Results 1 to 10 of 11
Thread: 2009 GTI TSI Throttle Body Failure?
    May 2020
    First time poster, new VCDS user and not a mechanic. I purchased a HEX-V2 recently because I had botched recall intake work done by a local VW dealer (Hillcrest VW PA) a while back and was intent on at least having some data that I could verify so I wouldn't get taken advantage of again.
    I found a local VW garage (Dub Junkie Pittsburgh) when I had an ABS light come on. Turned out to be failed tone rings/sensors in the rear and a bad ABS module (unfortunately not the code for the recall) which was replaced by the shop. They also replaced the air filter and an exhaust bracket.
    Fast forward a couple of months. I was driving and the car started running rough and went into limp mode. Made it home and the scan says cylinder 1 misfire. I decided to replace the coils and spark plugs. Did so successfully and car ran great for a few weeks.
    After coming home for an entire day of driving, city and highway, the car died in my driveway, EPC and engine light on. This is the scan from May 1, 2020:
    Friday,01,May,2020,18:30:29:27410
    VIN: WVWHV71K59W145008   License Plate:
    Mileage: 114890km-71389mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 62
              65 72
    VIN: WVWHV71K59W145008   Mileage: 114890km-71389miles
    Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
       Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI     0030
       Revision: AAH03---    Serial number: VWX7Z0H93NG7ZY
       Coding: 0403010A1C070160
       VCID: 698FBBFA957F5363E4C-803C
    000289 - Throttle Position Sensor (G69)
                   P0121 - 000 - Implausible Signal - MIL ON
                        Fault Status: 11100000
                        Mileage: 114895 km
                        Time: 18:07:16
                        RPM: 714 /min
                        Load: 34.9 %
                        Temperature: 84.0C
                        Temperature: 24.0C
                        Absolute Pres.: 970.0 mbar
                        Voltage: 13.462 V
    005445 - Throttle Valve Controller
                   P1545 - 000 - Malfunction - MIL ON
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 88.0C
                        Temperature: 48.0C
                        Voltage: 11.557 V
       Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
       Component: GSG DSG AG6     431 1907
       Revision: 04843012    Serial number: 00000809111027
       VCID: 221DECD628C9403B656-8076
       Revision: 00H45001
       Coding: 113B600D492600FF880B06E492210041B100
       VCID: 0059865E8A05B22B532-8054
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 243
                        Mileage: 114895 km
                        Count: 32768
                        Count: 4608
                        Count: 8193
                        Count: 50432
                        Count: 61184
       Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
       Component: Climatic PQ35   142 1212
       Revision: 00142032    Serial number: 00000000000000
       VCID: 78A9EEBEDED5FAEB6B2-802C
       Revision: 00H54000    Serial number: 00000008941994
       Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
       VCID: 333319928733D9B39E0-8066
       Component: Wischer 101008 021  0501
       Coding: 00038805
       Shop #: WSC 01357
       Component: 6K AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D0C73AM
       Coding: 0013899
       VCID: 6C81C2EE9A8D464B9FA-8038
       Subsystem 1 - Part No: 1K0 959 339 G
       Component: BF-Gewichtsens. 007 0007
       Subsystem 2 - Serial number: 6332MSME4165580AA
       Subsystem 3 - Serial number: 6342MSME4166281FF
       Subsystem 4 - Serial number: 6352QSME7D0E4030I
       Subsystem 5 - Serial number: 6362QSME0700430E6
       Subsystem 6 - Serial number: 63727SME1A04726B1
       Subsystem 7 - Serial number: 63827SME1A03542D%
       Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
       Coding: 0012122
       Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
       Component: KOMBIINSTRUMENT VDD 2416
       Revision: V0003000    Serial number: VWX7Z0H93NG7ZY
       Coding: 0007203
       Shop #: WSC 06413 444 52574
       VCID: 392F2BBAA55F23E354C-806C
       Component: J533  Gateway   H07 5063
       Revision:   H07 01    Serial number: 061008F1000752
       Coding: ED817F075002120002
       VCID: 3537278A8947C783B04-8060
       Component: IMMO            VDD 2416
       Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
       Component: SG EXT.PLAYER H13 0062
       Revision: A1001003    Serial number: 7667294529
       VCID: 2517F7CA35E7B703004-8070
       Part No SW: 3C0 035 684 B    HW: 3C0 035 684 B
       Component: RNS-MID       H02 0380
       Revision: AB001001    Serial number: VWZ6Z7K6268066
       Coding: 040100000100001600
       Shop #: WSC 06413 444 84164
       VCID: 221DECD624C9403B656-8076
                        Fault Frequency: 14
                        Reset counter: 243
                        Mileage: 114792 km
       Component: Tuer-SG         006 1219
       Coding: 0001205
       VCID: 38292EBE9E553AEBAB2-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Shop #: WSC 00000 028 00001
       Coding: 139006885103281B0904058FB0080F0488DC00
       VCID: 04518A4E921DAE0B77A-8050
       Part No SW: 1K6 035 456 C    HW: 1K6 035 456 C
       Component: 08K Audioverst.     0001
       Revision: 00001000    Serial number: 00000000182199
       VCID: 2C0102EE5A0D864BDFA-8078
       Coding: 0001204
       Part No: 1T0 907 357
       Coding: 0000003
       Shop #: WSC 46820 001 1048576
       VCID: 74B1DA8EC2BD9E8B47A-8020
                        Fault Frequency: 14
                        Reset counter: 243
                        Mileage: 114792 km
       Component: Tuer-SG         006 1302
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       Coding: 0100101
       Coding: 0001168
    End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.0V)-----------
    Hopefully the ABS code is from the ABS control module being replaced or something else? This was the first instance of any mention of throttle body errors. Interestingly after letting the car sit and cool down a bit it started right up and ran just fine until today.
    Drove on back roads today and had the EPC and check engine light come on when I pulled into a parking lot and car was idling roughly. Shut car off and tried starting again and it wouldn't start, just fast clicked. Let the car cool for about 20 minutes, tried again and the car started right up although was running rough at idle.
    Drove the car home and hooked it up to VCDS and this is the scan:
    Saturday,23,May,2020,22:45:10:27410
    Mileage: 115090km-71513mi   Repair Order:
              65 72
    VIN: WVWHV71K59W145008   Mileage: 115090km-71513miles
                   P0121 - 000 - Implausible Signal - Intermittent - MIL ON
                        Fault Status: 10100000
                        Mileage: 114895 km
                        Time: 18:07:16
                        RPM: 714 /min
                        Load: 34.9 %
                        Temperature: 84.0C
                        Temperature: 24.0C
                        Voltage: 13.462 V
                   P1545 - 000 - Malfunction - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 88.0C
                        Temperature: 48.0C
                        Voltage: 11.557 V
    001674 - ECM Power Relay Load Circuit
                   P068A - 000 - Opens Too Early - Intermittent
                        Temperature: 55.0C
                        Temperature: 45.0C
                        Voltage: 8.128 V
                        Mileage: 115093 km
                        Time: 22:36:52
                        Temperature: 72.0C
                        Temperature: 60.0C
                        Voltage: 12.065 V
    001378 - System Voltage
                   P0562 - 000 - Too Low - Intermittent
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 39.0C
                        Temperature: 18.0C
                        Voltage: 9.652 V
       Revision: 00H45001
                        Reset counter: 1
                        Mileage: 115093 km
                        Count: 14
                        Count: 13056
                        Count: 8193
                        Count: 50944
       Coding: 00038805
       Shop #: WSC 01357
       Coding: 0013899
       Coding: 0012122
       Coding: 0007203
                        Reset counter: 1
                        Mileage: 115088 km
       Coding: 0001205
       Coding: 0001204
       Coding: 0000003
                        Reset counter: 1
                        Mileage: 115088 km
       Coding: 0001168
       Coding: 0100101
       Coding: 0001168
    End----------(Elapsed Time: 01:23, VBatt start/end: 13.9V/13.9V)-----------
    Driving home the gas pedal depression almost seemed sort of desynchronized from the engine response, but ran very smoothly when I kept the RPMs higher than idle. Once I made it home I put the car in park and depressed the gas. The engine sounded great, but when I left off the gas the engine kept accelerating, so I slapped the gas pedal and it went back to rough idle. I tried this three times with the same result. Given this outcome I'm not going to be driving the car until I can track this problem down. I also graphed the throttle response and it looked a little weird. When I depressed the gas pedal I got a proper looking inverted curve set but then both curves immediately bumped inward ~10% toward the center 0 line which didn't seem to be normal.
    Is uninstalling and inspecting the throttle body a good place to start in this case? It'll probably take me a while to get the throttle body extracted but it doesn't look like you need anything but a T30, socket wrench, slotted screwdriver, catch cloth and patience. If the throttle body is gunked up I'll get a new one (Pierburg), new gasket, clean mating surfaces and install. I do know that the throttle bodies can be cleaned but I'm not sure I want to take the chance that the buildup blockage has damaged the internal plastic parts of the unit at 70k miles. Could a bad battery be causing this (unlikely)?
    Other than the first car being replaced and the current one having the transmission replaced under the recall it's been almost trouble free, I guess it was about time for a few issues to crop up. Any assistance provided is greatly appreciated. Thanks.
    Feb 2020
    New Zealand
    I’d remove it and inspect like you’ve said- the plastic gears are prone to wear causing issues at times
  3. Likes OSTexo liked this post
    Jul 2017
    Kenya
    Quote Originally Posted by OSTexo View Post
              65 72
                        Mileage: 114895 km
                        Time: 18:07:16
                        RPM: 714 /min
                        Load: 34.9 %
                        Temperature: 84.0C
                        Temperature: 24.0C
                        Voltage: 13.462 V
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 88.0C
                        Temperature: 48.0C
                        Voltage: 11.557 V
       Revision: 00H45001
                        Reset counter: 243
                        Mileage: 114895 km
                        Count: 32768
                        Count: 4608
                        Count: 8193
                        Count: 50432
                        Count: 61184
       Coding: 00038805
       Shop #: WSC 01357
       Coding: 0013899
       Coding: 0012122
       Coding: 0007203
                        Fault Frequency: 14
                        Reset counter: 243
                        Mileage: 114792 km
       Coding: 0001205
       Coding: 0001204
       Coding: 0000003
                        Fault Frequency: 14
                        Reset counter: 243
                        Mileage: 114792 km
       Coding: 0001168
       Coding: 0100101
       Coding: 0001168
              65 72
                        Mileage: 114895 km
                        Time: 18:07:16
                        RPM: 714 /min
                        Load: 34.9 %
                        Temperature: 84.0C
                        Temperature: 24.0C
                        Voltage: 13.462 V
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 88.0C
                        Temperature: 48.0C
                        Voltage: 11.557 V
                        Temperature: 55.0C
                        Temperature: 45.0C
                        Voltage: 8.128 V
                        Mileage: 115093 km
                        Time: 22:36:52
                        Temperature: 72.0C
                        Temperature: 60.0C
                        Voltage: 12.065 V
                        Date: 2047.15.31
                        Time: 31:63:63
                        Temperature: 39.0C
                        Temperature: 18.0C
                        Voltage: 9.652 V
       Revision: 00H45001
                        Reset counter: 1
                        Mileage: 115093 km
                        Count: 14
                        Count: 13056
                        Count: 8193
                        Count: 50944
       Coding: 00038805
       Shop #: WSC 01357
       Coding: 0013899
       Coding: 0012122
       Coding: 0007203
                        Reset counter: 1
                        Mileage: 115088 km
       Coding: 0001205
       Coding: 0001204
       Coding: 0000003
                        Reset counter: 1
                        Mileage: 115088 km
       Coding: 0001168
       Coding: 0100101
       Coding: 0001168
    this points to a faulty throttle valve controller,however more detective work needs to be done to rule out surprises,clean throttle valve, clearing codes in 01 and immediately do a TBA to see if it will be successful,either way trace TV wiring to ecu for corrossion,enough strain relief at throttle valve connector,if all check out fine,find a good TV to test with,... I think theres a TSB or TPI for this particular malfunction,worth scouring the internet for it
  5. Likes Jack@European_Parts, Uwe, Rollux, OSTexo liked this post
  6. #4
    The fault in the ABS is just a "Sympathy" code; the ABS saying it knows the ECU is unhappy.
    May 2020
    Thank you for all of the insight and suggestions. I'll post back here with results.
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    This should be worth reading.
    https://static.nhtsa.gov/odi/tsbs/20...06512-9340.pdf
    Good Luck
    May 2020
    Thanks for the bulletin. It seems that there is a correlation between the car being warmed up / driven and when the issue becomes apparent, or it could just be a false positive due to the time factor. I'm leaning toward the throttle body assembly itself but I'm planning on being wrong at least once, it's not going to be the first or the last time.
  10. #8
    May 2020
    Making progress. New throttle body is installed and I'll be opening up he old one this week to see if the plastic inside is damaged. I only found out after uninstall that the dealer had managed to mangle up the top hose clamp that compressed the hose to the throttle body, apparently the clamp should be clipped into the hose itself but on my hose it had been run out of the tabs. I ended up getting a Spulen silicone hose and it's a challenge to get it onto the throttle body. I did confirm that the hose will fit on both connections, it's just a bear to get this seated. Is there any sort of lubricant I could use that would make this hose install go a little easier that is safe for silicone, rubber and the engine? Thanks.
    P-80 Emulsion from International Products Corporation perhaps?
  11. #9
    I've always used washing up liquid (liquid detergent e.g. Fairy) to make fitting tight hoses easier.
  12. Likes Uwe, OSTexo liked this post
  13. #10
    May 2020
    South Africa
    You do not need any lubricant, I just did one yesterday. The issue is, when inserting the hose on the throttle body the hose is not properly inserted at the back (the part you can't see of the throttle body) of the throttle body. Insert the hose on the throttle body first and the plastic pipe from the intercooler last. In relation to the intercooler plastic pipe, there is a bolt which bolts the pipe to the engine, you need to undo it and that will allow movement of the plastic pipe.
    1.
  14. Likes OSTexo liked this post
