2009 EOS ABS issue after battery disconnection
dsto
C?ID=203608
After disconnecting the battery on my 2009 EOS the ABS, ESC, and Brake lights started flashing. I also have the yellow steering wheel light on. I tried driving it around to clear the code like I usually do and it did not go away. I did an autoscan and realized my ABS has lost its programming. Attached is the autoscan data. Can someone help me get the proper coding for my unit?
Sunday,24,May,2020,13:56:58:29487
VCDS Version: 20.4.1.0 (x64)
VIN: WVWBA71F49V011486   License Plate:
Chassis Type: 1F (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 26 42 44 46 52 56 62 63
          65 72
VIN: WVWBA71F49V011486   Mileage: 264210km-164172miles
1C-Position Sensing -- Status: Malfunction 0010
26-Auto Roof -- Status: Malfunction 0010
63-Entry Assist,D -- Status: OK 0000
   Part No SW: 06J 906 026 BE    HW: 06J 906 026 AF
   Component: MED17.5 TFSI 2,0    3289
   Revision: AAH03---    Serial number: VWX7Z0H73NL8JG
   Coding: 041C010A1C070160
   Shop #: WSC 00020 790 00000
   VCID: 6EFD24ED79E42AF6E9-803A
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Mileage: 264218 km
                    Time: 06:07:51
                    RPM: 1179 /min
                    Load: 15.3 %
                    Temperature: 81.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 11.938 V
Readiness: 0110 0101
   Part No SW: 02E 300 051 B    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1803
   Revision: 04843012    Serial number: 00000808130009
   Shop #: WSC 00020 000 90108
   VCID: 1205501D0D1CAE16AD-8046
18259 - Powertrain Data Bus
            P1851 - 000 - Missing Message from ABS Controller - Intermittent
                    Fault Frequency: 255
                    Reset counter: 40
                    Mileage: 264218 km
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Shop #: WSC 11630 004 1048576
   VCID: 00216A5593702C860B-8054
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 190
                    Mileage: 264219 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 338
                    Count: 49408
                    Reset counter: 190
                    Mileage: 264219 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 279
                    Count: 49408
                    Reset counter: 190
                    Mileage: 264219 km
                    Count: 3
                    Count: 12
                    Count: 12800
                    Count: 270
                    Count: 49408
                    Reset counter: 190
                    Mileage: 264219 km
                    Count: 7
                    Count: 12
                    Count: 12800
                    Count: 195
                    Count: 49152
                    Reset counter: 190
                    Mileage: 264219 km
                    Count: 7
                    Count: 12
                    Count: 12800
                    Count: 320
                    Count: 49152
   Part No: 1K0 907 044 AG
   Component: ClimatronicPQ35 066 0505
   VCID: 6CF92EE54FF8D8E6C7-8038
00716 - Air recirculation Flap Positioning Motor (V113)
01316 - ABS Control Module
   Revision: 00H54000    Serial number: 00000008702341
   Coding: 15848F0340041500470000000F00000000285D035C000120000000000000
   VCID: 334BF5995246471EC6-8066
   Subsystem 1 - Part No: 1Q1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 280808 022  0501
   Coding: 00038805
   Shop #: WSC 00020
   Part No SW: 8E0 035 593 M    HW: 8E0 035 593 M
   Component: SDAR SIRIUS     H07 0150
   Revision: 00000000    Serial number: AUZ4Z7H0399837
   Coding: 0000100
                    Fault Frequency: 10
                    Reset counter: 165
                    Mileage: 263750 km
                    Time: 18:45:43
01304 - Radio
                    Reset counter: 230
                    Mileage: 264219 km
                    Time: 10:27:06
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 72 Airbag VW8C      0180
   Revision: 92010018    Serial number: 003B3003WS82
   Coding: 0014130
   VCID: 3A55D8BD752CB65605-806E
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 3SM3D
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332SRB407C0CA141ÿ†63
   Subsystem 5 - Serial number: 0CA141ÿ†6342SRB407C347A54ÿ†63
   Subsystem 6 - Serial number: 347A54ÿ†6372URB403CE7B5DQÿ†63
   Subsystem 7 - Serial number: E7B5DQÿ†6382URB403CE7B1FPÿ
   Subsystem 8 - Serial number: E7B1FPÿ
   Part No SW: 1K0 953 549 BR    HW: 1K0 953 549 BR
   Component: J0527           051 0101
   Coding: 0010021
   VCID: 032B65594266379E16-8056
   Part No SW: 1Q0 920 974 G    HW: 1Q0 920 974 G
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H73NL8JG
   Coding: 0023203
   Shop #: WSC 00020 067 57207
   VCID: 3851C2B54B20A446F3-806C
                    Reset counter: 230
                    Mileage: 264218 km
                    Time: 05:57:19
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K0890100A2
   Coding: ED807F270413025000
   VCID: 354FCB815C32592EE8-8060
01304 - Radio
                    Fault Frequency: 13
                    Reset counter: 230
                    Mileage: 264216 km
                    Time: 09:16:49
                    Reset counter: 230
                    Mileage: 264218 km
                    Time: 05:57:20
   Part No SW: 1Q0 919 965     HW: 1Q0 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1350208TKZKZ02
   VCID: 79D707B130AA7D4E4C-802C
                    Reset counter: 230
                    Mileage: 264218 km
                    Time: 05:57:20
   Component: IMMO            VDD 2416
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 D    HW: 1Q0 959 255 D
   Component: Verdecksteuergeraet 0824
   Revision: 0033100M    Serial number: 082140162
   Coding: 0655364
   VCID: 3957C7B1702ABD4E0C-806C
                    Reset counter: 230
                    Mileage: 264218 km
                    Time: 05:57:20
                    Voltage: 12.30 V
                    Voltage: 12.30 V
                    Voltage: 4.90 V
                    Error Code: 0
   Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
   Component: Tuer-SG         006 1213
   Coding: 0001207
   VCID: 364DCC8D41345236E1-8062
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   VCID: 2A75E8FD858C06D675-807E
                    Reset counter: 240
                    Mileage: 264218 km
                    Time: 05:57:22
                    Voltage: 12.25 V
                        DU
                    Temperature: 30.0°C
                    Speed: 50.0 km/h
                    Speed: 50.0 km/h
   Component:    KSG PQ35 RDK 052 0221
   Coding: 13908A800186281B0804040FB0080E0488DC00
   Shop #: WSC 07437 444 128297
   VCID: 04296645476830A62F-8050
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0001206
   VCID: 3753C189463EAB3EFA-8062
Address 56: Radio
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         006 1301
   Coding: 0000128
   Shop #: WSC 00020 790 1012544
   VCID: 3449F68557484026DF-8060
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H02000    Serial number: 5DS008646-01--
   Component:    RDK              0450
   Coding: 0100100
                    Fault Status: 00110100
                    Reset counter: 227
                    Mileage: 255685 km
                    Time: 00:28:08
00625 - Vehicle Speed Signal
                    Fault Status: 00111000
                    Reset counter: 230
                    Mileage: 264218 km
                    Time: 05:57:21
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
End-------------------------(Elapsed Time: 01:29)--------------------------
Hi and welcome.
Your ABS module has lost its coding and that coding needs to be put back. However, the coding for these modules is very complicated and specific to the particular car.
Do you have any scans from before this happened? Look in your Scans sub-folder.
dsto
C?ID=203608
Sadly, I do not. My first scan was to try to diagnose this issue.
Is this car new to you? Because VCDS certainly isn't. ;)
Anyway, if you don't have the original coding, you'll have to wait for someone to try to build a coding for it, and I'm not up to speed on that.
dsto
C?ID=203608
Yeah, just picked it up. I was fixing the few necessary things on it and this happened...
dsto
C?ID=203608
That was it, thank you so much!
