Hi guys getting this fault in one of my cars, 9735699 - Pedestrian Protection Crash Sensor 2; Passenger Side. I couldn't find much about it. The car is an accident repair however I have been driving it for a few months with no problems, the code first appeared today.
Thank you
Sunday,24,May,2020,22:38:58:36487
VIN: WAUZZZF27KN108368 License Plate:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 2B 36 42 44 46 52 5F 6C 80 81 A5 AC
BB BC D6 D7 DE
VIN: WAUZZZF27KN108368 Mileage: 12587km-7821miles
80-Batt. reg. aux. accum. -- Status: Malfunction 0010
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DFBA) Labels:. 04L-907-309-V2.clb
Part No SW: 05L 906 027 E HW: 05L 907 309
Component: R4 2.0l TDI H22 6315
Revision: E1H22---
Coding: 0A2540322524050C34082000000400000000000000000000
ASAM Dataset: EV_ECM20TDI01105L906027E 005003
ROD: EV_ECM20TDI01105L906027AG.rod
VCID: 2E0508C0F09FAD0BF17-807A
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 AB HW: 0HK 927 156 B
Component: 0CK 20TDI RdW H01 0004
Revision: --H01--- Serial number: 0000002800
Coding: 000001
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 6D87CFCC3D19161388D-8038
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190092000714
Part No SW: 4K0 907 379 P HW: 4K0 907 379 A
Component: ESP9 Plus H06 0854
Coding: 0CAA499714A20A9E11A148970085D2D2F5B9C0309228508812004B4BAF9D03
ASAM Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 42DD4C705407396B05F-8016
415488 - TPMS Warning; Front Left Tire
C1055 00 [040] - Flat
Mileage: 12018 km
Date: 2020.05.20
Time: 01:54:54
98 00 00 2F 89 24 00 00 00 00
Unlearning counter according OBD-OBD unlearning counter: 24
419328 - TPMS Warning; Front Right Tire
C1057 00 [040] - Flat
Mileage: 12018 km
Date: 2020.05.20
Time: 01:54:54
419584 - TPMS Warning; Rear Left Tire
C1059 00 [040] - Flat
Mileage: 12018 km
Date: 2020.05.20
Time: 01:54:54
419840 - TPMS Warning; Rear Right Tire
C105B 00 [040] - Flat
Mileage: 12018 km
Date: 2020.05.20
Time: 01:54:54
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 GG HW: 4N0 907 063 AG
Component: BCM1 MLBevo H10 0653
Coding: 07000143C13900CD074C87081FAF8C68130B3310000600970101080039321C810A45093242560508000001000001001A0000000000010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014.rod
VCID: 79AFEB9C7951BAB3145-802C
Subsystem 1 - Part No SW: 4K2 955 119 HW: 4K2 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001902060500293
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 22795280X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4K2 941 501 HW: 4K2 941 501
Component: E1 - LTM H05 0053
Serial number: 16S01.04.1900301070
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE107011923611247
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 B HW: 4K0 947 135 B
Component: Dachmodul H42 0413
Serial number: B01151644
Coding: 0D0104
67735 - Databus
[MxB not available]
Reset counter: 58
Mileage: 12049 km
Date: 2020.05.21
Time: 14:23:32
average_Voltage_terminals: 15.00 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 26.50 °C
interior_temperature: 37.00 °C
Vehicle speed: 3.40 km/h
67736 - Databus
[Camera sensor blocked]
Reset counter: 58
Mileage: 12049 km
Date: 2020.05.21
Time: 14:23:58
average_Voltage_terminals: 14.90 V
Outside air temperature sensor-Outside air temperature on CAN: 27.00 °C
Vehicle speed: 17.65 km/h
405505 - Blower Output Reduction due to Energy Management
B10CE 00 [008] - -
Reset counter: 55
Mileage: 11722 km
Date: 2020.05.19
Time: 16:55:47
average_Voltage_terminals: 11.70 V
interior_temperature: 34.50 °C
Vehicle speed: 0.00 km/h
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 J HW: 4N0 959 655 J
Component: AirbagVW31 H01 2720
Serial number: 003YTM00PG00
Coding: AACCF0C00CC00000985400FFF08D40AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 43D349744B1D30630E9-8016
Subsystem 1 - Part No SW: ----------- HW: 480 000 904 19
Serial number: 35700000000A25AC3A3R
Subsystem 2 - Part No SW: ----------- HW: 480 000 604 19
Serial number: 358000000006D9FC0B3%
Subsystem 3 - Part No SW: ----------- HW: 480 031 504 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C20CFA9E31492H
Subsystem 4 - Part No SW: ----------- HW: 480 031 504 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C18A243260F9C9
Subsystem 5 - Part No SW: ----------- HW: 480 030 604 19
Component: FrontSensor_D 002 0149
Serial number: 355001C1C9C5B480CAD.
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 030 604 19
Component: FrontSensor_P 002 0149
Serial number: 356001C1C9CD71004A0A
Pedestrian Protection Center:
Subsystem 7 - Part No SW: ----------- HW: 480 031 707 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C244B28DD09F0D
Subsystem 8 - Part No SW: ----------- HW: 480 001 207 19
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000077C19DDBR
B148E 13 [137] - Open Circuit
Mileage: 12426 km
Date: 2020.05.24
Time: 12:00:35
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 S HW: 4N0 907 129 S
Component: Lenks.Modul H03 0005
ROD: EV_SMLSKLOAU736_AU58.rod
VCID: 41DF437C510122731C5-8014
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 790 C HW: 4K0 920 790 C
Component: FBenRDWACC--- H11 0153
Coding: A4A420C2688006000140E160B080080008001000
ASAM Dataset: EV_DashBoardAU65X 001017
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 2D070FCCFD99D613C8D-8078
Part No SW: 4N1 907 468 AL HW: 4N1 907 468 AB
Component: Gateway H14 0045
Revision: AA010003 Serial number: 038AA851719409
Coding: 02010005002086405A860002005B0132C81A000710000000097D078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003170
ROD: EV_CGateCONTIAU491_003_AU58.rod
VCID: 025D8C701487F96B45F-8056
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 7418631300190410099F
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 19000081704007
Coding: 8800000000000000
ROD: EV_ELVMarqMQBA0_VW41.rod
VCID: 34311AA81EB387DB873-8060
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000370461695
Coding: 007812400000B4010003010101010000000000000000000000000000004000
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 593 D HW: 4M1 959 593 D
Component: TSG FS001 0189
Serial number: YE007SCE20561
Coding: 001FDA0052010400A000B002
ROD: EV_DCU2DriveSideMAXHKLO.rod
VCID: 3E25388020FF5D8B617-806A
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0505
Coding: 94002101010000
ASAM Dataset: EV_EPSVWBSAU426 010017
ROD: EV_EPSVWBSAU426_010.rod
VCID: 323D1CB0E4A789EB95F-8066
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 CB HW: 4N0 907 064 B
Component: BCM2 MLBevo H14 0164
Coding: 013500002FB000406309A0000400000203030000804306502F04000000040030001F0100000011
ASAM Dataset: EV_BCM2CONTIAU651 009009
ROD: EV_BCM2CONTIAU651_009_AU58.rod
VCID: 71BFD3BC2121F2F3AC5-8024
Ignition key:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY190642LV7
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000046792444
Rear Spoiler Adjustment:
65760 - Databus
[Airbag control module: error value in signal AB_Gurtschloss_FA]
Reset counter: 53
Mileage: 11617 km
Date: 2020.05.11
Time: 23:41:16
Supply voltages-Supply voltage: Terminal 30: 13.425 V
Supply voltages-Supply voltage Terminal 30 - 2: 13.432 V
Supply voltages-Supply voltage Terminal 30 - 3: 13.564 V
general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
general_additional_freeze_frame-coprocessor_spi_status: 00000000
general_additional_freeze_frame-dataflash_status: 00000000
general_additional_freeze_frame-interior_temperature: -50.0 °C
general_additional_freeze_frame-Operating_Status: 00000000 00000000
general_additional_freeze_frame-production_mode: not active
general_additional_freeze_frame-reset_cause: 00000000
general_additional_freeze_frame-Reset_counter: 0
general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
general_additional_freeze_frame-subnetwork_status: 00000000 00000000
general_additional_freeze_frame-terminal_control_intern_status: 1B 02 8A 98 00 60
general_additional_freeze_frame-Transport_Mode: not active
general_additional_freeze_frame-Vehicle speed: 2.46 km/h
can_lin_communication_freeze_frame: 11111111 11111111 11111111 11111111
Part No SW: 4M1 959 592 D HW: 4M1 959 592 D
Component: TSG BFS001 0189
Serial number: YE007SCG02736
Coding: 001FDA005E010400A000B000
ROD: EV_DCU2PasseSideMAXHKLO.rod
VCID: 3D273F8C2DF9469378D-8068
Part No SW: 4K0 035 063 B HW: 4K0 035 063 A
Component: MU-H-LND-EU 046 2538
Coding: 01850101FF0A000043111101C00800302F0001E603F00800CE
ASAM Dataset: EV_MUHigGen2pALPI 001001
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 221DECF0B447196B65F-8076
Subsystem 1 - Part No: V03 959 804 BK
Component: MIB2P_EU_Q319 0400
Subsystem 2 - Part No SW: 4K1 919 605 G HW: 4K1 919 605 F
Component: DU AU58x Top H71 0170
Serial number: BHB00108031903200239
Subsystem 3 - Part No: V03 959 800 EG
Component: Gracenote2 1009
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 A HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0108
Serial number: 00004419000041764018
Display Unit 5 For Multimedia System:
Subsystem 5 - Part No SW: 4K4 919 603 G HW: 4K4 919 603 F
Component: DU AU58x Bot H71 0170
Serial number: BHB00117041903200469
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051900167718001
B201A 00 [009] - -
Reset counter: 3
Mileage: 11257 km
Date: 2020.05.04
Time: 18:40:03
Voltage terminal 30: 15.2 V
Status_Software_Version_Management-module_name: UPDATESTARTED
Address 6C: Back-up Cam. (J772) Labels:* Redir Fail!
Part No SW: 4M0 980 556 A HW: 4M0 980 556 A
Component: RVC Compact H15 0250
Coding: 0285010102002001C20040
ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
ROD: EV_CamSysRVRVCPANAMLBEv_005_VW53.rod
VCID: 333319B41BBD80E39E9-8066
Address 80: Batt. reg. aux. accum. (A1) Labels: None
Part No SW: 4K0 915 101 HW: 4K0 915 101
Component: MQ-BMS H20 0127
Serial number: 18000040263004
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 6099A6F8FACB4B7B33B-8034
40973 - Crash Shut-Down Activated
P1609 00 [009] - -
[Diag_F_Crash_NV_ShutOff]
Reset counter: 14
Mileage: 11695 km
Date: 2020.05.18
Time: 15:28:24
4125 - Implausible Data Received from Diagnostic Gateway Module
U0447 00 [008] - -
[Diag_C_HCAN_NVEM_07_IMR]
Fault Frequency: 39
Reset counter: 62
Mileage: 11695 km
Date: 2020.05.18
Time: 15:28:24
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4K2 713 041 H HW: 4K2 713 041 H
Component: GSM-LL H14 0051
Serial number: 19.085 40395
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 290FFBDCC971CA33245-807C
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AA HW: 4N0 907 107 F
Component: zFAS Var A H08 0291
Coding: 04C18600000000000000060000400424189D5600000000000000000000000000001900000000000000000000000000000000000000000000000080000000000000007818008000B000000000000000000080400000B0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001.rod
VCID: 7EA5F880607F9D8B217-802A
221281 - Control Module for Driver Assist Systems
C12D5 FA [008] - Image Processor does not Repsond.
Reset counter: 58
Mileage: 12049 km
Date: 2020.05.21
Time: 14:23:19
EyeQ error source: Camera error
Address AC: Reductant Control (J880) Labels: None
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H08 0004
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C0102C8C683DF1BDF3-8078
Part No SW: 4M1 959 595 D HW: 4M1 959 595 D
Component: TSG HFS003 0189
Serial number: YE007SCC07344
Coding: 000FD80000010400A000B000
VCID: 40D946785A0B2B7B13B-8014
Component: TSG HBFS003 0189
Serial number: YE007SCC0480E
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 572 DC HW: 4K0 941 572 D
Component: LMS_MLBevo H06 0031
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72BDDCB02427C9EB55F-8026
Address D7: Light Ctrl Right 2 (A27) Labels: None
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Address DE: Charger 1 for mobile dev (J1146) Labels:* None
Part No SW: 4K0 035 502 A HW: 4K0 035 502 A
Component: WLC Front H10 0057
Coding: 400000
ASAM Dataset: EV_Charg1MobilDevicAU651 004001
ROD: EV_Charg1MobilDevicAU651.rod
VCID: 1F1BE504873534834A1-804A
End----------(Elapsed Time: 01:44, VBatt start/end: 12.9V/13.0V)-----------
Thank you
