Results 1 to 7 of 7
Thread: 2011 GOLF GTI LOST ABS CODING
    May 2020
    South Africa
    Greetings, from South Africa.
    Im an enthusiastic hobbyist and glad to be part of the Ross-tech community.
    Kindly assist, my friends golf lost coding after repairs at a certain workshop. Now the ABS, ESC, and Brake lights started flashing. We have no previous auto scan to retrieve the ABS code.
    Saturday,23,May,2020,16:25:18:22233
    VCDS Version: 20.4.0.1 (x64)  HEX-NET CB: 0.4508.4
    Dealer/Shop Name: ShadeTree
    VIN: WVWZZZ1KZBW156309   License Plate:
    Mileage: 238910km-148451mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    VIN: WVWZZZ1KZBW156309   Mileage: 238910km-148451miles
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115 N    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0010
       Revision: AAH18---    Serial number:
       Coding: 0403000C18070160
       Shop #: WSC 31267 001 1048576
       VCID: 3522ED1A5C17AF2EE1-8060
    006439 - Relay for Aux Coolant Pump (J496)
                   P1927 - 000 - Open Circuit
                        Mileage: 238909 km
                        Date: 2020.05.23
                        Time: 00:46:41
                        RPM: 1288 /min
                        Load: 10.6 %
                        Speed: 34.0 km/h
                        Temperature: 98.0C
                        Temperature: 39.0C
                        Absolute Pres.: 830.0 mbar
                        Voltage: 13.716 V
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
                   P2015 - 000 - Implausible Signal
                        Mileage: 238909 km
                        Date: 2020.05.23
                        Time: 00:46:42
                        RPM: 1330 /min
                        Load: 22.3 %
                        Speed: 36.0 km/h
                        Temperature: 98.0C
                        Temperature: 39.0C
                        Absolute Pres.: 840.0 mbar
                        Voltage: 13.716 V
    008825 - Leak in Air Intake System
                   P2279 - 000 -
                        Mileage: 238910 km
                        Date: 2020.05.23
                        Time: 00:49:23
                        RPM: 794 /min
                        Load: 12.9 %
                        Temperature: 102.0C
                        Temperature: 48.0C
                        Voltage: 13.716 V
    Readiness: 1110 0101
       Revision: 00H31001
       VCID: 7DB2353AE4A7B76E69-8028
                        Reset counter: 55
                        Date: 2020.05.23
                        Time: 00:52:43
                        Count: 3
                        Count: 32768
                        Count: 20992
                        Count: 195
                        Count: 48896
                        Fault Status: 01100101
                        Reset counter: 55
                        Mileage: 238910 km
                        Date: 2020.05.23
                        Time: 00:51:56
                        Count: 3
                        Count: 32770
                        Count: 29184
                        Count: 279
                        Count: 48640
                        Reset counter: 55
                        Mileage: 238910 km
                        Date: 2020.05.23
                        Time: 00:51:56
                        Count: 3
                        Count: 32770
                        Count: 29184
                        Count: 270
                        Count: 48640
       Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
       Component: Climatronic   H19 1212
       Revision: 00001004
       Coding: 0010002002
       VCID: 7AB83E26FD8980564C-802E
              B10AB F0 [009] - Too Low
                        Reset counter: 121
                        Mileage: 232965 km
                        Date: 2020.01.09
                        Time: 00:15:37
       Part No SW: 1K0 937 086 R    HW: 1K0 937 086 R
       Component: BCM PQ35  M   111 0709
       Revision: AB111709
       Coding: 48180A3A8025F1C0408800C03404016449510288536D8D60648000200040
       VCID: 3FCE8F32AE2B657E3B-806A
       Subsystem 1 - Part No: 5K2 955 119
       Component: Wischer 29051  26  0512
       Coding: 009795
       Component: RLS 010612 05  54  0403
       Coding: 0230AD
    15 Faults Found:
    01506 - Bulb for Rear Fog; Right (L47)
                        Fault Status: 00101010
                        Fault Frequency: 127
                        Reset counter: 92
                        Mileage: 232990 km
                        Date: 2020.01.09
                        Time: 21:21:44
                            Term 15 On
                        Voltage: 13.80 V
                            Term 50 Off
                        Fault Status: 01101010
                        Reset counter: 55
                        Mileage: 232965 km
                        Date: 2020.01.09
                        Time: 00:16:06
                            Term 15 On
                        Voltage: 12.80 V
                            Term 50 Off
                014 - Defective
                        Fault Status: 01101110
                        Reset counter: 55
                        Mileage: 232990 km
                        Date: 2020.01.09
                        Time: 21:21:44
                            Term 15 On
                        Voltage: 13.80 V
                            Term 50 Off
                        Reset counter: 55
                        Mileage: 235257 km
                        Date: 2020.02.05
                        Time: 05:49:29
                            Term 15 On
                        Voltage: 13.70 V
                            Term 50 Off
                        Fault Status: 01101100
                        Reset counter: 55
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:20:39
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
                        Fault Status: 00100111
                        Reset counter: 88
                        Mileage: 238791 km
                        Date: 2020.05.16
                        Time: 00:04:12
                            Term 15 On
                        Voltage: 12.05 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238791 km
                        Date: 2020.05.16
                        Time: 00:29:40
                            Term 15 On
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238791 km
                        Date: 2020.05.16
                        Time: 00:29:40
                            Term 15 On
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238791 km
                        Date: 2020.05.16
                        Time: 00:29:42
                            Term 15 On
                        Voltage: 12.10 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:00:42
                            Term 15 On
                        Voltage: 13.85 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:00:42
                            Term 15 On
                        Voltage: 13.85 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:00:43
                            Term 15 On
                        Voltage: 13.90 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:00:45
                            Term 15 On
                        Voltage: 13.95 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:00:45
                            Term 15 On
                        Voltage: 13.95 V
                            Term 50 Off
                        Reset counter: 95
                        Mileage: 238907 km
                        Date: 2020.05.23
                        Time: 00:00:45
                            Term 15 On
                        Voltage: 13.95 V
                            Term 50 Off
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Component: AirbagVW10    013 0613
       Serial number: 003G5RAL25JM
       Coding: 00003958
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 312AD90A607F830EBD-8064
       Serial number: 3572MSME1D39726BZZZ2
       Serial number: 3582MSME3947726BZZZ0
       Serial number: 3512QSME701B1251ZZZJ
       Serial number: 3522QSME70331224ZZZE
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90440LEV0012G
       Coding: 1082140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 72A81606A5F9F81604-8026
       Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H31 0033
       Serial number: 0091331
       Coding: 820000
       Part No SW: 5K6 920 871     HW: 5K6 920 871
       Coding: 170B00
       VCID: 71AA190AA0FFC30EFD-8024
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 230512F1002068
       Coding: 350003
       VCID: 6A980E668D2930D6BC-803E
       Component: Tuer-SG         009 2120
       Coding: 0000692
       VCID: 312AD90AA87F830EBD-8064
    00913 - Window Regulator Switch; Front Right Driver (E81)
    00914 - Window Regulator Switch; Rear Left; Driver (E53)
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 74     3305
       Revision: 00H22000
       VCID: 373EE712461B5D3EF3-8062
                000 - - - MIL ON
                        Fault Status: 11100000
                        Mileage: 238910 km
                        Date: 2020.05.23
                        Time: 00:51:21
                        Battery Volts: 13.8 V
                            DU
                        Temperature: 39.0C
                        Count: 9
                        Steering Angle: 9.76
                            SteerAng n.Init
       Coding: 0000692
       VCID: 3228D606AD79B816C4-8066
       Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
       Component: RCD310 EU     H03 5006
       Revision: -----07S    Serial number: VWZ4Z2M1260553
       Coding: 05000400040005
       VCID: 72A81606ADF9F81604-8026
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Coding: 0000144
       VCID: 3620EA164111A436E8-8062
    End----------(Elapsed Time: 01:09, VBatt start/end: 13.6V/13.7V)-----------
    I have attached a copy of the auto scan we did, could you kindly assist with a proper ABS code
    Thank you.
    Aug 2016
    Eindhoven, NB, NL
    Could you give this a shot?
    163B600D89270000680E06E4912200813008
  3. Likes Uwe liked this post
    May 2020
    South Africa
    Thank you I will try and advise accordingly
    May 2020
    South Africa
    I gave the code a try (163B600D89270000680E06E4912200813008), however the reply was: coding rejected Error 12: sub-function not supported or invalid format
    Looks like your module's coding is one byte longer than what iichel calculated, so try adding '00' at the end for:
    163B600D89270000680E06E491220081300800
  7. Likes iichel liked this post
    Aug 2016
    Eindhoven, NB, NL
    Schoolboy error
  9. Likes Shade, Uwe liked this post
  10. #7
    May 2020
    South Africa
    Thank you, thank you. It worked.
  11. Likes PetrolDave, Uwe, Mari liked this post
