After disconnecting the battery on my 2009 EOS the ABS, ESC, and Brake lights started flashing. I also have the yellow steering wheel light on. I tried driving it around to clear the code like I usually do and it did not go away. I did an autoscan and realized my ABS has lost its programming. Attached is the autoscan data. Can someone help me get the proper coding for my unit?
Sunday,24,May,2020,13:56:58:29487
VCDS Version: 20.4.1.0 (x64)
VIN: WVWBA71F49V011486 License Plate:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 52 56 62 63
65 72
VIN: WVWBA71F49V011486 Mileage: 264210km-164172miles
26-Auto Roof -- Status: Malfunction 0010
63-Entry Assist,D -- Status: OK 0000
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 06J 906 026 BE HW: 06J 906 026 AF
Component: MED17.5 TFSI 2,0 3289
Revision: AAH03--- Serial number: VWX7Z0H73NL8JG
Coding: 041C010A1C070160
Shop #: WSC 00020 790 00000
VCID: 6EFD24ED79E42AF6E9-803A
005386 - Engine Off Timer Performance
P150A - 000 - - Intermittent
Mileage: 264218 km
Time: 06:07:51
RPM: 1179 /min
Load: 15.3 %
Temperature: 81.0°C
Temperature: 33.0°C
Absolute Pres.: 980.0 mbar
Voltage: 11.938 V
Readiness: 0110 0101
Part No SW: 02E 300 051 B HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1803
Revision: 04843012 Serial number: 00000808130009
Shop #: WSC 00020 000 90108
VCID: 1205501D0D1CAE16AD-8046
18259 - Powertrain Data Bus
P1851 - 000 - Missing Message from ABS Controller - Intermittent
Fault Frequency: 255
Reset counter: 40
Mileage: 264218 km
Part No SW: 1K0 907 379 AP HW: 1K0 907 379 AP
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Shop #: WSC 11630 004 1048576
VCID: 00216A5593702C860B-8054
00003 - Control Module
Fault Status: 01100101
Reset counter: 190
Mileage: 264219 km
Count: 3
Count: 12
Count: 12800
Count: 338
Count: 49408
Reset counter: 190
Mileage: 264219 km
Count: 3
Count: 12
Count: 12800
Count: 279
Count: 49408
Reset counter: 190
Mileage: 264219 km
Count: 3
Count: 12
Count: 12800
Count: 270
Count: 49408
Reset counter: 190
Mileage: 264219 km
Count: 7
Count: 12
Count: 12800
Count: 195
Count: 49152
Reset counter: 190
Mileage: 264219 km
Count: 7
Count: 12
Count: 12800
Count: 320
Count: 49152
Part No: 1K0 907 044 AG
Component: ClimatronicPQ35 066 0505
VCID: 6CF92EE54FF8D8E6C7-8038
Revision: 00H54000 Serial number: 00000008702341
Coding: 15848F0340041500470000000F00000000285D035C000120000000000000
VCID: 334BF5995246471EC6-8066
Subsystem 1 - Part No: 1Q1 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 280808 022 0501
Coding: 00038805
Shop #: WSC 00020
Part No SW: 8E0 035 593 M HW: 8E0 035 593 M
Component: SDAR SIRIUS H07 0150
Revision: 00000000 Serial number: AUZ4Z7H0399837
Coding: 0000100
Fault Frequency: 10
Reset counter: 165
Mileage: 263750 km
Time: 18:45:43
01304 - Radio
Reset counter: 230
Mileage: 264219 km
Time: 10:27:06
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 72 Airbag VW8C 0180
Revision: 92010018 Serial number: 003B3003WS82
Coding: 0014130
VCID: 3A55D8BD752CB65605-806E
Subsystem 1 - Part No: 1Q0 959 339 A
Component: BF-Gewichtsens. 007 0003
Subsystem 2 - Serial number: 3SM3D
Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332SRB407C0CA141ÿ†63
Subsystem 5 - Serial number: 0CA141ÿ†6342SRB407C347A54ÿ†63
Subsystem 6 - Serial number: 347A54ÿ†6372URB403CE7B5DQÿ†63
Subsystem 7 - Serial number: E7B5DQÿ†6382URB403CE7B1FPÿ
Subsystem 8 - Serial number: E7B1FPÿ
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0010021
VCID: 032B65594266379E16-8056
Part No SW: 1Q0 920 974 G HW: 1Q0 920 974 G
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H73NL8JG
Coding: 0023203
Shop #: WSC 00020 067 57207
VCID: 3851C2B54B20A446F3-806C
Reset counter: 230
Mileage: 264218 km
Time: 05:57:19
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K0890100A2
Coding: ED807F270413025000
VCID: 354FCB815C32592EE8-8060
01304 - Radio
Fault Frequency: 13
Reset counter: 230
Mileage: 264216 km
Time: 09:16:49
Reset counter: 230
Mileage: 264218 km
Time: 05:57:20
Part No SW: 1Q0 919 965 HW: 1Q0 919 965
Component: Kompass 002 0001
Revision: 00002000 Serial number: 1350208TKZKZ02
VCID: 79D707B130AA7D4E4C-802C
Reset counter: 230
Mileage: 264218 km
Time: 05:57:20
Component: IMMO VDD 2416
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 D HW: 1Q0 959 255 D
Component: Verdecksteuergeraet 0824
Revision: 0033100M Serial number: 082140162
Coding: 0655364
VCID: 3957C7B1702ABD4E0C-806C
Reset counter: 230
Mileage: 264218 km
Time: 05:57:20
Voltage: 12.30 V
Voltage: 12.30 V
Voltage: 4.90 V
Error Code: 0
Part No SW: 1Q0 959 701 E HW: 1Q0 959 701 E
Component: Tuer-SG 006 1213
Coding: 0001207
VCID: 364DCC8D41345236E1-8062
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 70 2301
Revision: 00H15000
VCID: 2A75E8FD858C06D675-807E
Reset counter: 240
Mileage: 264218 km
Time: 05:57:22
Voltage: 12.25 V
DU
Temperature: 30.0°C
Speed: 50.0 km/h
Speed: 50.0 km/h
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13908A800186281B0804040FB0080E0488DC00
Shop #: WSC 07437 444 128297
VCID: 04296645476830A62F-8050
Part No SW: 1Q0 959 702 E HW: 1Q0 959 702 E
Coding: 0001206
VCID: 3753C189463EAB3EFA-8062
Address 56: Radio
Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
Component: Tuer-SG 006 1301
Coding: 0000128
Shop #: WSC 00020 790 1012544
VCID: 3449F68557484026DF-8060
Address 63: Entry Assist,D Labels: 1Q0-959-790.lbl
Part No SW: 1Q0 959 790 A HW: 1Q0 959 790 A
Component: J572 EASYENTRY FS 0603
Revision: 00H02000 Serial number: 5DS008646-01--
Component: RDK 0450
Coding: 0100100
Fault Status: 00110100
Reset counter: 227
Mileage: 255685 km
Time: 00:28:08
00625 - Vehicle Speed Signal
Fault Status: 00111000
Reset counter: 230
Mileage: 264218 km
Time: 05:57:21
Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
Coding: 0000128
End-------------------------(Elapsed Time: 01:29)--------------------------
