2009 GTI TSI Throttle Body Failure?
OSTexo
C?ID=396114
First time poster, new VCDS user and not a mechanic. I purchased a HEX-V2 recently because I had botched recall intake work done by a local VW dealer (Hillcrest VW PA) a while back and was intent on at least having some data that I could verify so I wouldn't get taken advantage of again.
I found a local VW garage (Dub Junkie Pittsburgh) when I had an ABS light come on. Turned out to be failed tone rings/sensors in the rear and a bad ABS module (unfortunately not the code for the recall) which was replaced by the shop. They also replaced the air filter and an exhaust bracket.
Fast forward a couple of months. I was driving and the car started running rough and went into limp mode. Made it home and the scan says cylinder 1 misfire. I decided to replace the coils and spark plugs. Did so successfully and car ran great for a few weeks.
After coming home for an entire day of driving, city and highway, the car died in my driveway, EPC and engine light on. This is the scan from May 1, 2020:
Friday,01,May,2020,18:30:29:27410
VCDS Version: 20.4.0.1 (x64)  HEX-V2 CB: 0.4508.4
VIN: WVWHV71K59W145008   License Plate:
Mileage: 114890km-71389mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 47 52 55 56 62
          65 72
VIN: WVWHV71K59W145008   Mileage: 114890km-71389miles
   Part No SW: 1K0 907 115 AE    HW: 1K0 907 115 AA
   Revision: AAH03---    Serial number: VWX7Z0H93NG7ZY
   Coding: 0403010A1C070160
   VCID: 698FBBFA957F5363E4C-803C
000289 - Throttle Position Sensor (G69)
               P0121 - 000 - Implausible Signal - MIL ON
                    Fault Status: 11100000
                    Mileage: 114895 km
                    Time: 18:07:16
                    RPM: 714 /min
                    Load: 34.9 %
                    Temperature: 84.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.462 V
005445 - Throttle Valve Controller
               P1545 - 000 - Malfunction - MIL ON
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 88.0°C
                    Temperature: 48.0°C
                    Voltage: 11.557 V
   Part No SW: 02E 300 051 R    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     431 1907
   Revision: 04843012    Serial number: 00000809111027
   VCID: 221DECD628C9403B656-8076
   Part No SW: 1K0 907 379 AP    HW: 1K0 907 379 AP
   Component: ESP MK60EC1   H45 0107
   Revision: 00H45001
   Coding: 113B600D492600FF880B06E492210041B100
   Shop #: WSC 12345 123 12345
   VCID: 0059865E8A05B22B532-8054
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 243
                    Mileage: 114895 km
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 50432
                    Count: 61184
   Part No SW: 1K0 820 047 JM    HW: 1K0 820 047 JM
   Component: Climatic PQ35   142 1212
   Revision: 00142032    Serial number: 00000000000000
   VCID: 78A9EEBEDED5FAEB6B2-802C
   Revision: 00H54000    Serial number: 00000008941994
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   VCID: 333319928733D9B39E0-8066
   Component: Wischer 101008 021  0501
   Coding: 00038805
   Shop #: WSC 01357
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0C73AM
   Coding: 0013899
   VCID: 6C81C2EE9A8D464B9FA-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME4165580AA
   Subsystem 3 - Serial number: 6342MSME4166281FF
   Subsystem 4 - Serial number: 6352QSME7D0E4030I
   Subsystem 5 - Serial number: 6362QSME0700430E6
   Subsystem 6 - Serial number: 63727SME1A04726B1
   Subsystem 7 - Serial number: 63827SME1A03542D%
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0101
   Coding: 0012122
   Part No SW: 1K6 920 974 H    HW: 1K6 920 974 H
   Component: KOMBIINSTRUMENT VDD 2416
   Revision: V0003000    Serial number: VWX7Z0H93NG7ZY
   Coding: 0007203
   Shop #: WSC 06413 444 52574
   VCID: 392F2BBAA55F23E354C-806C
   Component: J533  Gateway   H07 5063
   Revision:   H07 01    Serial number: 061008F1000752
   Coding: ED817F075002120002
   VCID: 3537278A8947C783B04-8060
   Component: IMMO            VDD 2416
   Part No SW: 5N0 035 342 A    HW: 5N0 035 342 A
   Component: SG EXT.PLAYER H13 0062
   Revision: A1001003    Serial number: 7667294529
   VCID: 2517F7CA35E7B703004-8070
   Part No SW: 3C0 035 684 B    HW: 3C0 035 684 B
   Component: RNS-MID       H02 0380
   Revision: AB001001    Serial number: VWZ6Z7K6268066
   Coding: 040100000100001600
   Shop #: WSC 06413 444 84164
   VCID: 221DECD624C9403B656-8076
                    Fault Frequency: 14
                    Reset counter: 243
                    Mileage: 114792 km
   Component: Tuer-SG         006 1219
   Coding: 0001205
   VCID: 38292EBE9E553AEBAB2-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   Component:    KSG PQ35 RDK 052 0221
   Coding: 139006885103281B0904058FB0080F0488DC00
   VCID: 04518A4E921DAE0B77A-8050
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 1K6 035 456 C    HW: 1K6 035 456 C
   Component: 08K Audioverst.     0001
   Revision: 00001000    Serial number: 00000000182199
   VCID: 2C0102EE5A0D864BDFA-8078
   Coding: 0001204
   Part No: 1T0 907 357
   Coding: 0000003
   Shop #: WSC 46820 001 1048576
   VCID: 74B1DA8EC2BD9E8B47A-8020
                    Fault Frequency: 14
                    Reset counter: 243
                    Mileage: 114792 km
   Part No SW: 1K0 959 703 K    HW: 1K0 959 703 K
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   Component:    RDK              0450
   Coding: 0100101
   Part No SW: 1K0 959 704 K    HW: 1K0 959 704 K
   Coding: 0001168
End----------(Elapsed Time: 01:23, VBatt start/end: 12.1V/12.0V)-----------
Hopefully the ABS code is from the ABS control module being replaced or something else? This was the first instance of any mention of throttle body errors. Interestingly after letting the car sit and cool down a bit it started right up and ran just fine until today.
Drove on back roads today and had the EPC and check engine light come on when I pulled into a parking lot and car was idling roughly. Shut car off and tried starting again and it wouldn't start, just fast clicked. Let the car cool for about 20 minutes, tried again and the car started right up although was running rough at idle.
Drove the car home and hooked it up to VCDS and this is the scan:
Saturday,23,May,2020,22:45:10:27410
Mileage: 115090km-71513mi   Repair Order:
          65 72
VIN: WVWHV71K59W145008   Mileage: 115090km-71513miles
               P0121 - 000 - Implausible Signal - Intermittent - MIL ON
                    Fault Status: 10100000
                    Mileage: 114895 km
                    Time: 18:07:16
                    RPM: 714 /min
                    Load: 34.9 %
                    Temperature: 84.0°C
                    Temperature: 24.0°C
                    Voltage: 13.462 V
               P1545 - 000 - Malfunction - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 88.0°C
                    Temperature: 48.0°C
                    Voltage: 11.557 V
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Load: 0.0 %
                    Temperature: 55.0°C
                    Temperature: 45.0°C
                    Voltage: 8.128 V
                    Mileage: 115093 km
                    Time: 22:36:52
                    Load: 0.0 %
                    Temperature: 72.0°C
                    Temperature: 60.0°C
                    Voltage: 12.065 V
001378 - System Voltage
               P0562 - 000 - Too Low - Intermittent
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 39.0°C
                    Temperature: 18.0°C
                    Voltage: 9.652 V
   Revision: 00H45001
                    Reset counter: 1
                    Mileage: 115093 km
                    Count: 14
                    Count: 13056
                    Count: 8193
                    Count: 50944
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 0013899
   Coding: 0012122
   Coding: 0007203
                    Reset counter: 1
                    Mileage: 115088 km
   Coding: 0001205
   Coding: 0001204
   Coding: 0000003
                    Reset counter: 1
                    Mileage: 115088 km
   Coding: 0001168
   Component:    RDK              0450
   Coding: 0100101
   Coding: 0001168
End----------(Elapsed Time: 01:23, VBatt start/end: 13.9V/13.9V)-----------
Driving home the gas pedal depression almost seemed sort of desynchronized from the engine response, but ran very smoothly when I kept the RPMs higher than idle. Once I made it home I put the car in park and depressed the gas. The engine sounded great, but when I left off the gas the engine kept accelerating, so I slapped the gas pedal and it went back to rough idle. I tried this three times with the same result. Given this outcome I'm not going to be driving the car until I can track this problem down. I also graphed the throttle response and it looked a little weird. When I depressed the gas pedal I got a proper looking inverted curve set but then both curves immediately bumped inward ~10% toward the center 0 line which didn't seem to be normal.
Is uninstalling and inspecting the throttle body a good place to start in this case? It'll probably take me a while to get the throttle body extracted but it doesn't look like you need anything but a T30, socket wrench, slotted screwdriver, catch cloth and patience. If the throttle body is gunked up I'll get a new one (Pierburg), new gasket, clean mating surfaces and install. I do know that the throttle bodies can be cleaned but I'm not sure I want to take the chance that the buildup blockage has damaged the internal plastic parts of the unit at 70k miles. Could a bad battery be causing this (unlikely)?
Other than the first car being replaced and the current one having the transmission replaced under the recall it's been almost trouble free, I guess it was about time for a few issues to crop up. Any assistance provided is greatly appreciated. Thanks.
Rollux
New Zealand
C?ID=380572
I’d remove it and inspect like you’ve said- the plastic gears are prone to wear causing issues at times
Fredrick Awuor
Kenya
C?ID=309834
          65 72
                    Mileage: 114895 km
                    Time: 18:07:16
                    RPM: 714 /min
                    Load: 34.9 %
                    Temperature: 84.0°C
                    Temperature: 24.0°C
                    Voltage: 13.462 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 88.0°C
                    Temperature: 48.0°C
                    Voltage: 11.557 V
   Revision: 00H45001
                    Reset counter: 243
                    Mileage: 114895 km
                    Count: 32768
                    Count: 4608
                    Count: 8193
                    Count: 50432
                    Count: 61184
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 0013899
   Coding: 0012122
   Coding: 0007203
                    Fault Frequency: 14
                    Reset counter: 243
                    Mileage: 114792 km
   Coding: 0001205
   Coding: 0001204
   Coding: 0000003
                    Fault Frequency: 14
                    Reset counter: 243
                    Mileage: 114792 km
   Coding: 0001168
   Component:    RDK              0450
   Coding: 0100101
   Coding: 0001168
          65 72
                    Mileage: 114895 km
                    Time: 18:07:16
                    RPM: 714 /min
                    Load: 34.9 %
                    Temperature: 84.0°C
                    Temperature: 24.0°C
                    Voltage: 13.462 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 88.0°C
                    Temperature: 48.0°C
                    Voltage: 11.557 V
                    Load: 0.0 %
                    Temperature: 55.0°C
                    Temperature: 45.0°C
                    Voltage: 8.128 V
                    Mileage: 115093 km
                    Time: 22:36:52
                    Load: 0.0 %
                    Temperature: 72.0°C
                    Temperature: 60.0°C
                    Voltage: 12.065 V
                    Date: 2047.15.31
                    Time: 31:63:63
                    Load: 0.0 %
                    Temperature: 39.0°C
                    Temperature: 18.0°C
                    Voltage: 9.652 V
   Revision: 00H45001
                    Reset counter: 1
                    Mileage: 115093 km
                    Count: 14
                    Count: 13056
                    Count: 8193
                    Count: 50944
   Coding: 00038805
   Shop #: WSC 01357
   Coding: 0013899
   Coding: 0012122
   Coding: 0007203
                    Reset counter: 1
                    Mileage: 115088 km
   Coding: 0001205
   Coding: 0001204
   Coding: 0000003
                    Reset counter: 1
                    Mileage: 115088 km
   Coding: 0001168
   Component:    RDK              0450
   Coding: 0100101
   Coding: 0001168
this points to a faulty throttle valve controller,however more detective work needs to be done to rule out surprises,clean throttle valve, clearing codes in 01 and immediately do a TBA to see if it will be successful,either way trace TV wiring to ecu for corrossion,enough strain relief at throttle valve connector,if all check out fine,find a good TV to test with,... I think theres a TSB or TPI for this particular malfunction,worth scouring the internet for it
OSTexo
C?ID=396114
Thank you for all of the insight and suggestions. I'll post back here with results.
OSTexo
C?ID=396114
Thanks for the bulletin. It seems that there is a correlation between the car being warmed up / driven and when the issue becomes apparent, or it could just be a false positive due to the time factor. I'm leaning toward the throttle body assembly itself but I'm planning on being wrong at least once, it's not going to be the first or the last time.
OSTexo
C?ID=396114
Making progress. New throttle body is installed and I'll be opening up he old one this week to see if the plastic inside is damaged. I only found out after uninstall that the dealer had managed to mangle up the top hose clamp that compressed the hose to the throttle body, apparently the clamp should be clipped into the hose itself but on my hose it had been run out of the tabs. I ended up getting a Spulen silicone hose and it's a challenge to get it onto the throttle body. I did confirm that the hose will fit on both connections, it's just a bear to get this seated. Is there any sort of lubricant I could use that would make this hose install go a little easier that is safe for silicone, rubber and the engine? Thanks.
P-80 Emulsion from International Products Corporation perhaps?
I've always used washing up liquid (liquid detergent e.g. Fairy) to make fitting tight hoses easier.
Shade
South Africa
C?ID=291138
You do not need any lubricant, I just did one yesterday. The issue is, when inserting the hose on the throttle body the hose is not properly inserted at the back (the part you can't see of the throttle body) of the throttle body. Insert the hose on the throttle body first and the plastic pipe from the intercooler last. In relation to the intercooler plastic pipe, there is a bolt which bolts the pipe to the engine, you need to undo it and that will allow movement of the plastic pipe.
1.
OSTexo
C?ID=396114
Got everything reassembled today, did the adaptation using VCDS and took the car for a couple of test drives. Throttle response was noticeably better and the graph didn't have any of the odd dips present typical with the old throttle. I'll have the VW mechanic take a look at my work and check out the wiring to determine if there is evidence the wiring could be a contributing factor to this problem. Interestingly it looks like there is a bracket that hold two connectors to the bottom right side of the intake manifold via two screws? The connectors are seated in the bracket but the bracket is not connected to the intake. Does that bracket screw to the intake and if so is there a place to get replacement screws to attach? Maybe that's a question for the mechanic. Yet one more reason I'll never take my car to a dealer again.
I do have thoughts on a few things I've learned in this process that might make things easier for someone else doing this sort of work. A micro ratchet is a great tool for this job. I got a HBR5 from VIM as well as their low profile Torx bits and it made it much easier to reach screws crammed in tight spaces easier to reach. Only improvement I could think of is an articulating micro ratchet for some locations, e.g. rear screws on throttle body, but the micro ratchet with a short extension did the job. Another location the micro ratchet worked really well was to release the rear facing plastic tab on the U shaped engine air intake hose to release it from the bottom of the air filter housing.
The longest amount of time spent was removing the turbocharger intercooler pipe, but I'm confident that was in part due to the tech at the dealer mangling the upper hose clamp around the throttle body, it fought me for over an hour even with hose picks. Only once it was off and I looked up the image of what the hose clamp should actually look like did I realize the effort was not typical if the hose was installed and undamaged. All of the other screws and clamps came apart easily with a stubby ratcheting screwdriver and nut drivers.
Frankly if you have smaller hands/fingers removing the throttle body is going to be much easier. Enlisting the help of someone to uninstall and install the throttle body with those attributes is highly recommended. A medium sized lint free towel positioned to both block open pipes and catch any screws is a good idea. I had a cheap telescoping magnet just in case but I didn't need to use it.
Placing a small mirror on the towel will make aligning and installing the new throttle body gasket much easier. After fighting with the new more rigid turbocharger intercooler pipe I took a break and got some IPC P-80 Emulsion. I wiped it on the inside and edge of the silicone pipe only and in about 15 minutes the new pipe was installed, 14 of the minutes was really fighting the confined space I had to work with. Reinstalling the noise pipe took 5 seconds with the P-80, it's really remarkable stuff in my opinion.
I was curious what the old throttle body looked like inside so I unscrewed the Torx screws and used the Vamplier VT-002-6 (Engineer Japan rebranded tool for the NA market) to easily remove the shear screw. I was surprised to find the gears in pristine condition, not a hint of wear or broken teeth. The only thing that was a little odd was when I turned the small gear attached to the motor it consistently seemed to get harder to rotate in one area and made a whining sound, not sure if that is normal for the motor to do that or not.
Thank you for all of the assistance on the forum, I'm glad Ross Tech makes such an affordable and capable tool. While one can hope the UX of VCDS will improve over time to decrease support load even further I can say it's paid for itself many times over in a very short time in my case.
