New Zealand
    Hi again,
    after an issue with my wife's Allroad (not being levelled and still needs resolving), it is my turn
    Today I got "Gearbox malfunction: You can continue to drive". The message comes and goes. Briefly there was also a RED warning which I didn't capture as it went away. I have also noticed that the car was stuttering a bit while the RED warning was on. I have also lost the PRNDS lights.
    If there anything I can check before trying to get the car to Audi (160km away)?
    Any feedback would be much appreciated.
    Here is the scan:
     Monday,25,May,2020,17:13:21:28799
    VCDS Version: 19.6.2.2 (x64)
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 36 3B 42 44 46 52 53
              55 56 5F 62 69 6C 72 85 8B 8E 8F 90
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-CDUC)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 401 F    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0004
       Revision: 53H37---
       Coding: 0A254012057601020000
       Shop #: WSC 00070 824 98310
       ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
       ROD: EV_ECM30TDI0114G0907401F.rod
       VCID: 26430C635997727FFF-8072
    18660 - Start interruption due to insufficient engine speed
              P151D 00 [032] - -
       Part No SW: 4G2 927 156 M    HW: 0B5 927 156 K
       Component: 0B5 30 TDIRdW H03 0002
       Revision: --H03---    Serial number: 0000001123
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ASAM Dataset: EV_TCMDL501021 001010
       ROD: EV_TCMDL501021.rod
       VCID: 387FD21B8323F48F5D-806C
    6 Faults Found:
    7965 - Signal Line for Gear Display on Selector Lever
              P1893 00 [032] - Electrical Malfunction
                        Reset counter: 40
                        Mileage: 172050 km
                        Date: 2020.05.25
                        Time: 16:57:05
                        Engine speed: 1422 /min
                        Transmission input speed: 1422 /min
                        Transmission output speed: 458 /min
                        Engine torque: 176 Nm
                        Transmission fluid temperature: 72 ∞C
                        Accelerator position: 27.2 %
                        Clutch status: Kupplung 1 kann Moment ¸bertragen
    7966 - Signal Line for Gear Display on Selector Lever
              P1894 00 [032] - Implausible Signal
                        Reset counter: 40
                        Mileage: 172050 km
                        Date: 2020.05.25
                        Time: 16:57:08
                        Engine speed: 1235 /min
                        Transmission input speed: 1235 /min
                        Transmission output speed: 396 /min
                        Engine torque: 0 Nm
                        Accelerator position: 12.0 %
    7967 - Selector Lever Position Monitoring
              P1892 00 [032] - Malfunction
                        Reset counter: 40
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 17:00:08
                        Engine speed: 902 /min
                        Transmission input speed: 902 /min
                        Transmission output speed: 82 /min
                        Engine torque: -8 Nm
                        Transmission fluid temperature: 81 ∞C
                        Accelerator position: 0.0 %
                        Clutch status: Kupplung 2 kann Moment ¸bertragen
    18147 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [032] - -
                        Reset counter: 40
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 16:59:40
                        Engine speed: 751 /min
                        Transmission input speed: 751 /min
                        Transmission output speed: 0 /min
                        Engine torque: 52 Nm
                        Voltage terminal 30: 14.700 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.923 V
    7999 - No Communication with Instrument Cluster
              U0155 00 [032] - -
                        Reset counter: 40
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 16:59:45
                        Engine speed: 753 /min
                        Transmission input speed: 753 /min
                        Voltage terminal 30: 14.500 V
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.924 V
    8015 - Steering Column Control Module
              U0212 00 [032] - No Communications
                        Reset counter: 40
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 16:59:36
                        Engine speed: 925 /min
                        Transmission input speed: 925 /min
                        Transmission output speed: 154 /min
                        Engine torque: 4 Nm
                        Voltage_5V_CAN_pressuresensors-Param to DOP: 4.921 V
       Part No SW: 4G0 907 379 G    HW: 4G0 907 379 G
       Component: ESP PREMIUM   H09 0250
       Coding: 27A68701E465E180DB00
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: 3561DB2F943109E746-8060
    0067 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 80
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 16:59:39
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 40
                        Bit Info 3: 26
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: D8
                        Uz: BE
       Part No SW: 4H0 907 064 BT    HW: 4H0 907 064 BT
       Component: BCM2 2.0      H31 0330
       Coding: 01B83006000000000000
       VCID: 7CF70E0BFF9B18AFF9-8028
    00956 - Key 2
                002 - Lower Limit Exceeded
                        Fault Status: 01100010
                        Reset counter: 27
                        Mileage: 171645 km
                        Date: 2020.05.09
                        Time: 15:51:03
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0056
       Serial number: 07071100040400
       Coding: 3621600824
       ASAM Dataset: EV_AirCondiBasisUDS 002033
       VCID: 2447166B2FAB806FE1-8070
       Part No SW: 4H0 907 063 BF    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0100
       Revision: 20012002    Serial number: 00000000965136
       Coding: 2600201040349FE281810083A0001D0CCF9DE30827090101000004602101
       VCID: 6DD1334FB4E181277E-8038
       Component: WWS57X 110516  H35 0051
       Serial number:         110608053655
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11526277
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 22 06 2011  00000527
       Component: Humidity_Sens  H02 0002
       Serial number: 3968C5B5000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       VCID: 2345157722A5875798-8076
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901118300643
       Coding: 290B06
       Shop #: WSC 32336 000 1048576
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: 3B75CD17B215DF97B0-806E
       Part No SW: 4G0 907 561     HW: 4G0 907 561
       Component: ACC3          H15 0160
       Coding: 3D04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 001003
       ROD: EV_AdaptCruisContrAU57X_001.rod
       VCID: 67DD41679E1DAB7704-8032
    105472 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 16:59:39
                        Control Module temperature: 17 ∞C
                        Voltage terminal 15: 14.647 V
                        Longitudinal_acceleration_vehicle_reference: -0.30 m/s≤
    105984 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 162829 km
                        Date: 2019.10.04
                        Time: 08:11:31
                        Control Module temperature: 13 ∞C
                        Voltage terminal 15: 14.690 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.00 m/s≤
    106240 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 162829 km
                        Date: 2019.10.04
                        Time: 08:11:31
    140288 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 162829 km
                        Date: 2019.10.04
                        Time: 08:11:31
                        Voltage terminal 15: 14.651 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
                        Reset counter: 40
                        Mileage: 168107 km
                        Date: 2020.01.30
                        Time: 17:00:00
                        Control Module temperature: 26 ∞C
                        Voltage terminal 15: 13.355 V
                        Velocity_vehicle_reference: -0.02 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.09 m/s≤
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG00338Y0
       Coding: 30323436313330303630554A305234473053
       VCID: 3663DC23893702FF4F-8062
       Serial number: 3575HRB405V0INGSFP9Y
       Serial number: 3585HRB40550IODOF8H.
       Serial number: 3515JRB40550JNPM9H1T
       Serial number: 3525JRB404T0JL5E49BK
       Serial number: 3554VRB405J0JE3G29FK
       Serial number: 3564VRB405L0JE3GDO4
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Revision: --------    Serial number: 90372KFR000RC
       Coding: 00003C
       VCID: 377DD127863DFBF754-8062
       Component: E221 - MFL  H07 0009
       Serial number: 30 05 2011  B0020967
       Part No SW: 4G8 920 931 J    HW: 4G8 920 931 J
       Component: TDieRdwAcc    H71 0375
       Revision: 26181114    Serial number: 658080711592017
       Coding: 338708000F010008010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K_AU57.rod
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000191824
       Coding: 00CD077D00
       ROD: EV_GatewUDS_AU57.rod
       VCID: 326BE033655F1EDF63-8066
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650829486
       Voltage stabilizer:
       Serial number: 11188001794011200181
    0264 - Powertrain Databus (VAG Single-Wire Mode) (SAE  L Shorted H)
              U0009 00 [008] - -
                        Fault Frequency: 38
                        Reset counter: 80
                        Mileage: 172046 km
                        Date: 2020.05.25
                        Time: 16:49:23
                        Voltage terminal 30: 14.5 V
                        Voltage terminal 15: 14.6 V
                        Control Module temperature: 20 ∞C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Component: MEM-FS        H03 0153
       Revision: AA000000    Serial number: 00000006299091
       VCID: 77FD1127C6BD3BF794-8022
       Part No SW: 4G0 907 637 B    HW: 4G0 907 637 B
       Component: SARA 6D       H02 0004
       Revision: --------    Serial number: EJ1BPA4201A0W00
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D51F34F7C6141273E-8078
       Part No SW: 4G8 959 793 D    HW: 4G8 959 793
       Component: TSG FA        H05 0212
       Coding: 011F16204E01628002080003
       VCID: 4189BFFFD8F9B547EA-8014
                        Fault Frequency: 12
                        Reset counter: 249
                        Mileage: 159570 km
                        Date: 2019.08.13
                        Time: 16:47:36
       Component: RCEPS         H33 0010
       Revision: 00001000    Serial number: 0021103429
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0153037276
       Coding: 011A062000B90400832008842C0100000000000000000000000000000000
       Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
       Serial number: 0000000AP00000290349
    03637 - Roof Electronics Control Module; Function Limitation due to Overtemp
                        Fault Frequency: 68
                        Reset counter: 46
                        Mileage: 164175 km
                        Date: 2019.11.02
                        Time: 13:37:58
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F16204E01628002080002
    02123 - Door Warning Light / Entry Light
                        Fault Status: 00101100
                        Fault Frequency: 145
                        Reset counter: 77
                        Mileage: 159750 km
                        Date: 2019.08.15
                        Time: 12:01:05
       Revision: --------    Serial number: 00000000098725
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A5BF8534D8F561FDB-807E
    67840 - Left Parking Brake Motor Voltage Supply
              C100D 01 [000] - Electrical Malfunction
    397568 - Function Restriction due to Implausible Message(s)
              U1112 00 [008] - -
                        Reset counter: 80
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 17:00:02
                        Voltage terminal 30: 14.9 V
                        Internal Fault ID: 118
                        Vehicle speed: 16 km/h
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Internal Parking Brake state: Dynamic
       Serial number: 110703-0004-046
       Coding: 1121A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C57FE4B477B482F29-8078
       Part No SW: 4G0 035 056 J    HW: 4G0 035 056
       Component: Radio U STD   H52 0133
       Revision: AB001007    Serial number: 051GU0B7523382
       Coding: 070003020100000001
       VCID: 285F025B5B83640FCD-807C
       Part No SW: 4G0 035 754 P    HW: 4G0 035 754
       Component: H-BN-RW       H47 1034
       Revision: --------    Serial number: 430FU0B7507390
       Coding: 050A01000003E9EF6510AB2E00000003FC0001020000000000
       VCID: 3365E537924517D768-8066
       Subsystem 1 - Part No: 8R0 060 884 DJ
       Component: ROW 2016  0806
       Subsystem 2 - Part No SW: 4G0 919 605 A    HW: 4G0 919 605 A
       Serial number: AUZ8ZDB13010P11
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 A
       Component: E380 BDT C7  H08 0204
       Serial number: 90349KFS0007U
       Component: CD-Database  3371
                        Reset counter: 40
                        Mileage: 159569 km
                        Date: 2019.08.13
                        Time: 14:06:53
                        Text: DUA009,Front,M,0,0,6
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204001628002080002
       VCID: 4487B6EBC7EBA06FC1-8010
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Anhaenger     H07 0100
       Revision: 5G001001    Serial number: 00000135482843
       Coding: 0109080000000000
       VCID: 71E92F3FA8D965C75A-8024
       Revision: --H04---    Serial number: 525 PA8J19G1C7
       Coding: 1090004
       VCID: 26430C639197727FFF-8072
       Component: TSG HR        H04 0212
       Part No SW: 4G0 907 217     HW: 4H0 907 217 A
       Component: DPC-SG        H24 0034
       Coding: 6A040000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 65C14B6F6411B96736-8030
       Part No SW: 4G0 907 541     HW: 4G0 907 541
       Coding: 3D04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 001002
       ROD: EV_AdaptCruisContr2AU57X_001.rod
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 172052 km
                        Date: 2020.05.25
                        Time: 16:59:39
                        Voltage terminal 15: 14.699 V
                        Velocity_vehicle_reference: -0.00 m/s
                        Longitudinal_acceleration_vehicle_reference: -0.22 m/s≤
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 162829 km
                        Date: 2019.10.04
                        Time: 08:11:31
                        Voltage terminal 15: 14.179 V
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 162829 km
                        Date: 2019.10.04
                        Time: 08:11:31
                        Voltage terminal 15: 14.203 V
              U1113 00 [008] - -
                        Reset counter: 80
                        Mileage: 162829 km
                        Date: 2019.10.04
                        Time: 08:11:31
       Part No SW: 4G0 907 107 B    HW: 4H0 907 107
       Component: BV-SG         H29 0034
       Serial number: 000040182006117
       Coding: 0480081C0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 25410B6F24917967F6-8070
    0080 - Video Cable for Image Processing
              C1107 02 [024] - Signal Failure
              Intermittent - Confirmed - Not Tested Since Memory Clear
                        Fault Frequency: 9
                        Reset counter: 249
                        Mileage: 169372 km
                        Date: 2020.02.26
                        Time: 21:45:24
                        Outside air temperature: 21.0 ∞C
                        Voltage terminal 15: 13.1 V
                        Control Module temperature: 24.0 ∞C
    0161 - Video Cable for Image Processing
              C1107 02 [009] - Signal Failure
                        Fault Frequency: 139
                        Reset counter: 40
                        Mileage: 171422 km
                        Date: 2020.04.05
                        Time: 14:31:39
                        Outside air temperature: 17.0 ∞C
                        Voltage terminal 15: 13.2 V
                        Control Module temperature: 17.0 ∞C
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H05 0070
       Coding: 00660600031F037E000308004248D2010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 6FED2947B6ED73374C-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H05 0070
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       VCID: 70EF2A3BABD36CCF55-8024
    End-------------------------(Elapsed Time: 06:16)--------------------------
    May 2020
    New Zealand
    Checking some other posts, it looks like it might be a corroded TCM connector due to coolant leak. Is this the one on the attached diagram, can I get to it on my driveway?
    https://imgur.com/a/1xV4CtB
    I would think you'd have to raise the car some to get access. Ramps or jack-stands?
    Jan 2020
    Germany (Auto-Intern)
    Hi, I think this could actually be the case where the coolant valve lets the cooling water through the wiring harness to the control unit. But you need a lift to get to the valve.
  6. Likes Jack@European_Parts liked this post
    May 2020
    New Zealand
    Just got this checked and here are some photos:
    Why the issue with the coolant valve hasn't been recalled by Audi is beyond me.
    BTW What is the part number for the coolant control valve for Audi A6 4F (2011)?
    Amazing how this hasn't been recalled already, Worldwide huh?
    Does NZ have an equivalent of US NHTSA, if so maybe reach out to them?
  9. Likes ai_Ingo liked this post
  10. #7
    May 2020
    New Zealand
    I have already complained about this to Audi NZ and will follow this up with https://www.nzta.govt.nz
    What is even more interesting is the fact that the authorised Audi dealers which regularly service the cars don't inform (clearly they must know, no?) their customers about such issues, perhaps waiting for it to happen and cause a lot of damage, so they can then charge big dollars for big jobs.
  11. Likes Jack@European_Parts liked this post
  12. #8
    Or maybe let the consumers die in an accident wilfully wanton and deal with the civil suits versus the cost of recall worldwide?
  13. #9
    May 2020
    New Zealand
    Is this the right part number? 4H0121671D
    Is this N509 or N488, in the TSB they refer to both.
    Diagrams from dctech here where N509 is referred as Transmission Fluid Cooling Valve and N488 as Transmission Coolant Valve : https://www.audiworld.com/forums/a6-...issue-2972465/
  14. #10
    May 2020
    New Zealand
    ok, it looks like this is the right part for A6 4F (C7) 3.0 TDI 2012: 4H0121671D (N82/N509/N488)
